  4. admin hat falsche Version
    3.2k
    3.1k
adminfalsche versionsmartgarden
35 Beiträge 4 Kommentatoren 3.6k Aufrufe 4 Beobachtet
  • Rette70R Rette70
    @thomas-braun apt policy nodejs
    nodejs:
    Installed: 16.17.0-deb-1nodesource1
    Candidate: 16.17.0-deb-1nodesource1
    Version table:
    *** 16.17.0-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
    100 /var/lib/dpkg/status
    12.22.12~dfsg-1~deb11u1 500
    500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
    12.22.5~dfsg-2~11u1 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    Rette70R Offline
    Rette70R Offline
    Rette70
    @rette70
    iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "cloud"        : 4.2.2    , installed 4.1.1  [Updatable]
    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "history"      : 2.2.0    , installed 2.1.7  [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "openweathermap": 0.3.0   , installed 0.3.0
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
    Adapter    "smartgarden"  : 2.0.0    , installed 1.0.6  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "statistics"   : 2.2.0    , installed 2.1.1  [Updatable]
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
      @rette70 sagte in admin hat falsche Version:
      host.IoBroker-Master
      hast du Multihost?
      Rette70R Offline
      Rette70R Offline
      Rette70
      @homoran ja hab multihost
      Rette70R 1 Antwort Letzte Antwort
      • Rette70R Rette70
        Rette70R Offline
        Rette70R Offline
        Rette70
        @rette70
        pi@IoBroker-Slave:~ $ iobroker update
        Adapter    "admin"        : 6.2.22   , installed 5.3.8  [Updatable]
        Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
        Adapter    "discovery"    : 3.0.5    , installed 2.7.0  [Updatable]
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.33 [Updatable]
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.11 [Updatable]
        Adapter    "homekit-controller": 0.5.1, installed 0.3.3 [Updatable]
        Adapter    "info"         : 1.9.19   , installed 1.9.8  [Updatable]
        Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
        Adapter    "parcel"       : 0.0.20   , installed 0.0.12 [Updatable]
        Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
        Thomas BraunT Rette70R 2 Antworten Letzte Antwort
        • Rette70R Rette70
          @rette70
          @rette70
          Auf dem Slave:
          iobroker upgrade all
          Danach das gleiche auf dem Master
          • Rette70R Rette70
            @rette70
            Rette70R Offline
            Rette70R Offline
            Rette70
            @rette70 jetzt hatte der Master schon die neue Version. Ging aber auch nicht, als beide noch bei 5.. waren. Versuche den Slave Adapter updaten, ging aber gestern auch nicht. Kam auch Fehler 25 den ich nicht beseitigen konnte
            • Rette70R Rette70
              Rette70R Offline
              Rette70R Offline
              Rette70
              @rette70 ERROR: Process exited with code 25
              weniger
              mehr
              $ iobroker upgrade admin@6.2.22 --debug
              Update admin from @5.3.8 to @6.2.22
              NPM version: 8.15.0
              Installing iobroker.admin@6.2.22... (System call)
              npm ERR! code ENOTEMPTY
              npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-09-18T18_43_21_565Z-debug-0.log
              host.IoBroker-Slave Cannot install iobroker.admin@6.2.22: 217
              • Rette70R Rette70
                weniger
                mehr
                NPM version: 8.15.0
                @rette70
                Nicht aus der GUI, nimm ein Terminal dafür.
                • Rette70R Rette70
                  weniger
                  mehr
                  NPM version: 8.15.0
                  @rette70
                  Vermutlich aber was aus der Ecke:
                  https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                    @rette70
                    Rette70R Offline
                    Rette70R Offline
                    Rette70
                    @thomas-braun kannst du mir kurz bitte den Befehl schreiben?
                    • Rette70R Rette70
                      @rette70
                      Steht doch drin?
                      iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slave
                      Bei Multihost muss der Host angegeben werden.
                        @rette70
                        Steht doch drin?
                        Rette70R Offline
                        Rette70R Offline
                        Rette70
                        @thomas-braun ja danke. Dachte ist ein anderer Befehl.
                        hab jetzt über die Konsole installiert. Das gleiche
                        This upgrade of "admin" will at least introduce the following changes:
                        -> 6.2.22:
                        Corrected admin4 adapter settings
                        -> 6.2.21:
                        Corrected small JSON config issue
                        -> 6.2.20:
                        Corrected GUI issues
                        -> 6.2.19:
                        Corrected some issues
                        -> 6.2.18:
                        Corrected GUI bugs on custom settings
                        -> 6.2.17:
                        Corrected GUI bug on intro tab
                        -> 6.2.16:
                        Corrected many GUI issues
                        Added `stable` flag for repositories
                        Added reset button for repositories
                        Improved `writeFile` function for socket communication
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade admin from @5.3.8 to @6.2.22 now? [(y)es, (n)o]: y
                        NPM version: 8.15.0
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                        npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T18_55_48_988Z-debug-0.log
                        * ****list item****
                        • Rette70R Rette70
                          -> 6.2.22:
                          -> 6.2.21:
                          -> 6.2.20:
                          -> 6.2.19:
                          -> 6.2.18:
                          -> 6.2.17:
                          -> 6.2.16:
                          NPM version: 8.15.0
                          npm ERR! errno -39
                          * ****list item****
                          Das gleiche
                          Nein, ist nicht das gleiche.
                          Die Lösung hatte ich oben schon verlinkt.
                            Das gleiche
                            Rette70R Offline
                            Rette70R Offline
                            Rette70
                            pi@IoBroker-Slave:~ $ iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slav                                                               e
                            -> 6.2.22:
                            -> 6.2.21:
                            -> 6.2.20:
                            -> 6.2.19:
                            -> 6.2.18:
                            -> 6.2.17:
                            -> 6.2.16:
                            NPM version: 8.15.0
                            npm ERR! errno -39
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T19_01_57_380Z-debug-0.log
                            • Rette70R Rette70
                              -> 6.2.22:
                              -> 6.2.21:
                              -> 6.2.20:
                              -> 6.2.19:
                              -> 6.2.18:
                              -> 6.2.17:
                              -> 6.2.16:
                              NPM version: 8.15.0
                              npm ERR! errno -39
                              @rette70
                              Bitte CodeTags verwenden. Danke
                              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                              Auf beiden Kisten.
                                @rette70
                                Auf beiden Kisten.
                                Rette70R Offline
                                Rette70R Offline
                                Rette70
                                @thomas-braun Du bist mein Held!! Ich habe gestern den ganzen Tag daran gesessen und dein Post auch auf beiden durch geführt. Aber jetzt die manuelle Installation funktioniert. Eventl. weil ich nie den Host angegeben habe. Dachte wenn ich mit Putty auf dem drauf bin , weiß er das es dort hin soll.
                                Was sind Code TAGs?
                                Ah ok.
                                code_text
                                Habs gefunden. Vielen Dank
