  4. Visualisierung mit Node Red erstellen
4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    @mickym
    [{"result":"_result","table":0,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T05:50:55.302Z","_value":84,"_field":"value","_measurement":"Diastole"},{"result":"_result","table":0,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T06:07:26.39Z","_value":78,"_field":"value","_measurement":"Diastole"},{"result":"_result","table":0,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:07:26.438Z","_value":78,"_field":"value","_measurement":"Diastole"},{"result":"_result","table":0,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:22:26.52Z","_value":71,"_field":"value","_measurement":"Diastole"},{"result":"_result","table":1,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T05:51:28.093Z","_value":114,"_field":"value","_measurement":"Puls"},{"result":"_result","table":1,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T06:07:26.392Z","_value":106,"_field":"value","_measurement":"Puls"},{"result":"_result","table":1,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:07:26.442Z","_value":106,"_field":"value","_measurement":"Puls"},{"result":"_result","table":1,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:22:26.521Z","_value":85,"_field":"value","_measurement":"Puls"},{"result":"_result","table":2,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T05:50:25.342Z","_value":127,"_field":"value","_measurement":"Systole"},{"result":"_result","table":2,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-23T06:07:26.39Z","_value":114,"_field":"value","_measurement":"Systole"},{"result":"_result","table":2,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:07:26.439Z","_value":114,"_field":"value","_measurement":"Systole"},{"result":"_result","table":2,"_start":"2023-01-19T00:35:58.94679632Z","_stop":"2023-01-26T00:35:58.94679632Z","_time":"2023-01-24T07:22:26.521Z","_value":107,"_field":"value","_measurement":"Systole"}]
    mickymM Offline
    mickymM Offline
    mickym
    #3141
    @damrak2022 So ich habs fertig - grundsätzlich gilt, dass das Auslesen der Daten aus der Influx DB nur zum Initialisieren des Charts dient - weitere Werte lässt Du direkt in die Chart Node wandern.
    Also die DB Abfrage nur einmal machen - wenn der Flow neu gestartet wird.
    Löschen kann man die Chart Node in dem man ihr wie in der ersten Node ein leeres Array übergibt.
    Sprich die Inject Nodes mit Diastole etc. da müssen dann direkt die Datenpunkte über die iobroker IN Node davor und Du musst das topic setzen wie in den Inject-Nodes vorgegeben.
    Die Influx-DB Abfrage machst Du nur einmal beim Neustart des NodeRed Adapters - also einfach einmalig mit einer Inject Node die Query machen und dann in die von mir erstelle Change Node verbinden.
    Und wenn Du das JSONATA so gut verstehst, was ich da drin gemacht habe - dann können wir solche Aufgaben machen. Aber da muss ich selbst rumprobieren und ich glaube, dass Du da noch so weit entfernt bist (Lichtjahre 😁 ), dass wir uns da entsprechend austauschen könnten.
