  4. (gelöst) Adapter lassen sich nicht updaten
    5.8k
55 Beiträge 7 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • M michael_4358
    Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
    Update iot from @1.11.4 to @1.11.8
    NPM version: 8.11.0
    Installing iobroker.iot@1.11.8... (System call)
    npm WARN tarball tarball data for socksv5@https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9 (sha1-sjQ0+FwyNcrhxXborBfKzWTTuL0=) seems to be corrupted. Trying again.
    npm ERR! code EBADENGINE
    npm ERR! engine Unsupported engine
    npm ERR! engine Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
    npm ERR! notsup Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
    npm ERR! notsup Required: {"node":"^10 || ^12 || ^14 || ^15"}
    npm ERR! notsup Actual:   {"npm":"8.11.0","node":"v16.16.0"}
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-28T14_06_13_392Z-debug-0.log
    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js static/js/2.1d439ead.chunk.js application/javascript
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.LICENSE.txt static/js/2.1d439ead.chunk.js.LICENSE.txt text/plain
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.map static/js/2.1d439ead.chunk.js.map application/json
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js static/js/main.846bc990.chunk.js application/javascript
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js.map static/js/main.846bc990.chunk.js.map application/json
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js static/js/runtime-main.1a18d9e5.js application/javascript
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js.map static/js/runtime-main.1a18d9e5.js.map application/json
    mickymM Offline
    mickymM Offline
    mickym
    @michael_4358 Hast Du die package-lock.json entfernt?
    Also ich fürchte ich kann nicht mehr weiterhelfen (vielleicht aber noch andere) ausser mit meiner Radikalkur aber halt ohne Gewähr. ;)
    Mach mal eine Komplettsicherung, sodass Du notfalls auf Deinen jetzigen Stand zurückkehren kannst und probiere :
    https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/23?_=1658914381795
    • M michael_4358
      NPM version: 8.11.0
      @michael_4358
      sudo -H -u iobroker npm cache clear --force
      Durch die Herumrutscherei als root kann es aber auch sein, dass du da die Rechte verbogen hast (oder der chache beim root liegt. Oder anderes 'unerklärliches' Zeug passiert ist).
        @michael_4358
        michael_4358
        @thomas-braun said in Adapter lassen sich nicht updaten:
        @michael_4358
        wahrscheinlich hast du recht....
        wird wohl das beste sein
        back up hab ich
        also auf Anfang ❗️
        • M michael_4358
          @michael_4358
          back up hab ich
          also auf Anfang ❗️
          mickymM Offline
          mickymM Offline
          mickym
          @michael_4358 Na wenn Du Backup hast und eh neu aufbaust, kannst ja nochmal versuchen, das node_modules Verzeichnis wie beschrieben, neu aufzubauen.
          • M michael_4358
            dein shift klemmt...
            es ändert aber nichts am ablauf ob root oder nicht...
            @michael_4358 sagte in Adapter lassen sich nicht updaten:
            @thomas-braun sagte in Adapter lassen sich nicht updaten:
            Das Arbeiten unter root kann immer irgendetwas verbiegen, wo es erst viel später zu Problemen kommt.
            Wenn du jetzt neu anfangen willst, denke daran!
              michael_4358
              wollen nicht aber scheint wohl einfach zusein
                michael_4358
                als letzten versuch habe ich node js auf Version 15 zurück gespielt...
                nun geht wieder alles
                • M michael_4358
                  Meister MopperM Online
                  Meister Mopper
                  @michael_4358
                  Ungerade Versionen (z. B. 15) sind beta Versionen (für Entwickler). Stable sind die geraden (z. B. 14 < 16).
                  Proxmox und HA ...
                  Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                    @michael_4358
                    michael_4358
                    @meister-mopper
                    Mag sein❗️
                    Nach dieser Achterbahnfahrt werde ich das erstmal ruhen lassen ❗️
                    • M michael_4358
                      @meister-mopper
                      Mag sein❗️
                      @michael_4358
                      Die node 15 ist allerdings als Interims-Version schon wieder aus dem Support raus:
                      https://nodejs.org/en/about/releases/
                        @michael_4358
                        michael_4358
                        @thomas-braun said in (gelöst) Adapter lassen sich nicht updaten:
                        @michael_4358
                        das habe ich gelesen.
                        als lts wäre 14 noch gewesen..
                        warum ich 15 gewählt habe kann ich dir auch nicht sagen.
                        werde die tage ein gleiches system parallel installieren und testen
