  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 285.8k Aufrufe 40 Beobachtet
  • S Shadowhunter23
    Fehlt da nicht ein wget?
    #741
    @Shadowhunter23
    Oder ein curl...
    Hab es ergänzt.
    • S Abwesend
      S Abwesend
      Shadowhunter23
      #742
      Meine Zigbee Instanzen ( 5 an der Zahl ) werden so angezeigt:
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.        Please check your setting:
      tcp
      ⚠ HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'.        Please check your setting:
      tcp
      ⚠ HINT:
      Your zigbee.2 COM-Port is NOT matching 'by-id'.        Please check your setting:
      tcp
      ⚠ HINT:
      Your zigbee.3 COM-Port is NOT matching 'by-id'.        Please check your setting:
      tcp
      ⚠ HINT:
      Your zigbee.4 COM-Port is NOT matching 'by-id'.        Please check your setting:
      tcp
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port           Available by-id Ports               Status
      *** NodeJS-Installation ***
      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
      ioBroker Backup Analyzer
      • S Shadowhunter23
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        zigbee.X
        \nExtended Pan ID:
        \n*** MASKED ***
        \nPan ID:
        \n*** MASKED ***
        \nChannel:
        \n*** MASKED ***
        \nNetwork Key:
        \n*** MASKED ***
        #743
        @Shadowhunter23
        Prima Hinweise!
        Versuch jetzt nochmal. Hab den Code angepasst.
        • S Abwesend
          S Abwesend
          Shadowhunter23
          #744
          Gerne:
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          zigbee.X
          \nExtended Pan ID:
          \n*** MASKED ***
          \nPan ID:
          \n*** MASKED ***
          \nChannel:
          \n*** MASKED ***
          \nNetwork Key:
          \n*** MASKED ***
          zigbee.         ...//192.168.0.99:20108                                                 ✗ Not matching
          zigbee.0        tcp://192.168.0.64:20108
          tcp://192.168.0.69:20108                                          TCP Connection
          zigbee.         tcp://192.168.0.64:20108
          tcp://192.168.0.79:20108
          tcp://192.168.0.63:20108
          tcp://192.168.0.99:20108                                          TCP Connection
          zigbee.1        tcp://192.168.0.69:20108
          tcp://192.168.0.79:20108                                          TCP Connection
          zigbee.         tcp://192.168.0.69:20108
          zigbee.2        tcp://192.168.0.79:20108
          tcp://192.168.0.63:20108                                          TCP Connection
          zigbee.         tcp://192.168.0.79:20108
          zigbee.3        tcp://192.168.0.63:20108
          zigbee.         tcp://192.168.0.63:20108
          zigbee.4        tcp://192.168.0.99:20108                                                TCP Connection
          zigbee.         tcp://192.168.0.99:20108                                                TCP Connection
          • S Shadowhunter23
            Gerne:
            USB-Devices by-id:
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            zigbee.X
            \nExtended Pan ID:
            \n*** MASKED ***
            \nPan ID:
            \n*** MASKED ***
            \nChannel:
            \n*** MASKED ***
            \nNetwork Key:
            \n*** MASKED ***
            #745
            @Shadowhunter23
            Oh, das ist jetzt etwas zu ausführlich in der Ausgabe. Mal schauen wie ich das eingefangen bekomme...
            • S Shadowhunter23
              Gerne:
              USB-Devices by-id:
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              zigbee.X
              \nExtended Pan ID:
              \n*** MASKED ***
              \nPan ID:
              \n*** MASKED ***
              \nChannel:
              \n*** MASKED ***
              \nNetwork Key:
              \n*** MASKED ***
              #746
              @Shadowhunter23
              Probier jetzt nochmal bitte.
              • S Abwesend
                S Abwesend
                Shadowhunter23
                #747
                USB-Devices by-id:
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                zigbee.X
                \nExtended Pan ID:
                \n*** MASKED ***
                \nPan ID:
                \n*** MASKED ***
                \nChannel:
                \n*** MASKED ***
                \nNetwork Key:
                \n*** MASKED ***
                Instance        Configured Port                Available by-id Port           Status
                tcp://192.168.0.69:20108 -                              TCP Connection
                tcp://192.168.0.99:20108 -                              TCP Connection
                tcp://192.168.0.79:20108 -                              TCP Connection
                tcp://192.168.0.63:20108 -                              TCP Connection
                zigbee.4        tcp://192.168.0.99:20108       -                              TCP Connection
                zigbee.         tcp://192.168.0.99:20108       -                              TCP Connection
                • S Shadowhunter23
                  USB-Devices by-id:
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  zigbee.X
                  \nExtended Pan ID:
                  \n*** MASKED ***
                  \nPan ID:
                  \n*** MASKED ***
                  \nChannel:
                  \n*** MASKED ***
                  \nNetwork Key:
                  \n*** MASKED ***
                  #748
                  @Shadowhunter23
                  Und nochmal bitte einen Lauf... :-)
                  • S Abwesend
                    S Abwesend
                    Shadowhunter23
                    schrieb am zuletzt editiert von Shadowhunter23
                    #749
                    Für dich als Info, zur Sicherheit lösche ich das Script vorher immer.
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    \nExtended Pan ID:
                    \n*** MASKED ***
                    \nPan ID:
                    \n*** MASKED ***
                    \nChannel:
                    \n*** MASKED ***
                    \nNetwork Key:
                    \n*** MASKED ***
                    • S Shadowhunter23
                      USB-Devices by-id:
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      zigbee.X
                      \nExtended Pan ID:
                      \n*** MASKED ***
                      \nPan ID:
                      \n*** MASKED ***
                      \nChannel:
                      \n*** MASKED ***
                      \nNetwork Key:
                      \n*** MASKED ***
                      #750
                      @Shadowhunter23 sagte in iob diag - Skript:
                      Brauchst du nicht.
                      curl überschreibt das Ziel immer mit dem aktuellen Inhalt.
