  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • G Offline
    Gre4t0ne
    #6441
    Danke!
    Das hat schon mal die Errors eliminiert - habe auch diese Syntax Änderungen durchgeführt...
    ein paar Warnings habe ich noch:
    javascript.0
    2024-09-21 12:58:59.906	warn	at runNextTicks (node:internal/process/task_queues:60:5)
    javascript.0
    2024-09-21 12:58:59.906	warn	at fulfilled (script.js.NSPanel_v4_4_0_5:5:58)
    javascript.0
    2024-09-21 12:58:59.906	warn	at Object.next (script.js.NSPanel_v4_4_0_5:14:53)
    javascript.0
    2024-09-21 12:58:59.905	warn	at step (script.js.NSPanel_v4_4_0_5:33:23)
    javascript.0
    2024-09-21 12:58:59.905	warn	at script.js.NSPanel_v4_4_0_5:4106:50
    javascript.0
    2024-09-21 12:58:59.904	warn	at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20)
    javascript.0
    2024-09-21 12:58:59.903	warn	at new Promise (<anonymous>)
    javascript.0
    2024-09-21 12:58:59.903	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17
    javascript.0
    2024-09-21 12:58:59.902	warn	You are assigning a string to the state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    javascript.0
    2024-09-21 12:58:59.896	warn	at runNextTicks (node:internal/process/task_queues:60:5)
    javascript.0
    2024-09-21 12:58:59.895	warn	at fulfilled (script.js.NSPanel_v4_4_0_5:5:58)
    javascript.0
    2024-09-21 12:58:59.895	warn	at Object.next (script.js.NSPanel_v4_4_0_5:14:53)
    javascript.0
    2024-09-21 12:58:59.895	warn	at step (script.js.NSPanel_v4_4_0_5:33:23)
    javascript.0
    2024-09-21 12:58:59.894	warn	at script.js.NSPanel_v4_4_0_5:4106:50
    javascript.0
    2024-09-21 12:58:59.894	warn	at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20)
    javascript.0
    2024-09-21 12:58:59.894	warn	at new Promise (<anonymous>)
    javascript.0
    2024-09-21 12:58:59.893	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17
    javascript.0
    2024-09-21 12:58:59.891	warn	You are assigning a string to the state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    • G Gre4t0ne
      Danke!
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      TT-Tom
      #6442
      @gre4t0ne
      Das kann an den alten Ordnereigenschaften liegen. Lösche mal den Ordner Berry….. wird automatisch neu wieder angelegt.
      Gruß Tom
      https://github.com/tt-tom17
      NSPanel Script Wiki
      NSPanel Adapter Wiki
      G 1 Antwort Letzte Antwort
      • T TT-Tom
        @gre4t0ne
        Gre4t0ne
        #6443
        @tt-tom über die Admin Seite?
        Ist das der Berry_Driver folder (wo currentversion & online Version drinnen ist) und der bei 0_userdata liegt?
        • G Gre4t0ne
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #6444
          @gre4t0ne
          Ja - den:
          • G Offline
            Gre4t0ne
            #6445
            Ganzer Objektbaum oder nur das Objekt / sry habe Angst :joy:
            • G Gre4t0ne
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #6446
              @gre4t0ne
              Ganzer Objektbaum
              GregorSG 1 Antwort Letzte Antwort
              • ArmilarA Armilar
                @gre4t0ne
                Ganzer Objektbaum
                GregorSG Offline
                GregorSG Offline
                GregorS
                #6447
                Kann ich in einer cardGrid mit dem Icon "Power" ein Objekt (boole) in 0_userdata von
                false in true umschalten?
                Ich hätte gerne eine Seite um alle Verbarucher auszuschalten (Zentral-Aus) bzw. Zentral-Ein und alle Rolläden öffnen
                oder schließen.
                Das soll alles über einen Button passieren.
                Die entsprechenden Objekte habe ich in meinen Bloclys schon implementiert.
                Nur schaffe ich es nicht per Button umzuschalten.
                Vielen Dank
                INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
                • G Offline
                  Gre4t0ne
                  schrieb am zuletzt editiert von Gre4t0ne
                  #6448
                  Jetzt noch folgendes wiederkehrendes Warning imProtokoll:
                  HandleScreensaverUopdate: parseFormat ist not a function
                  Wenn ich im Skript Debugge dann kommen noch die tausende Warnings (habe jetzt einen großen Mittelteil davon rausgelöscht wg. der Länge):
                  21.9.2024, 19:04:55.273	[info ]: javascript.0 (2118) Stopping script script.js.NSPanel_v4_4_0_5
                  21.9.2024, 19:04:56.381	[info ]: javascript.0 (2118) Compiling TypeScript source script.js.NSPanel_v4_4_0_5
                  21.9.2024, 19:04:57.919	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: source code did not change, using cached compilation result...
                  21.9.2024, 19:04:58.215	[error]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: Error: Cannot find module '@iobroker-javascript.0/moment-parseformat'
                  21.9.2024, 19:04:58.217	[error]: javascript.0 (2118)     at script.js.NSPanel_v4_4_0_5:1176:19
                  21.9.2024, 19:04:58.246	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.JavaScriptVersion, state={"val":"v8.7.6","ack":true,"ts":1726938298246,"q":0,"from":"system.adapter.javascript.0","lc":1726914394966,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.247	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.ScriptName, state={"val":"NSPanel_v4_4_0_5","ack":true,"ts":1726938298247,"q":0,"from":"system.adapter.javascript.0","lc":1726914553446,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.250	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.JavaScriptVersion, state={"val":"v8.7.6","ack":true,"ts":1726938298250,"q":0,"from":"system.adapter.javascript.0","lc":1726914394966,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.251	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.ScriptName, state={"val":"NSPanel_v4_4_0_5","ack":true,"ts":1726938298251,"q":0,"from":"system.adapter.javascript.0","lc":1726914553446,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.276	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.NodeJSVersion, state={"val":"v18.17.1","ack":true,"ts":1726938298276,"q":0,"from":"system.adapter.javascript.0","lc":1726914394488,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.280	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObjects enabled - create Alias Channels possible
                  21.9.2024, 19:04:58.284	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.desiredVersion, state={"val":53,"ack":true,"ts":1726938298284,"q":0,"from":"system.adapter.javascript.0","lc":1695149197638,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.288	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: extendObject(id=0_userdata.0.NSPanel.1.ScreensaverInfo.bgColorIndicator, obj={"_id":"","type":"state","common":{"type":"number","name":"Color Indicator","role":"level","states":{"0":"black","1":"red","2":"green","3":"attention","4":"pink","5":"dark red"},"read":true,"write":true},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.292	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.activeBrightness, obj={"type":"channel","common":{"role":"slider","name":"activeBrightness"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.295	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Relay.1, obj={"type":"channel","common":{"role":"socket","name":"Relay.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.296	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.MRIcons.alternateMRIconSize.1, obj={"type":"channel","common":{"role":"socket","name":"alternateMRIconSize.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.300	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: weather alias for accuweather.0. already exists
