  4. Help Please - IOBroker is completly broken
    5.6k
19 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • IchBinSmartI Offline
    IchBinSmart
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4B
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: v16.17.0
    Nodejs-Version: v16.19.0
    NPM-Version: 8.15.0
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: -
    Hallo, folgendes Problem: ioBroker startet nicht mehr.
    iobroker -status liefert das folgende:
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module 'at-least-node'
    Require stack:
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/make-dir.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-sync/copy-sync.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-sync/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/make-dir.js:9:21)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1067:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/make-dir.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-sync/copy-sync.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-sync/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Wie kam es zu dem Problem? Ein Adapter lies sich nicht mehr update (der js-Adapter). Daraufhin habe ich in das Log geguckt. Dort hieß es (ein Beispiel von vielen):
    At-least-node Folder is not empty rename to ".at-least-node(+kryptische Zeichenfolge)
    Das habe ich gemacht - in der Hoffnung, dass das Problem dadurch gelöst wird. Im Nachhinein ziemlich dumm - und führt nun natürlich zu den Problemen, beim Start. Leider habe ich einen Corona-Schädel und mir fällt gerade nicht ein, wie ich das fixen kann?
    Folgendes habe ich versucht, hat aber nichts geändert:
    iobroker - fix
    npm -update
    npm -upgrade
    Außerdem habe ich versucht ioBroker neu zu installieren (einfach nochmal drüber) - geht aber auch nicht - da kommen wieder diese rename Aufforderungen:
        Installing ioBroker (3/4)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/aws-sign2
    npm ERR! dest /opt/iobroker/node_modules/.aws-sign2-fgczVxiT
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws-sign2' -> '/opt/iobroker/node_modules/.aws-sign2-fgczVxiT'
    npm ERR!     /home/pi/.npm/_logs/2023-01-01T17_16_19_154Z-debug-0.log
    Falls jmd. seine gute Tat für das neue Jahr also schon heute vollbringen will, bin ich über Hilfe dankbar. Sonst sitzen wir im Dunkeln 🕶 😖
    Vielen Dank,
    Rainer
    • IchBinSmartI IchBinSmart
      NPM-Version: 8.15.0
      Image genutzt: Nein
        throw err;
      Require stack:
        requireStack: [
      iobroker - fix
      npm -update
      npm -upgrade
      npm ERR! errno -39
      Vielen Dank,
      Rainer
      @ichbinsmart falsches Unterforum!
      das ist kein ioBroker Bug!
      sonst sieh mal hier
      https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8/1
      passt das?
      ich verschiebe das mal.
        IchBinSmart
        Danke & auch für das verschieben in die richtige Ecke. Der genannte Post würde die temporären Dateien löschen - aber ich möchte sie ja erstmal wieder reparieren. Wie kriege ich das hin?
          @ichbinsmart sagte in Help Please - IOBroker is completly broken:
          wozu.
          Die vorgeschlagene Umbenennung dient auch nur dazu sie "aus dem Weg" zu bekommen, damit sie neu angelegt werden können
            @ichbinsmart
            Zu allererst mal deine nodeJS-Installation gerade biegen...
            Das ist krumm.
            Und was sollen das für Befehle sein?
            npm -update
            npm -upgrade
            Ist ziemlicher Quatsch.
            IchBinSmartI 1 Antwort Letzte Antwort
              @ichbinsmart
              Das ist krumm.
              npm -update
              npm -upgrade
              IchBinSmart
              @thomas-braun - Wie soll ich node / nodejs denn bitte gerade biegen? Was genau ist krumm?
              Die Befehle sind tatsächlich quatsch. Sorry aber Corona-Wattekopf 🐶 . Ich habe natürlich folgendes ausgeführt:
              sudo apt-get update
              sudo apt-get upgrade
              Die Ordner sind zurück benannt und zumindest scheint erstmal wieder "einiges" zu laufen. Gibt es trotzdem eine Möglichkeit das generell bereinigen zu lassen?
              Vielen Dank,
              Rainer
                sudo apt-get update
                Vielen Dank,
                Rainer
                @ichbinsmart
                Zu nodejs: Siehe meine Signatur.
                Zu den kryptischen Verzeichnissen hatte die @Homoran ja schon den Link gegeben. Die müssen gelöscht werden.
                  @ichbinsmart
                  IchBinSmart
                  schrieb am zuletzt editiert von IchBinSmart
                  @thomas-braun, @Homoran Da das System offenbar durch die Rettungsversuche komplett verbogen war, habe ich:
                  • Ein neues Image auf dem Pi4b installiert
                  • pivccu3 neu installiert & backup eingespielt
                  • iobroker neu installiert und über das backup ein älteres Backup (kurz vor Weihnachten, vor den ganzen Problemen) installiert (Gemäß Befehl auf iobroker.de).
