  3. Off Topic
  4. Grafana
  5. bekomme Grafana absolut nicht auf Version 8
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
62 Beiträge 4 Kommentatoren 8.5k Aufrufe 4 Beobachtet
  • J Offline
    Jason
    #41
    @thomas-braun said in bekomme Grafana absolut nicht auf Version 8:
    echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
    Boah... es tut mir so leid
    pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    pi@raspberrypi:~ $ export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
    pi@raspberrypi:~ $ echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://www.pivccu.de/piVCCU stable InRelease
    Ign:6 https://repos.influxdata.com/raspbian buster InRelease
    Err:7 https://repos.influxdata.com/raspbian buster Release
      404  Not Found [IP: 143.204.89.64 443]
    Reading package lists... Done
    E: The repository 'https://repos.influxdata.com/raspbian buster Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    • J Jason
      #42
      @jason
      Was steht da jetzt drin?
      cat /etc/apt/sources.list.d/influxdb.list
      [Edit:]
      Ich seh schon... Mach mal aus raspbian ein debian
      • J Offline
        Jason
        #43
        Ok.. das sieht besser aus :-)
        Hit:1 https://packages.grafana.com/oss/deb stable InRelease
        Hit:2 https://www.pivccu.de/piVCCU stable InRelease
        Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [4,737 B]
        Hit:5 http://archive.raspberrypi.org/debian buster InRelease
        Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
        Get:7 https://repos.influxdata.com/debian buster/stable armhf Packages [939 B]
        Fetched 5,676 B in 2s (3,032 B/s)
        Building dependency tree
        All packages are up to date.
        • J Jason
          #44
          @jason
          Dann jetzt nochmal
          apt policy grafana*
          • J Offline
            Jason
            #45
            apt policy grafana*
            pi@raspberrypi:~ $ apt policy grafana*
            N: Unable to locate package grafana-enterprise_9.0.6_amd64.deb
            N: Couldn't find any package by glob 'grafana-enterprise_9.0.6_amd64.deb'
            N: Couldn't find any package by regex 'grafana-enterprise_9.0.6_amd64.deb'
            • J Jason
              apt policy grafana*
              #46
              @jason
              dpkg -l grafana*
              • J Offline
                Jason
                schrieb am zuletzt editiert von Jason
                #47
                dpkg -l grafana*
                pi@raspberrypi:~ $ dpkg -l grafana*
                dpkg-query: no packages found matching grafana-enterprise_9.0.6_amd64.deb
                • J Jason
                  dpkg -l grafana*
                  #48
                  @jason
                  Wie kommst du eigentlich an ein amd64-Paket für dein armhf-System? Auch von der yt-Unität?
                  Ich hab keine Ahnung wie man den Mumpitz wieder loswird...
                  • J Offline
                    Jason
                    #49
                    keine Ahnung wo das herkommt in der
                    /etc/apt/sources.list.d/grafana.list steht folgendes
                    deb https://packages.grafana.com/oss/deb stable main
                    pi@raspberrypi:/etc/apt $ dpkg --list 'grafana*'
                    Desired=Unknown/Install/Remove/Purge/Hold
                    | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                    |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                    ||/ Name               Version      Architecture Description
                    ii  grafana            9.0.6        armhf        Grafana
                    rc  grafana-enterprise 7.0.0        armhf        Grafana
                    wieso steht die enterprise 7.0.0 immer noch drin?
                    • J Jason
                      #50
                      @jason
                      rc = removal / config
                      Heißt, das Paket ist bis auf die config-Dateien entfernt worden.
                      Dein Problem ist aber eh grafana-enterprise_9.0.6_amd64.deb
                      • J Offline
                        Jason
                        #51
                        @jason said in bekomme Grafana absolut nicht auf Version 8:
                        dpkg -l grafana*
                        jetzt steht nix mehr von amd64 drin!!
