  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • teletapiT teletapi
    @armilar @TT-Tom
    Userdata:
      "common": {
        "type": "string",
        "write": true,
        "name": "0_userdata.0.NSPanel.GuestWiFi.Daten",
        "role": "state"
      "native": {},
      "type": "state",
      "from": "system.adapter.javascript.0",
      "user": "system.user.admin",
      "ts": 1749645612221,
      "_id": "0_userdata.0.NSPanel.GuestWiFi.Daten",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "common": {
        "type": "boolean",
        "write": true,
        "name": "0_userdata.0.NSPanel.GuestWiFi.Switch",
        "role": "state"
      "native": {},
      "type": "state",
      "ts": 1749645612236,
      "_id": "0_userdata.0.NSPanel.GuestWiFi.Switch",
      "acl": {
        "object": 1636,
        "state": 1636,
    Alias:
      "_id": "alias.0.NSPanel.Guest_Wifi.ACTUAL",
      "common": {
        "type": "string",
        "role": "state",
        "name": "ACTUAL",
        "alias": {
          "id": "0_userdata.0.NSPanel.GuestWiFi.Daten"
      "native": {},
      "type": "state",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1755073577992
      "_id": "alias.0.NSPanel.Guest_Wifi.SWITCH",
      "common": {
        "type": "boolean",
        "role": "state",
        "name": "SWITCH",
        "alias": {
          "id": "0_userdata.0.NSPanel.GuestWiFi.Switch"
      "native": {},
      "type": "state",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1755073578001
    Meinst du das hier mit Channel..?
      "_id": "alias.0.NSPanel.Guest_Wifi",
      "type": "channel",
      "common": {
        "role": "switch.mode.wlan",
        "name": "QR Page"
      "native": {},
      "ts": 1754779271697,
      "acl": {
        "object": 1636,
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #7441
    @teletapi
    Der wichtigste fehlt noch... der Channel...
    Denke aber das der passt, da du autoCreateALias: true benutzt...
    teletapiT 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @teletapi
      teletapiT Online
      teletapiT Online
      teletapi
      #7442
      @armilar schau mal hab ich editiert, ist das das richtige (Channel).?
        teletapiT Online
        teletapiT Online
        teletapi
        schrieb am zuletzt editiert von teletapi
        #7443
        @teletapi Das witzige ist doch das das Panel alles darstellt nur der QR Code wird nicht eingeblendet das Fenster für den QR Code ist halt Weiß. Hab ich vielleicht einen weißen anstatt schwarzen OR Code.... ? ich hab mir das mit Sicherheit irgendwie kaputt gemacht.
        Hier noch ein Screen vom Alias:
        ArmilarA 2 Antworten Letzte Antwort
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #7444
          @teletapi
          Nee, ich verstehe das im Moment auch nicht wirklich...
          im Bild ist ja die angegebene SSID zu sehen und aus den restlichen Daten wird der QR im TFT (HMI) erstellt. Du hast keinen Einfluss auf die Farben...
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #7445
            @teletapi
            Da dürfte das Problem liegen... Das Skript braucht einen info-Alias... keinen switch.mode.wlan
            ist es dann wohl auch nicht: bei mir auch
            • T Nicht stören
              T Nicht stören
              ticaki
              #7446
              Sonderzeichen im Passwort?
              Spenden
              • T ticaki
                teletapiT Online
                teletapiT Online
                teletapi
                #7447
                @ticaki ja ein Sonderzeichen, aber auch das hat vorher funktioniert. Ich kann auch das Wlan mit dem kleinen blauen Schalter deaktivieren und wieder aktivieren das geht alles
                  teletapiT Online
                  teletapiT Online
                  teletapi
                  #7448
                  Was könnte ich jetzt mal versuchen hatte gerade nochmal das aktuelle script runter geladen und meine Seiten und einstellungen angepasst aber auch das hat nix gebraucht.
                  Ich bin drauf und drann alle Daten zu löschen und bei 0 anzufangen sprich alle .Userdata.0 Ordner und Aliase zu löschen aber ich hab jetzt gerade mal echt keine Ahnung was ich machen kann..
