Panasonic comfort cloud Adapter funktioniert nicht mehr
habe gerade einen PI neu aufgesetzt.
Es ist ein älteres model aber das sollte ja nicht die rolle spielen.IO-Broker haben ich mit dem befehl "curl -sLf https://iobroker.net/install.sh | bash -" instaliert.
Das sagt der Adapter wenn er neu gestartet wird:
panasonic-comfort-cloud.0 2025-01-10 21:09:26.568 error Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:99:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:97:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:96:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24) panasonic-comfort-cloud.0 2025-01-10 21:09:25.887 info Login successful. panasonic-comfort-cloud.0 2025-01-10 21:09:21.992 info Loaded app version from GitHub: 1.21.0Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: IO-PI Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.51+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 3 Model B Rev 1.2 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 21:13:43 up 30 min, 2 users, load average: 0.58, 0.64, 0.84 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Fri 2025-01-10 21:13:43 CET Universal time: Fri 2025-01-10 20:13:43 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': Test HOME=/home/Test GROUPS=Test adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': js-controller is not running *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 951M 152M 517M 196K 349M 799M Swap: 536M 18M 518M Total: 1.5G 170M 1.0G Active iob-Instances: 1 907 M total memory 144 M used memory 113 M active memory 186 M inactive memory 493 M free memory 13 M buffer memory 319 M swap cache 511 M total swap 17 M used swap 494 M free swap *** top - Table Of Processes *** top - 21:13:44 up 30 min, 2 users, load average: 0.58, 0.64, 0.84 Tasks: 147 total, 1 running, 146 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 25.0 sy, 0.0 ni, 75.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 907.3 total, 492.8 free, 145.6 used, 333.3 buff/cache MiB Swap: 512.0 total, 494.7 free, 17.2 used. 761.7 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 318M 0 318M 0% /dev tmpfs tmpfs 91M 1008K 90M 2% /run /dev/mmcblk0p2 ext4 15G 3.6G 9.8G 27% / tmpfs tmpfs 454M 0 454M 0% /dev/shm tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 64M 447M 13% /boot/firmware tmpfs tmpfs 91M 0 91M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Jan 10 20:42:44 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=4cb582d8-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE [Fri Jan 10 20:42:48 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none. [Fri Jan 10 20:42:51 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 917M /var/ 205M /var/cache 200M /var/cache/apt 164M /var/lib 135M /var/lib/apt/lists Archived and active journals take up 36.0M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 181M /opt/iobroker/iobroker-data/ 176M /opt/iobroker/iobroker-data/files 158M /opt/iobroker/iobroker-data/files/admin.admin 157M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 157M /opt/iobroker/iobroker-data/files/admin.admin/custom/static The five largest files in iobroker-data are: 7.4M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map 6.8M /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is not running on this host. Objects type: jsonl States type: jsonl Hosts: IO-PI IO-PI (version: 7.0.6, hostname: IO-PI , alive, uptime: 652) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: "javascript" not found nodejs modules from github: 0 Adapter State system.adapter.admin.0 : admin : IO-PI - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.backitup.0 : backitup : IO-PI - enabled system.adapter.discovery.0 : discovery : IO-PI - enabled system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: IO-PI - enabled + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : IO-PI - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "discovery" : 5.0.0 , installed 5.0.0 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "panasonic-comfort-cloud": 3.0.3, installed 3.0.3 Objects and States Please stand by - This may take a while Objects: 170 States: 87 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 12 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 2534 548/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 2536 548/sshd: /usr/sbin udp 0 0 0.0.0.0:39976 0.0.0.0:* 104 4733 380/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4731 380/avahi-daemon: