  4. ([gelöst]) Daten Sonnensystem Resol auslesen per VBUS
118 Beiträge 15 Kommentatoren 38.5k Aufrufe 8 Beobachtet
  • BeagelB Offline
    BeagelB Offline
    Beagel
    #61
    Hallo zusammen, bin neu bei iobroker und mache meine ersten Versuche.
    Hab jetzt mal versucht meine Solaranlage abzufragen, ist eine Resol DeltaSol_SL über Resol-Lan-Adapter.
    als Script läuft 1.2, Werte werden mir auch angezeigt aber im Log kommen immer wieder diese Fehlermeldungen :
    host.ioBroker-BPi	2017-12-28 12:26:20.762	info	Restart adapter system.adapter.javascript.0 because enabled
    host.ioBroker-BPi	2017-12-28 12:26:20.761	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
    host.ioBroker-BPi	2017-12-28 12:26:20.760	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:98:9)
    host.ioBroker-BPi	2017-12-28 12:26:20.759	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:74:11)
    host.ioBroker-BPi	2017-12-28 12:26:20.758	error	Caught by controller[0]: at emitErrorNT (net.js:1278:8)
    host.ioBroker-BPi	2017-12-28 12:26:20.758	error	Caught by controller[0]: at Socket.emit (events.js:188:7)
    host.ioBroker-BPi	2017-12-28 12:26:20.756	error	Caught by controller[0]: at emitOne (events.js:96:13)
    host.ioBroker-BPi	2017-12-28 12:26:20.755	error	Caught by controller[0]: at Socket.onError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:370:13)
    host.ioBroker-BPi	2017-12-28 12:26:20.754	error	Caught by controller[0]: at onSocketTermination (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:341:22)
    host.ioBroker-BPi	2017-12-28 12:26:20.753	error	Caught by controller[0]: Error: Unable to connect
    javascript.0	2017-12-28 12:26:20.610	error	Error: Unable to connect at onSocketTermination (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:341:22) at Socket.onError (/opt/iobroker/node_modu
    javascript.0	2017-12-28 12:26:20.604	error	uncaught exception: Unable to connect
    javascript.0	2017-12-28 12:26:15.230	info	script.js.Vbus: registered 0 subscriptions and 1 schedule
    wenn ich im Script resolDL3 auskommentiere
    //*****************************SET VARs***************************************************************************
    var resolhost = '192.168.178.40';                         // Can be used with via.vbus.net OR internal 192xxxxx adress !
    var resolviaTag = 'xxxx';                   // only necessary if connected using VBus.net otherwise leave empty
    var resolpass = 'vbus';                     //default is set
    //var resolDL3 = false;                       //set to true if you use a DL3
    var worktime = 10000;                       // 10 second timer, collection all information takes some seconds [emoji6]
    var create_states = false;                  // initial on true to create states once, disable value afterwards to update states !!!
    //*****************************Dont edit something below*****
    kommt dann nur noch diese Fehlermeldung
    javascript.0	2017-12-28 12:20:40.016	error	at Object. (script.js.Vbus:29:4)
    javascript.0	2017-12-28 12:20:40.015	error	Error in callback: ReferenceError: resolDL3 is not defined
    was muss ich noch ändern?
    • BeagelB Offline
      BeagelB Offline
      Beagel
      #62
      Stelle auch gerade Fest das sich die Werte nicht aktualisieren , stehen noch immer auf den erstmal geholten Werten.
        dippi
        #63
        Hallo Dutchman
        ich habe im Iobroker die Werte einmal Level.Temperature und value.Temperature zugeortnet und getestet aber im CloudAdapter kommen die Werte immer noch mit an/auf an und nicht mit °C.
        Hast du das bei dir am laufen oder mach ich noch etwas falsch ?
        Dippi
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #64
          @dippi:
          Hallo Dutchman
          Dippi `
          müsste ich mal probieren selber noch nicht im cloud adapter benutzt
            dippi
            #65
            Hallo Dutchman
            Wenn du mal Zeit hast wäre es super wenn du es mal bei dir Testen könntest.