                  teletapiT T 2 Antworten Letzte Antwort
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    #7449
                    Ist vielleicht hier noch was falsch im script:
                    let Programmseite: PageType =
                        'type': 'cardGrid2',
                        'heading': 'Programmseite',
                        'useColor': true,
                        'items': [
                            { navigate: true, id: 'alias.0.NSPanel.allgemein.Abfall.event1', targetPage: 'Abfall', name: 'Abfall'}, //Schauen ob die farbe von "Abfall" sich ändert ansonsten .event1 wegmachen
                            { navigate: true, id: null, targetPage: 'GuestWifi', onColor: MSGreen, name: 'Gäste WLAN'},
                    let GuestWifi: PageType =
                        'type': "cardQR",
                        'heading': "Gäste Wlan",
                        'subPage': true,
                        'parent': Programmseite,
                        'items': [
                            { id: 'alias.0.NSPanel.Guest_Wifi',
                                   hidePassword: true, // true = Switch; false = Password
                                   hideEntity2: false,   // true = Switch or Password is Hide
                                   autoCreateALias: true}
                      TT-Tom
                      #7450
                      @teletapi
                      nur als test, nutze mal als SSID und Passwort "test", sprich im 0_userdata so
                      WIFI:T:WPA;S:test;P:test;H:;
                      Gruß Tom
                      https://github.com/tt-tom17
                      NSPanel Script Wiki
                      NSPanel Adapter Wiki
                      • T TT-Tom
                        @teletapi
                        teletapiT Online
                        teletapiT Online
                        teletapi
                        #7451
                        @tt-tom ja geht damit
                          TT-Tom
                          #7452
                          @teletapi
                          nutze mal deine Daten und schalte den switch aus
                          EDIT: welche Sonderzeichen hast du im Password. Du kannst nicht alle nutzen.
                          Gruß Tom
                          NSPanel Script Wiki
                          • T TT-Tom
                            @teletapi
                            teletapiT Online
                            teletapiT Online
                            teletapi
                            #7453
                            @tt-tom Oh man.... hab jetzt den gastzugang geändert kürzer und das Sonderzeichen aus dem Passwort und durch Buchstaben ersetzt und in die Daten vom 0.Userdata.0 eigetragen und geht wieder . Ich bin euch sehr dankbar für eure Hilfe. Wo soll der Kaffee hin..?
                              TT-Tom
                              #7454
                              @teletapi ich glaube es liegt an dem Sonderzeichen in deinem Password.
                              folgende dürfen nicht sein, ~ ; , ? :
                              Gruß Tom
                              NSPanel Script Wiki
                              • T TT-Tom
                                teletapiT Online
                                teletapiT Online
                                teletapi
                                #7455
                                @tt-tom diese Sonderzeichen hatte ich nicht drin da war ne "Raute" hatte aber bis dato funktioniert
                                T ArmilarA 2 Antworten Letzte Antwort
                                  TT-Tom
                                  #7456
                                  @teletapi
                                  okay wir werden das mal prüfen, danke für die Mitarbeit
                                  Gruß Tom
                                  NSPanel Script Wiki
                                  • T TT-Tom
                                    @teletapi
                                    teletapiT Online
                                    teletapiT Online
                                    teletapi
                                    #7457
                                    @tt-tom ich hab zu danken
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #7458
                                      @teletapi
                                      war irgendwas zumindest was im Skript bereits eine Unverträglichkeit beim Slice() hatte... War hinten wahrscheinlich nur Objektmüll drin... :+1:
                                      • B Bhenyamin
                                        @armilar
                                        @bhenyamin
                                        Bin mir nicht sicher ob das bei dir mir der TFT 4.9.4 geklappt hat... Genau da lag die Änderung, dass der den aktuellen >Sliderwert wieder zuordnet...
                                        Am Besten nochmal mit der v4.9.4 flashen.
                                        Also ich habe die 4.9.4 nochmal geflasht (was 5 Versuche brauchte, da jedes mal bei knapp über 80 % ein System Data Error kam) aber geändert hat es nichts.
                                        Meinst Du sicher die 4.9.4?
                                        Bhenyamin
                                        #7459
                                        @bhenyamin said in SONOFF NSPanel mit Lovelace UI:
                                        @armilar
                                        @bhenyamin
                                        Darf ich hier nochmal Pingen?
                                        Hast du noch einen Lösungsansatz für mich? Ich bekomme den Slider weiter nicht auf Spur. Er springt weiter...
                                        • B Bhenyamin
                                          @armilar
                                          @bhenyamin
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #7460
                                          @bhenyamin
                                          natürlich und jederzeit... dafür ist der Thread ja da :blush:
                                          Ich dachte nach der Konversation mit @TT-Tom (ACTUAL/SET) wäre das erledigt.
                                          Und genau das kann ich nicht reproduzieren. Der Slider arbeitet auf den Punkt exakt und kommt auch wieder nach einem Seitenwechsel zum eingestellten Wert zurück...
                                          EDIT: siehe
                                          EDIT2: was du nochmal machen könntest, wäre in der Tasmota Konsole "weblog 3" eingeben und den Part (Tasmota Log) mit dem Sliderspiel mal senden...
                                          ArmilarA B 2 Antworten Letzte Antwort
                                          32.6k
                                          82.1k
