  3. Off Topic
  4. Grafana
  5. bekomme Grafana absolut nicht auf Version 8
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
62 Beiträge 4 Kommentatoren 8.5k Aufrufe 4 Beobachtet
  • J Offline
    Jason
    natürlich nicht :(
    wie bekomme ich den?
    Vielen Dank für Deine Geduld !!!
    • J Jason
      natürlich nicht :(
      @jason
      wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
      export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
      echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
      • J Offline
        Jason
        @thomas-braun said in bekomme Grafana absolut nicht auf Version 8:
        Boah... es tut mir so leid
        pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
        pi@raspberrypi:~ $ export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
        pi@raspberrypi:~ $ echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
        pi@raspberrypi:~ $ sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:4 https://packages.grafana.com/oss/deb stable InRelease
        Hit:5 https://www.pivccu.de/piVCCU stable InRelease
        Ign:6 https://repos.influxdata.com/raspbian buster InRelease
        Err:7 https://repos.influxdata.com/raspbian buster Release
          404  Not Found [IP: 143.204.89.64 443]
        Reading package lists... Done
        E: The repository 'https://repos.influxdata.com/raspbian buster Release' does not have a Release file.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        • J Jason
          @jason
          Was steht da jetzt drin?
          cat /etc/apt/sources.list.d/influxdb.list
          [Edit:]
          Ich seh schon... Mach mal aus raspbian ein debian
          • J Offline
            Jason
            Ok.. das sieht besser aus :-)
            Hit:1 https://packages.grafana.com/oss/deb stable InRelease
            Hit:2 https://www.pivccu.de/piVCCU stable InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Get:4 https://repos.influxdata.com/debian buster InRelease [4,737 B]
            Hit:5 http://archive.raspberrypi.org/debian buster InRelease
            Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
            Get:7 https://repos.influxdata.com/debian buster/stable armhf Packages [939 B]
            Fetched 5,676 B in 2s (3,032 B/s)
            Building dependency tree
            All packages are up to date.
            • J Jason
              @jason
              Dann jetzt nochmal
              apt policy grafana*
              • J Offline
                Jason
                apt policy grafana*
                pi@raspberrypi:~ $ apt policy grafana*
                N: Unable to locate package grafana-enterprise_9.0.6_amd64.deb
                N: Couldn't find any package by glob 'grafana-enterprise_9.0.6_amd64.deb'
                N: Couldn't find any package by regex 'grafana-enterprise_9.0.6_amd64.deb'
                • J Jason
                  apt policy grafana*
                  @jason
                  dpkg -l grafana*
                  • J Offline
                    Jason
                    schrieb am zuletzt editiert von Jason
                    dpkg -l grafana*
                    pi@raspberrypi:~ $ dpkg -l grafana*
                    dpkg-query: no packages found matching grafana-enterprise_9.0.6_amd64.deb
                    • J Jason
                      dpkg -l grafana*
                      @jason
                      Wie kommst du eigentlich an ein amd64-Paket für dein armhf-System? Auch von der yt-Unität?
                      Ich hab keine Ahnung wie man den Mumpitz wieder loswird...
                      • J Offline
                        Jason
                        keine Ahnung wo das herkommt in der
                        /etc/apt/sources.list.d/grafana.list steht folgendes
                        deb https://packages.grafana.com/oss/deb stable main
                        pi@raspberrypi:/etc/apt $ dpkg --list 'grafana*'
                        Desired=Unknown/Install/Remove/Purge/Hold
                        | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                        |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                        ||/ Name               Version      Architecture Description
                        ii  grafana            9.0.6        armhf        Grafana
                        rc  grafana-enterprise 7.0.0        armhf        Grafana
                        wieso steht die enterprise 7.0.0 immer noch drin?
                        • J Jason
                          @jason
                          rc = removal / config
                          Heißt, das Paket ist bis auf die config-Dateien entfernt worden.