           "id": "e79f1c62ef97b36a",
           "type": "inject",
           "z": "1983aa28392732ca",
           "name": "Influx DB Abfrage zur Initialisierung",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "[{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:50:55.302Z\",\"_value\":84,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.39Z\",\"_value\":78,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:07:26.438Z\",\"_value\":78,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.52Z\",\"_value\":71,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:51:28.093Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.392Z\",\"_value\":106,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:07:26.442Z\",\"_value\":106,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.521Z\",\"_value\":85,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:50:25.342Z\",\"_value\":127,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.39Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:07:26.439Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.521Z\",\"_value\":107,\"_field\":\"value\",\"_measurement\":\"Systole\"}]",
           "payloadType": "json",
           "x": 220,
           "y": 280,
           "wires": [
                   "efd1ab4c73f3d571",
                   "a9c39616decfa97c"
           "id": "4d853addf9c082fb",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Diastole",
           "payload": "88",
           "payloadType": "num",
           "x": 500,
           "y": 120,
           "wires": [
                   "2d8acec0ec2da68e"
           "id": "2d8acec0ec2da68e",
           "type": "ui_chart",
           "name": "",
           "group": "57f13d6f733e5c9d",
           "order": 2,
           "width": 0,
           "height": 0,
           "label": "Blutdruck und Puls",
           "chartType": "line",
           "legend": "true",
           "xformat": "dd HH:mm",
           "interpolate": "linear",
           "nodata": "",
           "dot": false,
           "ymin": "",
           "ymax": "",
           "removeOlder": 1,
           "removeOlderPoints": "50",
           "removeOlderUnit": "604800",
           "cutout": 0,
           "useOneColor": false,
           "useUTC": false,
           "colors": [
               "#1f77b4",
               "#aec7e8",
               "#ff7f0e",
               "#2ca02c",
               "#98df8a",
               "#d62728",
               "#ff9896",
               "#9467bd",
               "#c5b0d5"
           "outputs": 1,
           "useDifferentColor": false,
           "className": "",
           "x": 770,
           "y": 180,
           "wires": [
           "id": "0ca3dc50cb11869a",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Systole",
           "payload": "170",
           "x": 490,
           "y": 160,
           "wires": [
                   "2d8acec0ec2da68e"
           "id": "efd1ab4c73f3d571",
           "type": "change",
           "name": "Create Object Arrays",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "[\t   {\t       \"series\" : [\"Systole\",\"Diastole\",\"Puls\"],\t       \"data\": [\t           [\t               payload[_measurement=\"Systole\"].{\t                   \"x\" : $toMillis(_time),\t                   \"y\" : _value\t    \t               }\t           ],\t           [\t               payload[_measurement=\"Diastole\"].{\t                   \"x\" : $toMillis(_time),\t                   \"y\" : _value\t    \t               }\t           ],\t           [\t               payload[_measurement=\"Puls\"].{\t                   \"x\" : $toMillis(_time),\t                   \"y\" : _value\t    \t               }\t           ]\t       ],\t       \"labels\" : [\"Systole\",\"Diastole\",\"Puls\"]\t    }\t]",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 500,
           "y": 280,
           "wires": [
                   "2d8acec0ec2da68e",
                   "cb3a1a566bc5679f"
           "id": "097b4e4032b4bcff",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Puls",
           "payload": "75",
           "x": 510,
           "y": 200,
           "wires": [
                   "2d8acec0ec2da68e"
           "id": "5b8909ad22babab7",
           "type": "inject",
           "name": "löschen",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "[]",
           "x": 510,
           "y": 60,
           "wires": [
                   "2d8acec0ec2da68e"
           "id": "a9c39616decfa97c",
           "type": "debug",
           "name": "Array aus InfluxDB Abfrage",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 520,
           "y": 320,
           "wires": []
           "id": "cb3a1a566bc5679f",
           "type": "debug",
           "name": "Array zur Initialisierung der Chart Node",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 830,
           "y": 280,
           "wires": []
           "id": "57f13d6f733e5c9d",
           "type": "ui_group",
           "name": "Test",
           "tab": "20b3095113f94d70",
           "order": 2,
           "disp": true,
           "width": "6",
           "collapse": false,
           "className": ""
           "id": "20b3095113f94d70",
           "type": "ui_tab",
           "name": "Home",
           "icon": "dashboard",
           "order": 1,
           "disabled": false,
           "hidden": false
    Du siehst wie man mit einer Change Node durch Filtern von Objekten und gleichzeitiger Neuerstellung - da ist JSONATA wirklich genial, völlig neue Objekte in der gewünschten Form erzeugen kann.
    Oben siehst Du ja das Array mit den Datensätzen aus der InfluxDB - das völlig neu erstellt wird, wie die Chart Node es braucht und wie es in der Beschreibung von Steve stand.
    Aus diesen Objekten:
    wurde diese alle je nach _measurement in verschiedene data Objekte gespeichert und gleichzeitig die Werte für die x und y-Achse generiert.
    Im ersten Array = grün findest Du alle systolischen Werte mit dem timestamp als x und der entsprechenden Wert als y.
    Im zweiten Array = gelb findest Du alle diastolischen Werte mit dem timestamp als x und der entsprechenden Wert als y.
