  4. Innogy Adapter im lokalen Netzt bleibt Gelb
    5.7k
118 Beiträge 5 Kommentatoren 16.7k Aufrufe 4 Beobachtet
  • S scout1978
    Instanz leider wieder Rot.
    Anbei das Log.
    2022-10-15 18:10:45.448 - info: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 started with pid 266570
    2022-10-15 18:10:49.032 - info: innogy-smarthome.0 (266570) starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
    2022-10-15 18:10:49.083 - info: innogy-smarthome.0 (266570) Trying to use local smarthome connection!
    2022-10-15 18:10:50.216 - error: innogy-smarthome.0 (266570) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-15 18:10:50.217 - error: innogy-smarthome.0 (266570) unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    2022-10-15 18:10:50.218 - error: innogy-smarthome.0 (266570) StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
    at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
    at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (node:events:513:28)
    at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
    at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
    at Object.onceWrapper (node:events:627:28)
    at IncomingMessage.emit (node:events:525:35)
    at endReadableNT (node:internal/streams/readable:1358:12)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
    2022-10-15 18:10:50.219 - error: innogy-smarthome.0 (266570) 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    2022-10-15 18:10:50.241 - info: innogy-smarthome.0 (266570) cleaned everything up...
    2022-10-15 18:10:50.242 - info: innogy-smarthome.0 (266570) terminating
    2022-10-15 18:10:50.244 - warn: innogy-smarthome.0 (266570) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-15 18:10:50.933 - error: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-15 18:10:50.933 - info: host.raspberrypi-Iobroker Restart adapter system.adapter.innogy-smarthome.0 because enabled
    2022-10-15 18:11:21.112 - info: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 started with pid 266697
    2022-10-15 18:11:24.489 - info: innogy-smarthome.0 (266697) starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
    2022-10-15 18:11:24.536 - info: innogy-smarthome.0 (266697) Trying to use local smarthome connection!
    2022-10-15 18:11:25.389 - error: innogy-smarthome.0 (266697) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-15 18:11:25.390 - error: innogy-smarthome.0 (266697) unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    2022-10-15 18:11:25.392 - error: innogy-smarthome.0 (266697) StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    2022-10-15 18:11:25.392 - error: innogy-smarthome.0 (266697) 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
    2022-10-15 18:11:25.415 - info: innogy-smarthome.0 (266697) cleaned everything up...
    2022-10-15 18:11:25.416 - info: innogy-smarthome.0 (266697) terminating
    2022-10-15 18:11:25.418 - warn: innogy-smarthome.0 (266697) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-15 18:11:26.096 - error: host.raspberrypi-Iobroker instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-15 18:11:26.096 - info: host.raspberrypi-Iobroker Restart adapter system.adapter.innogy-smarthome.0 because enabled
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @scout1978 bitte in Codetags setzen dann kann man auch lesen und zitieren. Danke
    Lehrling seit 1975 !!!
    • S scout1978
      Anbei das Log.
      @scout1978
      Setz das bitte in CodeTags. Das mag so niemand lesen.
        @scout1978
        scout1978
        Sorry
        	2022-10-15 18:18:07.126	info	Do not restart adapter system.adapter.innogy-smarthome.0 because disabled or deleted
        	2022-10-15 18:18:07.125	error	instance system.adapter.innogy-smarthome.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        innogy-smarthome.0
        	2022-10-15 18:18:06.452	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        innogy-smarthome.0
        	2022-10-15 18:18:06.389	error	adapter disabled
        	2022-10-15 18:17:36.452	info	"system.adapter.innogy-smarthome.0" disabled
        	2022-10-15 18:17:33.032	info	Restart adapter system.adapter.innogy-smarthome.0 because enabled
        	2022-10-15 18:17:33.031	error	instance system.adapter.innogy-smarthome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        innogy-smarthome.0
        	2022-10-15 18:17:32.356	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        innogy-smarthome.0
        	2022-10-15 18:17:32.355	info	terminating
        innogy-smarthome.0
        	2022-10-15 18:17:32.353	info	cleaned everything up...
        innogy-smarthome.0
        	2022-10-15 18:17:32.342	error	400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
        innogy-smarthome.0
        	2022-10-15 18:17:32.341	error	StatusCodeError: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:513:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:513:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:627:28) at IncomingMessage.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
        innogy-smarthome.0
        	2022-10-15 18:17:32.340	error	unhandled promise rejection: 400 - {"errorcode":1005,"description":"Missing argument or wrong value","messages":["Parameter [ OnState ] does not exist. Err: [ parameter [OnState] not found in action [SetState] ]"]}
        innogy-smarthome.0
        	2022-10-15 18:17:32.339	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        innogy-smarthome.0
        	2022-10-15 18:17:31.195	info	Trying to use local smarthome connection!
        innogy-smarthome.0
        	2022-10-15 18:17:31.148	info	starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v16.17.1, js-controller: 4.0.23
        S HomoranH 2 Antworten Letzte Antwort
        • S scout1978
          Sorry
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          innogy-smarthome.0
          scout1978
          Das ist auch gerade noch aufgetaucht
          • S scout1978
            scout1978
            Es scheint mit einem Java Skript zu tun zu haben. Habe die Javascript Instanz gestoppt. Jetzt funktioniert der Innogy Adapter.