                      Schau bitte jetzt nochmal.
                      • S Abwesend
                        S Abwesend
                        Shadowhunter23
                        #751
                        Wollte nur sicher gehen.
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        \nExtended Pan ID:
                        \n*** MASKED ***
                        \nPan ID:
                        \n*** MASKED ***
                        \nChannel:
                        \n*** MASKED ***
                        \nNetwork Key:
                        \n*** MASKED ***
                          Brauchst du nicht.
                          #752
                          Auf meinem 'simpel'-System schaut es so aus:
                          zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
                          • S Shadowhunter23
                            USB-Devices by-id:
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            zigbee.X
                            \nExtended Pan ID:
                            \n*** MASKED ***
                            \nPan ID:
                            \n*** MASKED ***
                            \nChannel:
                            \n*** MASKED ***
                            \nNetwork Key:
                            \n*** MASKED ***
                            #753
                            @Shadowhunter23
                            Und nochmal bitte...
                            Ziel ist solch ein Layout:
        ...00_23_93_2C_A8-if00-port2         ✗ Not matching
                            zigbee.1        /dev/ttyUSB0                        ...00_23_93_2C_A8-if00-port0         ✗ Not matching
                            zigbee.2        tcp://192.168.0.64:20108             -                                   TCP Connection
                            • S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #754
                              USB-Devices by-id:
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              zigbee.X
                              \nExtended Pan ID:
                              \n*** MASKED ***
                              \nPan ID:
                              \n*** MASKED ***
                              \nChannel:
                              \n*** MASKED ***
                              \nNetwork Key:
                              \n*** MASKED ***
                              • S Shadowhunter23
                                USB-Devices by-id:
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                zigbee.X
                                \nExtended Pan ID:
                                \n*** MASKED ***
                                \nPan ID:
                                \n*** MASKED ***
                                \nChannel:
                                \n*** MASKED ***
                                \nNetwork Key:
                                \n*** MASKED ***
                                #755
                                @Shadowhunter23
                                Deine 5 tcp-Verbindungen sind aber eine harte Nuss für mich... :-)
                                Ist aber auch bestimmt mit das komplexeste Setup, das hier im Forum von jemandem verwendet wird...
                                Versuch nun nochmal, bitte.
                                  @Shadowhunter23
                                  S Abwesend
                                  S Abwesend
                                  Shadowhunter23
                                  #756
                                  @Thomas-Braun sagte in iob diag - Skript:
                                  Die Stabilität gibt mir für meinen Teil Recht auch wenn es 5 Instanzen sind.
                                  USB-Devices by-id:
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  ⚠ HINT:
                                  tcp
                                  zigbee.X
                                  \nExtended Pan ID:
                                  \n*** MASKED ***
                                  \nPan ID:
                                  \n*** MASKED ***
                                  \nChannel:
                                  \n*** MASKED ***
                                  \nNetwork Key:
                                  \n*** MASKED ***
                                  tcp://192.168.0.69:20108 -                                   tcp
                                  tcp://192.168.0.99:20108 -                                   tcp
                                  tcp://192.168.0.79:20108 -                                   tcp
                                  tcp://192.168.0.63:20108 -                                   tcp
                                  zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
                                  zigbee.         tcp://192.168.0.99:20108            -                                   tcp
                                  • S Shadowhunter23
                                    USB-Devices by-id:
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    ⚠ HINT:
                                    tcp
                                    zigbee.X
                                    \nExtended Pan ID:
                                    \n*** MASKED ***
                                    \nPan ID:
                                    \n*** MASKED ***
                                    \nChannel:
                                    \n*** MASKED ***
                                    \nNetwork Key:
                                    \n*** MASKED ***
                                    #757
                                    @Shadowhunter23
                                    Bitte nochmal.
                                    • S Abwesend
                                      S Abwesend
                                      Shadowhunter23
                                      #758
                                      USB-Devices by-id:
                                      ⚠ HINT:
                                      tcp
                                      ⚠ HINT:
                                      tcp
                                      ⚠ HINT:
                                      tcp
                                      ⚠ HINT:
                                      tcp
                                      ⚠ HINT:
                                      tcp
                                      zigbee.X
                                      \nExtended Pan ID:
                                      \n*** MASKED ***
                                      \nPan ID:
                                      \n*** MASKED ***
                                      \nChannel:
                                      \n*** MASKED ***
                                      \nNetwork Key:
                                      \n*** MASKED ***
                                      • S Shadowhunter23
                                        USB-Devices by-id:
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        zigbee.X
                                        \nExtended Pan ID:
                                        \n*** MASKED ***
                                        \nPan ID:
                                        \n*** MASKED ***
                                        \nChannel:
                                        \n*** MASKED ***
                                        \nNetwork Key:
                                        \n*** MASKED ***
                                        #759
                                        @Shadowhunter23
                                        So langsam gehen mir die Ideen aus...
                                        Versuch nochmal.
                                        • S Abwesend
                                          S Abwesend
                                          Shadowhunter23
                                          #760
                                          USB-Devices by-id:
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          zigbee.X
                                          \nExtended Pan ID:
                                          \n*** MASKED ***
                                          \nPan ID:
                                          \n*** MASKED ***
                                          \nChannel:
                                          \n*** MASKED ***
                                          \nNetwork Key:
                                          \n*** MASKED ***