    Im dritten Array = hellblau findest Du alle Puls-Werte mit dem timestamp als x und der entsprechenden Wert als y.
    Hier der Inhalt des Change / JSONATA Erstellung des Objektes:
           "series" : ["Systole","Diastole","Puls"],
           "data": [
                   payload[_measurement="Systole"].{
                       "x" : $toMillis(_time),
                       "y" : _value
                   payload[_measurement="Diastole"].{
                       "y" : _value
                   payload[_measurement="Puls"].{
                       "y" : _value
           "labels" : ["Systole","Diastole","Puls"]
    Also wie gesagt beschäftige Dich mit Arrays, Objekten, Filterung und Objekterstellung mit JSONATA.
    Wenn Du das mit Javascript programmieren wolltest, bräuchtest Du das Mehrfache an Code.
    Wie gesagt der Schlüssel ist der Screenshot, wie die Arrays und Objekte aufgebaut sein müssen, den ich aus dem Artikel von Steve kopiert hatte (https://forum.iobroker.net/post/934428).
    Damrak2022D 2 Antworten Letzte Antwort
    • mickymM mickym
             "type": "inject",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 220,
             "y": 280,
             "wires": [
                     "efd1ab4c73f3d571",
                     "a9c39616decfa97c"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "payload": "88",
             "x": 500,
             "y": 120,
             "wires": [
                     "2d8acec0ec2da68e"
             "type": "ui_chart",
             "name": "",
             "order": 2,
             "width": 0,
             "height": 0,
             "legend": "true",
             "nodata": "",
             "dot": false,
             "ymin": "",
             "ymax": "",
             "removeOlder": 1,
             "cutout": 0,
             "useUTC": false,
             "colors": [
                 "#1f77b4",
                 "#aec7e8",
                 "#ff7f0e",
                 "#2ca02c",
                 "#98df8a",
                 "#d62728",
                 "#ff9896",
                 "#9467bd",
                 "#c5b0d5"
             "outputs": 1,
             "className": "",
             "x": 770,
             "y": 180,
             "wires": [
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "Systole",
             "payload": "170",
             "x": 490,
             "y": 160,
             "wires": [
                     "2d8acec0ec2da68e"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 500,
             "y": 280,
             "wires": [
                     "2d8acec0ec2da68e",
                     "cb3a1a566bc5679f"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "Puls",
             "payload": "75",
             "x": 510,
             "y": 200,
             "wires": [
                     "2d8acec0ec2da68e"
             "type": "inject",
             "name": "löschen",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "[]",
             "x": 510,
             "y": 60,
             "wires": [
                     "2d8acec0ec2da68e"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 520,
             "y": 320,
             "wires": []
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 830,
             "y": 280,
             "wires": []
             "type": "ui_group",
             "name": "Test",
             "order": 2,
             "disp": true,
             "width": "6",
             "collapse": false,
             "className": ""
             "type": "ui_tab",
             "name": "Home",
             "order": 1,
             "disabled": false,
             "hidden": false
             "data": [
                         "y" : _value
                         "y" : _value
                         "y" : _value
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      schrieb am zuletzt editiert von Damrak2022
      #3142
      @mickym Hallo Micky,
      erstmal vielen Dank.