                          Dein Problem ist aber eh grafana-enterprise_9.0.6_amd64.deb
                          • J Offline
                            Jason
                            @jason said in bekomme Grafana absolut nicht auf Version 8:
                            dpkg -l grafana*
                            jetzt steht nix mehr von amd64 drin!!
                            • J Jason
                              dpkg -l grafana*
                              @jason
                              apt policy grafana*
                              • J Offline
                                Jason
                                apt policy grafana*
                                grafana-enterprise-rpi:
                                  Installed: (none)
                                  Candidate: 7.0.0
                                  Version table:
                                     7.0.0 500
                                        500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                grafana-zabbix:
                                  Installed: (none)
                                  Candidate: 2.5.1-1
                                  Version table:
                                     2.5.1-1 500
                                grafana-enterprise:
                                  Installed: (none)
                                  Candidate: 7.0.0
                                  Version table:
                                     7.0.0 500
                                grafana:
                                  Installed: 9.0.6
                                  Candidate: 9.0.6
                                  Version table:
                                 *** 9.0.6 500
                                     9.0.5 500
                                     9.0.4 500
                                     9.0.3 500
                                     9.0.2 500
                                     9.0.1 500
                                     9.0.0 500
                                     8.5.10 500
                                     8.5.9 500
                                     8.5.6 500
                                     8.5.5 500
                                     8.5.4 500
                                     8.5.3 500
                                     8.5.2 500
                                     8.5.1 500
                                     8.5.0 500
                                     8.4.10 500
                                     8.4.7 500
                                     8.4.6 500
                                     8.4.5 500
                                     8.4.4 500
                                     8.4.3 500
                                     8.4.2 500
                                     8.4.1 500
                                     8.4.0 500
                                     8.3.10 500
                                     8.3.7 500
                                     8.3.6 500
                                     8.3.5 500
                                     8.3.4 500
                                     8.3.3 500
                                     8.3.2 500
                                     8.3.1 500
                                     8.3.0 500
                                     8.2.7 500
                                     8.2.6 500
                                     8.2.5 500
                                     8.2.4 500
                                     8.2.3 500
                                     8.2.2 500
                                     8.2.1 500
                                     8.2.0 500
                                     8.1.8 500
                                     8.1.7 500
                                     8.1.6 500
                                     8.1.5 500
                                     8.1.4 500
                                     8.1.3 500
                                     8.1.2 500
                                     8.1.1 500
                                     8.1.0 500
                                     8.0.7 500
                                     8.0.6 500
                                     8.0.5 500
                                     8.0.4 500
                                     8.0.3 500
                                     8.0.2 500
                                     8.0.1 500
                                     8.0.0 500
                                     7.5.16 500
                                     7.5.15 500
                                     7.5.13 500
                                     7.5.12 500
                                     7.5.11 500
                                     7.5.10 500
                                     7.5.9 500
                                     7.5.8 500
                                     7.5.7 500
                                     7.5.6 500
                                     7.5.5 500
                                     7.5.4 500
                                     7.5.3 500
                                     7.5.2 500
                                     7.5.1 500
                                     7.5.0 500
                                     7.4.5 500
                                     7.4.3 500
                                     7.4.2 500
                                     7.4.1 500
                                     7.4.0 500
                                     7.3.10 500
                                     7.3.7 500
                                     7.3.6 500
                                     7.3.5 500
                                     7.3.4 500
                                     7.3.3 500
                                     7.3.2 500
                                     7.3.1 500
                                     7.3.0 500
                                     7.2.2 500
                                     7.2.1 500
                                     7.2.0 500
                                     7.1.5 500
                                     7.1.4 500
                                     7.1.3 500
                                     7.1.2 500
                                     7.1.1 500
                                     7.1.0 500
                                     7.0.6 500
                                     7.0.5 500
                                     7.0.4 500
                                     7.0.3 500
                                     7.0.2 500
                                     7.0.1 500
                                     7.0.0 500
                                     6.7.6 500
                                     6.7.5 500
                                     6.7.4 500
