  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.2k Aufrufe 40 Beobachtet
  • S Abwesend
    S Abwesend
    Shadowhunter23
    schrieb am zuletzt editiert von Shadowhunter23
    #749
    Für dich als Info, zur Sicherheit lösche ich das Script vorher immer.
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'.
    tcp
    ⚠ HINT:
    Your zigbee.4 COM-Port is NOT matching 'by-id'.
    tcp
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        tcp://192.168.0.64:20108
    tcp://192.168.0.69:20108 -                                   TCP Connection
    zigbee.         tcp://192.168.0.64:20108
    tcp://192.168.0.79:20108
    tcp://192.168.0.63:20108
    tcp://192.168.0.99:20108 -                                   TCP Connection
    zigbee.1        tcp://192.168.0.69:20108
    tcp://192.168.0.79:20108 -                                   TCP Connection
    zigbee.         tcp://192.168.0.69:20108
    zigbee.2        tcp://192.168.0.79:20108
    tcp://192.168.0.63:20108 -                                   TCP Connection
    zigbee.         tcp://192.168.0.79:20108
    zigbee.3        tcp://192.168.0.63:20108
    zigbee.         tcp://192.168.0.63:20108
    zigbee.4        tcp://192.168.0.99:20108            -                                   TCP Connection
    zigbee.         tcp://192.168.0.99:20108            -                                   TCP Connection
    *** NodeJS-Installation ***
    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
    ioBroker Backup Analyzer
    • S Shadowhunter23
      USB-Devices by-id:
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      ⚠ HINT:
      tcp
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      #750
      @Shadowhunter23 sagte in iob diag - Skript:
      Brauchst du nicht.
      curl überschreibt das Ziel immer mit dem aktuellen Inhalt.
      Schau bitte jetzt nochmal.
      • S Abwesend
        S Abwesend
        Shadowhunter23
        #751
        Wollte nur sicher gehen.
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        zigbee.X
        \nExtended Pan ID:
        \n*** MASKED ***
        \nPan ID:
        \n*** MASKED ***
        \nChannel:
        \n*** MASKED ***
        \nNetwork Key:
        \n*** MASKED ***
          Brauchst du nicht.
          #752
          Auf meinem 'simpel'-System schaut es so aus:
          zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
          • S Shadowhunter23
            USB-Devices by-id:
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            ⚠ HINT:
            tcp
            zigbee.X
            \nExtended Pan ID:
            \n*** MASKED ***
            \nPan ID:
            \n*** MASKED ***
            \nChannel:
            \n*** MASKED ***
            \nNetwork Key:
            \n*** MASKED ***
            #753
            @Shadowhunter23
            Und nochmal bitte...
            Ziel ist solch ein Layout:
                                                            ...00_23_93_2C_A8-if00-port2         ✗ Not matching
            zigbee.1        /dev/ttyUSB0                        ...00_23_93_2C_A8-if00-port0         ✗ Not matching
            zigbee.2        tcp://192.168.0.64:20108             -                                   TCP Connection
            • S Abwesend
              S Abwesend
              Shadowhunter23
              #754
              USB-Devices by-id:
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              ⚠ HINT:
              tcp
              zigbee.X
              \nExtended Pan ID:
              \n*** MASKED ***
              \nPan ID:
              \n*** MASKED ***
              \nChannel:
              \n*** MASKED ***
              \nNetwork Key:
              \n*** MASKED ***
              • S Shadowhunter23
                USB-Devices by-id:
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                ⚠ HINT:
                tcp
                zigbee.X
                \nExtended Pan ID:
                \n*** MASKED ***
                \nPan ID:
                \n*** MASKED ***
                \nChannel:
                \n*** MASKED ***
                \nNetwork Key:
                \n*** MASKED ***
                #755
                @Shadowhunter23
                Deine 5 tcp-Verbindungen sind aber eine harte Nuss für mich... :-)
                Ist aber auch bestimmt mit das komplexeste Setup, das hier im Forum von jemandem verwendet wird...
                Versuch nun nochmal, bitte.
                  @Shadowhunter23
                  S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #756
                  @Thomas-Braun sagte in iob diag - Skript:
                  Die Stabilität gibt mir für meinen Teil Recht auch wenn es 5 Instanzen sind.