                  21.9.2024, 19:04:58.303	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.weatherForecast, obj={"type":"channel","common":{"role":"socket","name":"weatherForecast"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.306	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"dimmode~8~100","ack":false,"ts":1726938298306,"q":0,"from":"system.adapter.javascript.0","lc":1726938298306,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.307	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1726938298307,"q":0,"from":"system.adapter.javascript.0","lc":1726938298307,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.327	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1726938298327,"q":0,"from":"system.adapter.javascript.0","lc":1726938298327,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.332	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: No Updates for NSPanel available
                  21.9.2024, 19:04:58.333	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: registered 40 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  21.9.2024, 19:04:58.336	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Consumtion.MeanPower, state={"val":1.24,"ack":true,"ts":1726938298336,"q":0,"from":"system.adapter.javascript.0","lc":1726935715855,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.338	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1726938298338,"q":0,"from":"system.adapter.javascript.0","lc":1726938298338,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.340	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"time~19:04","ack":false,"ts":1726938298340,"q":0,"from":"system.adapter.javascript.0","lc":1726938298340,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.346	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"date~Samstag, 21. September 2024","ack":false,"ts":1726938298346,"q":0,"from":"system.adapter.javascript.0","lc":1726938298346,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.346	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1726938298346,"q":0,"from":"system.adapter.javascript.0","lc":1726938298346,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.349	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: No Updates for NSPanel available
                  21.9.2024, 19:04:58.357	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Config.Update.activ, state={"val":0,"ack":true,"ts":1726938298357,"q":0,"from":"system.adapter.javascript.0","lc":1695155409634,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.377	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: Desired TFT Firmware: 53 / v4.4.0
                  21.9.2024, 19:04:58.377	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: Installed TFT Firmware: 53 / v4.4.0
                  21.9.2024, 19:04:58.377	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.currentVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1726938298377,"q":0,"from":"system.adapter.javascript.0","lc":1726914394050,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.382	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.desiredVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1726938298382,"q":0,"from":"system.adapter.javascript.0","lc":1726914394141,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.384	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.IoBroker.ScriptVersion, obj={"type":"channel","common":{"role":"info","name":"Version NSPanelTS"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.384	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.ScripgtDebugStatus, obj={"type":"channel","common":{"role":"socket","name":"ScripgtDebugStatus"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.385	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.MQTT.portCheck, obj={"type":"channel","common":{"role":"socket","name":"mqttPortCheck"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.386	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Screensaver.alternativeScreensaverLayout, obj={"type":"channel","common":{"role":"socket","name":"alternativeScreensaverLayout"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.387	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Update.UpdateMessage, obj={"type":"channel","common":{"role":"socket","name":"UpdateMesssage"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.388	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Update.UpdateMessage, obj={"type":"channel","common":{"role":"socket","name":"UpdateMesssage"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.543	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.IoBroker.NodeJSVersion, obj={"type":"channel","common":{"role":"info","name":"Version NodeJS"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.694	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Relay.2, obj={"type":"channel","common":{"role":"socket","name":"Relay.2"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.694	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.MRIcons.alternateMRIconSize.2, obj={"type":"channel","common":{"role":"socket","name":"alternateMRIconSize.2"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.697	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.weatherForecastTimer, obj={"type":"channel","common":{"role":"socket","name":"weatherForecastTimer"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.698	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: Debug mode disabled
                  21.9.2024, 19:04:58.700	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: Command iob l i --port --enabled was not executed, while debug mode is active
