  3. Einsteigerfragen
  4. IoBroker ist nicht mehr über Browser erreichbar
    5.5k
73 Beiträge 3 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • B Bastel2021
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code 22
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! No connection to databases possible ...
    npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
    @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
    sudo -H -u iobroker npm install iobroker.js-controller --debug
      Bastel2021
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
      npm ERR! code 22
      npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
      • B Bastel2021
        npm ERR! code 22
        @bastel2021
        ls -lAh /opt/iobroker/iobroker-data/
          @bastel2021
          Bastel2021
          pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
          insgesamt 650M
          drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
          drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
          drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
          -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
          drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
          -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
          -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
          -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
          drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
          • B Bastel2021
            insgesamt 650M
            Die könnte etwas fett sein.
            iob fix
              iob fix
              Bastel2021
              pi@raspberrypi:/opt/iobroker $ iob fix
              library: loaded
              Library version=2022-12-09
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              • B Bastel2021
                library: loaded
                @bastel2021
                  @bastel2021
                  Bastel2021
                  insgesamt 456K
                  drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                  -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                  lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                  -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                  drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                  drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                  drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                  -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                  -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                  -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                  • B Bastel2021
                    insgesamt 456K
                    @bastel2021
                    ./iobroker -v
                      @bastel2021
                      ./iobroker -v
                      Bastel2021
                      pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                      node:internal/modules/cjs/loader:998
                        throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                          at node:internal/main/run_main_module:22:47 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      • B Bastel2021
                          throw err;
                          requireStack: []
                        @bastel2021
                        Fällt mir nix zu ein.
                          @bastel2021
                          Bastel2021
                          ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                          B Thomas BraunT 2 Antworten Letzte Antwort
                          • B Bastel2021
                            Bastel2021
                            ich meine ein Backup einspielen
                            • B Bastel2021
                              @bastel2021
                              Was haste denn da vorliegen?
                                @bastel2021
                                Bastel2021
                                IOBroker speichert doch die Backups auf dem RPI oder?
                                Kann man das nicht auffinden und dann benutzen?
                                • B Bastel2021
                                  @bastel2021
                                  Hast du keine Backups nach Extern gemacht?
                                  ls -lAh /opt/iobroker/backups/
                                  B 3 Antworten Letzte Antwort
                                    @bastel2021
                                    Bastel2021
                                    pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
                                    insgesamt 25M
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M  6. Jan 02:40 iobroker_2023_01_06-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M  7. Jan 02:40 iobroker_2023_01_07-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,3M  8. Jan 02:40 iobroker_2023_01_08-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,3M  9. Jan 02:40 iobroker_2023_01_09-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M 10. Jan 02:40 iobroker_2023_01_10-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M 11. Jan 02:40 iobroker_2023_01_11-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M 12. Jan 02:40 iobroker_2023_01_12-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,2M 13. Jan 02:40 iobroker_2023_01_13-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 2,3M 14. Jan 02:40 iobroker_2023_01_14-02_40_10_backupiobroker.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 4,4M 15. Jan 02:40 iobroker_2023_01_15-02_40_12_backupiobroker.tar.gz
                                      @bastel2021
                                      Bastel2021
                                      nein leider nicht nach extern!
                                      • B Bastel2021
                                        insgesamt 25M
                                        iobroker restore /opt/iobroker/backups/iobroker_2023_01_15-02_40_12_backupiobroker.tar.gz
                                          @bastel2021
                                          Bastel2021
                                          aber ich habe deine Zeit jetzt auch schon viel zu lange in Anspruch genommen! Danke auf jeden Fall dafür!!!