                  USB-Devices by-id:
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  ⚠ HINT:
                  tcp
                  zigbee.X
                  \nExtended Pan ID:
                  \n*** MASKED ***
                  \nPan ID:
                  \n*** MASKED ***
                  \nChannel:
                  \n*** MASKED ***
                  \nNetwork Key:
                  \n*** MASKED ***
                  tcp://192.168.0.69:20108 -                                   tcp
                  tcp://192.168.0.99:20108 -                                   tcp
                  tcp://192.168.0.79:20108 -                                   tcp
                  tcp://192.168.0.63:20108 -                                   tcp
                  zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
                  zigbee.         tcp://192.168.0.99:20108            -                                   tcp
                  • S Shadowhunter23
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    \nExtended Pan ID:
                    \n*** MASKED ***
                    \nPan ID:
                    \n*** MASKED ***
                    \nChannel:
                    \n*** MASKED ***
                    \nNetwork Key:
                    \n*** MASKED ***
                    #757
                    @Shadowhunter23
                    Bitte nochmal.
                    • S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #758
                      USB-Devices by-id:
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      ⚠ HINT:
                      tcp
                      zigbee.X
                      \nExtended Pan ID:
                      \n*** MASKED ***
                      \nPan ID:
                      \n*** MASKED ***
                      \nChannel:
                      \n*** MASKED ***
                      \nNetwork Key:
                      \n*** MASKED ***
                      • S Shadowhunter23
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        \nExtended Pan ID:
                        \n*** MASKED ***
                        \nPan ID:
                        \n*** MASKED ***
                        \nChannel:
                        \n*** MASKED ***
                        \nNetwork Key:
                        \n*** MASKED ***
                        #759
                        @Shadowhunter23
                        So langsam gehen mir die Ideen aus...
                        Versuch nochmal.
                        • S Abwesend
                          S Abwesend
                          Shadowhunter23
                          #760
                          USB-Devices by-id:
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          ⚠ HINT:
                          tcp
                          zigbee.X
                          \nExtended Pan ID:
                          \n*** MASKED ***
                          \nPan ID:
                          \n*** MASKED ***
                          \nChannel:
                          \n*** MASKED ***
                          \nNetwork Key:
                          \n*** MASKED ***
                          • S Shadowhunter23
                            USB-Devices by-id:
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            ⚠ HINT:
                            tcp
                            zigbee.X
                            \nExtended Pan ID:
                            \n*** MASKED ***
                            \nPan ID:
                            \n*** MASKED ***
                            \nChannel:
                            \n*** MASKED ***
                            \nNetwork Key:
                            \n*** MASKED ***
                            #761
                            @Shadowhunter23
                            Das schaut doch schon fast aus wie gewünscht...
                            Bitte jetzt nochmal laufen lassen.
                            Ich brauch übrigens nur den Part ab
                            Der Code davor wird nicht geändert.
                            • S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #762
                              Komplett ohne Log:
                              Script v.2026-03-08
                              *** BASE SYSTEM ***
                              Operating System: Debian GNU/Linux 13 (trixie)
                               Static hostname: iobroker
                                     Icon name: computer-container
                                       Chassis: container ☐
                                Virtualization: lxc
                                        Kernel: Linux 6.17.13-1-pve
                                  Architecture: x86-64
                              OS is similar to:
                              model name      : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
                              CPU threads     : 6
                              Docker          : false        Virtualization  : lxc        Kernel          : x86_64        Userland        : 64bit        Systemuptime and Load:        22:55:31 up  3:01,  2 users,  load average: 0.41, 0.39, 0.31        *** LIFE CYCLE STATUS ***        Operating System is the current Debian stable version codenamed 'trixie'!        *** TIME AND TIMEZONES ***        Local time: Sun 2026-03-08 22:55:31 CET        Universal time: Sun 2026-03-08 21:55:31 UTC        RTC time: n/a        Time zone: Europe/Berlin (CET, +0100)        System clock synchronized: yes        NTP service: inactive        RTC in local TZ: no        *** Users and Groups ***        User that called 'iob diag':        tobias
                              HOME=/home/tobias
                              GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                              iobroker
                              HOME=/home/iobroker
                              SUDO_HOME=/home/tobias
                              GROUPS=iobroker tty dialout audio video plugdev redis
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server:         Unknown
                              Display-Manager:        Not found
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:             10G        4.6G        6.1G        2.4M         63M        6.2G
                              Swap:           5.4G          0B        5.4G
                              Total:           16G        4.6G         11G
                              Active iob-Instances:   46
                                      10240 M total memory
                                       4355 M used memory
                                       4240 M active memory
                                          0 M inactive memory
                                       5825 M free memory
                                          0 M buffer memory
                                         60 M swap cache
                                       5120 M total swap
                                          0 M used swap
                                       5120 M free swap
                              top - 22:55:31 up  3:01,  2 users,  load average: 0.41, 0.39, 0.31
                              Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  1.6 us,  1.6 sy,  0.0 ni, 96.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :  10240.0 total,   5824.9 free,   4356.4 used,     60.8 buff/cache
                              MiB Swap:   5120.0 total,   5120.0 free,      0.0 used.   5883.6 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                              * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                              Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                      ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                      SUB    -> The low-level unit activation state, values depend on unit type.