            Vielen Dank
            Manuel
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #66
              @dippi:
              Hallo Dutchman
              Vielen Dank
              Manuel `
              Hi Manuel,
              Könntest du bitte Mal probieren wie in diesem Post erklärt:
              http://forum.iobroker.net/viewtopic.php?t=9969#p108864
              Send from mobile device
              Das schöne ios hat Auto Korrektur zum k****
              Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                dippi
                #67
                Hallo
                ich hab die einstellungen gemacht, nun bekomme ich folgende Warnmeldungen
                javascript.0 2018-01-02 15:04:51.082 warn at Object. (script.js.Dippi.Skript1:86:26)
                javascript.0 2018-01-02 15:04:51.081 warn at Array.forEach (native)
                javascript.0 2018-01-02 15:04:51.081 warn at script.js.Dippi.Skript1:158:21
                javascript.0 2018-01-02 15:04:51.081 warn Wrong type of javascript.0.vbus.00_7210_0010.values_raw.Temperaturesensor1: "string". Please fix, while deprecated and will not work in next versions.
                javascript.0 2018-01-02 15:04:30.953 warn at Object. (script.js.Dippi.Skript1:86:26)
                javascript.0 2018-01-02 15:04:30.952 warn at Array.forEach (native)
                javascript.0 2018-01-02 15:04:30.952 warn at script.js.Dippi.Skript1:158:21
                javascript.0 2018-01-02 15:04:30.950 warn Wrong type of javascript.0.vbus.00_7210_0010.values_raw.Temperaturesensor1: "string". Please fix, while deprecated and will not work in next versions.
                javascript.0 2018-01-02 15:04:10.952 warn at Object. (script.js.Dippi.Skript1:86:26)
                javascript.0 2018-01-02 15:04:10.952 warn at Array.forEach (native)
                javascript.0 2018-01-02 15:04:10.952 warn at script.js.Dippi.Skript1:158:21
                javascript.0 2018-01-02 15:04:10.950 warn Wrong type of javascript.0.vbus.00_7210_0010.values_raw.Temperaturesensor1: "string". Please fix, while deprecated and will not work in next versions.
                javascript.0 2018-01-02 15:03:50.952 warn at Object. (script.js.Dippi.Skript1:86:26)
                muss ich noch etwas Updaten ?
                Dippi
                  alexw85
                  #68
                  Nimm dieses Script, läuft bei mir seit Monaten astrein und ich steuere auch meine Heizkreise damit! Ich komm nur nicht dazu einen Adapter zu programmieren dafür…
                  Zuvor bitte im Javascript Adapter folgendes reinschreiben bei zusätzliche NPM Module: "resol-vbus, kue, optimist, express, q"
                  Dann dieses Script ausführen (IP Adresse und ggf. Password natürlich anpassen):
                  /*! ### ioBroker Script zum auslesen und konfigurieren von Resol und anderen auf VBus basierenden Steuerungen ### */
                  /*! ####### Das Script basiert auf auf dem Node JS Modul "resol-vbus" von Daniel Wippermann und wurde von ####### */
                  /*! ################### Dutchman, meifi2017 & AlexW für die Verwendung in ioBroker angepasst! ################### */
                  var fs = require('fs');
                  var express = require('express');
                  var kue = require('kue');
                  var _ = require('lodash');
                  var optimist = require('optimist');
                  var Q = require('q');
                  var vbus = require('resol-vbus/src/index');
                  var action = {
                  "loadAll" : true, // Bedeutet das beim Start des Scripts der Controller ausgelesen werden soll!
                  "out": "/opt/iobroker/ResolVBusConfigTest.json" // Pfad wo die gesamten Konfigurationswerte des Controllers beim Start des Scripts gespeichert werden sollen
                  /*! Hier bitte die spezifischen Verbindungsdaten eintragen! */
                  var config = {
                  "connection": {
                  "class": "TcpConnection",
                  "options": {
                  "host": "192.168.178.100", 	// IP-Adresse oder VBus.net Adresse hier eintragen
                  "viaTag": "", 		// Bei Verbindung über VBus.net ist hier das viaTag einzutragen
                  "password": "vbus", 	// Passwort, Standard ist: vbus
                  // "channel" : "1" 		// Channel, wird nur für die Verbindung über einen DL3 benötigt und ist standardmäßig auskommentiert!
