  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
    5.1k
1.2k Beiträge 114 Kommentatoren 469.6k Aufrufe 93 Beobachtet
  • A amnesia106
    Huhu, hat jemand nen Anstoß wie ich meinen Deye 800w WR mit dem mqtt client vom iobroer auslesen kann? Der Deye adapter lässt sich bei mir nicht installieren und endet mit Code 25.
    Rene55R Offline
    Rene55R Offline
    Rene55
    #781
    @amnesia106 Welche Version von nodeJS, Admin und jsController?
    Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
    ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
    Wetterstation: Froggit WH3000SE V1.6.6
    A 1 Antwort Letzte Antwort
    • Rene55R Rene55
      amnesia106
      #782
      @rene55
      iobroker add deyeidc auto --host DietPi --debug
      Installing iobroker.deyeidc@0.0.14... (System call)
      npm ERR! path /opt/iobroker/node_modules/bufferutil
      npm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.19.0 | linux | arm64npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:7702) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',
      npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-15T12_23_14_202Z-debug-0.log
      host.DietPi Cannot install iobroker.deyeidc@0.0.14: 1
      ERROR: Process exited with code 25
      Plattform: linux
      RAM: 3.7 GB
      Node.js: v18.19.0
      NPM: 10.2.3
      Rene55R 1 Antwort Letzte Antwort
      • A amnesia106
        @rene55
        Plattform: linux
        RAM: 3.7 GB
        Node.js: v18.19.0
        NPM: 10.2.3
        Rene55R Offline
        Rene55R Offline
        Rene55
        #783
        @amnesia106 Such mal iobroker error process exited with code 25. Da ist sicher eine Vorgehensweise beschrieben, die dir helfen könnte.
          amnesia106
          #784
          @rene55 ich hab den fehler auch nur bei dem Deye Adapter feststellen können, andere installieren ohne probleme
            amnesia106
            schrieb am zuletzt editiert von amnesia106
            #785
            €: node-gyp neu installiert und bufferutil nachgeschoben hat den Fehler behoben... sry
            Hab mal nen issue aufgemacht. Das komische: andere Adapter aus der repo laufen ohne Probleme durch. https://github.com/raschy/ioBroker.deyeidc/issues/81
            irgendwas mit bufferutil schlägt da anfangs fehl, jedoch finde ich da nichts konkretes.
            root@DietPi:~# npm ls bufferutil
            root@ /root
            ├── bufferutil@4.0.8
            └─┬ iobroker.deyeidc@0.0.14
              └─┬ websocket@1.0.34
                └── bufferutil@4.0.8 deduped
            root@DietPi:/opt/iobroker/node_modules# npm i bufferutil@4.0.8
            npm ERR! code 1
            npm ERR! gyp info using node@18.19.1 | linux | arm64
            npm ERR! (node:3962) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
            npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.19.1/include/node/common.gypi',
            npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.1',
            npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
            npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.1/<(target_arch)/node.lib',
            npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',
            npm ERR! gyp info spawn args   '-Dnode_engine=v8',
            npm ERR! gyp info spawn args   '--depth=.',
            npm ERR! gyp info spawn args   '--no-parallel',
            npm ERR! gyp info spawn args   '--generator-output',
            npm ERR! gyp info spawn args   'build',
            npm ERR! gyp info spawn args   '-Goutput_dir=.'
