  3. Einsteigerfragen
  4. IoBroker ist nicht mehr über Browser erreichbar
    5.5k
73 Beiträge 3 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • B Bastel2021
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! code 22
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! No connection to databases possible ...
    npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
    @bastel2021
    ls -lAh /opt/iobroker/iobroker-data/
      @bastel2021
      Bastel2021
      pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
      insgesamt 650M
      drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
      drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
      drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
      -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
      drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
      -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
      -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
      -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
      drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
      • B Bastel2021
        insgesamt 650M
        @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
        Die könnte etwas fett sein.
        iob fix
          iob fix
          Bastel2021
          pi@raspberrypi:/opt/iobroker $ iob fix
          library: loaded
          Library version=2022-12-09
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          • B Bastel2021
            library: loaded
            @bastel2021
              @bastel2021
              Bastel2021
              insgesamt 456K
              drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
              -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
              lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
              -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
              drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
              drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
              drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
              -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
              -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
              -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
              • B Bastel2021
                insgesamt 456K
                @bastel2021
                ./iobroker -v
                  @bastel2021
                  ./iobroker -v
                  Bastel2021
                  pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                  node:internal/modules/cjs/loader:998
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      at node:internal/main/run_main_module:22:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  • B Bastel2021
                      throw err;
                      requireStack: []
                    @bastel2021
                    Fällt mir nix zu ein.
                      @bastel2021
                      Bastel2021
                      ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                      B Thomas BraunT 2 Antworten Letzte Antwort
                      • B Bastel2021
                        Bastel2021
                        ich meine ein Backup einspielen
                        • B Bastel2021
                          @bastel2021
                          Was haste denn da vorliegen?
                            @bastel2021
                            Bastel2021
                            IOBroker speichert doch die Backups auf dem RPI oder?
                            Kann man das nicht auffinden und dann benutzen?
                            • B Bastel2021
                              @bastel2021
                              Hast du keine Backups nach Extern gemacht?
                              ls -lAh /opt/iobroker/backups/
                              B 3 Antworten Letzte Antwort
                                @bastel2021
                                Bastel2021
                                pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
                                insgesamt 25M
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M  6. Jan 02:40 iobroker_2023_01_06-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M  7. Jan 02:40 iobroker_2023_01_07-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,3M  8. Jan 02:40 iobroker_2023_01_08-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,3M  9. Jan 02:40 iobroker_2023_01_09-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M 10. Jan 02:40 iobroker_2023_01_10-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M 11. Jan 02:40 iobroker_2023_01_11-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M 12. Jan 02:40 iobroker_2023_01_12-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,2M 13. Jan 02:40 iobroker_2023_01_13-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 2,3M 14. Jan 02:40 iobroker_2023_01_14-02_40_10_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 4,4M 15. Jan 02:40 iobroker_2023_01_15-02_40_12_backupiobroker.tar.gz
                                  @bastel2021
                                  Bastel2021
                                  nein leider nicht nach extern!
                                  • B Bastel2021
                                    insgesamt 25M
                                    iobroker restore /opt/iobroker/backups/iobroker_2023_01_15-02_40_12_backupiobroker.tar.gz
                                      @bastel2021
                                      Bastel2021
                                      aber ich habe deine Zeit jetzt auch schon viel zu lange in Anspruch genommen! Danke auf jeden Fall dafür!!!
                                      • B Bastel2021
                                        Solltest du ändern. Lokale Backups sind keine.
                                        B 2 Antworten Letzte Antwort
                                          Bastel2021
                                          pi@raspberrypi:/opt/iobroker $ iobroker restore /opt/iobroker/backups/iobroker_2023_01_15-02_40_12_backupiobroker.tar.gz
                                            throw err;
                                            requireStack: []
