  4. Frigate Adapter für ioBroker
    1.0k
    6.1k
383 Beiträge 48 Kommentatoren 139.7k Aufrufe 45 Beobachtet
  • Q QuesT
    habe auch auf die 1.0 umgestellt und gleich versucht die Nachrichten via pushover zu senden. Leider stürtz der IoBroker komplett ab wenn ein Ereigniss getriggert wird. Per Telegram läuft es. Ist hier noch was zubeachten?
    tombox
    #161
    @quest brauch ich den Fehler log
    Q 1 Antwort Letzte Antwort
    • T tombox
      @hagst Kannst die logs wieder löschen und die GitHub version drüber installieren
      hagst
      #162
      @tombox sagte in Frigate Adapter für ioBroker:
      frigate.0
      2024-01-28 14:36:00.603	info	Device information created
      frigate.0
      2024-01-28 14:36:00.600	info	Fetch event history for 3 cameras
      frigate.0
      2024-01-28 14:36:00.586	info	Create device information for: Wald
      frigate.0
      2024-01-28 14:36:00.573	info	Create device information for: Terrasse
      frigate.0
      2024-01-28 14:36:00.558	info	Create device information for: Einfahrt
      frigate.0
      2024-01-28 14:36:00.527	info	Create Device information and fetch Event History
      frigate.0
      2024-01-28 14:35:55.551	info	frigate.0 (1789) MQTT client frigate subscribed to topics: frigate/# from broker 00d2ab76-66f6-4aa7-8018-159a69db4997
      frigate.0
      2024-01-28 14:35:55.526	info	Filter for message from client: frigate
      frigate.0
      2024-01-28 14:35:55.526	info	New client: frigate
      frigate.0
      2024-01-28 14:35:51.876	info	If you don't see a new client connected, please restart frigate and adapter.
      frigate.0
      2024-01-28 14:35:51.876	info	Please enter host: 'iobroker' and port: '1885' in frigate config
      frigate.0
      2024-01-28 14:35:51.876	info	MQTT server started and listening on port 1885
      frigate.0
      2024-01-28 14:35:51.793	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
      frigate.0
      2024-01-28 14:35:48.503	info	terminating
      frigate.0
      2024-01-28 14:35:48.002	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      frigate.0
      2024-01-28 14:35:48.002	info	terminating
      frigate.0
      2024-01-28 14:35:48.001	info	Got terminate signal TERMINATE_YOURSELF
      Jetzt sind die Einträge erstellt worden!
      • T tombox
        Q Offline
        Q Offline
        QuesT
        schrieb am zuletzt editiert von QuesT
        #163
        @tombox
        2024-01-28 15:10:07.144 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
        2024-01-28 15:10:08.172 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
        2024-01-28 15:10:27.144 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
        2024-01-28 15:10:27.639 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
        Danach startet der ioBroker neu.
        • Q QuesT
          @tombox
          tombox
          #164
          @quest bitte mal die GitHub version testen
          • T tombox
            Q Offline
            Q Offline
            QuesT
            #165
            @tombox
            2024-01-28 17:16:45.523 - error: pushover.0 (4298) Error from Pushover: message cannot be blank
            Stürzt aber nicht mehr ab.
            • Q QuesT
              @tombox
              tombox
              #166
              @quest dann nochmal installieren
              • T tombox
                Q Offline
                Q Offline
                QuesT
                #167
                @tombox
                Bild kommt nun an. Video noch nicht: pushover.0 (1051) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                • Q QuesT
                  @tombox
                  tombox
                  #168
                  @quest für den clip wäre noch ein debug log gut auch gerne per PN
                  • T tombox
                    Q Offline
                    Q Offline
                    QuesT
                    #169
                    @tombox
                    Vergiss es Pushover kann nur jpg.
                    Danke für die schnelle Hilfe.
                      MrHenker27
                      #170
                      Also zum ersten mal danke für den neuen Adapter.
