  4. Tado Adapter wird nicht mehr grün
97 Beiträge 6 Kommentatoren 12.0k Aufrufe 6 Beobachtet
  • S spooky82
    und noch ein paar Logs:
    tado.0
    2023-01-29 19:07:57.128	error	Disconnected from Tado cloud service ..., retry in 30 seconds !
    tado.0
    2023-01-29 19:07:57.127	error	Error in data refresh at step DoZones: Error: connect ETIMEDOUT 52.50.222.122:443
    tado.0
    2023-01-29 19:07:57.124	error	Error: connect ETIMEDOUT 52.50.222.122:443
    tado.0
    2023-01-29 18:47:30.421	warn	Sentry disabled, error catched: Error: DB closed
    tado.0
    2023-01-29 18:47:30.421	error	Error in function stateSetCreate(): Error: DB closed
    tado.0
    2023-01-29 18:47:30.420	warn	Sentry disabled, error catched: Error: DB closed
    tado.0
    2023-01-29 18:47:30.419	error	Error in function stateSetCreate(): Error: DB closed
    tado.0
    2023-01-29 18:47:30.419	warn	get state error: Connection is closed.
    tado.0
    2023-01-29 18:47:30.418	warn	get state error: Connection is closed.
    tado.0
    2023-01-29 18:47:29.865	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    tado.0
    2023-01-29 18:47:29.851	error	Exception-Code: ETIMEDOUT: connect ETIMEDOUT 54.155.201.13:443
    tado.0
    2023-01-29 18:47:29.851	error	Error: connect ETIMEDOUT 54.155.201.13:443 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
    tado.0
    2023-01-29 18:47:29.851	error	unhandled promise rejection: connect ETIMEDOUT 54.155.201.13:443
    tado.0
    2023-01-29 18:47:29.851	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tado.0
    2023-01-29 18:47:29.849	error	Error: connect ETIMEDOUT 54.155.201.13:443
    tado.0
    2023-01-29 18:36:14.543	error	Disconnected from Tado cloud service ..., retry in 30 seconds !
    tado.0
    2023-01-29 18:36:14.543	error	Error in data refresh at step DoZones: Error: connect ETIMEDOUT 54.75.202.73:443
    tado.0
    2023-01-29 18:36:14.523	error	Error: connect ETIMEDOUT 54.75.202.73:443
    Ich habe testweise ein Downgrade auf Version 0.4.0 gemacht - leider scheint das Problem (siehe Logfile) noch immer zu bestehen.
    Wer kümmert sich um den Adapter? Wenn kann man fragen?
    wendy2702W Offline
    wendy2702W Offline
    wendy2702
    #61
    @spooky82 sagte in Tado Adapter wird nicht mehr grün:
    52.50.222.122
    Ist diese Adresse denn noch erreichbar?
    Wenn du meinst es ich ein Adapter Bug, ein Issue auf Github machen.
    Da du aber scheinbar aktuell alleine mit deinem Problem bist denke es ist eher ein Lokales Problem.
    • wendy2702W wendy2702
      52.50.222.122
      spooky82
      #62
      @wendy2702 Nein die IP ist nicht erreichbar - aber ich weiß auch nicht wo der Fehler auf einmal herkommen könnte.
      Hast du evtl eine Idee, was lokal zum Problem führen könnte?
      R 1 Antwort Letzte Antwort
        Robbi12
        #63
        Also allein ist er nicht.
        Bei mir funktioniert das Ganze auch nicht mehr.
        • R Robbi12
          spooky82
          #64
          @robbi12 hast du einen ähnlichen Fehler?
          • S spooky82
            Robbi12
            #65
            @spooky82 Was hast du für einen Internetanbieter? Vielleicht liegt es daran
            • S spooky82
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #66
              @spooky82
              Hast du PiHole !?
              • R Robbi12
                spooky82
                #67
                @robbi12 Vodafone
                • GlasfaserG Glasfaser
                  @spooky82
                  Hast du PiHole !?
                  spooky82
                  #68
                  @glasfaser Nein
                  • R Robbi12
                    @wendy2702 said in Tado Adapter wird nicht mehr grün:
                    52.17.162.58:443
                    400 Bad Request
                    The plain HTTP request was sent to HTTPS port
                    ohne 443 geht er auf https und dann zur tado seite
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    #69
                    @spooky82
                    @robbi12 sagte in Tado Adapter wird nicht mehr grün:
                    52.17.162.58:443
                    400 Bad Request
                    Wie schon erwähnt .. habe ich kein Tado !
                    Bei diesem link und auch bei
                    habe ich auch diese Meldung wie @Robbi12
                    Falls es Interessiert " Anbieter Vodafone "
                      @spooky82
                      52.17.162.58:443
                      400 Bad Request
                      spooky82
                      #70
                      @glasfaser vll ist es ja wirklich ein Vodafone Problem...
                      @Robbi12 welchen Provider hast du?
                      • S spooky82
                        Robbi12
                        #71
                        @spooky82 Also ich habe Kabel Vodafone und kein PI Hole
                        • R Robbi12
                          spooky82
                          #72
                          @robbi12 also genau wie bei mir...hmm
                          • S spooky82
                            #73
                            Ich habe Kabel Vodafone (NRW), kann die IPs auch nicht erreichen, mein tado zickt aber nicht herum.
                            S wendy2702W 2 Antworten Letzte Antwort
                              spooky82
                              #74
                              @thomas-braun ich bin im ehemaligen Kabel Deutschland Netz
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #75
                                @thomas-braun sagte in Tado Adapter wird nicht mehr grün:
                                Kannst du im log sehen ob bei dir die gleichen IPs verwendet werden?
                                  #76
                                  @wendy2702
                                  Mein Log ist super ruhig. Keine Meldungen zu tado.
                                    @wendy2702
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    wendy2702
                                    #77
                                    @thomas-braun Und ich denke neu starten möchtest du den Adapter nicht für einen Test 😬
                                      #78
                                      @wendy2702
                                      Kann ich machen. Ändert aber nix bei mir. Bleibt ruhig.
                                        @wendy2702
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        wendy2702
                                        #79
                                        @thomas-braun Wäre halt mal interessant zu sehen im Debug ob er die gleichen IPs zu erreichen versucht.
                                        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          #80
                                          @wendy2702 sagte in Tado Adapter wird nicht mehr grün:
                                          Nach dem , nimmt der die URL
                                          const tado_auth_url = 'https://auth.tado.com';
                                          const tado_url = 'https://my.tado.com';
                                          https://github.com/DrozmotiX/ioBroker.tado/blob/main/main.js