            npm ERR! gyp info spawn args ]
            npm ERR! Traceback (most recent call last):
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
            npm ERR!     sys.exit(gyp.script_main())
            npm ERR!              ^^^^^^^^^^^^^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
            npm ERR!     return main(sys.argv[1:])
            npm ERR!            ^^^^^^^^^^^^^^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
            npm ERR!     return gyp_main(args)
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
            npm ERR!     [generator, flat_list, targets, data] = Load(
            npm ERR!                                             ^^^^^
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
            npm ERR!     result = gyp.input.Load(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
            npm ERR!     LoadTargetBuildFile(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
            npm ERR!     build_file_data = LoadOneBuildFile(
            npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
            npm ERR!     build_file_contents = open(build_file_path, "rU").read()
            npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
            npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
            npm ERR! gyp ERR! configure error
            npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
            npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
            npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
            npm ERR! gyp ERR! System Linux 6.1.21-v8+
            npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
            npm ERR! gyp ERR! node -v v18.19.1
            npm ERR! gyp ERR! node-gyp -v v7.1.2
            npm ERR! gyp ERR! not ok
            ? Rene55R 2 Antworten Letzte Antwort
            • A amnesia106
              root@ /root
              npm ERR! code 1
              npm ERR!                                             ^^^^^
              #786
              @amnesia106
              root.... eiderdaus.. :-)
              das Issue kannst du auch gleich wieder zu machen, da du dir mit deinem root-account deine Rechte im System in Node und NPM geschossen hast... :-(
              Log dich bitte mal als user ein, den du angelegt haben solltest, geh in /opt/iobroker und mach ein iobroker fix, das biegt hoffentlich die Rechte wieder gerade...
              • A amnesia106
                root@ /root
                npm ERR! code 1
                npm ERR!                                             ^^^^^
                Rene55R Offline
                Rene55R Offline
                Rene55
                #787
                @amnesia106 sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                Ich habe von diesen beiden Utilitys noch nie was gehört, geschweige denn installiert. Trotzdem viel Spaß mit dem Adapter.
                  timredlich
                  #788
                  Hallo ich habe einen Deye 600 Wechselrichter mit externem Relais. Ich nutze den Deydic Adapter zur Integration in IObroker. Ich versuche seit Wochen den Wechselrichter über den Source Analytics Adapter auszuwerten, ich nutze dazu das Register Et_ge0 Production Total. Am Ersten Tag wird noch richtig berechnet. Am darauffolgenden Tag steht schon der Totale Erzeugte Wert im Object Current Day. Es wird also nicht richtig berechnet. Ich habe noch einen Hoymiles Wechselrichter, den ich mit den gleichen einstellungen auswerte und da funktioniert es einwandfrei. Kann es daran liegen weil sich der Deye Abends/Nachts abschaltet und die DTU (ahoy) vom Hoymiles nicht. Hat irgendjemand source Analytics mit dem Deyedic Adapter zum laufen bekommen?
                  Rene55R R J 3 Antworten Letzte Antwort
                  • T timredlich
                    Rene55R Offline
                    Rene55R Offline
                    Rene55
                    schrieb am zuletzt editiert von Rene55
                    #789
                    @timredlich Wenn ich Deye glauben darf ist in Et_ge0 die Gesamtproduktion enthalten. Die wird wohl -wenn überhaupt - erst mit einem Totalreset wieder auf 0 gehen. Wenn du daraus die Tagesproduktion haben willst, musst du selbst was ausrechnen.
                    • T timredlich
                      Rico Sander
                      #790
                      @timredlich
                      .Etdy_ge0 Production Today
                      Das sollte der DP sein, den Du suchst. Nutzt Du den Adapter von @rene55 ?
                      Wenns nicht geht, wie man will
                      - muss mans tun, wie man kann.
                      • R Rico Sander
                        @timredlich
                        timredlich
                        #791
                        @wcag22 beim Hoymiles habe ich auch den Totalen Datenpunkt. Die Tagesleistung wird dann aus der Diferenz zu gestern berechnet. Das macht der Source Analytics Adapter von ganz allein. Beim Deyedic Datenpunkt klappt es nicht.
                        • T timredlich
                          Rene55R Offline
                          Rene55R Offline
                          Rene55
                          #792
                          @timredlich Liegt das am Inhalt des DP? Welche Daten erwartest Du da?
                          • T timredlich
                            jrudolph
                            #793
                            @timredlich Der Deye Adapter liefert die richtigen Werte und der gewählte Datenpunkt ist auch der richtige für die Verwendung mit Source Analytics.