                                     6.7.3 500
                                     6.7.2 500
                                     6.7.1 500
                                     6.7.0 500
                                     6.6.2 500
                                     6.6.1 500
                                     6.6.0 500
                                     6.5.3 500
                                     6.5.2 500
                                     6.5.1 500
                                     6.5.0 500
                                     6.4.5 500
                                     6.4.4 500
                                     6.4.3 500
                                     6.4.2 500
                                     6.4.1 500
                                     6.4.0 500
                                     6.3.7 500
                                     6.3.6 500
                                     6.3.5 500
                                     6.3.4 500
                                     6.3.3 500
                                     6.3.2 500
                                     6.3.1 500
                                     6.3.0 500
                                     6.2.5 500
                                     6.2.4 500
                                     6.2.3 500
                                     6.2.2 500
                                     6.2.1 500
                                     6.2.0 500
                                     6.1.6 500
                                     6.1.5 500
                                     6.1.4 500
                                     6.1.3 500
                                     6.1.2 500
                                     6.1.1 500
                                     6.1.0 500
                                     6.0.2 500
                                     6.0.1 500
                                     6.0.0 500
                                     5.4.5 500
                                     5.4.4 500
                                     5.4.3 500
                                     5.4.2 500
                                     5.4.1 500
                                     5.4.0 500
                                     5.3.4 500
                                     5.3.3 500
                                     5.3.2 500
                                     5.3.1 500
                                     5.3.0 500
                                     5.2.5 500
                                     5.2.4 500
                                     5.2.3 500
                                     5.2.2 500
                                     5.2.1 500
                                     5.2.0 500
                                grafana-rpi:
                                  Installed: (none)
                                  Candidate: 7.4.0
                                  Version table:
                                     7.4.0 500
                                     7.3.3 500
                                     7.3.2 500
                                     7.3.1 500
                                     7.3.0 500
                                     7.2.2 500
                                     7.2.1 500
                                     7.2.0 500
                                     7.1.5 500
                                     7.1.4 500
                                     7.1.3 500
                                     7.1.2 500
                                     7.1.1 500
                                     7.1.0 500
                                     7.0.6 500
                                     7.0.5 500
                                     7.0.4 500
                                     7.0.3 500
                                     7.0.2 500
                                     7.0.1 500
                                     7.0.0 500
                                     6.7.6 500
                                     6.7.4 500
                                     6.7.3 500
                                     6.7.2 500
                                     6.7.1 500
                                     6.7.0 500
                                     6.6.2 500
                                     6.6.1 500
                                     6.6.0 500
                                     6.5.3 500
                                     6.5.2 500
                                     6.5.1 500
                                     6.5.0 500
                                     6.4.5 500
                                     6.4.4 500
                                     6.4.3 500
                                     6.4.2 500
                                     6.4.1 500
                                     6.4.0 500
                                     6.3.7 500
                                     6.3.6 500
                                     6.3.5 500
                                     6.3.4 500
                                     6.3.3 500
                                     6.3.2 500
                                     6.3.1 500
                                     6.3.0 500
                                     6.2.5 500
                                     6.2.4 500
                                     6.2.3 500
                                     6.2.2 500
                                     6.2.1 500
                                     6.2.0 500
                                     6.1.6 500
                                     6.1.5 500
                                     6.1.4 500
                                     6.1.3 500
                                     6.1.2 500
                                     6.1.1 500
                                     6.1.0 500
                                pi@raspberrypi:~ $
                                • J Jason
                                  apt policy grafana*
                                    Installed: (none)
                                    Candidate: 7.0.0
                                    Version table:
                                       7.0.0 500
                                  grafana-zabbix:
                                    Installed: (none)
                                    Candidate: 2.5.1-1
                                    Version table:
                                       2.5.1-1 500
                                  grafana-enterprise:
                                    Installed: (none)
                                    Candidate: 7.0.0
                                    Version table:
                                       7.0.0 500
                                  grafana:
                                    Installed: 9.0.6
                                    Candidate: 9.0.6
