  4. Panasonic comfort cloud Adapter funktioniert nicht mehr
    5.4k
72 Beiträge 17 Kommentatoren 12.5k Aufrufe 13 Beobachtet
  • E Offline
    ecurb
    schrieb am zuletzt editiert von ecurb
    #61
    habe gerade einen PI neu aufgesetzt.
    Es ist ein älteres model aber das sollte ja nicht die rolle spielen.
    IO-Broker haben ich mit dem befehl "curl -sLf https://iobroker.net/install.sh | bash -" instaliert.
    Das sagt der Adapter wenn er neu gestartet wird:
    panasonic-comfort-cloud.0
    	2025-01-10 21:09:26.568	error	Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:99:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:97:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:96:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
    	2025-01-10 21:09:25.887	info	Login successful.
    	2025-01-10 21:09:21.992	info	Loaded app version from GitHub: 1.21.0
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: IO-PI
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:13:43 up 30 min,  2 users,  load average: 0.58, 0.64, 0.84
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-01-10 21:13:43 CET
               Universal time: Fri 2025-01-10 20:13:43 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Test
    HOME=/home/Test
    GROUPS=Test adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            951M        152M        517M        196K        349M        799M
    Swap:           536M         18M        518M
    Total:          1.5G        170M        1.0G
    Active iob-Instances:   1
              907 M total memory
              144 M used memory
              113 M active memory
              186 M inactive memory
              493 M free memory
               13 M buffer memory
              319 M swap cache
              511 M total swap
               17 M used swap
              494 M free swap
    top - 21:13:44 up 30 min,  2 users,  load average: 0.58, 0.64, 0.84
    Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    907.3 total,    492.8 free,    145.6 used,    333.3 buff/cache
    MiB Swap:    512.0 total,    494.7 free,     17.2 used.    761.7 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  318M     0  318M   0% /dev
    tmpfs          tmpfs      91M 1008K   90M   2% /run
    /dev/mmcblk0p2 ext4       15G  3.6G  9.8G  27% /
    tmpfs          tmpfs     454M     0  454M   0% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Fri Jan 10 20:42:44 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4cb582d8-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Fri Jan 10 20:42:48 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Fri Jan 10 20:42:51 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    917M    /var/
    205M    /var/cache
    200M    /var/cache/apt
    164M    /var/lib
    135M    /var/lib/apt/lists
    Archived and active journals take up 36.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    181M    /opt/iobroker/iobroker-data/
    176M    /opt/iobroker/iobroker-data/files
    158M    /opt/iobroker/iobroker-data/files/admin.admin
    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
    6.8M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IO-PI         IO-PI (version: 7.0.6, hostname: IO-PI   , alive, uptime: 652)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : IO-PI                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : IO-PI                              -  enabled
      system.adapter.discovery.0              : discovery             : IO-PI                              -  enabled
      system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: IO-PI                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "panasonic-comfort-cloud": 3.0.3, installed 3.0.3
    Objects and States
    Objects:        170
    States:         87
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 12
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2534       548/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2536       548/sshd: /usr/sbin
    udp        0      0 0.0.0.0:39976           0.0.0.0:*                           104        4733       380/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4731       380/avahi-daemon: r
    udp6       0      0 fe80::670f:5c02:79f:546 :::*                                0          5547       441/NetworkManager
    udp6       0      0 :::51930                :::*                                104        4734       380/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4732       380/avahi-daemon: r
    2025-01-10 21:12:34.664  - info: panasonic-comfort-cloud.0 (9739) Got terminate signal TERMINATE_YOURSELF
    2025-01-10 21:12:34.660  - info: discovery.0 (9515) Got terminate signal TERMINATE_YOURSELF
    2025-01-10 21:12:34.676  - info: discovery.0 (9515) terminating
    2025-01-10 21:12:34.679  - info: admin.0 (9489) Got terminate signal TERMINATE_YOURSELF
    2025-01-10 21:12:34.682  - info: host.IO-PI stopInstance system.adapter.admin.0 send kill signal
    2025-01-10 21:12:34.681  - info: discovery.0 (9515) Terminated (NO_ERROR): Without reason
    2025-01-10 21:12:34.684  - info: host.IO-PI stopInstance system.adapter.backitup.0 send kill signal
    2025-01-10 21:12:34.685  - info: host.IO-PI stopInstance system.adapter.discovery.0 send kill signal
    2025-01-10 21:12:34.686  - info: host.IO-PI stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
    2025-01-10 21:12:34.702  - info: admin.0 (9489) terminating
    2025-01-10 21:12:34.705  - info: admin.0 (9489) Terminated (NO_ERROR): Without reason
    2025-01-10 21:12:34.718  - info: backitup.0 (9496) terminating
    2025-01-10 21:12:34.722  - info: backitup.0 (9496) Terminated (NO_ERROR): Without reason
    2025-01-10 21:12:34.726  - info: panasonic-comfort-cloud.0 (9739) terminating
    2025-01-10 21:12:34.729  - info: panasonic-comfort-cloud.0 (9739) Terminated (NO_ERROR): Without reason
    2025-01-10 21:12:35.126  - info: discovery.0 (9515) terminating
    2025-01-10 21:12:35.135  - info: backitup.0 (9496) terminating
    2025-01-10 21:12:35.142  - info: panasonic-comfort-cloud.0 (9739) terminating
    2025-01-10 21:12:35.174  - info: admin.0 (9489) terminating
    2025-01-10 21:12:35.288  - info: host.IO-PI instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2025-01-10 21:12:35.343  - info: host.IO-PI instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2025-01-10 21:12:35.375  - info: host.IO-PI instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2025-01-10 21:12:35.415  - info: host.IO-PI instance system.adapter.panasonic-comfort-cloud.0 terminated with code 0 (NO_ERROR)
    2025-01-10 21:12:35.416  - info: host.IO-PI All instances are stopped.