                  • Da Javascript nach dem Backup nicht richtig funktioniert hat (*.htm not found), habe ich noch iob upload javascript ausgeführt.
                  Jetzt bleiben leider immer noch einige Adapter rot. Unter anderem cloud und iot adapter melden, dass es keine Konfigurationsdatai gäbe - in die Instanzeinstellungen komme ich nicht. Wie kann man das beheben? Ich bekomme leider keine weitere Fehlermeldung.
                  Mein Vorgehen war genau nach Anleitung - bis zum Backup hat auch alles gut geklappt - scheinbar funktioniert das Backup nicht 100% sauber und es sind nacharbeiten erforderlich.
                  Danke,
                  Rainer
                    Danke,
                    Rainer
                    @ichbinsmart
                    Gib mal die Ausgabe zu
                    iob diag
                    • crunchipC Abwesend
                      crunchipC Abwesend
                      welche Befehle?
                      nach welcher?
                        IchBinSmart
                        @crunchip folgende infos dazu:
                        • Pi-Image habe ich hierüber installiert: https://www.raspberrypi.com/software/
                        • pivccu3 habe ich nach dieser Anleitung installiert: https://www.electronicstudio.de/homematic-ccu-pivccu-installieren
                        • Das Restore der Geräte wurde anschließend in der weboberfläche von homematic durchgeführt
                        • IOBroker habe ich so installiert:
                        curl -sLf https://iobroker.net/install.sh | bash -
                        • Restore habe ich gemäß dieser Anleitung gemacht: https://forum.iobroker.net/topic/27271/howto-iobroker-restore-unter-linux-durchführen
                        ... die anderen angefragten Infos kommen sofort :-)...
                        Beste Grüße,
                        Rainer
                          @ichbinsmart
                          iob diag
                          IchBinSmart
                          Das ist dann dieses hier:
                          		     v.2022-12-31
                          Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
                          Installation: 		Native
                          Timezone: 		Europe/Berlin
                          User-ID: 		1000
                          X-Server: 		true
                          Boot Target: 		graphical.target
                          Pending OS-Updates: 	0
                          Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                          			/usr/bin/node 		v16.19.0
                          			/usr/bin/npm 		8.19.3
                          ioBroker Core: 		js-controller 		4.0.24
                          			admin 			6.3.5
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Status admin:
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          Pending iob updates: 	3
                          Objects: 		26197
                          States: 		23112
                          Size of iob-Database:
                          31M	/opt/iobroker/iobroker-data/objects.jsonl
                          13M	/opt/iobroker/iobroker-data/states.jsonl
                          Könnte vielleicht ein iob upload all fehlen? Ich bin mir nicht ganz sicher, was der Befehl macht. Aber iob upload javascript, hatte zumindest die javascript probleme behoben ;-)
                          Danke,
                          Rainer
                            		     v.2022-12-31
                            User-ID: 		1000
                            X-Server: 		true
                            			/usr/bin/npm 		8.19.3
                            			admin 			6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Status admin:
                            Objects: 		26197
                            States: 		23112
                            Danke,
                            Rainer
                            Versuch mal.
                            Aber schalt den Desktop/X-Server an der Kiste aus. Und patch das OS auf Stand.
                              Danke,
                              Rainer
                              bitte korrekten link!
                                IchBinSmart
                                @homoran @Thomas-Braun @crunchip :
                                • Ich meine den x-server braucht das pi os - es arbeitet nunmal über eine grafische Oberfläche - ihn abzuschalten wäre keine gute Idee.
                                • Die korrekten links hatte ich oben bereits alle gepostet.
                                • Nach dem iob upload all befehl scheint nun alles wieder zu laufen. Die Adapter sind alle aktuell und grün.
                                Vielen Dank an alle, die geholfen haben. Ihr seid die Besten ;-).
                                Ein gesundes neues Jahr,
                                Rainer
                                  Rainer
                                  Doch, das ist für den Betrieb als Server eine hervorragende Idee.
                                  Einen Server mit X-Server/Desktop zu betreiben ist eine dumme Idee.
                                    Rainer
                                    wieso das?
                                    das pi OS arbeitet auch headless. gibt es auch als light Version für Server direkt bei raspberrypi.org
                                    Der x-Server kann zusätzlich installiert werden, wenn man den Pi als "Desktop-Rechner" nutzen will.
                                    Das dafür voreingestellte Image hast du wahrscheinlich genommen.
                                      wieso das?
                                      IchBinSmart
                                      @homoran Ja - und würde ich gerne auch weiter verwenden ;-)
                                        @ichbinsmart
                                        Und wozu?
                                        Macht es nur komplexer.