                                    Version table:
                                   *** 9.0.6 500
                                       9.0.5 500
                                       9.0.4 500
                                       9.0.3 500
                                       9.0.2 500
                                       9.0.1 500
                                       9.0.0 500
                                       8.5.10 500
                                       8.5.9 500
                                       8.5.6 500
                                       8.5.5 500
                                       8.5.4 500
                                       8.5.3 500
                                       8.5.2 500
                                       8.5.1 500
                                       8.5.0 500
                                       8.4.10 500
                                       8.4.7 500
                                       8.4.6 500
                                       8.4.5 500
                                       8.4.4 500
                                       8.4.3 500
                                       8.4.2 500
                                       8.4.1 500
                                       8.4.0 500
                                       8.3.10 500
                                       8.3.7 500
                                       8.3.6 500
                                       8.3.5 500
                                       8.3.4 500
                                       8.3.3 500
                                       8.3.2 500
                                       8.3.1 500
                                       8.3.0 500
                                       8.2.7 500
                                       8.2.6 500
                                       8.2.5 500
                                       8.2.4 500
                                       8.2.3 500
                                       8.2.2 500
                                       8.2.1 500
                                       8.2.0 500
                                       8.1.8 500
                                       8.1.7 500
                                       8.1.6 500
                                       8.1.5 500
                                       8.1.4 500
                                       8.1.3 500
                                       8.1.2 500
                                       8.1.1 500
                                       8.1.0 500
                                       8.0.7 500
                                       8.0.6 500
                                       8.0.5 500
                                       8.0.4 500
                                       8.0.3 500
                                       8.0.2 500
                                       8.0.1 500
                                       8.0.0 500
                                       7.5.16 500
                                       7.5.15 500
                                       7.5.13 500
                                       7.5.12 500
                                       7.5.11 500
                                       7.5.10 500
                                       7.5.9 500
                                       7.5.8 500
                                       7.5.7 500
                                       7.5.6 500
                                       7.5.5 500
                                       7.5.4 500
                                       7.5.3 500
                                       7.5.2 500
                                       7.5.1 500
                                       7.5.0 500
                                       7.4.5 500
                                       7.4.3 500
                                       7.4.2 500
                                       7.4.1 500
                                       7.4.0 500
                                       7.3.10 500
                                       7.3.7 500
                                       7.3.6 500
                                       7.3.5 500
                                       7.3.4 500
                                       7.3.3 500
                                       7.3.2 500
                                       7.3.1 500
                                       7.3.0 500
                                       7.2.2 500
                                       7.2.1 500
                                       7.2.0 500
                                       7.1.5 500
                                       7.1.4 500
                                       7.1.3 500
                                       7.1.2 500
                                       7.1.1 500
                                       7.1.0 500
                                       7.0.6 500
                                       7.0.5 500
                                       7.0.4 500
                                       7.0.3 500
                                       7.0.2 500
                                       7.0.1 500
                                       7.0.0 500
                                       6.7.6 500
                                       6.7.5 500
                                       6.7.4 500
                                       6.7.3 500
                                       6.7.2 500
                                       6.7.1 500
                                       6.7.0 500
                                       6.6.2 500
                                       6.6.1 500
                                       6.6.0 500
                                       6.5.3 500
                                       6.5.2 500
                                       6.5.1 500
                                       6.5.0 500
                                       6.4.5 500
                                       6.4.4 500
                                       6.4.3 500
                                       6.4.2 500
                                       6.4.1 500
                                       6.4.0 500
                                       6.3.7 500
                                       6.3.6 500
                                       6.3.5 500
                                       6.3.4 500
                                       6.3.3 500
                                       6.3.2 500
                                       6.3.1 500
                                       6.3.0 500
                                       6.2.5 500
                                       6.2.4 500
                                       6.2.3 500
                                       6.2.2 500