                  /*! Ab hier reiner Code */
                  var timestamp;
                  var Live = function() {
                  var vbuslive = require('resol-vbus');
                  var headerSetlive = new vbuslive.HeaderSet();
                  var connlive;
                  // Schedule every 30 seconds
                  schedule("*/30 * * * * *", function () {
                  // Define connection values
                  var connectionConfigLive = config.connection;
                  var ConnectionLive = vbuslive [connectionConfigLive.class];
                  connlive = new ConnectionLive(connectionConfigLive.options);
                  // Log connection status
                  var onConnectionStateChange = function(state) {
                  console.debug(state);
                  var onPacket = function(packet) {
                  headerSetlive.addHeader(packet);
                  connlive.on('connectionState', onConnectionStateChange);
                  connlive.on('packet', onPacket);
                  connlive.connect().done(function() {
                  setTimeout(function() {
                  connlive.disconnect();
                  //create header packages
                  var packets = headerSetlive.getSortedHeaders();
                  var spec = vbuslive.Specification.getDefaultSpecification();
                  var packetFields = spec.getPacketFieldsForHeaders(packets);
                  var packet = null;
                  var counter = 0;
                  packetFields.forEach(function(packetField) {
                  counter = counter + 1;
                  if (packet !== packetField.packet) {
                  packet = packetField.packet;
                  console.debug(packetField.packetSpec.fullName);
                  // write values in memory
                  packetField.name = packetField.name.replace(/ /g,"");
                  console.debug("Value received : " + packetField.name + " = " + packetField.formatTextValue());
                  try{
                  if (getIdByName(packetField.name) != null) {
                  setState("vbus.values." + packetField.name , packetField.formatTextValue(), true);
                  } else {
                  createState("vbus.values." + packetField.name , {
                  type: 'string',
                  role: 'value',
                  def: packetField.formatTextValue(),
                  } catch(e){}
                  }, 10000);
                  var createStates = function() {
                  var file = action.out;
                  fs.readFile(file, 'utf8', function (err, body) {
                  if (err) {}
                  JSON.parse(body, (key, value) => {
                  var jsonkey = key;
                  var jsonvalue = value;
                  try{
                  if (jsonkey !== "" && getIdByName(jsonkey) != null)
                  setState("vbus.config." + jsonkey , parseFloat(jsonvalue), true);
                  } catch(e){}
                  try {
                  if (jsonkey !== "")
                  createState("vbus.config." + jsonkey , {
                  type: 'number',
                  role: 'value',
                  def: parseFloat(jsonvalue),
                  } catch (e){}
                  action.loadAll = false;
                  timestamp = Date.now();
                  var ready = "Ready for processing...";
                  setTimeout(console.log, 10000, ready);
                  return;
                  var writeStates = function() {
                  on({id: /^javascript\.\d\.vbus.config./, change: "ne"}, function (obj) {
                  var statename = obj.name;
                  var value = obj.state.val;
                  var lastChanged = getState(obj.id).lc;
                  if (typeof oldValue !== "undefined" && lastChanged > (timestamp + 10000)) {
                  console.log(statename + " hat sich von " + oldValue + " auf " + value + " geändert!");
                  jsonWrite = JSON.stringify({[statename] : value});
                  action.save = true;
                  action.data = jsonWrite;
                  setState("vbus.config." + statename , parseFloat(value), true);
                  return runSingleShot(action);
                  var promise = vbus.utils.promise;
                  var i18n = new vbus.I18N('en');
                  var reportProgress = function(message) {
                  var line;
                  if (_.isString(message)) {
                  line = message;
                  } else if (message.message === 'OPTIMIZING_VALUES') {
                  line = i18n.sprintf('Optimizing set of values for round %d', message.round);
                  } else if (message.message === 'GETTING_VALUE') {
                  line = i18n.sprintf('Getting value %d/%d, try %d: %s', message.valueNr, message.valueCount, message.tries, message.valueId);
                  } else if (message.message === 'SETTING_VALUE') {
                  line = i18n.sprintf('Setting value %d/%d, try %d: %s', message.valueNr, message.valueCount, message.tries, message.valueId);
                  } else if (message.message === 'CONNECTION_STATE') {
                  line = i18n.sprintf('Connection state changed to %s', message.connectionState);
                  } else if (message.message === 'WAITING_FOR_FREE_BUS') {
                  line = i18n.sprintf('Waiting for free bus');
                  } else if (message.message === 'RELEASING_BUS') {
                  line = i18n.sprintf('Releasing bus');
