  3. Einsteigerfragen
  4. Installation
  5. Docker Installation lädt admin Adapter nicht
30 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • F Offline
    ferrog
    Von der latest-v8 habe ich auch den debug log da, wenn das hilft. :)
    date	stream	content
    2023-05-13T15:47:44.269891044Z	stdout	host.buanet-iobroker4 check instance "system.adapter.backitup.0" for host "buanet-iobroker4"
    2023-05-13T15:47:44.268936383Z	stdout	host.buanet-iobroker4 check instance "system.adapter.discovery.0" for host "buanet-iobroker4"
    2023-05-13T15:47:44.261773893Z	stdout	host.buanet-iobroker4 check instance "system.adapter.admin.0" for host "buanet-iobroker4"
    2023-05-13T15:47:43.324870664Z	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    2023-05-13T15:47:43.324854124Z	stdout
    2023-05-13T15:47:43.324826964Z	stdout	Starting ioBroker...
    2023-05-13T15:47:43.324810644Z	stdout
    2023-05-13T15:47:43.324792724Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:47:43.324763044Z	stdout	-----                    Step 5 of 5: ioBroker startup                     -----
    2023-05-13T15:47:43.324711303Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:47:43.151326844Z	stdout
    2023-05-13T15:47:43.137833545Z	stdout
    2023-05-13T15:47:43.137783764Z	stdout	For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    2023-05-13T15:47:43.137721904Z	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    2023-05-13T15:47:43.137666384Z	stdout
    2023-05-13T15:47:43.137549184Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:47:43.137178864Z	stdout	-----                Step 4 of 5: Applying special settings                -----
    2023-05-13T15:47:43.137121543Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:47:43.136801153Z	stdout
    2023-05-13T15:47:43.136780253Z	stdout	Controller "js-controller": 4.0.24   , installed 4.0.24
    2023-05-13T15:47:43.136755553Z	stdout	Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    2023-05-13T15:47:43.136734123Z	stdout	Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    2023-05-13T15:47:43.136705853Z	stdout	Adapter    "admin"        : 6.3.5    , installed 6.3.5
    2023-05-13T15:47:43.136686453Z	stdout	Used repository: stable
    2023-05-13T15:47:43.136667773Z	stdout	[DEBUG] ##### iobroker update #####
    2023-05-13T15:47:43.136652193Z	stdout
    2023-05-13T15:47:43.136633283Z	stdout	Active repo(s): stable
    2023-05-13T15:47:43.136613743Z	stdout
    2023-05-13T15:47:43.136592113Z	stdout	beta          : http://download.iobroker.net/sources-dist-latest.json
    2023-05-13T15:47:43.136560053Z	stdout	stable        : http://download.iobroker.net/sources-dist.json
    2023-05-13T15:47:43.136483833Z	stdout	[DEBUG] ##### iobroker repo list #####
    2023-05-13T15:47:43.136467842Z	stdout
    2023-05-13T15:47:43.136448812Z	stdout	+ instance is alive
    2023-05-13T15:47:43.136432622Z	stdout
    2023-05-13T15:47:43.136410302Z	stdout	  system.adapter.discovery.0              : discovery             : buanet-iobroker4                         -  enabled
    2023-05-13T15:47:43.136383492Z	stdout	  system.adapter.backitup.0               : backitup              : buanet-iobroker4                         -  enabled
    2023-05-13T15:47:43.136333662Z	stdout	  system.adapter.admin.0                  : admin                 : buanet-iobroker4                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    2023-05-13T15:47:43.135936152Z	stdout	[DEBUG] ##### iobroker list instances #####
    2023-05-13T15:47:05.768075168Z	stdout
    2023-05-13T15:47:05.768028778Z	stdout	[DEBUG] Collecting some more ioBroker debug information...
    2023-05-13T15:47:05.767986918Z	stdout
    2023-05-13T15:47:05.767659268Z	stdout	Done.
    2023-05-13T15:47:04.692537448Z	stdout	The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
    2023-05-13T15:47:04.689835954Z	stdout	The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
    2023-05-13T15:47:04.687277530Z	stdout	Updating hostname to "buanet-iobroker4"... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
    2023-05-13T15:46:54.079547659Z	stdout	Hostname in ioBroker does not match the hostname of this container.