                              1 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              dmesg: read kernel buffer failed: Operation not permitted
                              No critical errors detected
                              *** FILESYSTEM ***
                              Filesystem             Type      Size  Used Avail Use% Mounted on
                              DATA/subvol-400-disk-0 zfs        20G  4.3G   16G  22% /
                              none                   tmpfs     492K  4.0K  488K   1% /dev
                              udev                   devtmpfs   16G     0   16G   0% /dev/tty
                              tmpfs                  tmpfs      16G     0   16G   0% /dev/shm
                              tmpfs                  tmpfs     6.3G  152K  6.3G   1% /run
                              tmpfs                  tmpfs      16G  1.9M   16G   1% /tmp
                              tmpfs                  tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                  tmpfs     3.2G   12K  3.2G   1% /run/user/1000
                              Messages concerning filesystems in dmesg:
                              Show mounted filesystems:
                              TARGET SOURCE                 FSTYPE OPTIONS
                              /      DATA/subvol-400-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
                              /var:
                              559M    /var/
                              221M    /var/cache
                              219M    /var/cache/apt
                              209M    /var/lib
                              166M    /var/cache/apt/archives
                              Archived and active journals take up 125.1M in the file system.
                              /opt/iobroker/backups:
                              136M    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              31M     /opt/iobroker/iobroker-data/
                              27M     /opt/iobroker/iobroker-data/files
                              20M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                              3.3M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                              2.8M    /opt/iobroker/iobroker-data/objects.jsonl
                              1.2M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
                              1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                              1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                              USB-Devices by-id:
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              ⚠ HINT:
                              tcp
                              zigbee.X
                              \nExtended Pan ID:
                              \n*** MASKED ***
                              \nPan ID:
                              \n*** MASKED ***
                              \nChannel:
                              \n*** MASKED ***
                              \nNetwork Key:
                              \n*** MASKED ***
                              /usr/bin/nodejs         v22.22.1
                              /usr/bin/node           v22.22.1
                              /usr/bin/npm            10.9.4
                              /usr/bin/npx            10.9.4
                              ✓ Node.js installation is correct
                              nodejs:
                                Installed: 22.22.1-1nodesource1
                                Candidate: 22.22.1-1nodesource1
                                Version table:
                               *** 22.22.1-1nodesource1 1001
                                   22.22.0-1nodesource1 1001
                                   22.21.0-1nodesource1 1001
                                   22.20.0-1nodesource1 1001
                                   22.19.0-1nodesource1 1001
                                   22.18.0-1nodesource1 1001
                                   22.17.1-1nodesource1 1001
                                   22.17.0-1nodesource1 1001
                                   22.16.0-1nodesource1 1001
                                   22.15.1-1nodesource1 1001
                                   22.15.0-1nodesource1 1001
                                   22.14.0-1nodesource1 1001
                                   22.13.1-1nodesource1 1001
                                   22.13.0-1nodesource1 1001
                                   22.12.0-1nodesource1 1001
                                   22.11.0-1nodesource1 1001
                                   22.10.0-1nodesource1 1001
                                   22.9.0-1nodesource1 1001
                                   22.8.0-1nodesource1 1001
                                   22.7.0-1nodesource1 1001
                                   22.6.0-1nodesource1 1001
                                   22.5.1-1nodesource1 1001
                                   22.5.0-1nodesource1 1001
                                   22.4.1-1nodesource1 1001
                                   22.4.0-1nodesource1 1001
                                   22.3.0-1nodesource1 1001
                                   22.2.0-1nodesource1 1001
                                   22.1.0-1nodesource1 1001
                                   22.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main amd64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              At least one iobroker host is running.
