  4. [Aufruf] Bitte js-controller 1.0.3 + admin 1.7.6 testen
17 Beiträge 10 Kommentatoren 3.2k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Es gibt neue Versionen von js-controller und admin und bevor die ins stable verschoben werden, währe es toll wenn jemand die testet.
    Die Änderungen tragen kosmetischer Character und die Vorbereitungen für admin-neo
    js-controller 1.0.3 (2017-06-01)
    (bluefox) getHostInfo for new admin
    (bluefox) allow using of files for certificates
    (bluefox) always install zwave with unsafe-perm option
    (apollon77) add handling for undefined
    (apollon77) uptime is a number only and no String/List/Array beside the fact that also with a number a "toString" should exist, or it's undefined because an old host is listed with no value ...
    admin
    1.7.6 (2017-06-01)
    (bluefox) Fix edit of the enum name
    1.7.5 (2017-05-20)
    (bluefox) catch error if translated object is not text
    (bluefox) update selectID.js
    (bluefox) do not open configuration dialog for instances with no config
    (Steiger04) select multiple auch bei data-name="[eigner-name]"
      Marcolotti
      Hallo Bluefox,
      bei der Admin Installation kommt folgender Fehler:
      root@iobroker2:/opt/iobroker# npm install iobroker.admin
      > mdns@2.3.3 install /opt/iobroker/node_modules/mdns
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/mdns/build'
        CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
      In file included from ../src/dns_sd.cpp:1:0:
      ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
       #include <dns_sd.h>^
      compilation terminated.
      dns_sd_bindings.target.mk:149: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/mdns/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp ERR! System Linux 3.16.0-4-686-pae
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/mdns
      gyp ERR! node -v v6.10.3
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      iobroker.core@0.1.0 /opt/iobroker
      └── (empty)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm ERR! code 1</dns_sd.h>
      CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
        Marcolotti
        Aber geht trotzdem alles. :?
        JS-Controller auf 1.0.3 und admin auf 1.7.6.
        • arteckA Offline
          arteckA Offline
          arteck
          der Include fehlt…hat einer vergessen was hochzuladen...
          • BluefoxB Offline
            BluefoxB Offline
            @arteck:
            der Include fehlt…hat einer vergessen was hochzuladen... `
            Mehr Info.
            Ist nicht klar wo was fehlt.
            • ThisoftT Offline
              ThisoftT Offline
              Thisoft
              Habe gestern alle Updates eingespielt. Bis jetzt läuft alles problemlos :D
              Hatte auch keine auffälligen Fehlermeldungen. Mal abgesehen von dem Slave auf dem noch node 0.6 drauf ist, aber da ists ja klar…
              • rantanplanR Offline
                rantanplanR Offline
                rantanplan
                Updates auf Win10 durchgeführt.
                Keine Probleme.
                Grüße
                Rantanplan
                • lobomauL Offline
                  lobomauL Offline
                  lobomau
                  Ich habe auf Pi3 geupdatet ohne Probleme danach, nur paar Fehlermeldungen (npm ERR) während der Installation.
                  Beim brix lief es nicht so gut. Habe dabei auch ein apt-get update und upgrade durchgeführt (8 ubuntu updates).
                  root@brix-3150:/opt/iobroker# sudo iobroker status
                  module.js:471
                      throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (module.js:469:15)
                      at Function.Module._load (module.js:417:25)
                      at Module.runMain (module.js:604:10)
                      at run (bootstrap_node.js:390:7)
                      at startup (bootstrap_node.js:150:9)
                      at bootstrap_node.js:505:3
                  EDIT: es reichte folgendes aus. Scheint erstmal normal zu laufen
                  root@brix-3150:/opt/iobroker# npm install iobroker.js-controller --production
                  Host: NUC8i3 mit Proxmox:
                  • Slave: Pi4
                  • K Offline
                    Kueppert
                    Hallo in die Runde,
                    habe mich auch getraut und wollte meinen Beitrag zum Test leisten. System läuft seit paar Minuten unauffällig. Hatte nur bei der installation auf meinem Raspberry Pi3 unten angehangene Fehlermeldung via Putty:
                    root@raspberrypi3:/opt/iobroker# sudo iobroker upgrade self
                    npm install iobroker.js-controller@1.0.3 –production --prefix "/opt/iobroker" (System call)
                    Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
                    Host "raspberrypi3" (linux) updated
                    Execute: chmod 777 -R /opt/iobroker
                    Chmod finished. Restart controller
                    Starting node restart.js
                    VG kueppert
                    PS: gerade festgestellt, dass beim Adapter fritz.box die history Einträge jetzt leer sind… Keine Ahnung, ob das nach einem Neustart immer so ist?!
                    • Jeeper.atJ Offline
                      Jeeper.atJ Offline
                      Jeeper.at
                      Hier auch alles OK.
                      Update auf einem Windows 10 System.
                      Lg
                      Günther
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        Läuft seit 12 Stunden ohne sichtbare Probleme
                        Send from mobile device
                          Turbo
                          Verdammt - bei mir läuft es natürlich wieder mal nicht…
                          Habe gerade zuerst admin und dann js-controller upgedatet. Danach verabschiedete sich iobroker...
