  4. Frigate Adapter für ioBroker
    6.3k
383 Beiträge 48 Kommentatoren 140.7k Aufrufe 45 Beobachtet
  • H hagst
    @tombox sagte in Frigate Adapter für ioBroker:
    @hagst ja genau korrekt
    Alte Version deinstalliert
    $ iobroker del frigate --debug
    Delete adapter "frigate"
    host.iobroker Counted 1 instances of frigate
    host.iobroker Counted 1 meta of frigate
    host.iobroker Counted 1 adapter for frigate
    host.iobroker Counted 29 channels of frigate
    host.iobroker Counted 325 states of frigate
    host.iobroker Counted 15 states of system.adapter.frigate
    host.iobroker Counted 327 states (io.frigate.*) from states
    host.iobroker Counted 16 states (system.adapter.frigate.*) from states
    host.iobroker Counted 1 objects of frigate
    host.iobroker file frigate.admin deleted
    host.iobroker Deleting 373 object(s).
    host.iobroker: Only 200 objects left to be deleted.
    host.iobroker Deleting 343 state(s).
    host.iobroker: Only 200 states left to be deleted.
    removed 145 packages in 2s
    89 packages are looking for funding run `npm fund` for details
    Process exited with code 0
    Alle alten Einträge sind gelöscht:Alt1.png
    Neue Version von Github installiert
    $ iobroker url iobroker-community-adapters/ioBroker.frigate --host iobroker --debug
    install iobroker-community-adapters/ioBroker.frigate
    NPM version: 10.2.4
    Installing iobroker-community-adapters/ioBroker.frigate... (System call)
    added 31 packages, and changed 1 package in 6s89 packages are looking for funding run `npm fund` for details
    upload [1] frigate.admin /opt/iobroker/node_modules/iobroker.frigate/admin/frigate.png frigate.png image/png
    upload [0] frigate.admin /opt/iobroker/node_modules/iobroker.frigate/admin/jsonConfig.json jsonConfig.json application/json
    Instanz hinzugefügt:
    $ iobroker add frigate auto --host iobroker --debug
    host.iobroker create instance frigate
    host.iobroker object system.adapter.frigate.0.connected created
    host.iobroker object system.adapter.frigate.0.compactMode created
    host.iobroker object system.adapter.frigate.0.cpu created
    host.iobroker object system.adapter.frigate.0.memHeapUsed created
    host.iobroker object system.adapter.frigate.0.memRss created
    host.iobroker object system.adapter.frigate.0.uptime created
    host.iobroker object system.adapter.frigate.0.sigKill created
    host.iobroker object system.adapter.frigate.0.logLevel created
    host.iobroker object frigate.0.info.connection created
    host.iobroker Set default value of frigate.0.info.connection: false
    host.iobroker object system.adapter.frigate.0 created
    Adapter-Einstellungen vorgenommen:
    Logdatei:
    frigate.0
    2024-01-28 13:30:41.958	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:30:41.881	info	frigate.0 (2510) MQTT client frigate subscribed to topics: frigate/# from broker cb4f78fc-a529-4ab9-985e-c192fa46b979
    frigate.0
    2024-01-28 13:30:41.828	info	Filter for message from client: frigate
    frigate.0
    2024-01-28 13:30:41.828	info	New client: frigate
    frigate.0
    2024-01-28 13:29:58.798	info	If you don't see a new client connected, please restart frigate and adapter.
    frigate.0
    2024-01-28 13:29:58.798	info	Please enter host: 'iobroker' and port: '1885' in frigate config
    frigate.0
    2024-01-28 13:29:58.798	info	MQTT server started and listening on port 1885
    frigate.0
    2024-01-28 13:29:58.727	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
    frigate.0
    2024-01-28 13:29:55.429	info	terminating
    frigate.0
    2024-01-28 13:29:54.927	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    frigate.0
    2024-01-28 13:29:54.927	info	terminating
    frigate.0
    2024-01-28 13:29:54.926	info	Got terminate signal TERMINATE_YOURSELF
    frigate.0
    2024-01-28 13:27:53.031	error	Please check if port 1883 is already in use. Use a different port in instance and frigate settings or restart ioBroker.