                  21.9.2024, 19:04:58.712	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Screensaver.ScreensaverAdvanced, obj={"type":"channel","common":{"role":"socket","name":"ScreensaverAdvanced"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.713	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.autoUpdate, obj={"type":"channel","common":{"role":"socket","name":"AutoUpdate"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.715	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.IoBroker.JavaScriptVersion, obj={"type":"channel","common":{"role":"info","name":"Version JavaScript Instanz"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.743	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota_Firmware.currentVersion, state={"val":"14.2.0","ack":true,"ts":1726938298743,"q":0,"from":"system.adapter.javascript.0","lc":1723984878935,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.757	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Uptime, state={"val":"6T04:32:00","ack":true,"ts":1726938298757,"q":0,"from":"system.adapter.javascript.0","lc":1726938298757,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.761	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.NSPanel_locales_json, state={"val":"{\"lights\":{\"Brightness\":{\"en-US\":\"Brightness\",\"de-DE\":\"Helligkeit\",\"nl-NL\":\"Helderheid\",\"da-DK\":\"Lysstyrke\",\"es-ES\":\"Brillo\",\"fr-FR\":\"Luminosité\",\"it-IT\":\"Luminosità\",\"ru-RU\":\"Яркость\",\"nb-NO\":\"Lysstyrke\",\"nn-NO\":\"Lysstyrke\",\"pl-PL\":\"Jasność\",\"pt-PT\":\"Brilho\",\"af-ZA\":\"Helderheid\",\"ar-SY\":\"السطوع\",\"bg-BG\":\"Яркост\",\"ca-ES\":\"Brillantor\",\"cs-CZ\":\"Jas\",\"el-GR\":\"Φωτεινότητα\",\"et-EE\":\"Heledus\",\"fa-IR\":\"روشنایی\",\"fi-FI\":\"Kirkkaus\",\"he-IL\":\"בהירות\",\"hr-xx\":\"Svjetlina\",\"hu-HU\":\"Fényerő\",\"hy-AM\":\"Պայծառություն\",\"id-ID\":\"Kecerahan\",\"is-IS\":\"Birtustig\",\"lb-xx\":\"Hellegkeet\",\"lt-LT\":\"Ryškumas\",\"ro-RO\":\"Luminozitate\",\"sk-SK\":\"Jas\",\"sl-SI\":\"Svetlost\",\"sv-SE\":\"Ljusstyrka\",\"th-TH\":\"ความสว่าง\",\"tr-TR\":\"Parlaklık\",\"uk-UA\":\"Яскравість\",\"vi-VN\":\"Độ sáng\",\"zh-CN\":\"亮度\",\"zh-TW\":\"亮度\"},\"Temperature\":{\"en-US\":\"Color temperature\",\"de-DE\":\"Farbtemperatur\",\"nl-NL\":\"Kleurtemperatuur\",\"da-DK\":\"Farvetemperatur\",\"es-ES\":\"Temperatura del color\",\"fr-FR\":\"Température de couleur\",\"it-IT\":\"Temperatura colore\",\"ru-RU\":\"Цветовая температура\",\"nb-NO\":\"Fargetemperatur\",\"nn-NO\":\"Fargetemperatur\",\"pl-PL\":\"Temperatura barwy\",\"pt-PT\":\"Temperatura de cor\",\"af-ZA\":\"Kleur temperatuur\",\"ar-SY\":\"درجة حرارة اللون\",\"bg-BG\":\"Цветова температура\",\"ca-ES\":\"Temperatura de color\",\"cs-CZ\":\"Teplota barvy\",\"el-GR\":\"Θερμοκρασία χρώματος\",\"et-EE\":\"Värvustemperatuur\",\"fa-IR\":\"دمای رنگ\",\"fi-FI\":\"Värilämpötila\",\"he-IL\":\"טמפרטורת הצבע\",\"hr-xx\":\"Temperatura boje\",\"hu-HU\":\"Színhőmérséklet\",\"hy-AM\":\"Գունային ջերմաստիճան\",\"id-ID\":\"Temperatur warna\",\"is-IS\":\"Litastig\",\"lb-xx\":\"Faarf Temperatur\",\"lt-LT\":\"Spalvos temperatūra\",\"ro-RO\":\"Temperatură de culoare\",\"sk-SK\":\"Teplota farby\",\"sl-SI\":\"Temperatura barve\",\"sv-SE\":\"Färgtemperatur\",\"th-TH\":\"อุณหภูมิสี\",\"tr-TR\":\"Renk sıcaklığı\",\"uk-UA\":\"Кольорова температура\",\"vi-VN\":\"Nhiệt độ màu\",\"zh-CN\":\"色温\",\"zh-TW\":\"色溫\"}},\"window\":{\"closed\":{\"en-US\":\"Closed\",\"de-DE\":\"Geschlossen\",\"nl-NL\":\"Dicht\",\"da-DK\":\"Lukket\",\"es-ES\":\"Cerrada\",\"fr-FR\":\"Fermée\",\"it-IT\":\"Chiusa\",\"ru-RU\":\"Закрыто\",\"nb-NO\":\"Lukket\",\"nn-NO\":\"Lukka\",\"pl-PL\":\"zamknięte\",\"pt-PT\":\"Fechada\",\"af-ZA\":\"Toe\",\"ar-SY\":\"مغلق\",\"bg-BG\":\"Затворен\",\"ca-ES\":\"Tancada\",\"cs-CZ\":\"Zavřeno\",\"el-GR\":\"Κλειστό\",\"et-EE\":\"Suletud\",\"fa-IR\":\"بسته\",\"fi-FI\":\"Suljettu\",\"he-IL\":\"סגור\",\"hr-xx\":\"Zatvoreno\",\"hu-HU\":\"Zárva\",\"hy-AM\":\"Փակված է\",\"id-ID\":\"Tertutup\",\"is-IS\":\"Loka\",\"lb-xx\":\"Zou\",\"lt-LT\":\"Uždaryta\",\"ro-RO\":\"Închis\",\"sk-SK\":\"Zatvorené\",\"sl-SI\":\"Zaprto\",\"sv-SE\":\"Stängt\",\"th-TH\":\"ปิดแล้ว\",\"tr-TR\":\"Kapalı\",\"uk-UA\":\"Зачинене\",\"vi-VN\":\"Đóng\",\"zh-CN\":\"关闭\",\"zh-TW\":\"關閉\"},\"opened\":{\"en-US\":\"Open\",\"de-DE\":\"Offen\",\"nl-NL\":\"Open\",\"da-DK\":\"Åben\",\"es-ES\":\"Abierta\",\"fr-FR\":\"Ouverte\",\"it-IT\":\"Aperta\",\"ru-RU\":\"Открыто\",\"nb-NO\":\"Åpent\",\"nn-NO\":\"Open\",\"pl-PL\":\"otwarte\",\"pt-PT\":\"Aberta\",\"af-ZA\":\"Oop\",\"ar-SY\":\"مفتوح\",\"bg-BG\":\"Отворен\",\"ca-ES\":\"Oberta\",\"cs-CZ\":\"Otevřeno\",\"el-GR\":\"Ανοιχτό\",\"et-EE\":\"Avatud\",\"fa-IR\":\"باز\",\"fi-FI\":\"Auki\",\"he-IL\":\"פתוח\",\"hr-xx\":\"Otvoreno\",\"hu-HU\":\"Nyitva\",\"hy-AM\":\"Բացել\",\"id-ID\":\"Terbuka\",\"is-IS\":\"Opna\",\"lb-xx\":\"Op\",\"lt-LT\":\"Atidaryta\",\"ro-RO\":\"Deschis\",\"sk-SK\":\"Otvorené\",\"sl-SI\":\"Odprto\",\"sv-SE\":\"Öppet\",\"th-TH\":\"เปิด\",\"tr-TR\":\"Açık\",\"uk-UA\":\"Відчинене\",\"vi-VN\":\"Mở\",\"zh-CN\":\"开启\",\"zh-TW\":\"開啟\"}},\"door\":{\"closed\":{\"en-US\":\"Closed\",\"de-DE\":\"Geschlossen\",\"nl-NL\":\"Dicht\",\"da-DK\":\"Lukket\",\"es-ES\":\"Cerrada\",\"fr-FR\":\"Fermée\",\"it-IT\":\"Chiusa\",\"ru-RU\":\"Закрыта\",\"nb-NO\":\"Lukket\",\"nn-NO\":\"Lukka\",\"pl-PL\":\"zamknięte\",\"pt-PT\":\"Fechada\",\"af-ZA\":\"Toe\",\"ar-SY\":\"مغلق\",\"bg-BG\":\"Затворена\",\"ca-ES\":\"Tancada\",\"cs-CZ\":\"Zavřeno\",\"el-GR\":\"Κλειστή\",\"et-EE\":\"Suletud\",\"fa-IR\":\"بسته\",\"fi-FI\":\"Suljettu\",\"he-IL\":\"סגורה\",\"hr-xx\":\"Zatvoreno\",\"hu-HU\":\"Zárva\",\"hy-AM\":\"Փակված է\",\"id-ID\":\"Tertutup\",\"is-IS\":\"Lokuð\",\"lb-xx\":\"Zou\",\"lt-LT\":\"Uždaryta\",\"ro-RO\":\"Închis\",\"sk-SK\":\"Zatvorené\",\"sl-SI\":\"Zaprto\",\"sv-SE\":\"Stängd\",\"th-TH\":\"ปิดแล้ว\",\"tr-TR\":\"Kapalı\",\"uk-UA\":\"Зачинені\",\"vi-VN\":\"Đóng\",\"zh-CN\":\"关闭\",\"zh-TW\":\"已關閉\"},\"opened\":{\"en-US\":\"Open\",\"de-DE\":\"Offen\",\"nl-NL\":\"Open\",\"da-DK\":\"Åben\",\"es-ES\":\"Abierta\",\"fr-FR\":\"Ouverte\",\"it-IT\":\"Aperta\",\"ru-RU\":\"Открыта\",\"nb-NO\":\"Åpen\",\"nn-NO\":\"Open\",\"pl-PL\":\"otwarte\",\"pt-PT\":\"Aberta\",\"af-ZA\":\"Oop\",\"ar-SY\":\"مفتوح\",\"bg-BG\":\"Отворена\",\"ca-ES\":\"Oberta\",\"cs-CZ\":\"Otevřeno\",\"el-GR\":\"Ανοιχτή\",\"et-EE\":\"Avatud\",\"fa-IR\":\"باز\",\"fi-FI\":\"Auki\",\"he-IL\":\"פתוחה\",\"hr-xx\":\"Otvori\",\"hu-HU\":\"Nyitva\",\"hy-AM\":\"Բացել\",\"id-ID\":\"Terbuka\",\"is-IS\":\"Opin\",\"lb-xx\":\"Op\",\"lt-LT\":\"Atidaryta\",\"ro-RO\":\"Deschis\",\"sk-SK\":\"Otvorené\",\"sl-SI\":\"Odprto\",\"sv-SE\":\"Öppen\",\"th-TH\":\"เปิด\",\"tr-TR\":\"Açık\",\"uk-UA\":\"Відчинені\",\"vi-VN\":\"Mở\",\"zh-CN\":\"开启\",\"zh-TW\":\"已開啟\"}},\"lock\":{\"LOCK\":{\"en-US\":\"Lock\",\"de-DE\":\"Verriegeln\",\"nl-NL\":\"Vergrendelen\",\"da-DK\":\"Lås\",\"es-ES\":\"Bloquear\",\"fr-FR\":\"Verrouiller\",\"it-IT\":\"Blocca\",\"ru-RU\":\"Закрыть\",\"nb-NO\":\"Lås\",\"nn-NO\":\"Lås\",\"pl-PL\":\"Zablokuj\",\"pt-PT\":\"Bloquear\",\"af-ZA\":\"Sluit toe\",\"ar-SY\":\"قفل\",\"bg-BG\":\"Заключване\",\"ca-ES\":\"Bloquejar\",\"cs-CZ\":\"Zamknout\",\"el-GR\":\"Κλείδωμα\",\"et-EE\":\"Lukusta\",\"fa-IR\":\"قفل\",\"fi-FI\":\"Lukitse\",\"he-IL\":\"נעילה\",\"hr-xx\":\"zaključati\",\"hu-HU\":\"Bezár\",\"hy-AM\":\"Կողպեք\",\"id-ID\":\"Kunci\",\"is-IS\":\"Læsa\",\"lb-xx\":\"Spären\",\"lt-LT\":\"Užrakinti\",\"ro-RO\":\"Blocat\",\"sk-SK\":\"Zamknúť\",\"sl-SI\":\"Zakleni\",\"sv-SE\":\"Lås\",\"th-TH\":\"ล็อค\",\"tr-TR\":\"Kilitle\",\"uk-UA\":\"Блокувати\",\"vi-VN\":\"Khóa\",\"zh-CN\":\"锁定\",\"zh-TW\":\"上鎖\"},\"UNLOCK\":{\"en-US\":\"Unlock\",\"de-DE\":\"Entriegeln\",\"nl-NL\":\"Ontgrendelen\",\"da-DK\":\"Lås op\",\"es-ES\":\"Desbloquear\",\"fr-FR\":\"Déverrouiller\",\"it-IT\":\"Sblocca\",\"ru-RU\":\"Открыть\",\"nb-NO\":\"Lås opp\",\"nn-NO\":\"Lås opp\",\"pl-PL\":\"Odblokuj\",\"pt-PT\":\"Desbloquear\",\"af-ZA\":\"Sluit oop\",\"ar-SY\":\"فتح\",\"bg-BG\":\"Отключване\",\"ca-ES\":\"Desbloquejar\",\"cs-CZ\":\"Odemknout\",\"el-GR\":\"Ξεκλείδωμα\",\"et-EE\":\"Ava\",\"fa-IR\":\"باز