  4. (gelöst) Adapter lassen sich nicht updaten
    5.8k
55 Beiträge 7 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • M michael_4358
    @mickym ok
    dann kann ich uodaten neustarten... zumindest versuchen
    mickymM Offline
    mickymM Offline
    mickym
    @michael_4358 sagte in Adapter lassen sich nicht updaten:
    @mickym ok
    Zumindest sollte wenn alles neu gemacht ist, nicht mehr am zigbee2mqtt liegen.
    • mickymM mickym
      @mickym ok
      michael_4358
      schrieb am zuletzt editiert von michael_4358
      @mickym said in Adapter lassen sich nicht updaten:
      @mickym ok
      Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
      Update iot from @1.11.4 to @1.11.8
      host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
      NPM version: 8.15.1
      Installing iobroker.iot@1.11.8... (System call)
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
      npm ERR! notsup Not compatible with your version of node/npm: zigbee2mqtt@1.18.3
      npm ERR! notsup Required: {"node":"^10 || ^12 || ^14 || ^15"}
      npm ERR! notsup Actual:   {"npm":"8.15.1","node":"v16.16.0"}
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-28T13_39_47_854Z-debug-0.log
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js static/js/2.1d439ead.chunk.js application/javascript
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.LICENSE.txt static/js/2.1d439ead.chunk.js.LICENSE.txt text/plain
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.map static/js/2.1d439ead.chunk.js.map application/json
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js static/js/main.846bc990.chunk.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js.map static/js/main.846bc990.chunk.js.map application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js static/js/runtime-main.1a18d9e5.js application/javascript
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js.map static/js/runtime-main.1a18d9e5.js.map application/json
      host.raspberrypi Adapter "system.adapter.iot.0" is started
      es geht immer noch nicht
      • M michael_4358
        @glasfaser
        update eines apapters..
        Update vis-icontwo from @0.87.0 to @0.89.0
        NPM version: 8.11.0
        Installing iobroker.vis-icontwo@0.89.0... (System call)
        npm ERR! notsup Actual:   {"npm":"8.11.0","node":"v16.16.0"}
        npm ERR!     /home/iobroker/.npm/_logs/2022-07-28T08_08_43_834Z-debug-0.log
        Adapter "system.adapter.vis.0" restarted.
        upload [1338] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
        upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/motion_people2.png Alarm/motion_people2.png image/png
        upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Arrows/arrow_2_down.png Arrows/arrow_2_down.png image/png
        upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/50.jpg Backgrounds/Seamless/50.jpg image/jpeg
        upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/mysql_02.png Brands/mysql_02.png image/png
        upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Awning/awning2_50.png Devices/Awning/awning2_50.png image/png
        upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_grafana.png Devices/Computers/pc_grafana.png image/png
        upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan1_on1.png Devices/Cooling/fan1_on1.png image/png
        upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/hub2.png Devices/Network/hub2.png image/png
        upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Printers/3D_printer_new.png Devices/Printers/3D_printer_new.png image/png
        upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/laser_off.png Devices/laser_off.png image/png
        upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_30.png Doors_Windows/Shutter/blinds2_30.png image/png
        upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/window_open.png Doors_Windows/window_open.png image/png
        upload [700] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Electricity/switch2.png Electricity/switch2.png image/png
        upload [650] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Hobbies/Train/subway.png Hobbies/Train/subway.png image/png
        upload [600] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Letters/Rounded/q.png Letters/Rounded/q.png image/png
        upload [550] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Lights/light_dim_plus.png Lights/light_dim_plus.png image/png
        upload [500] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Misc/A.png Misc/A.png image/png
        upload [450] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Navigations/nav_cam1.png Navigations/nav_cam1.png image/png
        upload [400] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/41.png Numbers/Rounded/41.png image/png
        upload [350] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/87.png Numbers/Rounded/87.png image/png
        upload [300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Player/on.png Player/on.png image/png
        upload [250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/bedroom2_POWER_on.png Rooms/bedroom2_POWER_on.png image/png
        upload [200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/hallway_POWER_on.png Rooms/hallway_POWER_on.png image/png
        upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/warehouse.png Rooms/warehouse.png image/png
        upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Signs/delete.png Signs/delete.png image/png
        upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/exercise.png Spa_Fitness/exercise.png image/png
        upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/sun-lounger.png Spa_Fitness/sun-lounger.png image/png
        upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/avalanche_land.png Weather/Warning/avalanche_land.png image/png
        upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/volcano.png Weather/Warning/volcano.png image/png
        upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Wind_Speeds/wind_speed_38-42.png Weather/Wind_Speeds/wind_speed_38-42.png image/png
        upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/day.png Weather/day.png image/png
        upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/direction_w.png Weather/direction_w.png image/png
        upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/pressure_gauge2.png Weather/pressure_gauge2.png image/png
        upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain.png Weather/rain.png image/png
        upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain_value.png Weather/rain_value.png image/png
        upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rainy.png Weather/rainy.png image/png
        upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow.png Weather/snow.png image/png
        upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow2.png Weather/snow2.png image/png
        upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow3.png Weather/snow3.png image/png
        upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow_value.png Weather/snow_value.png image/png
        upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/storm.png Weather/storm.png image/png
        upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun.png Weather/sun.png image/png
        upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun_value.png Weather/sun_value.png image/png
        upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunrise.png Weather/sunrise.png image/png
        upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunset.png Weather/sunset.png image/png
        upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp.png Weather/temp.png image/png
        upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp2.png Weather/temp2.png image/png
        upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp3.png Weather/temp3.png image/png
        upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wet.png Weather/wet.png image/png
        upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind.png Weather/wind.png image/png
        upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind_value.png Weather/wind_value.png image/png
        upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windsock.png Weather/windsock.png image/png
        upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windy.png Weather/windy.png image/png
        upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/admin.d.ts admin.d.ts video/mp2t
        upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/i1_150.png i1_150.png image/png
        upload [3] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/icontwo.png icontwo.png image/png
        upload [2] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/index_m.html index_m.html text/html
        upload [1] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css
        upload [0] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
        hier das update des text2cmd
        Update text2command from @2.2.1 to @2.2.2
        NPM version: 8.11.0
        Installing iobroker.text2command@2.2.2... (System call)
        sieht nach einem npm fehler aus....
        oder irre ich da?
        GlasfaserG Offline
        GlasfaserG Offline
        v16.16.0
        v16.16.0
        8.11.0
        wäre richtig ... wie du es oben hattest
        und jetzt
        NPM version: 8.15.1
        du hast NPM hochgezogen / update gemacht !
        • M michael_4358
          @mickym ok
          NPM version: 8.15.1
          mickymM Offline
          mickymM Offline
          mickym
          @michael_4358 Dann mach erst mal die leichte Version -
          wenn Du als pi angemeldet bist dann sichere Dir die Datei package-lock.json mal weg - die kann man ggf. dann später wegschmeissen.
          Mach mal folgendes:
          cd /opt/iobroker
          sudo mv package-lock.json /home/pi
          und probiere es dann nochmal.
          Ach ja und wie @Glasfaser schrieb kein Update von npm machen - aber probiere mal erst die package-lock.json aus dem Verzeichnis zu entfernen.
          Die npm Version sollte sich aber von selbst bereinigen, wenn Du wieder ein
          sudo apt update
          sudo apt upgrade
          machst und die sourcen im Paketmanager eingetragen sind.
          • GlasfaserG Glasfaser
            v16.16.0
            v16.16.0
            8.11.0
            und jetzt
            NPM version: 8.15.1
            michael_4358
            @glasfaser
            das war nicht gewollt...
            kann ich das wieder ändern❓
            • M michael_4358
              @glasfaser
              mickymM Offline
              mickymM Offline
              mickym
              @michael_4358 Hab ich Dir gerade geschrieben.