    2023-05-13T15:46:54.059817621Z	stdout	[DEBUG] Detected admin hostname is: buildkitsandbox
    2023-05-13T15:46:42.302764294Z	stdout	[DEBUG] Detected admin instance is: system.adapter.admin.0
    2023-05-13T15:46:30.593054575Z	stdout
    2023-05-13T15:46:30.592681875Z	stdout	Initializing a fresh installation of ioBroker... Done.
    2023-05-13T15:46:17.017145250Z	stdout
    2023-05-13T15:46:17.017122470Z	stdout	[DEBUG] Done.
    2023-05-13T15:46:17.017103560Z	stdout	[DEBUG] No custom states db settings detected.
    2023-05-13T15:46:17.017079960Z	stdout	[DEBUG] Checking custom states db settings...
    2023-05-13T15:46:17.017056440Z	stdout
    2023-05-13T15:46:17.017036120Z	stdout	[DEBUG] Done.
    2023-05-13T15:46:17.017016910Z	stdout	[DEBUG] No custom objects db settings detected.
    2023-05-13T15:46:17.016986970Z	stdout	[DEBUG] Checking custom objects db settings...
    2023-05-13T15:46:17.016960290Z	stdout
    2023-05-13T15:46:17.016887570Z	stdout	[DEBUG] Done.
    2023-05-13T15:46:17.016850860Z	stdout	[DEBUG] No multihost settings detected.
    2023-05-13T15:46:17.016789910Z	stdout	[DEBUG] Checking multihost settings...
    2023-05-13T15:46:17.016514139Z	stdout
    2023-05-13T15:46:17.016138619Z	stdout	Fixing "sudo-bug" by replacing sudo with gosu... Done.
    2023-05-13T15:46:16.659789089Z	stdout
    2023-05-13T15:46:16.659637289Z	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
    2023-05-13T15:46:16.532957762Z	stdout
    2023-05-13T15:46:16.532852711Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:46:16.532518601Z	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
    2023-05-13T15:46:16.532442081Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:46:16.531808700Z	stdout
    2023-05-13T15:46:16.454032021Z	stdout	Restoring initial ioBroker installation... Done.
    2023-05-13T15:46:13.558289354Z	stdout	There is no data detected in /opt/iobroker.
    2023-05-13T15:46:13.540199328Z	stdout
    2023-05-13T15:46:13.540141338Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:46:13.539836648Z	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
    2023-05-13T15:46:13.539720848Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:46:13.515052223Z	stdout
    2023-05-13T15:46:13.498686700Z	stdout	Registering maintenance script as command... Done.
    2023-05-13T15:46:13.489624958Z	stdout
    2023-05-13T15:46:11.611708519Z	stdout	Updating Linux packages on first run... Done.
    2023-05-13T15:44:58.139563752Z	stdout
    2023-05-13T15:44:58.139484412Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:58.139150351Z	stdout	-----                   Step 1 of 5: Preparing container                   -----
    2023-05-13T15:44:58.139113601Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:58.138838381Z	stdout
    2023-05-13T15:44:58.138825271Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    2023-05-13T15:44:58.138808701Z	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
    2023-05-13T15:44:58.138786791Z	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
    2023-05-13T15:44:58.138750911Z	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
    2023-05-13T15:44:58.138700951Z	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
    2023-05-13T15:44:58.138671261Z	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
    2023-05-13T15:44:58.138639391Z	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
    2023-05-13T15:44:58.138606510Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    2023-05-13T15:44:58.138574610Z	stdout
    2023-05-13T15:44:58.138538920Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:58.138133950Z	stdout	-----                    SETUID:              1000                         -----
    2023-05-13T15:44:58.137795309Z	stdout	-----                    SETGID:              1000                         -----
    2023-05-13T15:44:58.137270609Z	stdout	-----                    DEBUG:               true                         -----
    2023-05-13T15:44:58.136890868Z	stdout	-----                        Environment Variables                         -----
    2023-05-13T15:44:58.136862518Z	stdout	-----        -----
    2023-05-13T15:44:58.136566958Z	stdout	-----                    npm:                 9.5.1                        -----
    2023-05-13T15:44:56.354084526Z	stdout	-----                    node:                v18.16.0                     -----
    2023-05-13T15:44:55.910835981Z	stdout	-----                    build:               2023-04-26T23:45:40+00:00    -----
    2023-05-13T15:44:55.910802491Z	stdout	-----                    image:               v8.0.1                       -----
    2023-05-13T15:44:55.910770791Z	stdout	-----                          Version Information                         -----
    2023-05-13T15:44:55.910743501Z	stdout	-----        -----
    2023-05-13T15:44:55.910709461Z	stdout	-----                    hostname:            buanet-iobroker4             -----
    2023-05-13T15:44:55.910592891Z	stdout	-----                    arch:                x86_64                       -----
    2023-05-13T15:44:55.905641184Z	stdout	-----                          System Information                          -----
    2023-05-13T15:44:55.905620354Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:55.905600374Z	stdout