                  } else {
                  line = i18n.sprintf('%s: %s', message.message, JSON.stringify(message));
                  if (_.isNumber(message.round)) {
                  line = i18n.sprintf('[%d] %s', message.round, line);
                  console.log(line);
                  var loadJsonFile = function(filename) {
                  return promise(function(resolve, reject) {
                  fs.readFile(filename, function(err, data) {
                  if (err) {
                  reject(err);
                  } else {
                  resolve(data);
                  }).then(function(data) {
                  return JSON.parse(data);
                  var createConnection = function() {
                  var connectionConfig = config.connection;
                  var Connection = vbus [connectionConfig.class];
                  var conn = new Connection(connectionConfig.options);
                  conn.on('connectionState', function(state) {
                  reportProgress({
                  message: 'CONNECTION_STATE',
                  connectionState: state,
                  return conn;
                  var processCustomizationJob = function(context, job) {
                  'use strict';
                  return Q.fcall(function() {
                  reportProgress('Waiting for free bus...');
                  return context.connection.waitForFreeBus();
                  }).then(function(datagram) {
                  context.masterAddress = datagram.sourceAddress;
                  reportProgress('Found master with address 0x' + context.masterAddress.toString(16));
                  context.deviceAddress = context.masterAddress;
                  return vbus.ConfigurationOptimizerFactory.createOptimizerByDeviceAddress(context.deviceAddress);
                  }).then(function(optimizer) {
                  context.optimizer = optimizer;
                  context.customizer = new vbus.ConnectionCustomizer({
                  deviceAddress: context.deviceAddress,
                  connection: context.connection,
                  optimizer: context.optimizer,
                  }).then(function() {
                  var onProgress = function(progress) {
                  reportProgress(progress);
                  var command = job.data.command;
                  var config = job.data.config;
                  var currentConfig = context.currentConfig;
                  var options = {
                  optimize: false,
                  if (command === 'load') {
                  options.optimize = !config;
                  return context.customizer.loadConfiguration(config, options).progress(onProgress);
                  }).then(function(config) {
                  return context.optimizer.completeConfiguration(config, currentConfig);
                  context.currentConfig = config;
                  } else if (command === 'save') {
                  return context.customizer.saveConfiguration(config, currentConfig, options).progress(onProgress);
                  } else {
                  throw new Error('Unknown command ' + JSON.stringify(command));
                  var serve = function() {
                  'use strict';
                  var context = {};
                  return createConnection();
                  }).then(function(conn) {
                  context.connection = conn;
                  reportProgress('Connecting...');
                  return context.connection.connect();
                  var jobs = kue.createQueue();
                  jobs.process('customization', function(job, done) {
                  return processCustomizationJob(context, job);
                  }).done(function() {
                  console.log('Job done!');
                  done();
                  }, function(err) {
                  console.log('Job failed!');
                  done(err);
                  var app = express();
                  app.get('/config', function(req, res) {
                  var jsonConfig = _.reduce(context.currentConfig, function(memo, value) {
                  if (!value.ignored) {
                  memo [value.valueId] = value.value;
                  return memo;
                  res.json(jsonConfig);
                  app.use(kue.app);
                  app.listen(3000);
                  var runSingleShot = function(action) {
                  var context = {};
                  if (action.q) {
                  reportProgress = function() {};
                  }).then(function(oldConfig) {
                  context.oldConfig = oldConfig;
                  if (action.loadAll) {
                  return null;
                  } else if (action.load) {
                  return loadJsonFile(action.load);
                  }).then(function(loadConfig) {
                  context.loadConfig = loadConfig;
                  if (action.save) {
                  return JSON.parse(jsonWrite);
                  }).then(function(saveConfig) {
                  context.saveConfig = saveConfig;
                  if (!optimizer) {
                  reportProgress(i18n.sprintf('WARNING: Unable to create optimizer for master with address 0x%04X', context.masterAddress));
                  if (context.loadConfig !== undefined) {
                  var config = context.loadConfig;
                  var options = {
                  optimize: !config,
                  context.loadedConfig = config;
                  if (context.saveConfig !== undefined) {