    frigate.0
    2024-01-28 13:27:53.030	error	MQTT server error: Error: listen EADDRINUSE: address already in use :::1883
    frigate.0
    2024-01-28 13:27:52.893	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
    Ergebnis: :-/
    frigate.0
    2024-01-28 13:32:34.876	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:32:31.375	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:32:26.173	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:32:21.392	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:31:03.254	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:31:03.239	info	Device information created
    frigate.0
    2024-01-28 13:31:03.236	info	Fetch event history for 0 cameras
    frigate.0
    2024-01-28 13:31:03.236	info	{"Einfahrt":{"camera_fps":5,"process_fps":5,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":295,"capture_pid":299,"ffmpeg_pid":311},"Terrasse":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":297,"capture_pid":300,"ffmpeg_pid":306},"Wald":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":298,"capture_pid":302,"ffmpeg_pid":1285},"detectors":{"cpu":{"inference_speed":119.08,"detection_start":0,"pid":290}},"detection_fps":0,"service":{"uptime":10186,"version":"0.12.1-367d724","latest_version":"0.12.1","storage":{"/media/frigate/recordings":{"total":10464,"used":4280.4,"free":5630,"mount_type":"ext4"},"/media/frigate/clips":{"total":10464,"used":4280.4,"free":5630,"mount_type":"ext4"},"/tmp/cache":{"total":1000,"used":12.4,"free":987.6,"mount_type":"tmpfs"},"/dev/shm":{"total":67.1,"used":5.7,"free":61.4,"mount_type":"tmpfs"}},"temperatures":{},"last_updated":1706445063}}
    frigate.0
    2024-01-28 13:31:03.236	warn	No cameras found
    frigate.0
    2024-01-28 13:31:03.235	info	Create Device information and fetch Event History
    frigate.0
    frigate.0
    frigate.0
    frigate.0
    frigate.0
    frigate.0
    frigate.0
    frigate.0
    Nachtrag:
    Neustart ioBroker:
    frigate.0
    2024-01-28 13:43:41.697	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:43:41.680	info	Device information created
    frigate.0
    2024-01-28 13:43:41.677	info	Fetch event history for 0 cameras
    frigate.0
    2024-01-28 13:43:41.677	info	{"Einfahrt":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":295,"capture_pid":299,"ffmpeg_pid":311},"Terrasse":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":297,"capture_pid":300,"ffmpeg_pid":306},"Wald":{"camera_fps":5,"process_fps":5,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":298,"capture_pid":302,"ffmpeg_pid":4836},"detectors":{"cpu":{"inference_speed":92.58,"detection_start":0,"pid":290}},"detection_fps":0,"service":{"uptime":10944,"version":"0.12.1-367d724","latest_version":"0.12.1","storage":{"/media/frigate/recordings":{"total":10464,"used":4287.6,"free":5622.8,"mount_type":"ext4"},"/media/frigate/clips":{"total":10464,"used":4287.6,"free":5622.8,"mount_type":"ext4"},"/tmp/cache":{"total":1000,"used":11.3,"free":988.7,"mount_type":"tmpfs"},"/dev/shm":{"total":67.1,"used":5.7,"free":61.4,"mount_type":"tmpfs"}},"temperatures":{},"last_updated":1706445821}}
    frigate.0
    2024-01-28 13:43:41.677	warn	No cameras found
    frigate.0
    2024-01-28 13:43:41.676	info	Create Device information and fetch Event History
    frigate.0
    2024-01-28 13:42:44.876	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
    frigate.0
    2024-01-28 13:42:44.847	info	frigate.0 (734) MQTT client frigate subscribed to topics: frigate/# from broker cbd3cc19-f5b8-4d68-8252-e2cbe0736d9b
    frigate.0
    2024-01-28 13:42:44.784	info	Filter for message from client: frigate
    frigate.0
    2024-01-28 13:42:44.784	info	New client: frigate
    frigate.0
    2024-01-28 13:42:11.387	info	If you don't see a new client connected, please restart frigate and adapter.
    frigate.0
    2024-01-28 13:42:11.387	info	Please enter host: 'iobroker' and port: '1885' in frigate config
    frigate.0
    2024-01-28 13:42:11.387	info	MQTT server started and listening on port 1885
    frigate.0
    2024-01-28 13:42:11.316	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
    tombox
    #159
    @hagst Kannst die logs wieder löschen und die GitHub version drüber installieren
    H 1 Antwort Letzte Antwort
    • Q Offline
      Q Offline
      QuesT
      #160
      habe auch auf die 1.0 umgestellt und gleich versucht die Nachrichten via pushover zu senden. Leider stürtz der IoBroker komplett ab wenn ein Ereigniss getriggert wird. Per Telegram läuft es. Ist hier noch was zubeachten?
      • Q QuesT
        tombox
        #161
        @quest brauch ich den Fehler log
        Q 1 Antwort Letzte Antwort
        • T tombox
          H Online
          H Online
          hagst
          #162
          frigate.0
          2024-01-28 14:36:00.603	info	Device information created
          frigate.0
          2024-01-28 14:36:00.600	info	Fetch event history for 3 cameras
          frigate.0
          2024-01-28 14:36:00.586	info	Create device information for: Wald
          frigate.0
          2024-01-28 14:36:00.573	info	Create device information for: Terrasse
          frigate.0
          2024-01-28 14:36:00.558	info	Create device information for: Einfahrt
          frigate.0
          2024-01-28 14:36:00.527	info	Create Device information and fetch Event History
          frigate.0
          2024-01-28 14:35:55.551	info	frigate.0 (1789) MQTT client frigate subscribed to topics: frigate/# from broker 00d2ab76-66f6-4aa7-8018-159a69db4997
          frigate.0
          2024-01-28 14:35:55.526	info	Filter for message from client: frigate
          frigate.0
          2024-01-28 14:35:55.526	info	New client: frigate
          frigate.0
          2024-01-28 14:35:51.876	info	If you don't see a new client connected, please restart frigate and adapter.