کردن\",\"fi-FI\":\"Avaa lukitus\",\"he-IL\":\"ביטול נעילה\",\"hr-xx\":\"Otključati\",\"hu-HU\":\"Kinyit\",\"hy-AM\":\"Բացել\",\"id-ID\":\"Buka\",\"is-IS\":\"Aflæsa\",\"lb-xx\":\"Entspären\",\"lt-LT\":\"Atrakinti\",\"ro-RO\":\"Deblocare\",\"sk-SK\":\"Odomknúť\",\"sl-SI\":\"Odkleni\",\"sv-SE\":\"Lås upp\",\"th-TH\":\"ปลดล็อค\",\"tr-TR\":\"Kilidi aç\",\"uk-UA\":\"Розблокувати\",\"vi-VN\":\"Mở khóa\",\"zh-CN\":\"解锁\",\"zh-TW\":\"解鎖\"}},\"blinds\":{\"Position\":{\"en-US\":\"Position\",\"de-DE\":\"Position\",\"nl-NL\":\"Positie\",\"da-DK\":\"Position\",\"es-ES\":\"Posición\",\"fr-FR\":\"Position\",\"it-IT\":\"Apertura\",\"ru-RU\":\"Положение\",\"nb-NO\":\"Posisjon\",\"nn-NO\":\"Posisjon\",\"pl-PL\":\"Pozycja\",\"pt-PT\":\"Posição\",\"af-ZA\":\"Posisie\",\"ar-SY\":\"موضع\",\"bg-BG\":\"Позиция\",\"ca-ES\":\"Posició\",\"cs-CZ\":\"Pozice\",\"el-GR\":\"Θέση\",\"et-EE\":\"Asend\",\"fa-IR\":\"موقعیت\",\"fi-FI\":\"Sijainti\",\"he-IL\":\"מיקום\",\"hr-xx\":\"Pozicija\",\"hu-HU\":\"Pozíció\",\"hy-AM\":\"Դիրք\",\"id-ID\":\"Posisi\",\"is-IS\":\"Staðsetning\",\"lb-xx\":\"Positioun\",\"lt-LT\":\"Padėtis\",\"ro-RO\":\"Poziţie\",\"sk-SK\":\"Poloha\",\"sl-SI\":\"Položaj\",\"sv-SE\":\"Position\",\"th-TH\":\"ตำแหน่ง\",\"tr-TR\":\"Pozisyon\",\"uk-UA\":\"Положення\",\"vi-VN\":\"Vị trí\",\"zh-CN\":\"位置\",\"zh-TW\":\"位置\"},\"tilt_position\":{\"en-US\":\"Tilt position\",\"de-DE\":\"Kippstellung\",\"nl-NL\":\"Kantelpositie\",\"da-DK\":\"Vippeposition\",\"es-ES\":\"Posición inclinada\",\"fr-FR\":\"Inclinaison\",\"it-IT\":\"Inclinazione\",\"ru-RU\":\"Наклон\",\"nb-NO\":\"Vend posisjon\",\"nn-NO\":\"Tiltposisjon\",\"pl-PL\":\"Pochylenie\",\"pt-PT\":\"Posição de inclinação\",\"af-ZA\":\"Kantel posisie\",\"ar-SY\":\"وضع الإمالة\",\"bg-BG\":\"Наклон\",\"ca-ES\":\"Inclinació\",\"cs-CZ\":\"Náklon\",\"el-GR\":\"Θέση ανάκλισης\",\"et-EE\":\"Kalde asend\",\"fa-IR\":\"موقعیت شیب\",\"fi-FI\":\"Kallistus\",\"he-IL\":\"הטיה\",\"hr-xx\":\"Položaj nagiba\",\"hu-HU\":\"Döntési pozíció\",\"hy-AM\":\"Դիրքի թեքությունը\",\"id-ID\":\"Posisi kemiringan\",\"is-IS\":\"Hallastaða\",\"lb-xx\":\"Kippestellung\",\"lt-LT\":\"Pakreipimo padėtis\",\"ro-RO\":\"Poziție de înclinare\",\"sk-SK\":\"Poloha sklonu\",\"sl-SI\":\"Položaj nagiba\",\"sv-SE\":\"Tilt position\",\"th-TH\":\"ตำแหน่งการเอียง\",\"tr-TR\":\"Tilt pozisyonu\",\"uk-UA\":\"Положення нахилу\",\"vi-VN\":\"Nghiêng vị trí\",\"zh-CN\":\"倾斜位置\",\"zh-TW\":\"葉片位置\"}},\"thermostat\":{\"Currently\":{\"en-US\":\"Currently\",\"de-DE\":\"Aktuell\",\"nl-NL\":\"Momenteel\",\"da-DK\":\"Aktuelt\",\"es-ES\":\"Actualmente\",\"fr-FR\":\"Actuellement\",\"it-IT\":\"Attualmente\",\"ru-RU\":\"Сейчас\",\"nb-NO\":\"Er nå\",\"nn-NO\":\"Akkurat no\",\"pl-PL\":\"Obecnie\",\"pt-PT\":\"Atualmente\",\"af-ZA\":\"Tans\",\"ar-SY\":\"حاليا\",\"bg-BG\":\"В момента\",\"ca-ES\":\"Actual\",\"cs-CZ\":\"Aktuálně\",\"el-GR\":\"Αυτή τη στιγμή\",\"et-EE\":\"Hetkel\",\"fa-IR\":\"در حال حاضر\",\"fi-FI\":\"Tällä hetkellä\",\"he-IL\":\"כעת\",\"hr-xx\":\"Trenutno\",\"hu-HU\":\"Jelenleg\",\"hy-AM\":\"Ներկայումս\",\"id-ID\":\"Saat ini\",\"is-IS\":\"Er núna\",\"lb-xx\":\"Momentan\",\"lt-LT\":\"Šiuo metu\",\"ro-RO\":\"În prezent\",\"sk-SK\":\"Aktuálne\",\"sl-SI\":\"Trenutno\",\"sv-SE\":\"Nuvarande\",\"th-TH\":\"ในขณะนี้\",\"tr-TR\":\"Şu an\",\"uk-UA\":\"В даний час\",\"vi-VN\":\"Hiện tại\",\"zh-CN\":\"当前\",\"zh-TW\":\"目前狀態\"},\"State\":{\"en-US\":\"State\",\"de-DE\":\"Zustand\",\"nl-NL\":\"Toestand\",\"da-DK\":\"Tilstand\",\"es-ES\":\"Estado\",\"fr-FR\":\"État\",\"it-IT\":\"Stato\",\"ru-RU\":\"Состояние\",\"nb-NO\":\"Tilstand\",\"nn-NO\":\"Tilstand\",\"pl-PL\":\"Stan\",\"pt-PT\":\"Estado\",\"af-ZA\":\"\",\"ar-SY\":\"\",\"bg-BG\":\"\",\"ca-ES\":\"Estat\",\"cs-CZ\":\"Stav\",\"el-GR\":\"Κατάσταση\",\"et-EE\":\"Olek\",\"fa-IR\":\"\",\"fi-FI\":\"Tila\",\"he-IL\":\"מצב\",\"hr-xx\":\"\",\"hu-HU\":\"Állapot\",\"hy-AM\":\"\",\"id-ID\":\"Status\",\"is-IS\":\"Staða\",\"lb-xx\":\"\",\"lt-LT\":\"\",\"ro-RO\":\"\",\"sk-SK\":\"Stav\",\"sl-SI\":\"Stanje\",\"sv-SE\":\"Tillstånd\",\"th-TH\":\"สถานะ\",\"tr-TR\":\"Durum\",\"uk-UA\":\"Стан\",\"vi-VN\":\"\",\"zh-CN\":\"状态\",\"zh-TW\":\"狀態\"},\"Action\":{\"en-US\":\"Operation\",\"de-DE\":\"Aktion\",\"nl-NL\":\"Werking\",\"da-DK\":\"Drifttype\",\"es-ES\":\"Modo\",\"fr-FR\":\"Opération\",\"it-IT\":\"Operazione\",\"ru-RU\":\"Режим работы\",\"nb-NO\":\"Operasjon\",\"nn-NO\":\"Operasjon\",\"pl-PL\":\"Tryb pracy\",\"pt-PT\":\"Operação\",\"af-ZA\":\"Operasie\",\"ar-SY\":\"الوضع\",\"bg-BG\":\"Режим\",\"ca-ES\":\"Funcionament\",\"cs-CZ\":\"Provoz\",\"el-GR\":\"Λειτουργία\",\"et-EE\":\"Töörežiim\",\"fa-IR\":\"عملیات\",\"fi-FI\":\"Toiminto\",\"he-IL\":\"פעולה\",\"hr-xx\":\"operacija\",\"hu-HU\":\"Működés\",\"hy-AM\":\"Գործողություն\",\"id-ID\":\"Operasi\",\"is-IS\":\"Aðgerð\",\"lb-xx\":\"Aktioun\",\"lt-LT\":\"Operacija\",\"ro-RO\":\"Operație\",\"sk-SK\":\"Prevádzka\",\"sl-SI\":\"Delovanje\",\"sv-SE\":\"Driftläge\",\"th-TH\":\"การทำงาน\",\"tr-.
                  ang tersedia\",\"is-IS\":\"Laus útgáfa\",\"lb-xx\":\"Verfügbar Versioun\",\"lt-LT\":\"Galima versija\",\"ro-RO\":\"Versiune disponibilă\",\"sk-SK\":\"Dostupná verzia\",\"sl-SI\":\"Razpoložljiva različica\",\"sv-SE\":\"Tillgänglig version\",\"th-TH\":\"รุ่นที่มีจำหน่าย\",\"tr-TR\":\"Mevcut sürüm\",\"uk-UA\":\"Доступна версія\",\"vi-VN\":\"Phiên bản có sẵn\",\"zh-CN\":\"可用版本\",\"zh-TW\":\"可用版本\"},\"update_tasmota\":{\"en-US\":\"Update Tasmota\",\"de-DE\":\"Tasmota Update\"},\"berry_driver\":{\"en-US\":\"Berry Driver\",\"de-DE\":\"Berry-Driver\",\"nl-NL\":\"Berry Driver\",\"da-DK\":\"Berry Driver\",\"es-ES\":\"Berry Driver\",\"fr-FR\":\"Berry Driver\",\"it-IT\":\"Berry Driver\",\"ru-RU\":\"Berry Driver\",\"nb-NO\":\"Berry Driver\",\"nn-NO\":\"Berry Driver\",\"pl-PL\":\"Berry Driver\",\"pt-PT\":\"Berry Driver\",\"af-ZA\":\"Berry Driver\",\"ar-SY\":\"Berry Driver\",\"bg-BG\":\"Berry Driver\",\"ca-ES\":\"Berry Driver\",\"cs-CZ\":\"Berry Driver\",\"el-GR\":\"Berry Driver\",\"et-EE\":\"Berry Driver\",\"fa-IR\":\"Berry Driver\",\"fi-FI\":\"Berry Driver\",\"he-IL\":\"Berry Driver\",\"hr-xx\":\"Berry Driver\",\"hu-HU\":\"Berry Driver\",\"hy-AM\":\"Berry Driver\",\"id-ID\":\"Berry Driver\",\"is-IS\":\"Berry Driver\",\"lb-xx\":\"Berry Driver\",\"lt-LT\":\"Berry Driver\",\"ro-RO\":\"Berry Driver\",\"sk-SK\":\"Berry Driver\",\"sl-SI\":\"Berry Driver\",\"sv-SE\":\"Berry Driver\",\"th-TH\":\"Berry Driver\",\"tr-TR\":\"Berry Driver\",\"uk-UA\":\"Berry Driver\",\"vi-VN\":\"Berry Driver\",\"zh-CN\":\"Berry Driver\",\"zh-TW\":\"Berry Driver\"},\"update_berry_driver\":{\"en-US\":\"Update Berry Driver\",\"de-DE\":\"Berry-Driver Update\"},\"nextion_tft\":{\"en-US\":\"Nextion TFT\",\"de-DE\":\"Nextion-TFT\",\"nl-NL\":\"Nextion TFT\",\"da-DK\":\"Nextion TFT\",\"es-ES\":\"Nextion TFT\",\"fr-FR\":\"Nextion TFT\",\"it-IT\":\"Nextion TFT\",\"ru-RU\":\"Nextion TFT\",\"nb-NO\":\"Nextion TFT\",\"nn-NO\":\"Nextion TFT\",\"pl-PL\":\"Nextion TFT\",\"pt-PT\":\"Nextion TFT\",\"af-ZA\":\"Nextion TFT\",\"ar-SY\":\"Nextion TFT\",\"bg-BG\":\"Nextion TFT\",\"ca-ES\":\"Nextion TFT\",\"cs-CZ\":\"Nextion TFT\",\"el-GR\":\"Nextion TFT\",\"et-EE\":\"Nextion TFT\",\"fa-IR\":\"Nextion TFT\",\"fi-FI\":\"Nextion