  3. Einsteigerfragen
  4. IoBroker ist nicht mehr über Browser erreichbar
73 Beiträge 3 Kommentatoren 7.6k Aufrufe 2 Beobachtet
    @bastel2021
    Sorry, muss
    sudo -H -u iobroker npm cache clear --force
    lauten.
    Bastel2021
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm cache clear --forcecd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN Not Found: /opt/iobroker
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code 22
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! No connection to databases possible ...
    npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_59_37_585Z-debug-0.log
    • B Bastel2021
      npm ERR! code 22
      @bastel2021
      iobroker fix
      B 1 Antwort Letzte Antwort
        Bastel2021
        @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
        iobroker fix
          @bastel2021
          iobroker fix
          Bastel2021
          pi@raspberrypi:~ $ iobroker fix
          library: loaded
          Library version=2022-12-09
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          pi@raspberrypi:~ $
          • B Bastel2021
            library: loaded
            pi@raspberrypi:~ $
            @bastel2021
            Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
              @bastel2021
              Bastel2021
              library: loaded
              pi@raspberrypi:~ $
              • B Bastel2021
                library: loaded
                pi@raspberrypi:~ $
                @bastel2021
                cd /opt/iobroker
                  @bastel2021
                  cd /opt/iobroker
                  Bastel2021
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm ERR! code 22
                  npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
                  • B Bastel2021
                    npm ERR! code 22
                    @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
                    sudo -H -u iobroker npm install iobroker.js-controller --debug
                      Bastel2021
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
                      npm ERR! code 22
                      npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
                      • B Bastel2021
                        npm ERR! code 22
                        @bastel2021
                        ls -lAh /opt/iobroker/iobroker-data/
                          @bastel2021
                          Bastel2021
                          pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                          insgesamt 650M
                          drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                          drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                          drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                          -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                          drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                          -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                          -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                          -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                          drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                          • B Bastel2021
                            insgesamt 650M
                            Die könnte etwas fett sein.
                            iob fix
                              iob fix
                              Bastel2021
                              pi@raspberrypi:/opt/iobroker $ iob fix
                              library: loaded
                              • B Bastel2021
                                library: loaded
                                @bastel2021
                                  @bastel2021
                                  Bastel2021
                                  insgesamt 456K
                                  drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                                  -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                                  lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                                  -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                                  drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                                  drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                                  drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                                  -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                                  -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                                  -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                                  • B Bastel2021
                                    insgesamt 456K
                                    @bastel2021
                                    ./iobroker -v
                                      @bastel2021
                                      ./iobroker -v
                                      Bastel2021
                                      pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                                      node:internal/modules/cjs/loader:998
                                        throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                          at node:internal/main/run_main_module:22:47 {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: []
                                      • B Bastel2021
                                          throw err;
                                          requireStack: []
                                        @bastel2021
                                        Fällt mir nix zu ein.
                                          @bastel2021
                                          Bastel2021
                                          ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                                          B Thomas BraunT 2 Antworten Letzte Antwort
