  3. Einsteigerfragen
  4. IoBroker ist nicht mehr über Browser erreichbar
    5.5k
73 Beiträge 3 Kommentatoren 7.6k Aufrufe 2 Beobachtet
    Bastel2021
    @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
    iobroker fix
      @bastel2021
      iobroker fix
      Bastel2021
      pi@raspberrypi:~ $ iobroker fix
      library: loaded
      Library version=2022-12-09
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      pi@raspberrypi:~ $
      • B Bastel2021
        library: loaded
        pi@raspberrypi:~ $
        @bastel2021
        Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
          @bastel2021
          Bastel2021
          library: loaded
          pi@raspberrypi:~ $
          • B Bastel2021
            library: loaded
            pi@raspberrypi:~ $
            @bastel2021
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
              @bastel2021
              cd /opt/iobroker
              Bastel2021
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN old lockfile
              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
              npm WARN old lockfile This is a one-time fix-up, please be patient...
              npm ERR! code 22
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! command failed
              npm ERR! command sh -c -- node iobroker.js setup first
              npm ERR! No connection to databases possible ...
              npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
              • B Bastel2021
                npm ERR! code 22
                @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
                sudo -H -u iobroker npm install iobroker.js-controller --debug
                  Bastel2021
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
                  npm ERR! code 22
                  npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
                  • B Bastel2021
                    npm ERR! code 22
                    @bastel2021
                    ls -lAh /opt/iobroker/iobroker-data/
                      @bastel2021
                      Bastel2021
                      pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                      insgesamt 650M
                      drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                      drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                      drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                      -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                      drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                      -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                      -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                      -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                      drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                      • B Bastel2021
                        insgesamt 650M
                        Die könnte etwas fett sein.
                        iob fix
                          iob fix
                          Bastel2021
                          pi@raspberrypi:/opt/iobroker $ iob fix
                          library: loaded
                          • B Bastel2021
                            library: loaded
                            @bastel2021
                              @bastel2021
                              Bastel2021
                              insgesamt 456K
                              drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                              -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                              lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                              -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                              drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                              drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                              drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                              -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                              -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                              -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                              • B Bastel2021
                                insgesamt 456K
                                @bastel2021
                                ./iobroker -v
                                  @bastel2021
                                  ./iobroker -v
                                  Bastel2021
                                  pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                                  node:internal/modules/cjs/loader:998
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                      at node:internal/main/run_main_module:22:47 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  • B Bastel2021
                                      throw err;
                                      requireStack: []
                                    @bastel2021
                                    Fällt mir nix zu ein.
                                      @bastel2021
                                      Bastel2021
                                      ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                                      B Thomas BraunT 2 Antworten Letzte Antwort
                                      • B Bastel2021
                                        Bastel2021
                                        ich meine ein Backup einspielen
                                        • B Bastel2021
                                          @bastel2021
                                          Was haste denn da vorliegen?