TFT\",\"he-IL\":\"Nextion TFT\",\"hr-xx\":\"Nextion TFT\",\"hu-HU\":\"Nextion TFT\",\"hy-AM\":\"Nextion TFT\",\"id-ID\":\"Nextion TFT\",\"is-IS\":\"Nextion TFT\",\"lb-xx\":\"Nextion TFT\",\"lt-LT\":\"Nextion TFT\",\"ro-RO\":\"Nextion TFT\",\"sk-SK\":\"Nextion TFT\",\"sl-SI\":\"Nextion TFT\",\"sv-SE\":\"Nextion TFT\",\"th-TH\":\"Nextion TFT\",\"tr-TR\":\"Nextion TFT\",\"uk-UA\":\"Nextion TFT\",\"vi-VN\":\"Nextion TFT\",\"zh-CN\":\"Nextion TFT\",\"zh-TW\":\"Nextion TFT\"},\"nspanel_model\":{\"en-US\":\"NSPanel Model\",\"de-DE\":\"NSPanel Version\"},\"desired_release\":{\"en-US\":\"Desired Version\",\"de-DE\":\"Benötigte Version\",\"nl-NL\":\"Vereiste versie\",\"da-DK\":\"Påkrævet version\",\"es-ES\":\"Versión requerida\",\"fr-FR\":\"Version requise\",\"it-IT\":\"Versione richiesta\",\"ru-RU\":\"Требуемая версия\",\"nb-NO\":\"Nødvendig versjon\",\"nn-NO\":\"Nødvendig versjon\",\"pl-PL\":\"Wymagana wersja\",\"pt-PT\":\"Versão necessária\",\"af-ZA\":\"Vereiste weergawe\",\"ar-SY\":\"النسخة المطلوبة\",\"bg-BG\":\"Задължителна версия\",\"ca-ES\":\"Versió obligatòria\",\"cs-CZ\":\"Požadovaná verze\",\"el-GR\":\"Απαιτούμενη έκδοση\",\"et-EE\":\"Nõutav versioon\",\"fa-IR\":\"نسخه مورد نیاز\",\"fi-FI\":\"Vaadittu versio\",\"he-IL\":\"גרסה נדרשת\",\"hr-xx\":\"Potrebna verzija\",\"hu-HU\":\"Kötelező verzió\",\"hy-AM\":\"Պահանջվող տարբերակ\",\"id-ID\":\"Versi yang diperlukan\",\"is-IS\":\"Áskilin útgáfa\",\"lb-xx\":\"Néideg Versioun\",\"lt-LT\":\"Reikalinga versija\",\"ro-RO\":\"Versiune obligatorie\",\"sk-SK\":\"Požadovaná verzia\",\"sl-SI\":\"Zahtevana različica\",\"sv-SE\":\"Obligatorisk version\",\"th-TH\":\"เวอร์ชันที่ต้องการ\",\"tr-TR\":\"Gerekli sürüm\",\"uk-UA\":\"Потрібна версія\",\"vi-VN\":\"Phiên bản bắt buộc\",\"zh-CN\":\"所需版本\",\"zh-TW\":\"所需版本\"},\"update_nextion_tft\":{\"en-US\":\"Update Nextion TFT\",\"de-DE\":\"Nextion TFT Update\"},\"update_message\":{\"en-US\":\"Update Notifications\",\"de-DE\":\"Update Mitteilungen\"},\"scriptname\":{\"en-US\":\"Script name\",\"de-DE\":\"Skriptname\"},\"hiddencards_offon\":{\"en-US\":\"hidden Cards (on/off)\",\"de-DE\":\"ausgeblendete Seiten (an/aus)\"}}","ack":true,"ts":1726938298787,"q":0,"from":"system.adapter.javascript.0","lc":1726914394140,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.793	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.SSId, state={"val":"my_Crib","ack":true,"ts":1726938298793,"q":0,"from":"system.adapter.javascript.0","lc":1662053557155,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.800	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.BSSId, state={"val":"2C:91:AB:15:C7:62","ack":true,"ts":1726938298800,"q":0,"from":"system.adapter.javascript.0","lc":1726480800398,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.815	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Channel, state={"val":11,"ack":true,"ts":1726938298815,"q":0,"from":"system.adapter.javascript.0","lc":1726308000368,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.817	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Mode, state={"val":"HT20","ack":true,"ts":1726938298817,"q":0,"from":"system.adapter.javascript.0","lc":1715965320115,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.818	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.RSSI, state={"val":92,"ack":true,"ts":1726938298818,"q":0,"from":"system.adapter.javascript.0","lc":1726938298818,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.820	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Signal, state={"val":-54,"ack":true,"ts":1726938298820,"q":0,"from":"system.adapter.javascript.0","lc":1726938298820,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.822	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Product, state={"val":"SONOFF NSPanel","ack":true,"ts":1726938298822,"q":0,"from":"system.adapter.javascript.0","lc":1695149200537,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.824	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Uptime, obj={"type":"channel","common":{"role":"info","name":"Uptime"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.825	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Version, obj={"type":"channel","common":{"role":"info","name":"Version"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.825	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Hardware, obj={"type":"channel","common":{"role":"info","name":"Hardware"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.826	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.AP, obj={"type":"channel","common":{"role":"info","name":"AP"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.827	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.SSId, obj={"type":"channel","common":{"role":"info","name":"SSId"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.827	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.BSSId, obj={"type":"channel","common":{"role":"info","name":"BSSId"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.828	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Channel, obj={"type":"channel","common":{"role":"info","name":"Channel"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.828	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Mode, obj={"type":"channel","common":{"role":"info","name":"Mode"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.829	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.RSSI, obj={"type":"channel","common":{"role":"info","name":"RSSI"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.829	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Signal, obj={"type":"channel","common":{"role":"info","name":"Signal"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.830	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Product, obj={"type":"channel","common":{"role":"info","name":"Product"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.901	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota_Firmware.currentVersion, state={"val":"14.2.0","ack":true,"ts":1726938298901,"q":0,"from":"system.adapter.javascript.0","lc":1723984878935,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.904	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Uptime, state={"val":"6T04:32:00","ack":true,"ts":1726938298904,"q":0,"from":"system.adapter.javascript.0","lc":1726938298904,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.907	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Version, state={"val":"14.2.0(release-tasmota32)","ack":true,"ts":1726938298907,"q":0,"from":"system.adapter.javascript.0","lc":1723984878942,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.914	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Hardware, state={"val":"ESP32-D0WD-V3\r\nv3.0","ack":true,"ts":1726938298914,"q":0,"from":"system.adapter.javascript.0","lc":1697813125495,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.916	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.AP, state={"val":1,"ack":true,"ts":1726938298916,"q":0,"from":"system.adapter.javascript.0","lc":1662053557151,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.924	