                                       6.2.1 500
                                       6.2.0 500
                                       6.1.6 500
                                       6.1.5 500
                                       6.1.4 500
                                       6.1.3 500
                                       6.1.2 500
                                       6.1.1 500
                                       6.1.0 500
                                       6.0.2 500
                                       6.0.1 500
                                       6.0.0 500
                                       5.4.5 500
                                       5.4.4 500
                                       5.4.3 500
                                       5.4.2 500
                                       5.4.1 500
                                       5.4.0 500
                                       5.3.4 500
                                       5.3.3 500
                                       5.3.2 500
                                       5.3.1 500
                                       5.3.0 500
                                       5.2.5 500
                                       5.2.4 500
                                       5.2.3 500
                                       5.2.2 500
                                       5.2.1 500
                                       5.2.0 500
                                  grafana-rpi:
                                    Installed: (none)
                                    Candidate: 7.4.0
                                    Version table:
                                       7.4.0 500
                                       7.3.3 500
                                       7.3.2 500
                                       7.3.1 500
                                       7.3.0 500
                                       7.2.2 500
                                       7.2.1 500
                                       7.2.0 500
                                       7.1.5 500
                                       7.1.4 500
                                       7.1.3 500
                                       7.1.2 500
                                       7.1.1 500
                                       7.1.0 500
                                       7.0.6 500
                                       7.0.5 500
                                       7.0.4 500
                                       7.0.3 500
                                       7.0.2 500
                                       7.0.1 500
                                       7.0.0 500
                                       6.7.6 500
                                       6.7.4 500
                                       6.7.3 500
                                       6.7.2 500
                                       6.7.1 500
                                       6.7.0 500
                                       6.6.2 500
                                       6.6.1 500
                                       6.6.0 500
                                       6.5.3 500
                                       6.5.2 500
                                       6.5.1 500
                                       6.5.0 500
                                       6.4.5 500
                                       6.4.4 500
                                       6.4.3 500
                                       6.4.2 500
                                       6.4.1 500
                                       6.4.0 500
                                       6.3.7 500
                                       6.3.6 500
                                       6.3.5 500
                                       6.3.4 500
                                       6.3.3 500
                                       6.3.2 500
                                       6.3.1 500
                                       6.3.0 500
                                       6.2.5 500
                                       6.2.4 500
                                       6.2.3 500
                                       6.2.2 500
                                       6.2.1 500
                                       6.2.0 500
                                       6.1.6 500
                                       6.1.5 500
                                       6.1.4 500
                                       6.1.3 500
                                       6.1.2 500
                                       6.1.1 500
                                       6.1.0 500
                                  pi@raspberrypi:~ $
                                  @jason
                                  Das müsste jetzt sauber sein.
                                  • J Offline
                                    Jason
                                    ok, wie gehts weiter? weil laufen tut es noch nicht :(
                                    • J Jason
                                      @jason sagte in bekomme Grafana absolut nicht auf Version 8:
                                      Heißt?
                                      systemctl status grafana-server
                                      • J Offline
                                        Jason
                                        pi@raspberrypi:~ $ systemctl status grafana-server
                                        ● grafana-server.service - Grafana instance
                                           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                                           Active: failed (Result: exit-code) since Mon 2022-08-08 19:34:23 CEST; 2h 35min ago
                                             Docs: http://docs.grafana.org
                                          Process: 679 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb
                                         Main PID: 679 (code=exited, status=203/EXEC)
                                        Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
                                        Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                                        Aug 08 19:34:23 raspberrypi systemd[1]: Stopped Grafana instance.
                                        Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Start request repeated too quickly.
                                        Aug 08 19:34:23 raspberrypi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                                        Aug 08 19:34:23 raspberrypi systemd[1]: Failed to start Grafana instance.
                                        • J Jason
                                          @jason
                                          sudo reboot