                  var saveConfig = context.saveConfig;
                  var oldConfig = context.oldConfig;
                  var options = {
                  optimize: false,
                  return context.customizer.saveConfiguration(saveConfig, oldConfig, options).progress(onProgress);
                  } else {
                  return config;
                  var jsonConfig = _.reduce(config, function(memo, value) {
                  return memo;
                  jsonConfig = JSON.stringify(jsonConfig);
                  if (action.out) {
                  return vbus.utils.promise(function(resolve, reject) {
                  fs.writeFile(action.out, jsonConfig, function(err) {
                  if (err) {
                  reject(err);
                  } else {
                  resolve();
                  } else {
                  console.log(jsonConfig);
                  }).finally(function() {
                  reportProgress('Disconnecting...');
                  if (context.connection !== null) {
                  context.connection.disconnect();
                  var main = function() {
                  var argv = optimist.argv;
                  if (argv.serve) {
                  return serve();
                  } else {
                  Q.fcall(main)
                  .then(createStates)
                  .then(writeStates)
                  .then(Live)
                  .done();
                  Gesendet von meinem SM-T819 mit Tapatalk
                    dippi
                    #69
                    Hallo
                    ich bekomme folgende Fehlermeldung im Log bei dem Skript:
                    host.ioBroker-Pi	2018-01-07 11:41:38.093	info	Restart adapter system.adapter.javascript.0 because enabled
                    host.ioBroker-Pi	2018-01-07 11:41:38.093	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                    Caught	2018-01-07 11:41:38.092	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                    Caught	2018-01-07 11:41:38.092	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
                    Caught	2018-01-07 11:41:38.092	error	by controller[0]: at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
                    Caught	2018-01-07 11:41:38.092	error	by controller[0]: at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
                    Caught	2018-01-07 11:41:38.090	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
                    Caught	2018-01-07 11:41:38.090	error	by controller[0]: at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
                    Caught	2018-01-07 11:41:38.090	error	by controller[0]: at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
                    Caught	2018-01-07 11:41:38.090	error	by controller[0]: at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
                    Caught	2018-01-07 11:41:38.089	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
                    Caught	2018-01-07 11:41:38.089	error	by controller[0]: at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
                    Caught	2018-01-07 11:41:38.089	error	by controller[0]: at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
                    Caught	2018-01-07 11:41:38.088	error	by controller[0]: TypeError: Cannot read property 'optimizeLoadConfiguration' of null
                    javascript.0	2018-01-07 11:41:38.033	info	script.js.Dippi.Resol_2: Connection state changed to DISCONNECTED
                    javascript.0	2018-01-07 11:41:38.022	error	at process._tickCallback (internal/process/next_tick.js:104:9)
                    javascript.0	2018-01-07 11:41:38.022	error	at _combinedTickCallback (internal/process/next_tick.js:73:7)
                    javascript.0	2018-01-07 11:41:38.022	error	at flush (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:125:13)
                    javascript.0	2018-01-07 11:41:38.022	error	at runSingle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:137:13)
                    javascript.0	2018-01-07 11:41:38.022	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:624:44
                    javascript.0	2018-01-07 11:41:38.022	error	at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:816:13)
                    javascript.0	2018-01-07 11:41:38.022	error	at self.promiseDispatch.done (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:883:30)
                    javascript.0	2018-01-07 11:41:38.022	error	at _fulfilled (/opt/iobroker/node_modules/iobroker.javascript/node_modules/q/q.js:854:54)
                    javascript.0	2018-01-07 11:41:38.022	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:233:32
                    javascript.0	2018-01-07 11:41:38.022	error	at callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/connection-customizer.js:102:34)
                    javascript.0	2018-01-07 11:41:38.022	error	at constructor._optimizeLoadConfiguration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/customizer.js:169:30)
                    javascript.0	2018-01-07 11:41:38.022	error	TypeError: Cannot read property 'optimizeLoadConfiguration' of null
                    javascript.0	2018-01-07 11:41:38.022	error	uncaught exception: Cannot read property 'optimizeLoadConfiguration' of null
                    javascript.0	2018-01-07 11:41:38.005	info	script.js.Dippi.Resol_2: Connection state changed to DISCONNECTING
                    javascript.0	2018-01-07 11:41:38.003	info	script.js.Dippi.Resol_2: Disconnecting...
