  4. (gelöst) Adapter lassen sich nicht updaten
    5.8k
55 Beiträge 7 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • M michael_4358
    @glasfaser
    das war nicht gewollt...
    kann ich das wieder ändern❓
    mickymM Offline
    mickymM Offline
    mickym
    #41
    @michael_4358 Hab ich Dir gerade geschrieben.
    • mickymM mickym
      michael_4358
      #42
      @mickym said in Adapter lassen sich nicht updaten:
      ist noch auf der 8.15 ...
      • M michael_4358
        #43
        @michael_4358
        sudo apt install --reinstall nodejs
          michael_4358
          #44
          Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
          Update iot from @1.11.4 to @1.11.8
          NPM version: 8.11.0
          Installing iobroker.iot@1.11.8... (System call)
          npm WARN tarball tarball data for socksv5@https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9 (sha1-sjQ0+FwyNcrhxXborBfKzWTTuL0=) seems to be corrupted. Trying again.
          npm ERR! code EBADENGINE
          npm ERR! engine Unsupported engine
          npm ERR! engine Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
          npm ERR! notsup Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
          npm ERR! notsup Required: {"node":"^10 || ^12 || ^14 || ^15"}
          npm ERR! notsup Actual:   {"npm":"8.11.0","node":"v16.16.0"}
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-28T14_06_13_392Z-debug-0.log
          upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
          upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
          upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
          upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
          upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
          upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
          upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
          upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
          upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
          upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
          upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
          upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
          upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js static/js/2.1d439ead.chunk.js application/javascript
          upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.LICENSE.txt static/js/2.1d439ead.chunk.js.LICENSE.txt text/plain
          upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.map static/js/2.1d439ead.chunk.js.map application/json
          upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js static/js/main.846bc990.chunk.js application/javascript
          upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js.map static/js/main.846bc990.chunk.js.map application/json
          upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js static/js/runtime-main.1a18d9e5.js application/javascript
          upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js.map static/js/runtime-main.1a18d9e5.js.map application/json
          mickymM Thomas BraunT 2 Antworten Letzte Antwort
          • M michael_4358
            NPM version: 8.11.0
            mickymM Offline
            mickymM Offline
            mickym
            #45
            @michael_4358 Hast Du die package-lock.json entfernt?
            Also ich fürchte ich kann nicht mehr weiterhelfen (vielleicht aber noch andere) ausser mit meiner Radikalkur aber halt ohne Gewähr. ;)
            Mach mal eine Komplettsicherung, sodass Du notfalls auf Deinen jetzigen Stand zurückkehren kannst und probiere :
            https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/23?_=1658914381795
            • M michael_4358
              NPM version: 8.11.0
              #46
              @michael_4358
              sudo -H -u iobroker npm cache clear --force
              Durch die Herumrutscherei als root kann es aber auch sein, dass du da die Rechte verbogen hast (oder der chache beim root liegt. Oder anderes 'unerklärliches' Zeug passiert ist).
                @michael_4358
                michael_4358
                #47
                @thomas-braun said in Adapter lassen sich nicht updaten:
                @michael_4358
                wahrscheinlich hast du recht....
                wird wohl das beste sein
                back up hab ich
                also auf Anfang ❗️
                • M michael_4358
                  @michael_4358
                  back up hab ich
                  also auf Anfang ❗️
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #48
                  @michael_4358 Na wenn Du Backup hast und eh neu aufbaust, kannst ja nochmal versuchen, das node_modules Verzeichnis wie beschrieben, neu aufzubauen.
                  • M michael_4358
                    dein shift klemmt...
                    es ändert aber nichts am ablauf ob root oder nicht...
                    #49
                    @michael_4358 sagte in Adapter lassen sich nicht updaten:
                    @thomas-braun sagte in Adapter lassen sich nicht updaten:
                    Das Arbeiten unter root kann immer irgendetwas verbiegen, wo es erst viel später zu Problemen kommt.
                    Wenn du jetzt neu anfangen willst, denke daran!
                      michael_4358
                      #50
                      wollen nicht aber scheint wohl einfach zusein
                        michael_4358
                        #51
                        als letzten versuch habe ich node js auf Version 15 zurück gespielt...
                        nun geht wieder alles
                        • M michael_4358
                          Meister MopperM Online
                          Meister Mopper
                          #52
                          @michael_4358
                          Ungerade Versionen (z. B. 15) sind beta Versionen (für Entwickler). Stable sind die geraden (z. B. 14 < 16).
                          Proxmox und HA ...
                            @michael_4358
                            michael_4358
                            #53
                            @meister-mopper
                            Mag sein❗️
                            Nach dieser Achterbahnfahrt werde ich das erstmal ruhen lassen ❗️
                            • M michael_4358
                              @meister-mopper
                              Mag sein❗️
                              #54
                              @michael_4358
                              Die node 15 ist allerdings als Interims-Version schon wieder aus dem Support raus:
                              https://nodejs.org/en/about/releases/
                                @michael_4358
                                michael_4358
                                #55
                                @thomas-braun said in (gelöst) Adapter lassen sich nicht updaten:
                                @michael_4358
                                das habe ich gelesen.
                                als lts wäre 14 noch gewesen..
                                warum ich 15 gewählt habe kann ich dir auch nicht sagen.
                                werde die tage ein gleiches system parallel installieren und testen