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.SSId, state={"val":"my_Crib","ack":true,"ts":1726938298924,"q":0,"from":"system.adapter.javascript.0","lc":1662053557155,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.928	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.BSSId, state={"val":"2C:91:AB:15:C7:62","ack":true,"ts":1726938298928,"q":0,"from":"system.adapter.javascript.0","lc":1726480800398,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.934	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Channel, state={"val":11,"ack":true,"ts":1726938298934,"q":0,"from":"system.adapter.javascript.0","lc":1726308000368,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.935	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.IoBroker.ScriptName, obj={"type":"channel","common":{"role":"info","name":"Scriptname"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.937	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Mode, state={"val":"HT20","ack":true,"ts":1726938298937,"q":0,"from":"system.adapter.javascript.0","lc":1715965320115,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.941	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.RSSI, state={"val":92,"ack":true,"ts":1726938298940,"q":0,"from":"system.adapter.javascript.0","lc":1726938298940,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.953	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Wifi.Signal, state={"val":-54,"ack":true,"ts":1726938298953,"q":0,"from":"system.adapter.javascript.0","lc":1726938298953,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.963	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota.Product, state={"val":"SONOFF NSPanel","ack":true,"ts":1726938298963,"q":0,"from":"system.adapter.javascript.0","lc":1695149200537,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.970	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Uptime, obj={"type":"channel","common":{"role":"info","name":"Uptime"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.971	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Version, obj={"type":"channel","common":{"role":"info","name":"Version"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.971	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Hardware, obj={"type":"channel","common":{"role":"info","name":"Hardware"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.972	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.AP, obj={"type":"channel","common":{"role":"info","name":"AP"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.972	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.SSId, obj={"type":"channel","common":{"role":"info","name":"SSId"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.972	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.BSSId, obj={"type":"channel","common":{"role":"info","name":"BSSId"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.973	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Channel, obj={"type":"channel","common":{"role":"info","name":"Channel"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.973	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Mode, obj={"type":"channel","common":{"role":"info","name":"Mode"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.973	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.RSSI, obj={"type":"channel","common":{"role":"info","name":"RSSI"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.973	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Wifi.Signal, obj={"type":"channel","common":{"role":"info","name":"Signal"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:58.973	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota.Product, obj={"type":"channel","common":{"role":"info","name":"Product"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.042	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.entityChangeTime, obj={"type":"channel","common":{"role":"slider","name":"entityChangeTime"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.076	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Screensaver.autoWeatherColorScreensaverLayout, obj={"type":"channel","common":{"role":"socket","name":"alternativeScreensaverLayout"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.077	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.NSPanel_ipAddress, state={"val":"192.168.178.70","ack":true,"ts":1726938299077,"q":0,"from":"system.adapter.javascript.0","lc":1662053556518,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.078	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.NSPanel_ipAddress, state={"val":"192.168.178.70","ack":true,"ts":1726938299077,"q":0,"from":"system.adapter.javascript.0","lc":1662053556518,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.080	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ipAddress, obj={"type":"channel","common":{"role":"info","name":"ipAddress"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.081	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.ipAddress, obj={"type":"channel","common":{"role":"info","name":"ipAddress"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.082	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.ScriptVersion, state={"val":"v4.4.0.5","ack":true,"ts":1726938299082,"q":0,"from":"system.adapter.javascript.0","lc":1726914393932,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.355	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.onlineVersion, state={"val":"53","ack":true,"ts":1726938299355,"q":0,"from":"system.adapter.javascript.0","lc":1694865600261,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.358	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.onlineVersion, state={"val":"53","ack":true,"ts":1726938299358,"q":0,"from":"system.adapter.javascript.0","lc":1694865600261,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.376	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.currentVersion, state={"val":null,"ts":1726938299376,"q":0,"from":"system.adapter.javascript.0","lc":1726938299376,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.379	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.currentVersion, state={"val":"9","ack":true,"ts":1726938299379,"q":0,"from":"system.adapter.javascript.0","lc":1726938299379,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.388	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Display.BerryDriver, obj={"type":"channel","common":{"role":"info","name":"Berry Driver"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.401	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.currentVersion, state={"val":null,"ts":1726938299401,"q":0,"from":"system.adapter.javascript.0","lc":1726938299401,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.407	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.currentVersion, state={"val":"9","ack":true,"ts":1726938299407,"q":0,"from":"system.adapter.javascript.0","lc":1726938299407,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.408	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Screensaver.timeoutScreensaver, obj={"type":"channel","common":{"role":"slider","name":"timeoutScreensaver"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.418	