                        • J Jason
                          dpkg -l grafana*
                          #52
                          @jason
                          apt policy grafana*
                          • J Offline
                            Jason
                            #53
                            apt policy grafana*
                            grafana-enterprise-rpi:
                              Installed: (none)
                              Candidate: 7.0.0
                              Version table:
                                 7.0.0 500
                                    500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                            grafana-zabbix:
                              Installed: (none)
                              Candidate: 2.5.1-1
                              Version table:
                                 2.5.1-1 500
                            grafana-enterprise:
                              Installed: (none)
                              Candidate: 7.0.0
                              Version table:
                                 7.0.0 500
                                    100 /var/lib/dpkg/status
                            grafana:
                              Installed: 9.0.6
                              Candidate: 9.0.6
                              Version table:
                             *** 9.0.6 500
                                 9.0.5 500
                                 9.0.4 500
                                 9.0.3 500
                                 9.0.2 500
                                 9.0.1 500
                                 9.0.0 500
                                 8.5.10 500
                                 8.5.9 500
                                 8.5.6 500
                                 8.5.5 500
                                 8.5.4 500
                                 8.5.3 500
                                 8.5.2 500
                                 8.5.1 500
                                 8.5.0 500
                                 8.4.10 500
                                 8.4.7 500
                                 8.4.6 500
                                 8.4.5 500
                                 8.4.4 500
                                 8.4.3 500
                                 8.4.2 500
                                 8.4.1 500
                                 8.4.0 500
                                 8.3.10 500
                                 8.3.7 500
                                 8.3.6 500
                                 8.3.5 500
                                 8.3.4 500
                                 8.3.3 500
                                 8.3.2 500
                                 8.3.1 500
                                 8.3.0 500
                                 8.2.7 500
                                 8.2.6 500
                                 8.2.5 500
                                 8.2.4 500
                                 8.2.3 500
                                 8.2.2 500
                                 8.2.1 500
                                 8.2.0 500
                                 8.1.8 500
                                 8.1.7 500
                                 8.1.6 500
                                 8.1.5 500
                                 8.1.4 500
                                 8.1.3 500
                                 8.1.2 500
                                 8.1.1 500
                                 8.1.0 500
                                 8.0.7 500
                                 8.0.6 500
                                 8.0.5 500
                                 8.0.4 500
                                 8.0.3 500
                                 8.0.2 500
                                 8.0.1 500
                                 8.0.0 500
                                 7.5.16 500
                                 7.5.15 500
                                 7.5.13 500
                                 7.5.12 500
                                 7.5.11 500
                                 7.5.10 500
                                 7.5.9 500
                                 7.5.8 500
                                 7.5.7 500
                                 7.5.6 500
                                 7.5.5 500
                                 7.5.4 500
                                 7.5.3 500
                                 7.5.2 500
                                 7.5.1 500
                                 7.5.0 500
                                 7.4.5 500
                                 7.4.3 500
                                 7.4.2 500
                                 7.4.1 500
                                 7.4.0 500
                                 7.3.10 500
                                 7.3.7 500
                                 7.3.6 500
                                 7.3.5 500
                                 7.3.4 500
                                 7.3.3 500
                                 7.3.2 500
                                 7.3.1 500
                                 7.3.0 500
                                 7.2.2 500
                                 7.2.1 500
                                 7.2.0 500
                                 7.1.5 500
                                 7.1.4 500
                                 7.1.3 500
                                 7.1.2 500
                                 7.1.1 500
                                 7.1.0 500
                                 7.0.6 500
                                 7.0.5 500
                                 7.0.4 500
                                 7.0.3 500
                                 7.0.2 500
                                 7.0.1 500
                                 7.0.0 500
                                 6.7.6 500
                                 6.7.5 500
                                 6.7.4 500
                                 6.7.3 500
                                 6.7.2 500
                                 6.7.1 500
                                 6.7.0 500
                                 6.6.2 500
                                 6.6.1 500
                                 6.6.0 500
                                 6.5.3 500
                                 6.5.2 500
                                 6.5.1 500
                                 6.5.0 500
                                 6.4.5 500
                                 6.4.4 500
                                 6.4.3 500
                                 6.4.2 500