    2025-01-10 21:12:35.511  - info: host.IO-PI terminated
    • E ecurb
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      Test
      HOME=/home/Test
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           536M         18M        518M
                907 M total memory
                144 M used memory
                113 M active memory
                493 M free memory
                 13 M buffer memory
                319 M swap cache
                511 M total swap
                 17 M used swap
                494 M free swap
      *** FILESYSTEM ***
      /var:
      917M    /var/
      205M    /var/cache
      200M    /var/cache/apt
      164M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.10
      Adapter State
      + instance is alive
      Objects and States
      Objects:        170
      States:         87
      Pending Updates: 12
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #62
      @ecurb
      Sieht nach diesem Issue aus
      https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/60
      Infos dazu kann nur der dev geben.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        rainereglinsky
        #63
        Heute hat Panasonic mal wieder was geändert, neue Datenschutzrichtlinie und natürlich wohl Änderungen am System. Der aktuelle Adapter v3.0.3 aus dem Github von Marc2016 verbindet sich nicht mehr.
        • E Online
          E Online
          emil70
          #64
          issue: (https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/79) ist dazu schon eröffnet
          gruss emil70
          iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
          • E Online
            E Online
            emil70
            #65
            Mit 2.1.0 geht es
            gruss emil70
            • G Offline
              grombiegel
              #66
              mit 2.1.0 werden die Objekte bei mir angelegt, aber leider wird kein Status mit der Klima ausgetauscht.
              Egal ob ein/aus oder connected oder Temperatursensor - da verändert sich nichts, die Klima wird damit nicht ausgelesen.
              Hat jemand noch eine Idee?
              Deinstalliert und sämtliche andere Versionen haben nicht funktioniert.
              Es ist echt ein Mist, gefühlt alle 6 Monate geht nix mehr....
              E 1 Antwort Letzte Antwort
              • G grombiegel
                E Online
                E Online
                emil70
                #67
                @grombiegel
                Geht hier ohne Probleme. Ob mit App geschaltet oder über Alexa und meinem Blockly
                Hast du lang genug gewartet?
                Was hast du in den Einstellungen bei "Aktualisierungsintervall" eingestellt?
                gruss emil70
                • G Offline
                  grombiegel
                  #68
                  1 Minute, die Instanz ist sofort da, aber die Objekte werden nicht installiert - eben dachte ich das passt, Klima war an. Hab dann Temperatur geändert und ca. 5 Minuten später ausgeschaltet. connect wird angezeigt, jedoch steht operate jetzt immer noch auf On...temp set steht auch noch unverändert
                  • G grombiegel
                    E Online
                    E Online
                    emil70
                    schrieb am zuletzt editiert von emil70
                    #69
                    @grombiegel
                    nutzt du das App und den Adapter mit den gleichem Benutzer und PW?
                    Oder hast du dir ein Zweitaccount gemacht?
                    gruss emil70
                    • G Offline
                      grombiegel
                      #70
                      App und Adapter mit selben Zugangsdaten, App funktioniert auch korrekt
                      • G Offline
                        grombiegel
                        #71
                        nanu, jetzt funktioniert die Kommunikation, hatte nochmals die App aufgerufen eine Änderung durchgeführt und jetzt werden die Daten auch im Adapter aktualisiert - danke für die Unterstützung
                          adson
                          schrieb am zuletzt editiert von adson
                          #72
                          Ich bekomme leider einen Fehler (wurde oben schonmal so ähnlich gepostet, leider ohne für mich erkennbare Lösung). Ich bitte um Hilfe...
                          error Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:107:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:105:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:104:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
