  4. admin hat falsche Version
    1.0k
    6.1k
adminfalsche versionsmartgarden
35 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • Rette70R Rette70
    Das gleiche Problem besteht immer noch.
    jemand eine idee
    @rette70 said in admin hat falsche Version:
    host.IoBroker-Master
    2022-09-18 19:44:39.025 error startInstance system.adapter.shelly.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=5.3.3"!
    @rette70
    Von beiden Systemen, wenn das ein Multihostsetup sein sollte.
    Rette70R 1 Antwort Letzte Antwort
      @rette70
      Rette70R Offline
      Rette70R Offline
      Rette70
      @thomas-braun apt policy nodejs
      nodejs:
      Installed: 16.17.0-deb-1nodesource1
      Candidate: 16.17.0-deb-1nodesource1
      Version table:
      *** 16.17.0-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
      12.22.12~dfsg-1~deb11u1 500
      500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
      12.22.5~dfsg-2~11u1 500
      500 http://deb.debian.org/debian bullseye/main arm64 Packages
      • Rette70R Rette70
        nodejs:
        Version table:
        Rette70R Offline
        Rette70R Offline
        Rette70
        @rette70
        iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "backitup"     : 2.4.10   , installed 2.4.10
        Adapter    "cloud"        : 4.2.2    , installed 4.1.1  [Updatable]
        Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
        Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
        Adapter    "history"      : 2.2.0    , installed 2.1.7  [Updatable]
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
        Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "material"     : 1.1.2    , installed 1.1.2
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "onvif"        : 0.4.4    , installed 0.4.4
        Adapter    "openweathermap": 0.3.0   , installed 0.3.0
        Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
        Adapter    "smartgarden"  : 2.0.0    , installed 1.0.6  [Updatable]
        Adapter    "statistics"   : 2.2.0    , installed 2.1.1  [Updatable]
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "tuya"         : 3.6.15   , installed 3.6.15
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
          @rette70 sagte in admin hat falsche Version:
          hast du Multihost?
          Rette70R Offline
          Rette70R Offline
          Rette70
          @homoran ja hab multihost
          • Rette70R Rette70
            Rette70R Offline
            Rette70R Offline
            Rette70
            @rette70
            pi@IoBroker-Slave:~ $ iobroker update
            Adapter    "admin"        : 6.2.22   , installed 5.3.8  [Updatable]
            Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
            Adapter    "discovery"    : 3.0.5    , installed 2.7.0  [Updatable]
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.33 [Updatable]
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.11 [Updatable]
            Adapter    "homekit-controller": 0.5.1, installed 0.3.3 [Updatable]
            Adapter    "info"         : 1.9.19   , installed 1.9.8  [Updatable]
            Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
            Adapter    "parcel"       : 0.0.20   , installed 0.0.12 [Updatable]
            Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
            Thomas BraunT Rette70R 2 Antworten Letzte Antwort
            • Rette70R Rette70
              @rette70
              @rette70
              Auf dem Slave:
              iobroker upgrade all
              Danach das gleiche auf dem Master
              • Rette70R Rette70
                @rette70
                Rette70R Offline
                Rette70R Offline
                Rette70
                @rette70 jetzt hatte der Master schon die neue Version. Ging aber auch nicht, als beide noch bei 5.. waren. Versuche den Slave Adapter updaten, ging aber gestern auch nicht. Kam auch Fehler 25 den ich nicht beseitigen konnte
                • Rette70R Rette70
                  Rette70R Offline
                  Rette70R Offline
                  Rette70
                  @rette70 ERROR: Process exited with code 25
                  weniger
                  mehr
                  $ iobroker upgrade admin@6.2.22 --debug
                  Update admin from @5.3.8 to @6.2.22
                  NPM version: 8.15.0
                  Installing iobroker.admin@6.2.22... (System call)
                  npm ERR! code ENOTEMPTY
                  npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-09-18T18_43_21_565Z-debug-0.log
                  host.IoBroker-Slave Cannot install iobroker.admin@6.2.22: 217
                  • Rette70R Rette70
                    weniger
                    mehr
                    NPM version: 8.15.0
                    @rette70
                    Nicht aus der GUI, nimm ein Terminal dafür.