    2023-05-13T15:44:55.905577174Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:55.905550654Z	stdout	-----                          Please be patient!                          -----
    2023-05-13T15:44:55.905521824Z	stdout	-----                    Startupscript is now running!                     -----
    2023-05-13T15:44:55.905477654Z	stdout	-----              Welcome to your ioBroker Docker container!              -----
    2023-05-13T15:44:55.905451524Z	stdout	-----        -----
    2023-05-13T15:44:55.905419324Z	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
    2023-05-13T15:44:55.905390034Z	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
    2023-05-13T15:44:55.905361324Z	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
    2023-05-13T15:44:55.905330424Z	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
    2023-05-13T15:44:55.905294234Z	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
    2023-05-13T15:44:55.905256144Z	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
    2023-05-13T15:44:55.905231994Z	stdout	-----        -----
    2023-05-13T15:44:55.905202714Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:55.905086203Z	stdout	-------------------------     2023-05-13 17:44:55      -------------------------
    2023-05-13T15:44:55.901358018Z	stdout	--------------------------------------------------------------------------------
    2023-05-13T15:44:55.900853518Z	stdout	 ```
    Keba P30, 50kWp SMA, 15kWh Victron MP2, Daikin LLWP, Docker@SynologyDS923+
    • GlasfaserG Offline
      GlasfaserG Offline
      @ferrog
      in deinen beigestellten Logs ist nichts zu erkennen ... sollte alles funktionieren .
      Dann bitte die V8 installieren , starten ....
      und die Full Ausgabe von
      iob diag
      Nimm auch bitte einen anderen Browser den du noch nie für IoBroker genutzt hast , und rufe die Seite auf !
      • F Offline
        ferrog
        schrieb am zuletzt editiert von ferrog
        Anbei dann noch die Diag von v8:
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : v8.0.1
        Virtualization  : Unknown (buanet/Synology?)
        Distributor ID:	Debian
        Description:	Debian GNU/Linux 11 (bullseye)
        Release:	11
        Codename:	bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         18:08:27 up  3:20,  0 users,  load average: 0.73, 0.84, 0.80
        CPU threads: 4
        *** Time and Time Zones ***
        Sat May 13 16:08:27 UTC 2023
        Sat May 13 18:08:27 CEST 2023
        CEST +0200
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            3.9G        1.3G        246M        1.1G        2.3G        950M
        Swap:           4.4G        181M        4.2G
        Total:          8.3G        1.5G        4.4G
                 3890 M total memory
                 1304 M used memory
                  902 M active memory
                 1076 M inactive memory
                  246 M free memory
                   11 M buffer memory
                 2327 M swap cache
                 4383 M total swap
                  181 M used swap
                 4202 M free swap
        *** FILESYSTEM ***
        Filesystem             Type   Size  Used Avail Use% Mounted on
        /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /
        tmpfs                  tmpfs   64M     0   64M   0% /dev
        tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/fs/cgroup
        shm                    tmpfs   64M     0   64M   0% /dev/shm
        /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /opt/iobroker
        /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /etc/hosts
        tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/acpi
        tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/scsi
        tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/firmware
        [Sat May 13 14:49:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Sat May 13 14:49:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Sat May 13 14:49:03 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Sat May 13 14:49:03 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Sat May 13 14:49:03 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
        [Sat May 13 14:49:03 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
        [Sat May 13 14:49:08 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
        [Sat May 13 14:49:31 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
        TARGET             SOURCE        FSTYPE OPTIONS
        /                  /dev/mapper/cachedev_1[/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=440,subvol=/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282
        |-/opt/iobroker    /dev/mapper/cachedev_1[/@syno/docker/iobv81]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=257,subvol=/@syno/docker/iobv81
        |-/etc/resolv.conf /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf
        |-/etc/hostname    /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname
        `-/etc/hosts       /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts
        /var:
        33M	/var/
        30M	/var/lib
        18M	/var/lib/apt/lists
        18M	/var/lib/apt
        13M	/var/lib/dpkg
        /opt/iobroker/backups:
        0	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        18M	/opt/iobroker/iobroker-data/
        14M	/opt/iobroker/iobroker-data/files