                    javascript.0	2018-01-07 11:41:37.999	info	script.js.Dippi.Resol_2: [1] Optimizing set of values for round 1
                    javascript.0	2018-01-07 11:41:37.981	info	script.js.Dippi.Resol_2: WARNING: Unable to create optimizer for master with address 0x7210
                    javascript.0	2018-01-07 11:41:37.971	info	script.js.Dippi.Resol_2: Found master with address 0x7210
                    javascript.0	2018-01-07 11:41:36.347	info	script.js.Dippi.Resol_2: Waiting for free bus...
                    javascript.0	2018-01-07 11:41:36.346	info	script.js.Dippi.Resol_2: Connection state changed to CONNECTED
                    javascript.0	2018-01-07 11:41:36.222	info	script.js.Dippi.Resol_2: Connection state changed to CONNECTING
                    muss ich noch was Updaten ?
                    Gruß Dippi
                      alexw85
                      #70
                      @dippi:
                      Hallo
                      Gruß Dippi `
                      Hmm… Also er erkennt den Controller, connected und dann meldet das Skript das er die Config nicht laden kann und deshalb die ganzen Fehlermeldungen.
                      Welcher Resol Regler ist das? Hängt da vieleicht ein DL3 dran? Stimmt das Passwort?
                      Gesendet von meinem SM-G955F mit Tapatalk
                        dippi
                        #71
                        Guten Morgen
                        ne es hängt ein SKSC3 Regler und ein HK Regler dran.
                        Dippi
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #72
                          @dippi:
                          Guten Morgen
                          Dippi `
                          Die Geräte arbeiten aber auf resol-vbus?
                          Laut docu des npm Moduls werden folgende Geräte unterstützt:
                           Supported Devices & Services
                          All current RESOL controllers with VBus
                          RESOL DL2 Datalogger
                          RESOL DL3 Datalogger
                          RESOL VBus/LAN interface adapter
                          RESOL VBus/USB interface adapter
                          RESOL VBus.net
                            dippi
                            #73
                            Hallo
                            ja klar das andere Skript klappt ja. Hab nur das Problem das ich die Daten nicht in den Cloud Adapter rein bekomme als Temperatur sondern nur als An/Aus.
                            Gruß Dippi
                              alexw85
                              #74
                              Er erkennt aber mit dem Master 0x7210 einen SKSR 1/2/3
                              Wenn ich das richtig verstehe sollte da aber ein 0x7211 erkannt werden müssen?!
                              Wenn das andere Skript funktioniert, schonmal in den Objekten alles gelöscht was das Skript angelegt hat und neu gestartet? Nicht das durch die verschiedenen Skripte falsch formatierte States angelegt wurden und es deswegen nicht geht…
                                dippi
                                #75
                                Hallo
                                die Daten bei den Obijekten hatte ich schon gelöscht, ich hab jetzt eine neue Karte mit dem image vom IObroker gemacht und wollte den Module installieren.
                                Schon beim ersten Modul bekomme ich folgende Fehlermeldung:
                                pi@All-in-One-Pi:/opt/iobroker/node_modules/iobroker.javascript $ sudo npm install resol-vbus
                                > serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                                > node-pre-gyp install --fallback-to-build
                                node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.4 (node-v48 ABI) (falling back to source compile with node-gyp)
                                gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.11.4"
                                gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/.node-gyp"
                                make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build“ wird betreten
                                make: *** Keine Regel vorhanden, um das Ziel „../.node-gyp/6.11.4/include/node/common.gypi“,
                                  benötigt von „Makefile“, zu erstellen.  Schluss.