                      Leider bekomm ich Warn Meldungen im Log -.-
                      State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
                      • M MrHenker27
                        tombox
                        #171
                        @mrhenker27 kommt das mit der 1.0.2?
                        • T tombox
                          MrHenker27
                          #172
                          @tombox
                          okay, war die 1.0.0 hab jetzt über GIT mal die 1.0.2 installiert. Scheint behoben zu sein.
                          • M MrHenker27
                            @tombox
                            MarkA
                            #173
                            Leider geht mit dem neuen Adapter die Kombination von Frigate in Verbindung mit Touble-Take und Compreface zur Personenerkennung nicht mehr, da alle mit dem gleichen MQTT Server sprechen müssen.
                            • M MarkA
                              tombox
                              #174
                              @marka Eigentlich sollte das gehen. Bitte mal die GitHub version installieren und einfach als mqtt host den iobroker eingeben
                              • T tombox
                                MarkA
                                #175
                                das geht bei mir so leider nicht. So wie ich die neue Version verstanden habe, bringt sie einen eigenen MQTT Broker mit. Dies möchte ich nicht, da ich bereits den MQTT Adapter, sowie den SONOFF Adapter für MQTT laufen habe, mit jeweils vielen Integrationen, je nachdem wie die Daten ankommen.
                                Dazu kommt noch, dass der Frigate Adapter MQTT keine Authentifizierung benutzt.
                                  ralf2201
                                  #176
                                  wie kann ich denn wieder auf die alte Version zurück? Kann mir da jemand helfen?
                                  • R ralf2201
                                    martinschm
                                    schrieb am zuletzt editiert von martinschm
                                    #177
                                    Installation hat gleich geklappt, hab lediglich den MQTT Port angepasst. Telegram Benachrichtiung kam auch gleich an, sehr cool gemacht. Vielen Dank für die neue Adapter Version.
                                    Kurze Frage noch zu den State
                                    Warum hat der Channel "Motion" auch nochmal einen Wert ?
                                    Und welchen State muß ich nehmen wenn ich in meiner Visualisierung "kurz" anzeigen will ob es eine Bewegung gab. Irgendwann sollte der State ja auch mal wieder falsch sein, oder ?
                                    Bei mir schein der State "state" unter Motion immer auf true zu stehen.
                                    Und wisst ihr zufällig wie ich den Livestream einer Kamera aus frigate in meiner Visualisierung einbinde ?
                                    • M MarkA
                                      tombox
                                      #178
                                      @MarkA
                                      Alles klar aber wenn man Double Take mit dem Adapter verbindet werden alle Double Take Status korrekt in den Adapter Objekten angezeigt
                                      @ralf2201
                                      Das letzte Symbol mit dem Plus
                                      • T tombox
                                        @MarkA
                                        @ralf2201
                                        MarkA
                                        #179
                                        @tombox said in Frigate Adapter für ioBroker:
                                        @MarkA
                                        ich Verstehe es wohl nicht. Aktuell läuft das bei mir wie folgt:
                                        • Frigate erkennt eine Person und meldet das per MQTT
                                        • per MQTT bekommt wiederum DoubleTake das ganze mit und sendet die entsprechenden Images per MQTT weiter an Compreface
                                        • Compreface schaut ob die Person bekannt ist und wenn ja, wird per MQTT zurückgemeldet, welche Person das ist
                                        Wenn ich alle drei Komponenten auf den Adapter MQTT einstelle, funktioniert das o.g. Verhalten nicht mehr, da keine MQTT Verbindungen von DT und CF aufgebaut werden können.
                                        • M MarkA
                                          @MarkA
                                          tombox
                                          #180
                                          @marka
                                          Frigate verbindet sich mit Adapter MQTT und sendet Events
                                          DoubleTake verbindet sich mit Adapter MQTT und empfängt die Events und sendet eigene Events die unter Adapter Objekte abgespeichert werden
                                          DoubleTake verbindet sich via API und API Key mit Compreface