        13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        3.3M	/opt/iobroker/iobroker-data/objects.jsonl
        2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.16.0
        /usr/bin/node 		v18.16.0
        /usr/bin/npm 		9.5.1
        /usr/bin/npx 		9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	"javascript" not found
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : buanet-iobroker4                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : buanet-iobroker4                         -  enabled
        + system.adapter.discovery.0              : discovery             : buanet-iobroker4                         -  enabled
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Objects and States
        Objects: 	143
        States: 	104
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1575259    -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1575252    -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1576185    -
        2023-05-13 17:47:43.755  - info: host.buanet-iobroker4 iobroker.js-controller version 4.0.24 js-controller starting
        2023-05-13 17:47:43.758  - info: host.buanet-iobroker4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 hostname: buanet-iobroker4, node: v18.16.0
        2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 ip addresses: 172.17.0.6
        2023-05-13 17:47:44.092  - info: host.buanet-iobroker4 connected to Objects and States
        2023-05-13 17:47:44.102  - info: host.buanet-iobroker4 Node.js version has changed from unknown to 18.16.0
        2023-05-13 17:47:44.123  - info: host.buanet-iobroker4 added notifications configuration of host
        2023-05-13 17:47:44.258  - info: host.buanet-iobroker4 3 instances found
        2023-05-13 17:47:44.270  - info: host.buanet-iobroker4 starting 3 instances
        2023-05-13 17:47:44.296  - info: host.buanet-iobroker4 instance system.adapter.admin.0 started with pid 1828
        2023-05-13 17:47:44.522  - info: host.buanet-iobroker4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2023-05-13 17:47:45.624  - info: admin.0 (1828) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all states
        2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all objects
        2023-05-13 17:47:45.792  - info: admin.0 (1828) received all objects
        2023-05-13 17:47:45.918  - info: admin.0 (1828) http server listening on port 8081
        2023-05-13 17:47:45.919  - info: admin.0 (1828) Use link "http://localhost:8081" to configure.
        2023-05-13 17:47:45.922  - info: admin.0 (1828) socket.io server listening on port 8081
        2023-05-13 17:47:48.281  - info: host.buanet-iobroker4 instance system.adapter.discovery.0 started with pid 1856
        2023-05-13 17:47:48.835  - info: discovery.0 (1856) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 17:47:52.281  - info: host.buanet-iobroker4 instance system.adapter.backitup.0 started with pid 1871
        2023-05-13 17:47:52.895  - info: backitup.0 (1871) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 17:47:52.996  - info: backitup.0 (1871) [iobroker] backup will be activated at 02:40 every 1 day(s)
        		     v.2023-04-16
        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
        Kernel: 		4.4.180+
        Installation: 		Docker
        Timezone: 		Etc/UTC
        User-ID: 		0
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
        			/usr/bin/npm 		9.5.1
        			/usr/bin/npx 		9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            3.9G        1.3G        285M        1.1G        2.3G        917M
        Swap:           4.4G        184M        4.2G
        Total:          8.3G        1.5G        4.5G
        Active iob-Instances: 	4
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		143
        States: 		104
        Size of iob-Database:
        228K	/opt/iobroker/iobroker-data/states.jsonl
        Habe extra Firefox runtergeladen, funktioniert aber leider auch nicht :(
        • F ferrog
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : v8.0.1
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          /root
          root
          X-Server: 	false
          Desktop:
          Terminal:
          *** MEMORY ***
                   3890 M total memory
                   1304 M used memory
                    902 M active memory
                    246 M free memory
                     11 M buffer memory
                   2327 M swap cache
                   4383 M total swap
                    181 M used swap
                   4202 M free swap
          *** FILESYSTEM ***
          /var:
          33M	/var/
          30M	/var/lib
          18M	/var/lib/apt
          13M	/var/lib/dpkg
          /usr/bin/npm 		9.5.1
          /usr/bin/npx 		9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.3.5
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	143
          States: 	104
          Pending Updates: 0
          		     v.2023-04-16
          Kernel: 		4.4.180+
          Timezone: 		Etc/UTC
          User-ID: 		0
          X-Server: 		false
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          MEMORY:
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		143
          States: 		104
          GlasfaserG Offline
          GlasfaserG Offline
          @ferrog sagte in Docker Installation lädt admin Adapter nicht:
          ... auch ein Loop mit dem ioBroker Zeichen !?