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Display.BerryDriver, obj={"type":"channel","common":{"role":"info","name":"Berry Driver"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.425	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.onlineVersion, state={"val":null,"ts":1726938299425,"q":0,"from":"system.adapter.javascript.0","lc":1726938299425,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.431	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.onlineVersion, state={"val":null,"ts":1726938299431,"q":0,"from":"system.adapter.javascript.0","lc":1726938299431,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.434	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Berry_Driver.onlineVersion, obj={"type":"channel","common":{"role":"info","name":"onlineVersion"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.435	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Berry_Driver.onlineVersion, obj={"type":"channel","common":{"role":"info","name":"onlineVersion"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.454	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.TFT_Firmware.onlineVersion, state={"val":"4.4.0","ack":true,"ts":1726938299454,"q":0,"from":"system.adapter.javascript.0","lc":1711879200389,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.456	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.TFT_Firmware.onlineVersion, state={"val":"4.4.0","ack":true,"ts":1726938299456,"q":0,"from":"system.adapter.javascript.0","lc":1711879200389,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.559	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.onlineVersion, state={"val":"9","ack":true,"ts":1726938299559,"q":0,"from":"system.adapter.javascript.0","lc":1726938299559,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.560	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Berry_Driver.onlineVersion, state={"val":"9","ack":true,"ts":1726938299560,"q":0,"from":"system.adapter.javascript.0","lc":1726938299560,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.634	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota_Firmware.onlineVersion, obj={"type":"channel","common":{"role":"info","name":"onlineVersion"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.635	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Tasmota_Firmware.onlineVersion, obj={"type":"channel","common":{"role":"info","name":"onlineVersion"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.681	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Config.Screensaver.screenSaverDoubleClick, obj={"type":"channel","common":{"role":"socket","name":"screenSaverDoubleClick"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.701	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota_Firmware.onlineVersion, state={"val":"14.2.0","ack":true,"ts":1726938299701,"q":0,"from":"system.adapter.javascript.0","lc":1723716000728,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.713	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Tasmota_Firmware.onlineVersion, state={"val":"14.2.0","ack":true,"ts":1726938299713,"q":0,"from":"system.adapter.javascript.0","lc":1723716000728,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:04:59.778	[info ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: hidden Cards disabled
                  21.9.2024, 19:05:00.001	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=mqtt.0.cmnd.nspanel_0C007C.CustomSend, state={"val":"time~19:05","ack":false,"ts":1726938300001,"q":0,"from":"system.adapter.javascript.0","lc":1726938300001,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:28.345	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.ScreensaverInfo.weatherForecast, state={"val":true,"ack":false,"ts":1726938328345,"q":0,"from":"system.adapter.javascript.0","lc":1726938328345,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:50.997	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Sensor.Time, state={"val":"2024-09-21\r\n18:05:50","ack":true,"ts":1726938350997,"q":0,"from":"system.adapter.javascript.0","lc":1726938350997,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.000	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Sensor.TempUnit, state={"val":"°C","ack":true,"ts":1726938351000,"q":0,"from":"system.adapter.javascript.0","lc":1662053653619,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.001	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setForeignState(id=0_userdata.0.NSPanel.1.Sensor.ANALOG.Temperature, state={"val":27.7,"ack":true,"ts":1726938351001,"q":0,"from":"system.adapter.javascript.0","lc":1726938051022,"c":"script.js.NSPanel_v4_4_0_5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.003	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Sensor.ANALOG.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.004	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Sensor.ESP32.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.005	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Sensor.Time, obj={"type":"channel","common":{"role":"info","name":""},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  21.9.2024, 19:05:51.005	[warn ]: javascript.0 (2118) script.js.NSPanel_v4_4_0_5: setObject(id=alias.0.NSPanel.1.Sensor.TempUnit, obj={"type":"channel","common":{"role":"info","name":""},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                  • G Offline
                    Gre4t0ne
                    #6449
                    Doch noch Errors im Protokoll entdeckt ABER diese kommen nur 1x beim Starten des Skriptes:
                    javascript.02024-09-21 19:06:17.560	error	at Script.runInContext (node:vm:135:12)
                    javascript.0
                    2024-09-21 19:06:17.559	error	at script.js.NSPanel_v4_4_0_5:1176:19
                    javascript.0
                    2024-09-21 19:06:17.559	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
                    javascript.0
                    2024-09-21 19:06:17.559	error	at require (node:internal/modules/cjs/helpers:121:18)
                    javascript.0
                    2024-09-21 19:06:17.558	error	at Module.require (node:internal/modules/cjs/loader:1143:19)
                    javascript.0
                    2024-09-21 19:06:17.558	error	script.js.NSPanel_v4_4_0_5: Error: Cannot find module '@iobroker-javascript.0/moment-parseformat'
                    • G Gre4t0ne
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      TT-Tom
                      #6450
                      @gre4t0ne
                      Du musst in der Instanz Einstellung das npm Modul
                      moment-parseformat
                      eintragen. Wenn du moment auch nicht drin hast, bitte auch eintragen.
                      Wiki
                      Gruß Tom
                      NSPanel Script Wiki
                      • GregorSG GregorS
                        oder schließen.
                        Vielen Dank
                        TT-Tom
                        #6451
                        @gregors
                        Lies dir mal die Wiki Beitrag durch. Der Typ Steckdose hat die Eigenschaft ein/aus.