                    • Rette70R Rette70
                      weniger
                      mehr
                      NPM version: 8.15.0
                      @rette70
                      Vermutlich aber was aus der Ecke:
                      https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                        @rette70
                        Rette70R Offline
                        Rette70R Offline
                        Rette70
                        @thomas-braun kannst du mir kurz bitte den Befehl schreiben?
                        • Rette70R Rette70
                          @rette70
                          Steht doch drin?
                          iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slave
                          Bei Multihost muss der Host angegeben werden.
                            @rette70
                            Steht doch drin?
                            Rette70R Offline
                            Rette70R Offline
                            Rette70
                            @thomas-braun ja danke. Dachte ist ein anderer Befehl.
                            hab jetzt über die Konsole installiert. Das gleiche
                            This upgrade of "admin" will at least introduce the following changes:
                            -> 6.2.22:
                            Corrected admin4 adapter settings
                            -> 6.2.21:
                            Corrected small JSON config issue
                            -> 6.2.20:
                            Corrected GUI issues
                            -> 6.2.19:
                            Corrected some issues
                            -> 6.2.18:
                            Corrected GUI bugs on custom settings
                            -> 6.2.17:
                            Corrected GUI bug on intro tab
                            -> 6.2.16:
                            Corrected many GUI issues
                            Added `stable` flag for repositories
                            Added reset button for repositories
                            Improved `writeFile` function for socket communication
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade admin from @5.3.8 to @6.2.22 now? [(y)es, (n)o]: y
                            NPM version: 8.15.0
                            npm ERR! syscall rename
                            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                            npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T18_55_48_988Z-debug-0.log
                            * ****list item****
                            • Rette70R Rette70
                              -> 6.2.22:
                              -> 6.2.21:
                              -> 6.2.20:
                              -> 6.2.19:
                              -> 6.2.18:
                              -> 6.2.17:
                              -> 6.2.16:
                              NPM version: 8.15.0
                              npm ERR! errno -39
                              * ****list item****
                              Das gleiche
                              Nein, ist nicht das gleiche.
                              Die Lösung hatte ich oben schon verlinkt.
                                Das gleiche
                                Rette70R Offline
                                Rette70R Offline
                                Rette70
                                pi@IoBroker-Slave:~ $ iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slav                                                               e
                                -> 6.2.22:
                                -> 6.2.21:
                                -> 6.2.20:
                                -> 6.2.19:
                                -> 6.2.18:
                                -> 6.2.17:
                                -> 6.2.16:
                                NPM version: 8.15.0
                                npm ERR! errno -39
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T19_01_57_380Z-debug-0.log
                                • Rette70R Rette70
                                  -> 6.2.22:
                                  -> 6.2.21:
                                  -> 6.2.20:
                                  -> 6.2.19:
                                  -> 6.2.18:
                                  -> 6.2.17:
                                  -> 6.2.16:
                                  NPM version: 8.15.0
                                  npm ERR! errno -39
                                  @rette70
                                  Bitte CodeTags verwenden. Danke
                                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                  Auf beiden Kisten.
                                    @rette70
                                    Auf beiden Kisten.
                                    Rette70R Offline
                                    Rette70R Offline
                                    Rette70
                                    @thomas-braun Du bist mein Held!! Ich habe gestern den ganzen Tag daran gesessen und dein Post auch auf beiden durch geführt. Aber jetzt die manuelle Installation funktioniert. Eventl. weil ich nie den Host angegeben habe. Dachte wenn ich mit Putty auf dem drauf bin , weiß er das es dort hin soll.
                                    Was sind Code TAGs?
                                    Ah ok.
                                    code_text
                                    Habs gefunden. Vielen Dank