                                 6.4.1 500
                                 6.4.0 500
                                 6.3.7 500
                                 6.3.6 500
                                 6.3.5 500
                                 6.3.4 500
                                 6.3.3 500
                                 6.3.2 500
                                 6.3.1 500
                                 6.3.0 500
                                 6.2.5 500
                                 6.2.4 500
                                 6.2.3 500
                                 6.2.2 500
                                 6.2.1 500
                                 6.2.0 500
                                 6.1.6 500
                                 6.1.5 500
                                 6.1.4 500
                                 6.1.3 500
                                 6.1.2 500
                                 6.1.1 500
                                 6.1.0 500
                                 6.0.2 500
                                 6.0.1 500
                                 6.0.0 500
                                 5.4.5 500
                                 5.4.4 500
                                 5.4.3 500
                                 5.4.2 500
                                 5.4.1 500
                                 5.4.0 500
                                 5.3.4 500
                                 5.3.3 500
                                 5.3.2 500
                                 5.3.1 500
                                 5.3.0 500
                                 5.2.5 500
                                 5.2.4 500
                                 5.2.3 500
                                 5.2.2 500
                                 5.2.1 500
                                 5.2.0 500
                            grafana-rpi:
                              Installed: (none)
                              Candidate: 7.4.0
                              Version table:
                                 7.4.0 500
                                 7.3.3 500
                                 7.3.2 500
                                 7.3.1 500
                                 7.3.0 500
                                 7.2.2 500
                                 7.2.1 500
                                 7.2.0 500
                                 7.1.5 500
                                 7.1.4 500
                                 7.1.3 500
                                 7.1.2 500
                                 7.1.1 500
                                 7.1.0 500
                                 7.0.6 500
                                 7.0.5 500
                                 7.0.4 500
                                 7.0.3 500
                                 7.0.2 500
                                 7.0.1 500
                                 7.0.0 500
                                 6.7.6 500
                                 6.7.4 500
                                 6.7.3 500
                                 6.7.2 500
                                 6.7.1 500
                                 6.7.0 500
                                 6.6.2 500
                                 6.6.1 500
                                 6.6.0 500
                                 6.5.3 500
                                 6.5.2 500
                                 6.5.1 500
                                 6.5.0 500
                                 6.4.5 500
                                 6.4.4 500
                                 6.4.3 500
                                 6.4.2 500
                                 6.4.1 500
                                 6.4.0 500
                                 6.3.7 500
                                 6.3.6 500
                                 6.3.5 500
                                 6.3.4 500
                                 6.3.3 500
                                 6.3.2 500
                                 6.3.1 500
                                 6.3.0 500
                                 6.2.5 500
                                 6.2.4 500
                                 6.2.3 500
                                 6.2.2 500
                                 6.2.1 500
                                 6.2.0 500
                                 6.1.6 500
                                 6.1.5 500
                                 6.1.4 500
                                 6.1.3 500
                                 6.1.2 500
                                 6.1.1 500
                                 6.1.0 500
                            pi@raspberrypi:~ $
                            • J Jason
                              apt policy grafana*
                                Installed: (none)
                                Candidate: 7.0.0
                                Version table:
                                   7.0.0 500
                              grafana-zabbix:
                                Installed: (none)
                                Candidate: 2.5.1-1
                                Version table:
                                   2.5.1-1 500
                              grafana-enterprise:
                                Installed: (none)
                                Candidate: 7.0.0
                                Version table:
                                   7.0.0 500
                              grafana:
                                Installed: 9.0.6
                                Candidate: 9.0.6
                                Version table:
                               *** 9.0.6 500
                                   9.0.5 500
                                   9.0.4 500
                                   9.0.3 500
                                   9.0.2 500
                                   9.0.1 500
                                   9.0.0 500
                                   8.5.10 500
                                   8.5.9 500
                                   8.5.6 500
                                   8.5.5 500
                                   8.5.4 500
                                   8.5.3 500
                                   8.5.2 500
                                   8.5.1 500
                                   8.5.0 500
                                   8.4.10 500
                                   8.4.7 500
                                   8.4.6 500
                                   8.4.5 500
                                   8.4.4 500
                                   8.4.3 500
                                   8.4.2 500