          Hast du eine Host oder Bridge Netzwerk !
          • F Offline
            ferrog
            Ja, auch in loop.
            Ich habe noch den alten "raspi" iobroker im Netz, aber nicht aktiv host bzw. slave konfiguriert. Sind die sich dann auch ohne Konfiguration im Wege?
            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            • F ferrog
              Ja, auch in loop.
              @ferrog
              tcp6       0      0 :::8081
              Da läuft der Admin wohl nur auf ipv6.
              Edith: Vergiss es, ist bei mir auch so.
              • F ferrog
                Ja, auch in loop.
                GlasfaserG Offline
                GlasfaserG Offline
                Nein .. passt so .
                Was ist mit :
                @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
                Bitte immer alle Fragen beantworten !
                Wenn Bridge ... dann versuche zum Test Host .
                • F ferrog
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : v8.0.1
                  Release:	11
                  Codename:	bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                  CEST +0200
                  Etc/UTC
                  root
                  /root
                  root
                  X-Server: 	false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                           3890 M total memory
                           1304 M used memory
                            902 M active memory
                            246 M free memory
                             11 M buffer memory
                           2327 M swap cache
                           4383 M total swap
                            181 M used swap
                           4202 M free swap
                  *** FILESYSTEM ***
                  /var:
                  33M	/var/
                  30M	/var/lib
                  18M	/var/lib/apt
                  13M	/var/lib/dpkg
                  /usr/bin/npm 		9.5.1
                  /usr/bin/npx 		9.5.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.3.5
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	143
                  States: 	104
                  Pending Updates: 0
                  		     v.2023-04-16
                  Kernel: 		4.4.180+
                  Timezone: 		Etc/UTC
                  User-ID: 		0
                  X-Server: 		false
                  			/usr/bin/npm 		9.5.1
                  			/usr/bin/npx 		9.5.1
                  MEMORY:
                  			admin 			6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		143
                  States: 		104
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Sehe gerade ...
                  Also Bridge
                  • F Offline
                    ferrog
                    Ah, gemeint war docker. Ja das war Bridge, habe gerade auch Host versucht, leider genau so. Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
                    Oder kann der Port 8081 auch einfach gemappt werden? (Habe leider noch nicht zum Laufen bekommen…)
                    • F ferrog
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Welcher Port hat er denn ,
                      dann würdest du aber nicht ioBroker mit 8081 erreichen !
                      Der Loop ist ein anderer ( Fehler ) . kann Ihn aber nicht erkennen .
                      Zeige mal die Ausgabe von
                      iob logs --watch
                      wenn du im Loop bist
                      • F Offline
                        ferrog
                        Logs —watch von latest-v8:
                        2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
                        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
                        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
                        2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
                        2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
                        2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
                        2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
                        2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
                        2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
                        2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                        2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                        2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
                        2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
                        2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
                        2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
                        2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
                        2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
                        2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
                        2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
                        2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
                        2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                        2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
                        2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
                        2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                        2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
                        2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                        2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        • F ferrog
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Logs
                          Bitte aktuell zeigen !!
                          • F Offline
                            ferrog
                            Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
                            • F ferrog
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
                              • GlasfaserG Glasfaser
                                iob logs --watch
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @ferrog
                                Kann du nicht meine Fragen beantworten !?
                                  @ferrog
                                  HomoranH Offline
                                  HomoranH Offline
                                  @ferrog
                                  bitte lesen und befolgen!
                                  • F Offline
                                    ferrog
                                    Ich habe das nicht als Frage verstanden.
                                    Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
                                    • F ferrog
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Lösche alle diese Einträge !
                                      Hier wird nur der Port vorgegeben :
                                      siehe Beispiel Containereinstellung
                                      und das ausschalten / haken bei dir raus
                                      • F Offline
                                        ferrog
                                        WOW, vielen Dank! Daran hats gelegen.
                                        Und großen Respekt an die Schnelligkeit eurer Unterstützung!
                                        Zum Hintergrund: Belegt Webstation dann in dem Container den besagten Port?
                                        • F ferrog
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          ... aber mühselig erfragt ;)
                                          Jipp , deshalb meine Frage :
                                          @ferrog