                                make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build“ wird verlassen
                                gyp ERR! build error
                                gyp ERR! stack Error: `make` failed with exit code: 2
                                gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
                                gyp ERR! stack     at emitTwo (events.js:106:13)
                                gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                                gyp ERR! System Linux 4.9.41-v7+
                                gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.javascript/no        de_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/Release"
                                gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                                gyp ERR! node -v v6.11.4
                                gyp ERR! node-gyp -v v3.6.0
                                gyp ERR! not ok
                                node-pre-gyp ERR! build error
                                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_module        s/iobroker.javascript/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/R        elease' (1)
                                node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
                                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                                node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
                                node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                node-pre-gyp ERR! System Linux 4.9.41-v7+
                                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
                                node-pre-gyp ERR! node -v v6.11.4
                                node-pre-gyp ERR! node-pre-gyp -v v0.6.32
                                node-pre-gyp ERR! not ok
                                Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.javascript/node_modu        les/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build/Release' (1)
                                pi@All-in-One-Pi:/opt/iobroker/node_modules/iobroker.javascript $</anonymous>
                                Auch bei dem Github Link kommt der Fehler 404
                                Dippi
                                  alexw85
                                  #76
                                  @dippi:
                                  Hallo
                                  gyp ERR! not ok
                                  Dippi ` Root hat kein Zugriff? Ist die SD Karte kaputt oder das Filesystem ReadOnly gemountet? :) Das npm install ist schlecht, hatte ich am Anfang auch gemacht, beim nächsten Update des Javascript Adapter ist alles wieder weg, daher besser im WebIf unter Instanzen bei den Einstellungen zum Javascript bei "zusätzliche NPM Module installieren" oder so ähnlich kommagetrennt die Module reinschreiben die du brauchst, dann kommen sie nach dem Update wieder!
                                    dippi
                                    #77
                                    Hi
                                    ja das kann schon sein das das System noch Read only ist, hast du mir bitte den Befehl um die Rechte zu vergeben.
                                    und welche Module muss ich im Adapter reinschreiben.
                                    Dippi
                                      alexw85
                                      #78
                                      @dippi:
                                      Hi
                                      Dippi ` So anbei die Bilder, normal sollte das Filesystem nicht Schreibgeschützt sein, aber ich hatte bei einem Raspberry der mir zwei Kamerabilder angezeigt und selbst eine Raspicam zum aufzeichnen hatte das Problem das mir 2-3x die SD Karte kaputtgegangen ist mit selben Erscheinungen weil das Netzteil zu schwach war! ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 6253e3.jpg">https://uploads.tapatalk-cdn.com/20180109/322b747749eec58115b43765416253e3.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 424748.jpg">https://uploads.tapatalk-cdn.com/20180109/2541e38fa1ee7affce9690e037424748.jpg</link_text>" />
                                      Gesendet von meinem SM-T819 mit Tapatalk~~~~
                                        dippi
                                        #79
                                        Hallo
                                        ich hab die Eintragungen im Javascript Adapter eingtragen, beim Installieren kommen folgende Fehlermeldungen.
                                        javascript.0 2018-01-09 19:46:35.839 info Stop script script.js.Dippi.Skript1
                                        javascript.0 2018-01-09 19:45:52.467 info received all objects
                                        javascript.0 2018-01-09 19:45:51.606 info received all states
                                        javascript.0 2018-01-09 19:45:50.538 info requesting all objects
                                        javascript.0 2018-01-09 19:45:50.534 info requesting all states
                                        javascript.0 2018-01-09 19:45:50.492 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modul
                                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent
                                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                                        javascript.0 2018-01-09 19:45:50.490 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                                        javascript.0 2018-01-09 19:45:50.490 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modul
                                        javascript.0 2018-01-09 19:45:50.489 error npm
                                        javascript.0 2018-01-09 19:45:50.489 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:50.487 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                                        javascript.0 2018-01-09 19:45:50.485 error npm
                                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                                        javascript.0 2018-01-09 19:45:50.485 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                                        javascript.0 2018-01-09 19:45:50.485 error enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/nod
                                        javascript.0 2018-01-09 19:45:50.476 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.476 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_mo
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validato
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/no
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-str
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_mo
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                                        javascript.0 2018-01-09 19:45:50.474 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once/packag
                                        javascript.0 2018-01-09 19:45:50.474 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignor
                                        javascript.0 2018-01-09 19:45:50.466 error npm
                                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/pac
                                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug/packa
                                        javascript.0 2018-01-09 19:45:50.466 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/package.
                                        javascript.0 2018-01-09 19:45:50.466 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/package.js
                                        javascript.0 2018-01-09 19:45:50.464 error npm
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/package
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs/package.j
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringi
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/package
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validato
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/pa
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-str
                                        javascript.0 2018-01-09 19:45:50.464 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist/package.
