  4. Innogy Adapter im lokalen Netzt bleibt Gelb
    3.2k
    3.1k
118 Beiträge 5 Kommentatoren 16.2k Aufrufe 4 Beobachtet
  • S scout1978
    pi@raspberrypi-Iobroker:/opt/iobroker $ sudo apt install nodejs
    Reading package lists... Done
    Building dependency tree... Done
    The following NEW packages will be installed:
      nodejs
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 26.4 MB of archives.
    After this operation, 126 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.17.1-deb-1nodesource1 [26.4 MB]
    Fetched 26.4 MB in 2s (11.3 MB/s)
    Selecting previously unselected package nodejs.
    (Reading database ... 61159 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.17.1-deb-1nodesource1_arm64.deb ...
    Unpacking nodejs (16.17.1-deb-1nodesource1) ...
    Setting up nodejs (16.17.1-deb-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypi-Iobroker:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && i                                     ob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.1
    v16.17.1
    8.15.0
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    /opt/iobroker
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
    Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    All packages are up to date.
    nodejs:
      Installed: 16.17.1-deb-1nodesource1
      Candidate: 16.17.1-deb-1nodesource1
      Version table:
     *** 16.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    #41
    @scout1978
    Passt jetzt.
      @scout1978
      Passt jetzt.
      scout1978
      #42
      Oh gut habe gerade gesucht und nicht gefunden. Danke
      • S scout1978
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #43
        @scout1978 falls dann alles soweit vom System her ok ist dann zurück zu Deinem eigentlichen Anliegen:
        https://community.livisi.de/lsh-howto-de/
        Bitte absolut genau befolgen - so hab ich das auch gemacht und mein Adapter läuft seit Wochen zuverlässig auf "local Smarthome"
        Lehrling seit 1975 !!!
        • DJMarc75D DJMarc75
          scout1978
          #44
          @djmarc75
          Hallo und Danke für die Hilfe. Ich glaube ich habe es genauso gemacht.
          In der App das Lokale Smarthome aktiviert.....den Anweisungen gefolgt...Passwort neu vergeben...Nutzungsbedingungen Akzeptiert....feste Ip.
          Über den Browser komme ich auch auf die Zentrale.
          Das einzige was mir nicht klar ist wenn ich die Ip:8080 eingebe, soll ich mich ja anmelden da passiert aber nichts (habe auch nicht verstanden was dort passieren soll).
          Habe ich in der Anleitung etwas überlesen?
          Grüße Gernot
          DJMarc75D 2 Antworten Letzte Antwort
          • S scout1978
            @djmarc75
            Grüße Gernot
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #45
            @scout1978 sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
            keine Ahnung ?! welchen Hub hast Du denn so prinzipiell ? v1 oder v2 ?
              scout1978
              #46
              @djmarc75
              V2
              • S scout1978
                @djmarc75
                Grüße Gernot
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #47
                bestimmt eine Kleinigkeit, aber ich muss mich da nochmal einlesen... nur heut leider nichtmehr - sorry. gerne morgen, da ist der Kopf frei
                  scout1978
                  #48
                  @djmarc75
                  Habe es gerade nocheinmal versucht.....Ganz ehrlich der 30 Vesuch und siehe da Instanz Grün!
                  • S scout1978
                    @djmarc75
                    scout1978
                    #49
                    Vielen Dank für Eure Hilfe !!!!!
                    Wenn ich herausfinde was es war werde ich hier posten!
                    • S scout1978
                      scout1978
                      #50
                      Instanz leider wieder Rot.
                      Anbei das Log.
                      2022-10-15 18:10:45.448 - info: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 started with pid 266570
                      2022-10-15 18:10:49.032 - info: innogy-smarthome.0 (266570) starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
                      2022-10-15 18:10:49.083 - info: innogy-smarthome.0 (266570) Trying to use local smarthome connection!
                      2022-10-15 18:10:50.216 - error: innogy-smarthome.0 (266570) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2022-10-15 18:10:50.217 - error: innogy-smarthome.0 (266570) unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      2022-10-15 18:10:50.218 - error: innogy-smarthome.0 (266570) StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
                      at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
                      at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
                      at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                      at Request.emit (node:events:513:28)
                      at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                      at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                      at Object.onceWrapper (node:events:627:28)
                      at IncomingMessage.emit (node:events:525:35)
                      at endReadableNT (node:internal/streams/readable:1358:12)
                      at processTicksAndRejections (node:internal/process/task_queues:83:21)
                      2022-10-15 18:10:50.219 - error: innogy-smarthome.0 (266570) 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      2022-10-15 18:10:50.241 - info: innogy-smarthome.0 (266570) cleaned everything up...
                      2022-10-15 18:10:50.242 - info: innogy-smarthome.0 (266570) terminating
                      2022-10-15 18:10:50.244 - warn: innogy-smarthome.0 (266570) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2022-10-15 18:10:50.933 - error: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2022-10-15 18:10:50.933 - info: host.raspberrypi-Iobroker Restart adapter system.adapter.innogy-smarthome.0 because enabled
                      2022-10-15 18:11:21.112 - info: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 started with pid 266697
                      2022-10-15 18:11:24.489 - info: innogy-smarthome.0 (266697) starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
                      2022-10-15 18:11:24.536 - info: innogy-smarthome.0 (266697) Trying to use local smarthome connection!