      Mit besten Grüßen
      Andy
      • mickymM mickym
               "type": "inject",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 220,
               "y": 280,
               "wires": [
                       "efd1ab4c73f3d571",
                       "a9c39616decfa97c"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "payload": "88",
               "x": 500,
               "y": 120,
               "wires": [
                       "2d8acec0ec2da68e"
               "type": "ui_chart",
               "name": "",
               "order": 2,
               "width": 0,
               "height": 0,
               "legend": "true",
               "nodata": "",
               "dot": false,
               "ymin": "",
               "ymax": "",
               "removeOlder": 1,
               "cutout": 0,
               "useUTC": false,
               "colors": [
                   "#1f77b4",
                   "#aec7e8",
                   "#ff7f0e",
                   "#2ca02c",
                   "#98df8a",
                   "#d62728",
                   "#ff9896",
                   "#9467bd",
                   "#c5b0d5"
               "outputs": 1,
               "className": "",
               "x": 770,
               "y": 180,
               "wires": [
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "Systole",
               "payload": "170",
               "x": 490,
               "y": 160,
               "wires": [
                       "2d8acec0ec2da68e"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 500,
               "y": 280,
               "wires": [
                       "2d8acec0ec2da68e",
                       "cb3a1a566bc5679f"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "Puls",
               "payload": "75",
               "x": 510,
               "y": 200,
               "wires": [
                       "2d8acec0ec2da68e"
               "type": "inject",
               "name": "löschen",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "[]",
               "x": 510,
               "y": 60,
               "wires": [
                       "2d8acec0ec2da68e"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 520,
               "y": 320,
               "wires": []
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 830,
               "y": 280,
               "wires": []
               "type": "ui_group",
               "name": "Test",
               "order": 2,
               "disp": true,
               "width": "6",
               "collapse": false,
               "className": ""
               "type": "ui_tab",
               "name": "Home",
               "order": 1,
               "disabled": false,
               "hidden": false
               "data": [
                           "y" : _value
                           "y" : _value
                           "y" : _value
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #3143
        @mickym Also, wenn ich das alles halbwegs richtig verstehe, hast Du hier die Werte von der Systole und Diastole eingearbeitet. Das zeigt sich ja auch im Debug:
        Die Nodes für den Puls muss ich noch dementsprechend hinzufügen, richtig?
        Ich habe jetzt mal die Chart Node hinten drangehängt, sehe hier aber nur eine Linie, obwohl es laut Debug ja zwei Werte sein müssten, das verwundert mich etwas.
        Mit besten Grüßen
        Andy
        mickymM 2 Antworten Letzte Antwort
          mickymM Offline
          mickymM Offline
          mickym
          #3144
          @damrak2022 mach doch bitte das was ich geschrieben habe. Schmeiß alles weg, was du hast. Du brauchst doch nur die Change Node zwischen der chartnode und influx-dB platzieren. Zusätzlich kommen dann noch die aktuellen Werte rein. Ich hab alles beschrieben- ich will’s eigentlich nicht nochmal schreiben.
          Siehst du in meinem Flow irgendwelche Switch nodes?? - ich hab doch alles quasi fix und fertig für dich aufbereitet
          War wohl mein Fehler - habe einen Mist exportiert! Sorry und Entschuldigung!
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #3145
            @mickym Okay, mache ich. Nur das mit der Change Node war mir nicht klar.
            Mit besten Grüßen
            Andy
              mickymM Offline
              mickymM Offline
              mickym
              #3146
              @damrak2022 Ich wundere mich, wie Du überhaupt zu diesen Nodes kommst - das waren meine Fehlversuche - ich schau mal ob ich Dir über haupt das richtige exportiert habe.
              Importiere den Flow nochmal neu - ich glaube ich habe beim Export einen Fehler gemacht.
                mickymM Offline
                mickymM Offline
                mickym
                #3147
                @damrak2022 sagte in Visualisierung mit Node Red erstellen:
                Also das war ein Versehen - Du hast meine Tests und Fehlversuche importiert. ;) Der Flow muss so aussehen, wie auf dem Screenshot:
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #3148
                  @mickym Jetzt fehlt nur der korrekte Export von Dir😄
                  Mit besten Grüßen
                  Andy
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #3149
                    @damrak2022 ich hab das in dem Beitrag unten ausgetauscht- also einfach nochmal neu importieren
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #3150
                      @mickym Okay, danke.
                      Mit besten Grüßen
                      Andy
                      • mickymM mickym
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #3151
                        ich brauche mal Deinen Ratschlag: Ich wollte jetzt die Daten von der Influx auslesen um auch mein Gewicht im Liniendiagramm darzustellen. Ich hätte das dann so nachgebaut, wie Du es mit dem Blutdruck/Puls gemacht hast.