              • mickymM mickym
                michael_4358
                ist noch auf der 8.15 ...
                • M michael_4358
                  @michael_4358
                  sudo apt install --reinstall nodejs
                    michael_4358
                    NPM version: 8.11.0
                    npm WARN tarball tarball data for socksv5@https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9 (sha1-sjQ0+FwyNcrhxXborBfKzWTTuL0=) seems to be corrupted. Trying again.
                    npm ERR!     /home/iobroker/.npm/_logs/2022-07-28T14_06_13_392Z-debug-0.log
                    mickymM Thomas BraunT 2 Antworten Letzte Antwort
                    • M michael_4358
                      NPM version: 8.11.0
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @michael_4358 Hast Du die package-lock.json entfernt?
                      Also ich fürchte ich kann nicht mehr weiterhelfen (vielleicht aber noch andere) ausser mit meiner Radikalkur aber halt ohne Gewähr. ;)
                      Mach mal eine Komplettsicherung, sodass Du notfalls auf Deinen jetzigen Stand zurückkehren kannst und probiere :
                      https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/23?_=1658914381795
                      • M michael_4358
                        NPM version: 8.11.0
                        @michael_4358
                        sudo -H -u iobroker npm cache clear --force
                        Durch die Herumrutscherei als root kann es aber auch sein, dass du da die Rechte verbogen hast (oder der chache beim root liegt. Oder anderes 'unerklärliches' Zeug passiert ist).
                          @michael_4358
                          michael_4358
                          @thomas-braun said in Adapter lassen sich nicht updaten:
                          @michael_4358
                          wahrscheinlich hast du recht....
                          wird wohl das beste sein
                          back up hab ich
                          also auf Anfang ❗️
                          • M michael_4358
                            @michael_4358
                            back up hab ich
                            also auf Anfang ❗️
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @michael_4358 Na wenn Du Backup hast und eh neu aufbaust, kannst ja nochmal versuchen, das node_modules Verzeichnis wie beschrieben, neu aufzubauen.
                            • M michael_4358
                              dein shift klemmt...
                              es ändert aber nichts am ablauf ob root oder nicht...
                              @thomas-braun sagte in Adapter lassen sich nicht updaten:
                              Das Arbeiten unter root kann immer irgendetwas verbiegen, wo es erst viel später zu Problemen kommt.
                              Wenn du jetzt neu anfangen willst, denke daran!
                                michael_4358
                                wollen nicht aber scheint wohl einfach zusein
                                  michael_4358
                                  als letzten versuch habe ich node js auf Version 15 zurück gespielt...
                                  nun geht wieder alles
                                  • M michael_4358
                                    Meister MopperM Online
                                    Meister Mopper
                                    @michael_4358
                                    Ungerade Versionen (z. B. 15) sind beta Versionen (für Entwickler). Stable sind die geraden (z. B. 14 < 16).
                                    Proxmox und HA ...
                                    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                      @michael_4358
                                      michael_4358
                                      @meister-mopper
                                      Mag sein❗️
                                      Nach dieser Achterbahnfahrt werde ich das erstmal ruhen lassen ❗️
                                      • M michael_4358
                                        @meister-mopper
                                        Mag sein❗️
                                        @michael_4358
                                        Die node 15 ist allerdings als Interims-Version schon wieder aus dem Support raus:
                                        https://nodejs.org/en/about/releases/
                                          @michael_4358
                                          michael_4358
                                          @thomas-braun said in (gelöst) Adapter lassen sich nicht updaten:
                                          @michael_4358
                                          das habe ich gelesen.
                                          als lts wäre 14 noch gewesen..
                                          warum ich 15 gewählt habe kann ich dir auch nicht sagen.
                                          werde die tage ein gleiches system parallel installieren und testen