                      2022-10-15 18:11:25.389 - error: innogy-smarthome.0 (266697) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2022-10-15 18:11:25.390 - error: innogy-smarthome.0 (266697) unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      2022-10-15 18:11:25.392 - error: innogy-smarthome.0 (266697) StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      2022-10-15 18:11:25.392 - error: innogy-smarthome.0 (266697) 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                      2022-10-15 18:11:25.415 - info: innogy-smarthome.0 (266697) cleaned everything up...
                      2022-10-15 18:11:25.416 - info: innogy-smarthome.0 (266697) terminating
                      2022-10-15 18:11:25.418 - warn: innogy-smarthome.0 (266697) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2022-10-15 18:11:26.096 - error: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2022-10-15 18:11:26.096 - info: host.raspberrypi-Iobroker Restart adapter system.adapter.innogy-smarthome.0 because enabled
                      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                      • S scout1978
                        Anbei das Log.
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #51
                        @scout1978 bitte in Codetags setzen dann kann man auch lesen und zitieren. Danke
                        • S scout1978
                          Anbei das Log.
                          #52
                          @scout1978
                          Setz das bitte in CodeTags. Das mag so niemand lesen.
                            @scout1978
                            scout1978
                            #53
                            Sorry
                            	2022-10-15 18:18:07.126	info	Do not restart adapter system.adapter.innogy-smarthome.0 because disabled or deleted
                            	2022-10-15 18:18:07.125	error	instance system.adapter.innogy-smarthome.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                            innogy-smarthome.0
                            	2022-10-15 18:18:06.452	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                            innogy-smarthome.0
                            	2022-10-15 18:18:06.389	error	adapter disabled
                            	2022-10-15 18:17:36.452	info	"system.adapter.innogy-smarthome.0" disabled
                            	2022-10-15 18:17:33.032	info	Restart adapter system.adapter.innogy-smarthome.0 because enabled
                            	2022-10-15 18:17:33.031	error	instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.356	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.355	info	terminating
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.353	info	cleaned everything up...
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.342	error	400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.341	error	StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:513:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:513:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:627:28) at IncomingMessage.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.340	error	unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
                            innogy-smarthome.0
                            	2022-10-15 18:17:32.339	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            innogy-smarthome.0
                            	2022-10-15 18:17:31.195	info	Trying to use local smarthome connection!
                            innogy-smarthome.0
                            	2022-10-15 18:17:31.148	info	starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
                            S HomoranH 2 Antworten Letzte Antwort
                            • S scout1978
                              Sorry
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              innogy-smarthome.0
                              scout1978
                              #54
                              Das ist auch gerade noch aufgetaucht
                              • S scout1978
                                scout1978
                                #55
                                Es scheint mit einem Java Skript zu tun zu haben. Habe die Javascript Instanz gestoppt. Jetzt funktioniert der Innogy Adapter.
                                Werde die einzelnen Skripte nun einmal durchsuchen.
                                Kann mir eventuell zu folgendem Log noch etwas sagen?
                                2022-10-15 19:17:19.935 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Index" has no existing object, this might lead to an error in future versions
                                2022-10-15 19:17:19.937 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.KeyPressCounter" has no existing object, this might lead to an error in future versions
                                2022-10-15 19:17:19.939 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Type" has no existing object, this might lead to an error in future versions
                                2022-10-15 19:17:22.299 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Index" has no existing object, this might lead to an error in future versions
                                2022-10-15 19:17:22.300 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.KeyPressCounter" has no existing object, this might lead to an error in future versions
                                2022-10-15 19:17:22.301 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Type" has no existing object, this might lead to an error in future versions
                                • S scout1978
                                  Sorry
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  innogy-smarthome.0
                                  HomoranH Offline
                                  HomoranH Offline
                                  #56
                                  ich kenne den Adapter nicht, aber fehlt da etwas in der Konfiguration?
                                    scout1978
                                    #57
                                    Habe nochmal alles geprüft, in mienen Einstellungen sollte alles passen. Der Adapter hat auch keine weiteren Einstellmöglichkeiten.Habe auch ein entsprechendes Gerät neu initialisiert. Fehlermeldung kommt immer noch. Habe auf GitHub nun nach Hilfe gefragt.
                                    Danke nocheinmal für Eure Hilfe
                                    • S scout1978
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #58
                                      Bitte zeig mal einen Screenshot davon, weil "sollte alles passen" eventuell "falsch" bedeutet.
                                        scout1978
                                        #59
                                        @djmarc75
                                        Hallo was genau soll ich dir schicken?
                                        HomoranH DJMarc75D 2 Antworten Letzte Antwort
                                        • S scout1978
                                          @djmarc75
                                          HomoranH Offline
                                          HomoranH Offline
                                          #60
                                          @djmarc75