          frigate.0
          2024-01-28 14:35:51.876	info	Please enter host: 'iobroker' and port: '1885' in frigate config
          frigate.0
          2024-01-28 14:35:51.876	info	MQTT server started and listening on port 1885
          frigate.0
          2024-01-28 14:35:51.793	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
          frigate.0
          2024-01-28 14:35:48.503	info	terminating
          frigate.0
          2024-01-28 14:35:48.002	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          frigate.0
          2024-01-28 14:35:48.002	info	terminating
          frigate.0
          2024-01-28 14:35:48.001	info	Got terminate signal TERMINATE_YOURSELF
          Jetzt sind die Einträge erstellt worden!
          • T tombox
            Q Offline
            Q Offline
            QuesT
            schrieb am zuletzt editiert von QuesT
            #163
            @tombox
            2024-01-28 15:10:07.144 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
            2024-01-28 15:10:08.172 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
            2024-01-28 15:10:27.144 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
            2024-01-28 15:10:27.639 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
            Danach startet der ioBroker neu.
            • Q QuesT
              @tombox
              tombox
              #164
              @quest bitte mal die GitHub version testen
              • T tombox
                Q Offline
                Q Offline
                QuesT
                #165
                @tombox
                2024-01-28 17:16:45.523 - error: pushover.0 (4298) Error from Pushover: message cannot be blank
                Stürzt aber nicht mehr ab.
                • Q QuesT
                  @tombox
                  tombox
                  #166
                  @quest dann nochmal installieren
                  • T tombox
                    Q Offline
                    Q Offline
                    QuesT
                    #167
                    @tombox
                    Bild kommt nun an. Video noch nicht: pushover.0 (1051) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                    • Q QuesT
                      @tombox
                      tombox
                      #168
                      @quest für den clip wäre noch ein debug log gut auch gerne per PN
                      • T tombox
                        Q Offline
                        Q Offline
                        QuesT
                        #169
                        @tombox
                        Vergiss es Pushover kann nur jpg.
                        Danke für die schnelle Hilfe.
                          MrHenker27
                          #170
                          Also zum ersten mal danke für den neuen Adapter.
                          Leider bekomm ich Warn Meldungen im Log -.-
                          • M MrHenker27
                            tombox
                            #171
                            @mrhenker27 kommt das mit der 1.0.2?
                            • T tombox
                              MrHenker27
                              #172
                              @tombox
                              okay, war die 1.0.0 hab jetzt über GIT mal die 1.0.2 installiert. Scheint behoben zu sein.
                              • M MrHenker27
                                @tombox
                                MarkA
                                #173
                                Leider geht mit dem neuen Adapter die Kombination von Frigate in Verbindung mit Touble-Take und Compreface zur Personenerkennung nicht mehr, da alle mit dem gleichen MQTT Server sprechen müssen.
                                • M MarkA
                                  tombox
                                  #174
                                  @marka Eigentlich sollte das gehen. Bitte mal die GitHub version installieren und einfach als mqtt host den iobroker eingeben
                                  • T tombox
                                    MarkA
                                    #175
                                    das geht bei mir so leider nicht. So wie ich die neue Version verstanden habe, bringt sie einen eigenen MQTT Broker mit. Dies möchte ich nicht, da ich bereits den MQTT Adapter, sowie den SONOFF Adapter für MQTT laufen habe, mit jeweils vielen Integrationen, je nachdem wie die Daten ankommen.
                                    Dazu kommt noch, dass der Frigate Adapter MQTT keine Authentifizierung benutzt.
                                    • R Offline
                                      ralf2201
                                      #176
                                      wie kann ich denn wieder auf die alte Version zurück? Kann mir da jemand helfen?
                                      • R ralf2201
                                        martinschm
                                        schrieb am zuletzt editiert von martinschm
                                        #177
                                        Installation hat gleich geklappt, hab lediglich den MQTT Port angepasst. Telegram Benachrichtiung kam auch gleich an, sehr cool gemacht. Vielen Dank für die neue Adapter Version.
                                        Kurze Frage noch zu den State
                                        Warum hat der Channel "Motion" auch nochmal einen Wert ?
                                        Und welchen State muß ich nehmen wenn ich in meiner Visualisierung "kurz" anzeigen will ob es eine Bewegung gab. Irgendwann sollte der State ja auch mal wieder falsch sein, oder ?
                                        Bei mir schein der State "state" unter Motion immer auf true zu stehen.
                                        Und wisst ihr zufällig wie ich den Livestream einer Kamera aus frigate in meiner Visualisierung einbinde ?
                                        • M MarkA
                                          tombox
                                          #178
                                          @MarkA
                                          Alles klar aber wenn man Double Take mit dem Adapter verbindet werden alle Double Take Status korrekt in den Adapter Objekten angezeigt
                                          @ralf2201
                                          Das letzte Symbol mit dem Plus