                          Habe jetzt schon einiges versucht, inkl. iobroker Neuinstallation - keine Reaktion, nur npm Fehler...
                          root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production
                          npm ERR! Linux 4.4.43-v7+
                          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
                          npm ERR! node v4.7.2
                          npm ERR! npm  v2.15.11
                          npm ERR! file /root/.npm/iobroker.js-controller/1.0.3/package/package.json
                          npm ERR! code EJSONPARSE
                          npm ERR! Failed to parse json
                          npm ERR! No data, empty input at 1:1
                          npm ERR!
                          npm ERR! ^
                          npm ERR! File: /root/.npm/iobroker.js-controller/1.0.3/package/package.json
                          npm ERR! Failed to parse package.json data.
                          npm ERR! package.json must be actual JSON, not just JavaScript.
                          npm ERR!
                          npm ERR! This is not a bug in npm.
                          npm ERR! Tell the package author to fix their package.json file. JSON.parse
                          npm ERR! Please include the following file with any support request:
                          npm ERR!     /opt/iobroker/npm-debug.log
                          root@raspberrypi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
                          npm ERR! not a package /opt/iobroker/iobroker
                          npm ERR! addLocal Could not install /opt/iobroker/iobroker
                          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
                          npm ERR! path /tmp/npm-1585-16846667/unpack-82b0f14b7517/package.json
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall open
                          npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-1585-16846667/unpack-82b0f14b7517/package.json'
                          npm ERR! enoent This is most likely not a problem with npm itself
                          npm ERR! enoent and is related to npm not being able to find a file.
                          npm ERR! enoent
                          Kann mir bitte mal jemand helfen?
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            was sagt der
                              Turbo
                              root@raspberrypi:/opt/iobroker# /opt/iobroker/npm-debug.log
                              -bash: /opt/iobroker/npm-debug.log: Keine Berechtigung
                              :shock:
                              Habe jetzt nochmal downgegradet - mit den alten Versionen läuft alles wieder…
                                Jeeper.atJ Offline
                                Jeeper.at
                                Immer zuerst den Controller, dann Admin updaten.
                                Lg
                                Günther
                                  Turbo
                                  Jippie - läuft! Vielen Dank. Jetzt muss ich nur noch mein web.1 (SSL Zugriff) wieder zum Laufen bringen.
                                  Was zur Hölle ist "greenlock"?!?
                                  host.raspberrypi	2017-06-05 19:48:18.722	error	instance system.adapter.web.1 terminated with code 0 (OK)
                                  web.1	2017-06-05 19:48:18.314	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                  web.1	2017-06-05 19:48:18.314	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                  web.1	2017-06-05 19:48:18.314	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:639:21)
                                  web.1	2017-06-05 19:48:18.314	error	at /opt/iobroker/node_modules/iobroker.web/main.js:166:29
                                  web.1	2017-06-05 19:48:18.314	error	at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:507:28)
                                  web.1	2017-06-05 19:48:18.314	error	at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:13:25)
                                  web.1	2017-06-05 19:48:18.314	error	at require (internal/module.js:12:17)
                                  web.1	2017-06-05 19:48:18.314	error	at Module.require (module.js:353:17)
                                  web.1	2017-06-05 19:48:18.314	error	at Function.Module._load (module.js:276:25)
                                  web.1	2017-06-05 19:48:18.314	error	at Function.Module._resolveFilename (module.js:325:15)
                                  web.1	2017-06-05 19:48:18.314	error	Error: Cannot find module 'greenlock'
                                  web.1	2017-06-05 19:48:18.294	error	uncaught exception: Cannot find module 'greenlock'
                                    Marcolotti
                                    Guten Morgen,
                                    was mir heute aufgefallen ist, da ich nun 2 ModBus-Instanzen habe. Die erste Instanz ist knapp 2 Jahre alt und die neue ein paar Tage.
                                    Schaut mal. (Einstellungen unter ModBus sind identisch außer die Adressen) Es gibt in der letzten Instanz Input-Level und Output-Level. Ist das so geplant?
                                    Jetzt bekomme ich ab und an auch mal den gleichen Fehler wie Apollon:
                                    modbus.1	2017-06-10 06:14:30.985	warn	Poll error count: 6 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:30.969	warn	Poll error count: 5 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:30.508	warn	Poll error count: 4 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:30.380	warn	Poll error count: 3 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:30.360	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:30.211	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:29.589	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:27.973	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:27.950	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:25.665	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.954	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.787	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.767	warn	Poll error count: 3 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.609	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.325	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:24.178	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:21.907	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:21.769	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:18.751	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:18.584	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:18.421	warn	Poll error count: 1 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:18.122	warn	Poll error count: 3 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:17.975	warn	Poll error count: 2 code: "App Timeout"
                                    modbus.1	2017-06-10 06:14:17.823	warn	Poll error count: 1 code: "App Timeout"
                                    Daten kommen trotzdem.
                                    Gruß Marco