                                   8.4.1 500
                                   8.4.0 500
                                   8.3.10 500
                                   8.3.7 500
                                   8.3.6 500
                                   8.3.5 500
                                   8.3.4 500
                                   8.3.3 500
                                   8.3.2 500
                                   8.3.1 500
                                   8.3.0 500
                                   8.2.7 500
                                   8.2.6 500
                                   8.2.5 500
                                   8.2.4 500
                                   8.2.3 500
                                   8.2.2 500
                                   8.2.1 500
                                   8.2.0 500
                                   8.1.8 500
                                   8.1.7 500
                                   8.1.6 500
                                   8.1.5 500
                                   8.1.4 500
                                   8.1.3 500
                                   8.1.2 500
                                   8.1.1 500
                                   8.1.0 500
                                   8.0.7 500
                                   8.0.6 500
                                   8.0.5 500
                                   8.0.4 500
                                   8.0.3 500
                                   8.0.2 500
                                   8.0.1 500
                                   8.0.0 500
                                   7.5.16 500
                                   7.5.15 500
                                   7.5.13 500
                                   7.5.12 500
                                   7.5.11 500
                                   7.5.10 500
                                   7.5.9 500
                                   7.5.8 500
                                   7.5.7 500
                                   7.5.6 500
                                   7.5.5 500
                                   7.5.4 500
                                   7.5.3 500
                                   7.5.2 500
                                   7.5.1 500
                                   7.5.0 500
                                   7.4.5 500
                                   7.4.3 500
                                   7.4.2 500
                                   7.4.1 500
                                   7.4.0 500
                                   7.3.10 500
                                   7.3.7 500
                                   7.3.6 500
                                   7.3.5 500
                                   7.3.4 500
                                   7.3.3 500
                                   7.3.2 500
                                   7.3.1 500
                                   7.3.0 500
                                   7.2.2 500
                                   7.2.1 500
                                   7.2.0 500
                                   7.1.5 500
                                   7.1.4 500
                                   7.1.3 500
                                   7.1.2 500
                                   7.1.1 500
                                   7.1.0 500
                                   7.0.6 500
                                   7.0.5 500
                                   7.0.4 500
                                   7.0.3 500
                                   7.0.2 500
                                   7.0.1 500
                                   7.0.0 500
                                   6.7.6 500
                                   6.7.5 500
                                   6.7.4 500
                                   6.7.3 500
                                   6.7.2 500
                                   6.7.1 500
                                   6.7.0 500
                                   6.6.2 500
                                   6.6.1 500
                                   6.6.0 500
                                   6.5.3 500
                                   6.5.2 500
                                   6.5.1 500
                                   6.5.0 500
                                   6.4.5 500
                                   6.4.4 500
                                   6.4.3 500
                                   6.4.2 500
                                   6.4.1 500
                                   6.4.0 500
                                   6.3.7 500
                                   6.3.6 500
                                   6.3.5 500
                                   6.3.4 500
                                   6.3.3 500
                                   6.3.2 500
                                   6.3.1 500
                                   6.3.0 500
                                   6.2.5 500
                                   6.2.4 500
                                   6.2.3 500
                                   6.2.2 500
                                   6.2.1 500
                                   6.2.0 500
                                   6.1.6 500
                                   6.1.5 500
                                   6.1.4 500
                                   6.1.3 500
                                   6.1.2 500
                                   6.1.1 500
                                   6.1.0 500
                                   6.0.2 500
                                   6.0.1 500
                                   6.0.0 500
                                   5.4.5 500
                                   5.4.4 500
                                   5.4.3 500
                                   5.4.2 500
                                   5.4.1 500
                                   5.4.0 500
                                   5.3.4 500
                                   5.3.3 500
                                   5.3.2 500
                                   5.3.1 500
                                   5.3.0 500
                                   5.2.5 500
                                   5.2.4 500
                                   5.2.3 500
                                   5.2.2 500
                                   5.2.1 500
                                   5.2.0 500
                              grafana-rpi:
                                Installed: (none)
                                Candidate: 7.4.0
                                Version table:
                                   7.4.0 500