                              Objects type: redis
                              States  type: redis
                              Hosts:
                              iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 10891)
                              Core adapters versions
                              js-controller:  7.1.0
                              admin:          7.8.3
                              javascript:     9.0.18
                              nodejs modules from github:     0
                              Adapter State
                              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                system.adapter.ankersolix2.0            : ankersolix2           : iobroker                                 - disabled
                              + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                              + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                              + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                              + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                              + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                              + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                              + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                              + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                              + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                              + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                              + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                              + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                              + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                              + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                              + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                              + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                              + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                              + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): beta
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: beta
                              Adapter    "admin"        : 7.8.3    , installed 7.8.3
                              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                              Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                              Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
                              Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                              Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
                              Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
                              Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                              Adapter    "device-watcher": 2.15.5  , installed 2.15.5
                              Adapter    "email"        : 2.0.4    , installed 2.0.4
                              Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                              Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                              Adapter    "ical"         : 1.19.7   , installed 1.19.7
                              Adapter    "iot"          : 5.0.12   , installed 5.0.12
                              Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                              Controller "js-controller": 7.1.0    , installed 7.1.0
                              Adapter    "lg-thinq"     : 1.1.6    , installed 1.1.6
                              Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                              Adapter    "mytime"       : 2.3.2    , installed 2.3.2
                              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                              Adapter    "notification-manager": 1.3.0, installed 1.3.0
                              Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                              Adapter    "operating-hours": 1.4.1  , installed 1.4.1
                              Adapter    "ping"         : 2.1.0    , installed 2.1.0
                              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                              Adapter    "sayit"        : 5.1.0    , installed 5.1.0
                              Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                              Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                              Adapter    "text2command" : 4.0.0    , installed 4.0.0
                              Adapter    "trashschedule": 5.2.1    , installed 5.2.1
                              Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                              Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
                              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                              Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                              Adapter    "web"          : 8.0.0    , installed 8.0.0
                              Adapter    "ws"           : 4.0.0    , installed 4.0.0
                              Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
                              Objects and States
                              Objects:        12439
                              States:         11004
                              Hit:1 http://security.debian.org trixie-security InRelease
                              Hit:2 http://deb.debian.org/debian trixie InRelease
                              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                              Reading package lists... Done
                              Pending systemupdates: 0
                              *** Listening Ports ***
                              Netid    State     Recv-Q    Send-Q       Local Address:Port         Peer Address:Port    Process        udp      UNCONN    0         0                  0.0.0.0:6666              0.0.0.0:*        users:(("io.tuya.0",pid=943,fd=40))                                                   udp      UNCONN    0         0                  0.0.0.0:6667              0.0.0.0:*        users:(("io.tuya.0",pid=943,fd=41))                                                   udp      UNCONN    0         0                  0.0.0.0:sunrpc            0.0.0.0:*        users:(("rpcbind",pid=141,fd=5),("systemd",pid=1,fd=35))                              udp      UNCONN    0         0                  0.0.0.0:mdns              0.0.0.0:*        users:(("io.chromecast.0",pid=615,fd=35))                                             udp      UNCONN    0         0                  0.0.0.0:coap              0.0.0.0:*        users:(("io.shelly.0",pid=899,fd=52))                                                 udp      UNCONN    0         0                     [::]:sunrpc               [::]:*        users:(("rpcbind",pid=141,fd=7),("systemd",pid=1,fd=37))                              tcp      LISTEN    0         511          192.168.0.222:9092              0.0.0.0:*        users:(("io.nuki.0",pid=808,fd=31))                                                   tcp      LISTEN    0         4096               0.0.0.0:sunrpc            0.0.0.0:*        