                                        javascript.0 2018-01-09 19:45:50.464 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/deep-extend/package.json'
                                        javascript.0 2018-01-09 19:45:50.454 error enoent
                                        javascript.0 2018-01-09 19:45:50.450 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.450 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/package
                                        javascript.0 2018-01-09 19:45:50.450 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                                        javascript.0 2018-01-09 19:45:50.450 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist/package.json'
                                        javascript.0 2018-01-09 19:45:50.444 error enoent
                                        javascript.0 2018-01-09 19:45:50.443 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.443 error enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/package.json'
                                        javascript.0 2018-01-09 19:45:50.433 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.433 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/package.json'
                                        javascript.0 2018-01-09 19:45:50.433 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/semver/package.json'
                                        javascript.0 2018-01-09 19:45:50.433 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/package.json'
                                        javascript.0 2018-01-09 19:45:50.431 error npm
                                        javascript.0 2018-01-09 19:45:50.431 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/package.json'
                                        javascript.0 2018-01-09 19:45:50.431 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/package.json'
                                        javascript.0 2018-01-09 19:45:50.430 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/package.json'
                                        javascript.0 2018-01-09 19:45:50.428 error enoent
                                        javascript.0 2018-01-09 19:45:50.416 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/package.json'
                                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/package.json'
                                        javascript.0 2018-01-09 19:45:50.416 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/package.json'
                                        javascript.0 2018-01-09 19:45:50.416 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/package.json'
                                        javascript.0 2018-01-09 19:45:50.415 error enoent
                                        javascript.0 2018-01-09 19:45:50.414 error npm WARN
                                        javascript.0 2018-01-09 19:45:50.414 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign/package.json'
                                        javascript.0 2018-01-09 19:45:50.414 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys/package.json'
                                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent
                                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/package.json'
                                        javascript.0 2018-01-09 19:45:50.413 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie/package.json'
                                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/package.json'
                                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/package.json'
                                        javascript.0 2018-01-09 19:45:50.412 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/package.json'
                                        javascript.0 2018-01-09 19:45:50.411 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/package.json'
                                        javascript.0 2018-01-09 19:45:50.411 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/package.json'
                                        javascript.0 2018-01-09 19:45:50.409 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander/package.json'
                                        javascript.0 2018-01-09 19:45:50.406 error enoent
                                        javascript.0 2018-01-09 19:45:50.404 error
                                        javascript.0 2018-01-09 19:45:50.401 error WARN
                                        javascript.0 2018-01-09 19:45:50.399 error
                                        javascript.0 2018-01-09 19:45:50.397 error npm
                                        javascript.0 2018-01-09 19:45:50.383 info └── optimist@0.6.1
                                        javascript.0 2018-01-09 19:45:50.383 info iobroker.javascript@3.4.0 /opt/iobroker/node_modules/iobroker.javascript
                                        javascript.0 2018-01-09 19:45:33.372 info npm install optimist --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                        javascript.0 2018-01-09 19:45:33.283 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                                        javascript.0 2018-01-09 19:45:33.283 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                                        javascript.0 2018-01-09 19:45:33.282 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:33.281 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:33.281 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                                        javascript.0 2018-01-09 19:45:33.280 error npm
                                        javascript.0 2018-01-09 19:45:33.278 error WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/
                                        javascript.0 2018-01-09 19:45:33.276 error
                                        javascript.0 2018-01-09 19:45:33.273 error npm
                                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatu
                                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-
                                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-st
                                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ign
                                        javascript.0 2018-01-09 19:45:33.261 error npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_mod
                                        javascript.0 2018-01-09 19:45:33.240 error ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_module
                                        javascript.0 2018-01-09 19:45:33.237 error enoent
                                        javascript.0 2018-01-09 19:45:33.235 error
                                        debug pm WARN
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signatur
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_mod
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/nod
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stre
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_mod
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-y
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-str
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once/package
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-igno
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/pack
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug/packag
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/package.j
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/package.j
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/package.
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie/
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs/package.js
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringif
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/package.
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/pac
                                        debug pm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist/package.j
                                        Ich hab das Skript vom 05.01.2018 genommen und die IP Adresse geändert.
                                        Dippi
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #80
                                          Hi @alexw85,
                                          Ich habe jetzt auch mal das neue script eingesetzt und damit sollte es ja auch moeglich sein daten zu aendern richtig ?
                                          Schick varible zurueck aber nach 30 sekunden wird sie wieder die halten ist da noch ein bestimmter trick ?
                                          Greetz,
                                          Dutch
