  3. Einsteigerfragen
  4. IoBroker ist nicht mehr über Browser erreichbar
    5.5k
73 Beiträge 3 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • B Bastel2021
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2022-12-09
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    pi@raspberrypi:~ $
    @bastel2021
    Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
      @bastel2021
      Bastel2021
      library: loaded
      pi@raspberrypi:~ $
      • B Bastel2021
        library: loaded
        pi@raspberrypi:~ $
        @bastel2021
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @bastel2021
          cd /opt/iobroker
          Bastel2021
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm ERR! code 22
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c -- node iobroker.js setup first
          npm ERR! No connection to databases possible ...
          npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
          • B Bastel2021
            npm ERR! code 22
            @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
            sudo -H -u iobroker npm install iobroker.js-controller --debug
              Bastel2021
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
              npm ERR! code 22
              npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
              • B Bastel2021
                npm ERR! code 22
                @bastel2021
                ls -lAh /opt/iobroker/iobroker-data/
                  @bastel2021
                  Bastel2021
                  pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                  insgesamt 650M
                  drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                  drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                  drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                  -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                  drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                  -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                  -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                  -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                  drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                  • B Bastel2021
                    insgesamt 650M
                    Die könnte etwas fett sein.
                    iob fix
                      iob fix
                      Bastel2021
                      pi@raspberrypi:/opt/iobroker $ iob fix
                      library: loaded
                      • B Bastel2021
                        library: loaded
                        @bastel2021
                          @bastel2021
                          Bastel2021
                          insgesamt 456K
                          drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                          -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                          lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                          -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                          drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                          drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                          drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                          -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                          -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                          -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                          • B Bastel2021
                            insgesamt 456K
                            @bastel2021
                            ./iobroker -v
                              @bastel2021
                              ./iobroker -v
                              Bastel2021
                              pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                              node:internal/modules/cjs/loader:998
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                  at node:internal/main/run_main_module:22:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              • B Bastel2021
                                  throw err;
                                  requireStack: []
                                @bastel2021
                                Fällt mir nix zu ein.
                                  @bastel2021
                                  Bastel2021
                                  ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                                  B Thomas BraunT 2 Antworten Letzte Antwort
                                  • B Bastel2021
                                    Bastel2021
                                    ich meine ein Backup einspielen
                                    • B Bastel2021
                                      @bastel2021
                                      Was haste denn da vorliegen?
                                        @bastel2021
                                        Bastel2021
                                        IOBroker speichert doch die Backups auf dem RPI oder?
                                        Kann man das nicht auffinden und dann benutzen?
                                        • B Bastel2021
                                          @bastel2021
                                          Hast du keine Backups nach Extern gemacht?
                                          ls -lAh /opt/iobroker/backups/
                                          B 3 Antworten Letzte Antwort