            Werde die einzelnen Skripte nun einmal durchsuchen.
            Kann mir eventuell zu folgendem Log noch etwas sagen?
            2022-10-15 19:17:19.935 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Index" has no existing object, this might lead to an error in future versions
            2022-10-15 19:17:19.937 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.KeyPressCounter" has no existing object, this might lead to an error in future versions
            2022-10-15 19:17:19.939 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Type" has no existing object, this might lead to an error in future versions
            2022-10-15 19:17:22.299 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Index" has no existing object, this might lead to an error in future versions
            2022-10-15 19:17:22.300 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.KeyPressCounter" has no existing object, this might lead to an error in future versions
            2022-10-15 19:17:22.301 - warn: innogy-smarthome.0 (280224) State "innogy-smarthome.0.Gäste-WC.Deckenlampe-Gäste-WC.Type" has no existing object, this might lead to an error in future versions
            • S scout1978
              Sorry
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              innogy-smarthome.0
              @scout1978 sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
              ich kenne den Adapter nicht, aber fehlt da etwas in der Konfiguration?
                scout1978
                Habe nochmal alles geprüft, in mienen Einstellungen sollte alles passen. Der Adapter hat auch keine weiteren Einstellmöglichkeiten.Habe auch ein entsprechendes Gerät neu initialisiert. Fehlermeldung kommt immer noch. Habe auf GitHub nun nach Hilfe gefragt.
                Danke nocheinmal für Eure Hilfe
                • S scout1978
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Bitte zeig mal einen Screenshot davon, weil "sollte alles passen" eventuell "falsch" bedeutet.
                  • DJMarc75D DJMarc75
                    scout1978
                    @djmarc75
                    Hallo was genau soll ich dir schicken?
                    HomoranH DJMarc75D 2 Antworten Letzte Antwort
                    • S scout1978
                      @djmarc75
                      @djmarc75
                      • S scout1978
                        @djmarc75
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        einen Screenshot von den Instanzeinstellungen...
                        Da gibts ne super Anleitung - nach der hab ich den Adapter auch zum Laufen gebracht.
                          scout1978
                          @djmarc75
                          Der Adapter läuft inzwischen..... Er Produziert nur komische Log Meldungen....
                          Log siehe oben....
                          DJMarc75D HomoranH 2 Antworten Letzte Antwort
                          • S scout1978
                            @djmarc75
                            Log siehe oben....
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Schön für Dich aber woran lag es nun ?
                            Und das sind WARNMELDUNGEN und keine Fehler.
                            Ich bekomme diese Meldungen auch (und auch jeder Andere).
                            Wenn Du die nicht sehen willst dann musst DU das LOG-Level vom Adapter auf ERROR stellen. Macht bei dem Adapter im Moment eh Sinn weil an dem noch weiterentwickelt wird und noch nicht zu 100% rund läuft.
                            • S scout1978
                              @djmarc75
                              Log siehe oben....
                              seitcwann?
                              ich finde den post nicht.
                              Log siehe oben....
                              wo?
                              Link dahin bitte.
                              oder meinst du damit den Screenshit eines Mikrofilms?
                                seitcwann?
                                Log siehe oben....
                                wo?
                                Link dahin bitte.
                                scout1978
                                am 15.10 um 19.19
                                • S scout1978
                                  am 15.10 um 19.19
                                  scout1978
                                  #66
                                  Sorry weis nicht wie ich euch da hin linken kann
                                  • S scout1978
                                    am 15.10 um 19.19
                                    #67
                                    kommt da noch was?
                                    so:
                                    https://forum.iobroker.net/post/873971
                                    wie @DJMarc75 schon sagte sind das nur Warnungen für den Entwickler
                                      kommt da noch was?
                                      so:
                                      scout1978
                                      #68
                                      Dann mache ich hier zu und bedanke mich für die Geduld und Hilfe!!!!
                                      Falls ich das betreffende Blockly finde mache ich noch einen kurzen Nachtrag.
                                      Master67M 1 Antwort Letzte Antwort
                                      • S scout1978
                                        Master67M Offline
                                        Master67M Offline
                                        Master67
                                        #69
                                        Hmmm...... ich habe auch ein Problem mit dem Adapter, ich denke bei mir liegt aber der Fehler bei meiner "alten" Zentrale die noch V1 ist.
                                        Im Adapter wird folgendes Beschreiben "Once, you've updated your SmartHomeController to at least version 8.17, you can activate the Local SmartHome.
                                        If you've done so, please enter the IP of the SmartHomeController and your password in the fields below"
                                        Die Softwareversion in der V1 ist aber die 3.40.6, und soweit ich das verstanden habe, gibt es die nicht höher.
                                        Da bleibt mir nix anders übrig als mir eine V2 zu kaufen, wenn ich den ioBroker weiter für die Livisi Aktoren nutzen will, oder
                                        ich muss das Livisi System auf einen anderen Server umziehen.... alles Doof!
                                        Gruß Master67
                                        • Master67M Master67
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #70
                                          @master67
                                          https://community.livisi.de/lsh-faq-de/#
                                          Dort mal unter "Einrichtung, Registrierung & Geräte " den ersten Punkt mit den Vorraussetzungen anklicken.
                                          Das könnte u.U. helfen ob Du eine unterstützte HW hast.