                        Gruß Tom
                        NSPanel Script Wiki
                        • G Gre4t0ne
                          TT-Tom
                          #6452
                          @gre4t0ne Das Script hat eine eigene script-Debug-Funktion. Einschalten über das Panel im Servicemenü unter Einstellungen/Script oder den Datenpunkt 0_userdata.0.NSPanel.1.Config.ScripgtDebugStatus auf true setzen. Damit bekommen wir die Daten, die wir fürs erste brauchen.
                          Gruß Tom
                          NSPanel Script Wiki
                          L 1 Antwort Letzte Antwort
                          • T TT-Tom
                            lustig29
                            #6453
                            Ich habe schon mehrere Videos gesehen, in dem auf einem Shelly Wall Display, Home Assitant läuft.
                            Wäre denn nicht sowas ähnliches auf dem Ns Panel mit Iobroker möglich?
                            • L lustig29
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #6454
                              @lustig29
                              Kann mir da nun nichts drunter vorstellen... Du meinst per Web-Seite? Oder HA auf dem NSPanel?
                              • ArmilarA Armilar
                                @lustig29
                                lustig29
                                #6455
                                @armilar
                                link text
                                • L lustig29
                                  @armilar
                                  link text
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #6456
                                  @lustig29
                                  Ah okay - HA-Dashboard - verstanden :grin:
                                  geht nicht mit dem Sonoff NSPanel - aber mit dem Sonoff NSPanel Pro. :blush: (andere Baustelle)
                                  Sowohl das NSPanel Pro als auch das Shelly Wall Display arbeiten nicht unter ESP32/Tasmota mit Nextion, sondern sind ganz normale Android-Geräte.
                                  Beim Shelly Wall Display, funktioniert das ohne Jailbreak offensichtlich nur mit HA. Auf dem NSPanel Pro kannst du mit den bekannten Hacks z.B. eine ioBroker VIS als Webseite laden...
                                  Preislich liegen Shelly Wall Display und NSPanel Pro nah zusammen - aber immer noch ca. 60€ über dem NSPanel (habe die meisten bei ca. 40€ geschossen). Daher bleibt das NSPanel wohl die günstigste komplett Visu für das komplette Smart Home ;-)
                                  L K haus-automatisierungH 3 Antworten Letzte Antwort
                                  • ArmilarA Armilar
                                    @lustig29
                                    lustig29
                                    #6457
                                    @armilar
                                    Ah ok.
                                    Danke für die ausgiebige Erklärung. Aber es ist auch eine einfacher Programmierung des Ns Panels geplant, bzw. in Arbeit, oder?
                                      TT-Tom
                                      #6458
                                      @lustig29
                                      Ja es ist ein Adapter in Planung. Der über die Admin Oberfläche konfiguriert wird. Die HMI ist noch in der Planungsphase.
                                      Gruß Tom
                                      https://github.com/tt-tom17
                                      NSPanel Script Wiki
                                      NSPanel Adapter Wiki
                                      W 1 Antwort Letzte Antwort
                                      • T TT-Tom
                                        @lustig29
                                        W Offline
                                        W Offline
                                        wolwin
                                        #6459
                                        Zuerst einmal: vielen Dank für eure Arbeit - super!!
                                        Trotzdem brauche ich mal Unterstützung ...
                                        Auf dem NSPanel ist Tasmota 13.4 und die Display Firmware nspanel-v4.4.0.tft installiert (mit Tasmota 14.2 konnte v4.4.0 nicht aufgespielt werden). Als MQTT-Server wird ein externer Mosquitto Server benutzt. Unter HomeAssistant konnte das NSPanel erfolgreich in Betrieb genommen werden - läuft. Da ich einen Vergleich mit dem ioBroker wollte, habe ich auch hier die Installation mit dem DEV-Script v4.4.0.6 (wg. MQTT-Client) durchgeführt.
                                        Hier passiert der erste Fehler: der automatische Updater im Script knallt bei der Erstinstallation des NSPanels im ioBroker den Display Firmware 3.3.1 auf das NSPanel, obwohl schon die benötigte 4.4.0 auf dem Gerät war. Ergebnis: um 90 Grad gedrehte Fehlermeldung im Display. Mit dem Befehl
                                        FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.4.0.tft
                                        in der Tasmota Konsole kann das wieder bereinigt werden ...
                                        Als Reminder würde ich einen Feature Request vorschlagen:
                                        • Auto-Config Flags für das Unterdücken eines Auto-Updates in den Funktionen
                                          • update_tasmota_firmware();
                                          • update_berry_driver_version();
                                          • update_tft_firmware();
                                            jeweils im vor dem try-Bereich
                                        Dann wird das Script erneut gestartet, aber es wird nichts über den MQTT-Server Richtung NSPanel geschickt. 0_userdate und alias sind vom Script richtig erzeugt worden, auch der CustomSend Eintrag ist vorhanden. Die MQTT publish Geräte-Einstellung ist für CustomSend, GetDriverVersion und POWER gesetzt. Stattdessen wird alle 6 Sekunden die Init-Schleife durchlaufen (CustomSend = Null)
                                        26.9.2024, 19:00:30.124	[info ]: javascript.0 (600) Compiling TypeScript source script.js.common.NSPanel.NSPanelTs_073
                                        26.9.2024, 19:00:30.500	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: source code did not change, using cached compilation result...
                                        26.9.2024, 19:00:30.678	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: setObjects enabled - create Alias Channels possible
                                        26.9.2024, 19:00:30.679	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: weather alias for accuweather.0. already exists
                                        26.9.2024, 19:00:30.710	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: registered 40 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        26.9.2024, 19:00:30.974	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Desired TFT Firmware: 53 / v4.4.0
                                        26.9.2024, 19:00:30.974	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Installed TFT Firmware: 53 / v4.4.0
                                        26.9.2024, 19:00:31.081	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Debug mode disabled
                                        26.9.2024, 19:00:32.060	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: hidden Cards disabled
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Start MQTT-Port-Check -------------------------------------
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- admin.0                   - 8081
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- hm-rpc.0                  - 0
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- hm-rpc.1                  - 0
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- hm-rpc.2                  - 0
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- hm-rpc.3                  - 0
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- mqtt-client.0             - 1883
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- simple-api.0              - 8087
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: -- web.0                     - 8082
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: - MQTT-Port-Check OK: Instance of Adapter: mqtt-client.0 is running on Port:1883
                                        26.9.2024, 19:00:33.611	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: End MQTT-Port-Check ---------------------------------------
                                        26.9.2024, 19:00:34.808	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Desired TFT Firmware: 53 / v4.4.0
                                        26.9.2024, 19:00:34.808	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Installed TFT Firmware: 53 / v4.4.0
                                        26.9.2024, 19:00:40.797	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Desired TFT Firmware: 53 / v4.4.0
                                        26.9.2024, 19:00:40.797	[info ]: javascript.0 (600) script.js.common.NSPanel.NSPanelTs_073: Installed TFT Firmware: 53 / v4.4.0
                                        Bei der Jscript Version 8.8.3 sind die NPM Modulen axios, moment, moment-parseformat und dayjs angegeben.
                                        Was habe ich übersehen - wo ist der Fehler?
                                        • ArmilarA Armilar
                                          @lustig29
                                          Kuckuckmann
                                          #6460
                                          @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                                          @lustig29
                                          Klaro, Shelly hat auf der IFA ja bekannt gegeben, dass sie mit HA nun auch kooperieren. Klingt für mich nur logisch, dass man dann die App nativ auf dem Gerät installieren/nutzen kann.
                                          LG
                                          NSPanel Dokumentation im GitHub Wiki:
                                          32.6k
                                          82.1k