users:(("rpcbind",pid=141,fd=4),("systemd",pid=1,fd=34))                              tcp      LISTEN    0         511                0.0.0.0:1882              0.0.0.0:*        users:(("io.shelly.1",pid=921,fd=45))                                                 tcp      LISTEN    0         511                0.0.0.0:1883              0.0.0.0:*        users:(("io.mqtt.0",pid=756,fd=35))                                                   tcp      LISTEN    0         100              127.0.0.1:smtp              0.0.0.0:*        users:(("master",pid=371,fd=13))                                                      tcp      LISTEN    0         511              127.0.0.1:redis             0.0.0.0:*        users:(("redis-server",pid=164,fd=8))                                                 tcp      LISTEN    0         100                  [::1]:smtp                 [::]:*        users:(("master",pid=371,fd=14))                                                      tcp      LISTEN    0         511                  [::1]:redis                [::]:*        users:(("redis-server",pid=164,fd=9))                                                 tcp      LISTEN    0         4096                  [::]:sunrpc               [::]:*        users:(("rpcbind",pid=141,fd=6),("systemd",pid=1,fd=36))                              tcp      LISTEN    0         511                      *:http                    *:*        users:(("apache2",pid=207,fd=4),("apache2",pid=206,fd=4),("apache2",pid=204,fd=4))    tcp      LISTEN    0         4096                     *:ssh                     *:*        users:(("sshd",pid=191,fd=3),("systemd",pid=1,fd=65))                                 tcp      LISTEN    0         511                      *:3000                    *:*        users:(("io.fullybrowser",pid=689,fd=30))                                             tcp      LISTEN    0         511                      *:8087                    *:*        users:(("io.simple-api.0",pid=1316,fd=35))                                            tcp      LISTEN    0         511                      *:8082                    *:*        users:(("io.web.0",pid=1441,fd=35))                                                   tcp      LISTEN    0         511                      *:tproxy                  *:*        users:(("io.admin.0",pid=401,fd=39))
                              Das einfügen ab Listening Ports ist gerade schwierig. Müsste ich morgen Mal vom PC machen.
                              • S Shadowhunter23
                                Komplett ohne Log:
                                Script v.2026-03-08
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                CPU threads     : 6
                                HOME=/home/tobias
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           5.4G          0B        5.4G
                                Total:           16G        4.6G         11G
                                         4355 M used memory
                                            0 M inactive memory
                                         5825 M free memory
                                            0 M buffer memory
                                           60 M swap cache
                                         5120 M total swap
                                            0 M used swap
                                         5120 M free swap
                                *** FILESYSTEM ***
                                /var:
                                559M    /var/
                                221M    /var/cache
                                219M    /var/cache/apt
                                209M    /var/lib
                                USB-Devices by-id:
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                ⚠ HINT:
                                tcp
                                zigbee.X
                                \nExtended Pan ID:
                                \n*** MASKED ***
                                \nPan ID:
                                \n*** MASKED ***
                                \nChannel:
                                \n*** MASKED ***
                                \nNetwork Key:
                                \n*** MASKED ***
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                admin:          7.8.3
                                javascript:     9.0.18
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        12439
                                States:         11004
                                #763
                                @Shadowhunter23
                                Nur die Tabelle mit den Zigbee-Ports (oder wie es gerade bei dir aussieht) reicht.
                                Versuch nochmal.
                                • S Abwesend
                                  S Abwesend
                                  Shadowhunter23
                                  #764
                                  Leider als Bild
                                  • S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #765
                                    Oder meinst du den Bereich:
                                    • S Shadowhunter23
                                      Leider als Bild
                                      #766
                                      @Shadowhunter23
                                      Nein, ich meine nur die Zigbee-relevante Tabelle mit
                                      überschrieben.
                                      Bei mir halt dieses Layout:
                                      Deine Listening Ports spielen keine Rolle.
                                      • S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #767
                                        Jetzt ist es wohl spät, ich...
                                        USB-Devices by-id:
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        ⚠ HINT:
                                        tcp
                                        zigbee.X
                                        \nExtended Pan ID:
                                        \n*** MASKED ***
                                        \nPan ID:
                                        \n*** MASKED ***
                                        \nChannel:
                                        \n*** MASKED ***
                                        \nNetwork Key:
                                        \n*** MASKED ***
                                        sed: -e expression #1, char 134: unknown command: `/'
                                        • S Shadowhunter23
                                          USB-Devices by-id:
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          ⚠ HINT:
                                          tcp
                                          zigbee.X
                                          \nExtended Pan ID:
                                          \n*** MASKED ***
                                          \nPan ID:
                                          \n*** MASKED ***
                                          \nChannel:
                                          \n*** MASKED ***
                                          \nNetwork Key:
                                          \n*** MASKED ***
                                          #768
                                          @Shadowhunter23
                                          Ich hab sed jetzt angepasst. Versuch nochmal.
