  4. Nodejs v18.12.1
    5.8k
Nodejs v18.12.1
382 Beiträge 10 Kommentatoren 73.2k Aufrufe 8 Beobachtet
  • KrisiunK Krisiun
    Sonst weiß ich leider echt nicht was ich machen soll
    #201
    @krisiun
    tail -n 15 -F /var/log/kern.log
    • KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #202
      @thomas-braun sagte in Nodejs v18.12.1:
      Nov 24 10:11:12 raspberrypi4-iob kernel: [   17.991733] Bluetooth: HCI UART protocol Broadcom registered
      Nov 24 10:11:13 raspberrypi4-iob kernel: [   18.216285] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      Nov 24 10:11:13 raspberrypi4-iob kernel: [   18.216294] Bluetooth: BNEP filters: protocol multicast
      Nov 24 10:11:13 raspberrypi4-iob kernel: [   18.216306] Bluetooth: BNEP socket layer initialized
      Nov 24 10:11:13 raspberrypi4-iob kernel: [   18.399553] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:14 raspberrypi4-iob kernel: [   19.413804] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:14 raspberrypi4-iob kernel: [   20.027858] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:15 raspberrypi4-iob kernel: [   21.057956] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:16 raspberrypi4-iob kernel: [   21.648003] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:17 raspberrypi4-iob kernel: [   22.689612] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:18 raspberrypi4-iob kernel: [   23.327294] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:19 raspberrypi4-iob kernel: [   24.367543] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:19 raspberrypi4-iob kernel: [   24.928220] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:20 raspberrypi4-iob kernel: [   25.939910] broken atomic modeset userspace detected, disabling atomic
      Nov 24 10:11:21 raspberrypi4-iob kernel: [   26.523927] broken atomic modeset userspace detected, disabling atomic
      • KrisiunK Krisiun
        #203
        @krisiun sagte in Nodejs v18.12.1:
        Das ist eine Meldung, die vom immer noch mitlaufenden Scheiß-Desktop kommt.
        Mach den Kram AUS!!!!
        KrisiunK 1 Antwort Letzte Antwort
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #204
          Und wie?
          • KrisiunK Krisiun
            Und wie?
            #205
            @krisiun
            sudo raspi-config
            Und dann irgendwo in den Boot-Optionen stellst du
            Boot in CLI
            ein. Kann gerade nicht genauer nachschauen.
            • KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #206
              sudo raspi-config
              Ich schau mal. Melde mich später nochmal. Danke
              • KrisiunK Krisiun
                sudo raspi-config
                #207
                @krisiun
                Damit du wieder Luft zum Atmen hast:
                sudo rm /var/log/kern.log.1
                dann in
                sudo raspi-config
                diesen Menüpunkt aktivieren:
                1 System Options
                S5 Boot / Auto Login
                B1 Console
                Dann nicht mehr per RemoteDesktop oder sowas auf das System springen sondern ausschließlich per Terminal/Konsole/Shell/puTTY/ssh (nenn es wie du willst)
                • KrisiunK Offline
                  KrisiunK Offline
                  Krisiun
                  #208
                  sudo raspi-config
                  Desktop habe ich so gut wie nie benutzt nur putty.
                  Aber iobroker läuft leider immer noch nicht
                  • KrisiunK Krisiun
                    sudo raspi-config
                    #209
                    Das ist ja wurscht. Der läuft/lief aber.
                      #210
                      who -r
                      df -h
                      sagt?
                      • KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #211
                        df -h
                        pi@raspberrypi4-iob:~ $ df -h
                        Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                        /dev/root       117G    106G  6,4G   95% /
                        devtmpfs        1,8G       0  1,8G    0% /dev
                        tmpfs           1,9G       0  1,9G    0% /dev/shm
                        tmpfs           1,9G    8,5M  1,9G    1% /run
                        tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                        tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
                        /dev/mmcblk0p1  253M     49M  204M   20% /boot
                        tmpfs           384M       0  384M    0% /run/user/1000
                        • KrisiunK Krisiun
                          df -h
                          #212
                          @krisiun
                          who -r
                          • KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #213
                            passiert nichts
                            • KrisiunK Krisiun
                              passiert nichts
                              #214
                              @krisiun
                              Kann nicht sein.
                              • KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #215
                                pi@raspberrypi4-iob:~ $ who -r
                                         Runlevel 3   2022-11-24 12:29
                                • KrisiunK Krisiun
                                  #216
                                  @krisiun
                                  Passiert ja doch was...
                                  iob status
                                  sagt?
                                  • KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #217
                                    iob status
                                    Nichts
                                    pi@raspberrypi4-iob:~ $ iob status
                                    • KrisiunK Krisiun
                                      iob status
                                      Nichts
                                      #218
                                      @krisiun
                                      systemctl status iobroker.service
                                      • KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #219
                                        pi@raspberrypi4-iob:~ $ systemctl status iobroker.service
                                        ● iobroker.service
                                           Loaded: bad-setting (Reason: Unit iobroker.service has a bad unit file settin
                                           Active: inactive (dead)
                                        • KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #220
                                          Thomas ich habe in 20 min einen Arzt Termin. Bitte sei mir nicht böse. Ich melde mich später nochmal.
                                          Das ist für mich sehr, sehr wichtig.
                                          Danke Dir