                        Allerdings bekomme ich jetzt folgende Debug Meldung wenn ich das Gewicht so versuche auszulesen:
                        Bildschirm­foto 2023-01-27 um 02.07.14.png Bildschirm­foto 2023-01-27 um 02.04.27.png Bildschirm­foto 2023-01-27 um 02.04.16.png
                        Nur kann ich mit der Fehlermeldung nicht wirklich was anfangen. Hast Du eine Idee, was hier falsch ist?
                        Mit besten Grüßen
                        Andy
                        • mickymM Offline
                          mickymM Offline
                          mickym
                          #3152
                          @damrak2022 Nun in Deinem aggregateWindow referenzierst Du ein Objekt mit dem Namen v und das gibt es nicht. Anstelle von v.WindowPeriod - solltest Du direkt die Periode eingeben, die aggregieren willst.
                          Du scheinst ja nicht die einzelnen Werte abfragen zu wollen, sondern den Mittelwert über bestimmte Zeitspannen zu bilden. Warum?
                          Hier hast die Syntax - aber wie gesagt, warum?
                          https://docs.influxdata.com/flux/v0.x/stdlib/universe/aggregatewindow/
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #3153
                            @mickym Damit ich dann das Array, so wie gestern kopieren kann, um es dann mit der Inject Node anzufragen und nachzubauen.
                            Mit besten Grüßen
                            Andy
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #3154
                              @damrak2022 Dazu musst Du doch nichts aggregieren. Ich würde mal die Zeile 5 weglassen.
                              So oft steigst Du ja nicht auf die Waage, dass Du das aggregieren musst. Ein Beispiel siehst Du ja in dem verlinkten Code:
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #3155
                                @mickym Stimmt Zeile 5 war der Fehler.
                                Mit besten Grüßen
                                Andy
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #3156
                                  Ja Du musst lesen - v war kein definiertes Objekt.
                                  aggregateWindow(every: 1m, fn: mean)
                                  Hier in dem Beispiel werden mittelwerte über alle Werte, die innerhalb von einer Minute auftauchen - aggregiert.
                                  Die Fehlermeldung war doch klar: "undefined identifier v" und diesen hast Du referenziert über das Objekt v mit der Eigenschaft WindowsPeriod - die wird aber nur in der GUI der InfluxDB gesetzt und hat nichts mit der Datenbank zu tun.
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #3157
                                    @mickym So sieht es momentan aus:
                                    Bildschirm­foto 2023-01-27 um 02.36.36.png Bildschirm­foto 2023-01-27 um 02.35.25.png
                                    4 verschiedene Daten mit 4 unterschiedlichen Werten. Aber vielleicht hast Du recht, das ich das länger mit Daten füttern muss.
                                    Mit besten Grüßen
                                    Andy
                                    • mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #3158
                                      @damrak2022 Ich hab dir schon mal gesagt, Du sollst die DB Abfrage nur zum Initialisieren nehmen und sonst die Datenpunkte direkt.
                                      Ich sehe hier genau 3 Werte die auch so in der Linie abgebildet werden. Der 26.1. ist in Deinem Chart gar nicht zu sehen.
                                      Am 23.1. ist 114, am 24.1. immer noch 114 dann sinkt es auf 107 - da ist doch gar nicht die ganze Zeit drauf.
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #3159
                                        @mickym sagte in Visualisierung mit Node Red erstellen:
                                        Ja, das hattest Du geschrieben und da wollte ich noch nachfragen, da ich es nicht ganz verstanden habe. Muss ich am Flow noch was anpassen, oder wie verstehe ich das? Ich weiß nicht was ich hier dann. genau machen soll?
                                        Mit besten Grüßen
                                        Andy
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #3160
                                          @damrak2022 Nochmal die Datenbank fragst Du nur einmal ab. Ansonsten siehst Du doch 3 Inject Nodes. Da hängst Du iobroker In Nodes dran, die immer die aktuellen Werte direkt in den Chart speichern. Die DB Abfrage machst Du nur um gleich zu Beginn eine Historie zu haben.