                            Leider hat Source Analytics einige Probleme bei der Auswertung von Daten, die sich selten oder über Nacht nicht ändern bzw. aktualisiert werden. Diese Probleme werden u.a. in den Issues #478, #704 und #905 auf der Github Seite beschrieben. In #478 ist ein Workaround mit einem Blockly Script beschrieben. Mal ausprobieren.
                            Ich hatte Source Analytics bisher nicht im Einsatz, aber nun mal testweise aufgesetzt. Hat für das Deye BKW korrekt funktioniert.
                            • J jrudolph
                              timredlich
                              #794
                              @jrudolph Ich habe jetzt manuell einen Datenpunkt angelegt, den ich mit Source Analytics auswerte. Diesen Datenpunkt aktualisiere ich jede Minute mit den Werten vom Deydic Adapter. Leider hatte Source Analytics wieder nicht richtig berechnet. Gestern habe ich die Auswertung gestartet. Somit zeigte heute Morgen der Punkt Previous Day 0,7 kWh an und der Punkt Current Day 427,7 kWh. Normalerweise müsste Current Day bei 0 kWh liegen. Die 427 hatte ich als Aktuellen Zählerstand (Day,Week, Month, Quarter und Year ) eingetragen. Aktiviert war: Verbrauch berechnen und Erkennung der Zurücksetzung des Gerätewerts Aktiviert.
                              Eduard77E 1 Antwort Letzte Antwort
                              • T timredlich
                                Eduard77E Online
                                Eduard77E Online
                                Eduard77
                                #795
                                @timredlich
                                Wie aktualisierst du dein manueller DP.
                                Bei mir funktioniert es.
                                Ich habe es so eingestellt. Der Wert wird nur dann aktualisiert, wenn er Größer als letztes ist.
                                T 2 Antworten Letzte Antwort
                                • Eduard77E Eduard77
                                  @timredlich
                                  timredlich
                                  #796
                                  @edis77 ich habe ein Interval von 1 Minute angelegt, so das jede Minute der Datenpunkt Production Total abgefragt wird und in den Datenpunkt PV_Carport geschrieben wird. Ich werde jetzt aber mal deine Variante ausprobiern.
                                    @timredlich
                                    timredlich
                                    #797
                                    @edis77 So habe jetzt mal übers Wochenende getestet. Und mit deiner Variante des Scripts funktioniert es tatsächlich. Die Auswertung passt und ich muss jetzt keinen zusätzlichen Shelly verbauen. Danke für die Hilfe.
                                    • mosfetM Offline
                                      mosfetM Offline
                                      mosfet
                                      #798
                                      ich habe einen Deye sun-10k-sg04lp3-eu an dem ein ethernet datenlogger steckt. Jetzt wollte ich mittels dieses Adapters die daten des Wechselrichters auslesen.
                                      Ich habe einige der Register aus dieser Config hier ausprobiert: https://github.com/raschy/ioBroker.deyeidc/blob/main/deyeidc.Sun10KP3.json
                                      Es hat aber nichts funktioniert.
                                      Mein log sieht so aus:
                                      Bei fast jedem Versuch gibt es Checksummen Fehler. Datenpunkte wurden von dem Adapter bisher noch keine angelegt.
                                      Habt ihr eine Idee was das Problem sein könnte?
                                      • mosfetM mosfet
                                        Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        #799
                                        @mosfet Der Checksummen-Fehler rührt aus dem WR. Hab ich vorige Tage auch mal gehabt und war irgendwann wieder verschwunden. Ursache unbekannt.
                                        Die Datenpunkte werden erst angelegt, wenn gültige Daten empfangen werden.
                                        mosfetM 1 Antwort Letzte Antwort
                                        • Rene55R Rene55
                                          mosfetM Offline
                                          mosfetM Offline
                                          mosfet
                                          #800
                                          @rene55 said in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                          Hm ok. Sieht die config denn soweit i.O. aus?
                                          Ich wüsste langsam nicht mehr warum ich keine Werte empfange. Den Checksummenfehler bekomme ich bei fast jedem Versuch, aber nicht immer. Am Ende ist aber immer ein Timeout in der Connection.