r udp6 0 0 fe80::670f:5c02:79f:546 :::* 0 5547 441/NetworkManager udp6 0 0 :::51930 :::* 104 4734 380/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4732 380/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-01-10 21:12:34.664 - info: panasonic-comfort-cloud.0 (9739) Got terminate signal TERMINATE_YOURSELF 2025-01-10 21:12:34.660 - info: discovery.0 (9515) Got terminate signal TERMINATE_YOURSELF 2025-01-10 21:12:34.676 - info: discovery.0 (9515) terminating 2025-01-10 21:12:34.679 - info: admin.0 (9489) Got terminate signal TERMINATE_YOURSELF 2025-01-10 21:12:34.682 - info: host.IO-PI stopInstance system.adapter.admin.0 send kill signal 2025-01-10 21:12:34.681 - info: discovery.0 (9515) Terminated (NO_ERROR): Without reason 2025-01-10 21:12:34.684 - info: host.IO-PI stopInstance system.adapter.backitup.0 send kill signal 2025-01-10 21:12:34.685 - info: host.IO-PI stopInstance system.adapter.discovery.0 send kill signal 2025-01-10 21:12:34.686 - info: host.IO-PI stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal 2025-01-10 21:12:34.702 - info: admin.0 (9489) terminating 2025-01-10 21:12:34.705 - info: admin.0 (9489) Terminated (NO_ERROR): Without reason 2025-01-10 21:12:34.718 - info: backitup.0 (9496) terminating 2025-01-10 21:12:34.722 - info: backitup.0 (9496) Terminated (NO_ERROR): Without reason 2025-01-10 21:12:34.726 - info: panasonic-comfort-cloud.0 (9739) terminating 2025-01-10 21:12:34.729 - info: panasonic-comfort-cloud.0 (9739) Terminated (NO_ERROR): Without reason 2025-01-10 21:12:35.126 - info: discovery.0 (9515) terminating 2025-01-10 21:12:35.135 - info: backitup.0 (9496) terminating 2025-01-10 21:12:35.142 - info: panasonic-comfort-cloud.0 (9739) terminating 2025-01-10 21:12:35.174 - info: admin.0 (9489) terminating 2025-01-10 21:12:35.288 - info: host.IO-PI instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR) 2025-01-10 21:12:35.343 - info: host.IO-PI instance system.adapter.admin.0 terminated with code 0 (NO_ERROR) 2025-01-10 21:12:35.375 - info: host.IO-PI instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) 2025-01-10 21:12:35.415 - info: host.IO-PI instance system.adapter.panasonic-comfort-cloud.0 terminated with code 0 (NO_ERROR) 2025-01-10 21:12:35.416 - info: host.IO-PI All instances are stopped. 2025-01-10 21:12:35.511 - info: host.IO-PI terminated@ecurb
Sieht nach diesem Issue aus
https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/60Infos dazu kann nur der dev geben.
Heute hat Panasonic mal wieder was geändert, neue Datenschutzrichtlinie und natürlich wohl Änderungen am System. Der aktuelle Adapter v3.0.3 aus dem Github von Marc2016 verbindet sich nicht mehr.
issue: (https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/79) ist dazu schon eröffnet
mit 2.1.0 werden die Objekte bei mir angelegt, aber leider wird kein Status mit der Klima ausgetauscht.
Egal ob ein/aus oder connected oder Temperatursensor - da verändert sich nichts, die Klima wird damit nicht ausgelesen.
Hat jemand noch eine Idee?
Deinstalliert und sämtliche andere Versionen haben nicht funktioniert.
Es ist echt ein Mist, gefühlt alle 6 Monate geht nix mehr.... -
Es ist echt ein Mist, gefühlt alle 6 Monate geht nix mehr....Geht hier ohne Probleme. Ob mit App geschaltet oder über Alexa und meinem Blockly
Hast du lang genug gewartet?
Was hast du in den Einstellungen bei "Aktualisierungsintervall" eingestellt? -
1 Minute, die Instanz ist sofort da, aber die Objekte werden nicht installiert - eben dachte ich das passt, Klima war an. Hab dann Temperatur geändert und ca. 5 Minuten später ausgeschaltet. connect wird angezeigt, jedoch steht operate jetzt immer noch auf On...temp set steht auch noch unverändert
@grombiegel
nutzt du das App und den Adapter mit den gleichem Benutzer und PW?Oder hast du dir ein Zweitaccount gemacht?
App und Adapter mit selben Zugangsdaten, App funktioniert auch korrekt
nanu, jetzt funktioniert die Kommunikation, hatte nochmals die App aufgerufen eine Änderung durchgeführt und jetzt werden die Daten auch im Adapter aktualisiert - danke für die Unterstützung
Ich bekomme leider einen Fehler (wurde oben schonmal so ähnlich gepostet, leider ohne für mich erkennbare Lösung). Ich bitte um Hilfe...
error Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:107:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:105:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:104:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