                                   7.3.3 500
                                   7.3.2 500
                                   7.3.1 500
                                   7.3.0 500
                                   7.2.2 500
                                   7.2.1 500
                                   7.2.0 500
                                   7.1.5 500
                                   7.1.4 500
                                   7.1.3 500
                                   7.1.2 500
                                   7.1.1 500
                                   7.1.0 500
                                   7.0.6 500
                                   7.0.5 500
                                   7.0.4 500
                                   7.0.3 500
                                   7.0.2 500
                                   7.0.1 500
                                   7.0.0 500
                                   6.7.6 500
                                   6.7.4 500
                                   6.7.3 500
                                   6.7.2 500
                                   6.7.1 500
                                   6.7.0 500
                                   6.6.2 500
                                   6.6.1 500
                                   6.6.0 500
                                   6.5.3 500
                                   6.5.2 500
                                   6.5.1 500
                                   6.5.0 500
                                   6.4.5 500
                                   6.4.4 500
                                   6.4.3 500
                                   6.4.2 500
                                   6.4.1 500
                                   6.4.0 500
                                   6.3.7 500
                                   6.3.6 500
                                   6.3.5 500
                                   6.3.4 500
                                   6.3.3 500
                                   6.3.2 500
                                   6.3.1 500
                                   6.3.0 500
                                   6.2.5 500
                                   6.2.4 500
                                   6.2.3 500
                                   6.2.2 500
                                   6.2.1 500
                                   6.2.0 500
                                   6.1.6 500
                                   6.1.5 500
                                   6.1.4 500
                                   6.1.3 500
                                   6.1.2 500
                                   6.1.1 500
                                   6.1.0 500
                              pi@raspberrypi:~ $
                              #54
                              @jason
                              Das müsste jetzt sauber sein.
                              • J Offline
                                Jason
                                #55
                                ok, wie gehts weiter? weil laufen tut es noch nicht :(
                                • J Jason
                                  #56
                                  @jason sagte in bekomme Grafana absolut nicht auf Version 8:
                                  Heißt?
                                  systemctl status grafana-server
                                  • J Offline
                                    Jason
                                    #57
                                    pi@raspberrypi:~ $ systemctl status grafana-server
                                    ● grafana-server.service - Grafana instance
                                       Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                                       Active: failed (Result: exit-code) since Mon 2022-08-08 19:34:23 CEST; 2h 35min ago
                                         Docs: http://docs.grafana.org
                                      Process: 679 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb
                                     Main PID: 679 (code=exited, status=203/EXEC)
                                    Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
                                    Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                                    Aug 08 19:34:23 raspberrypi systemd[1]: Stopped Grafana instance.
                                    Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Start request repeated too quickly.
                                    Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                                    Aug 08 19:34:23 raspberrypi systemd[1]: Failed to start Grafana instance.
                                    • J Jason
                                      #58
                                      @jason
                                      sudo reboot
                                      • J Offline
                                        Jason
                                        #59
                                        gleiches Spiel :(
                                           Active: failed (Result: exit-code) since Mon 2022-08-08 22:13:22 CEST; 8min ago
                                          Process: 706 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb
                                         Main PID: 706 (code=exited, status=203/EXEC)
                                        Aug 08 22:13:22 raspberrypi systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
                                        Aug 08 22:13:22 raspberrypi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                                        Aug 08 22:13:22 raspberrypi systemd[1]: Stopped Grafana instance.
                                        Aug 08 22:13:22 raspberrypi systemd[1]: grafana-server.service: Start request repeated too quickly.
                                        Aug 08 22:13:22 raspberrypi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                                        Aug 08 22:13:22 raspberrypi systemd[1]: Failed to start Grafana instance.
                                        lines 1-13/13 (END)
                                        • Thomas BraunT Online
                                          #60
                                          Versuch mal
                                          sudo apt-get --purge remove grafana
                                          Killt dir aber die config.
                                          sudo apt install grafana
                                          sollte es dann wieder frisch draufladen.
