Nodejs v18.12.1
@thomas-braun sagte in Nodejs v18.12.1:
tail -n 15 -F /var/log/kern.log
tail -n 15 -F /var/log/kern.log Nov 24 10:11:12 raspberrypi4-iob kernel: [ 17.991733] Bluetooth: HCI UART protocol Broadcom registered Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216285] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216294] Bluetooth: BNEP filters: protocol multicast Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216306] Bluetooth: BNEP socket layer initialized Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.399553] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:14 raspberrypi4-iob kernel: [ 19.413804] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:14 raspberrypi4-iob kernel: [ 20.027858] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:15 raspberrypi4-iob kernel: [ 21.057956] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:16 raspberrypi4-iob kernel: [ 21.648003] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:17 raspberrypi4-iob kernel: [ 22.689612] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:18 raspberrypi4-iob kernel: [ 23.327294] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:19 raspberrypi4-iob kernel: [ 24.367543] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:19 raspberrypi4-iob kernel: [ 24.928220] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:20 raspberrypi4-iob kernel: [ 25.939910] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:21 raspberrypi4-iob kernel: [ 26.523927] broken atomic modeset userspace detected, disabling atomic -
tail -n 15 -F /var/log/kern.log Nov 24 10:11:12 raspberrypi4-iob kernel: [ 17.991733] Bluetooth: HCI UART protocol Broadcom registered Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216285] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216294] Bluetooth: BNEP filters: protocol multicast Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.216306] Bluetooth: BNEP socket layer initialized Nov 24 10:11:13 raspberrypi4-iob kernel: [ 18.399553] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:14 raspberrypi4-iob kernel: [ 19.413804] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:14 raspberrypi4-iob kernel: [ 20.027858] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:15 raspberrypi4-iob kernel: [ 21.057956] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:16 raspberrypi4-iob kernel: [ 21.648003] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:17 raspberrypi4-iob kernel: [ 22.689612] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:18 raspberrypi4-iob kernel: [ 23.327294] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:19 raspberrypi4-iob kernel: [ 24.367543] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:19 raspberrypi4-iob kernel: [ 24.928220] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:20 raspberrypi4-iob kernel: [ 25.939910] broken atomic modeset userspace detected, disabling atomic Nov 24 10:11:21 raspberrypi4-iob kernel: [ 26.523927] broken atomic modeset userspace detected, disabling atomic@krisiun sagte in Nodejs v18.12.1:
Das ist eine Meldung, die vom immer noch mitlaufenden Scheiß-Desktop kommt.
Mach den Kram AUS!!!! -
Mach den Kram AUS!!!!@thomas-braun
Und wie? -
Und wie?sudo raspi-configUnd dann irgendwo in den Boot-Optionen stellst du
Boot in CLI
ein. Kann gerade nicht genauer nachschauen. -
sudo raspi-config
Ich schau mal. Melde mich später nochmal. Danke
sudo raspi-config
Damit du wieder Luft zum Atmen hast:
sudo rm /var/log/kern.log.1dann in
sudo raspi-configdiesen Menüpunkt aktivieren:
1 System Options S5 Boot / Auto Login B1 ConsoleDann nicht mehr per RemoteDesktop oder sowas auf das System springen sondern ausschließlich per Terminal/Konsole/Shell/puTTY/ssh (nenn es wie du willst)
sudo raspi-config
Desktop habe ich so gut wie nie benutzt nur putty.
Aber iobroker läuft leider immer noch nicht -
sudo raspi-config
Aber iobroker läuft leider immer noch nicht@krisiun sagte in Nodejs v18.12.1:
Das ist ja wurscht. Der läuft/lief aber.
df -h
pi@raspberrypi4-iob:~ $ df -h Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf /dev/root 117G 106G 6,4G 95% / devtmpfs 1,8G 0 1,8G 0% /dev tmpfs 1,9G 0 1,9G 0% /dev/shm tmpfs 1,9G 8,5M 1,9G 1% /run tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup /dev/mmcblk0p1 253M 49M 204M 20% /boot tmpfs 384M 0 384M 0% /run/user/1000 -
df -h
pi@raspberrypi4-iob:~ $ df -h Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf /dev/root 117G 106G 6,4G 95% / devtmpfs 1,8G 0 1,8G 0% /dev tmpfs 1,9G 0 1,9G 0% /dev/shm tmpfs 1,9G 8,5M 1,9G 1% /run tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup /dev/mmcblk0p1 253M 49M 204M 20% /boot tmpfs 384M 0 384M 0% /run/user/1000who -r -
Kann nicht sein.
iob status
Nichts
pi@raspberrypi4-iob:~ $ iob status pi@raspberrypi4-iob:~ $ -
iob status
Nichts
pi@raspberrypi4-iob:~ $ iob status pi@raspberrypi4-iob:~ $systemctl status iobroker.service -
pi@raspberrypi4-iob:~ $ systemctl status iobroker.service ● iobroker.service Loaded: bad-setting (Reason: Unit iobroker.service has a bad unit file settin Active: inactive (dead) -
Thomas ich habe in 20 min einen Arzt Termin. Bitte sei mir nicht böse. Ich melde mich später nochmal.
Das ist für mich sehr, sehr wichtig.
Danke Dir -
