  4. admin hat falsche Version
    1.0k
    6.1k
adminfalsche versionsmartgarden
35 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • Rette70R Rette70
    Das gleiche Problem besteht immer noch.
    jemand eine idee
    @rette70 said in admin hat falsche Version:
    host.IoBroker-Master
    2022-09-18 19:44:39.025 error startInstance system.adapter.shelly.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=5.3.3"!
    @rette70
    Frisches Basissystem?
    iobroker update
    sagt?
    • Rette70R Rette70
      jemand eine idee
      @rette70 sagte in admin hat falsche Version:
      hast du Multihost?
      Rette70R 1 Antwort Letzte Antwort
      • Rette70R Rette70
        jemand eine idee
        @rette70
        Von beiden Systemen, wenn das ein Multihostsetup sein sollte.
          @rette70
          Rette70R Offline
          Rette70R Offline
          Rette70
          @thomas-braun apt policy nodejs
          nodejs:
          Installed: 16.17.0-deb-1nodesource1
          Candidate: 16.17.0-deb-1nodesource1
          Version table:
          *** 16.17.0-deb-1nodesource1 500
          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
          12.22.12~dfsg-1~deb11u1 500
          500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
          12.22.5~dfsg-2~11u1 500
          500 http://deb.debian.org/debian bullseye/main arm64 Packages
          • Rette70R Rette70
            nodejs:
            Version table:
            Rette70R Offline
            Rette70R Offline
            Rette70
            @rette70
            iobroker update
            Used repository: stable
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
            Adapter    "backitup"     : 2.4.10   , installed 2.4.10
            Adapter    "cloud"        : 4.2.2    , installed 4.1.1  [Updatable]
            Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
            Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
            Adapter    "history"      : 2.2.0    , installed 2.1.7  [Updatable]
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
            Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
            Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
            Adapter    "javascript"   : 6.0.0    , installed 6.0.0
            Controller "js-controller": 4.0.23   , installed 4.0.23
            Adapter    "material"     : 1.1.2    , installed 1.1.2
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "onvif"        : 0.4.4    , installed 0.4.4
            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
            Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
            Adapter    "shelly"       : 6.0.0    , installed 6.0.0
            Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
            Adapter    "smartgarden"  : 2.0.0    , installed 1.0.6  [Updatable]
            Adapter    "statistics"   : 2.2.0    , installed 2.1.1  [Updatable]
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
            Adapter    "text2command" : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tuya"         : 3.6.15   , installed 3.6.15
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
            Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
              hast du Multihost?
              Rette70R Offline
              Rette70R Offline
              Rette70
              @homoran ja hab multihost
              • Rette70R Rette70
                Rette70R Offline
                Rette70R Offline
                Rette70
                @rette70
                pi@IoBroker-Slave:~ $ iobroker update
                Adapter    "admin"        : 6.2.22   , installed 5.3.8  [Updatable]
                Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
                Adapter    "discovery"    : 3.0.5    , installed 2.7.0  [Updatable]
                Adapter    "hm-rega"      : 3.0.40   , installed 3.0.33 [Updatable]
                Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.11 [Updatable]
                Adapter    "homekit-controller": 0.5.1, installed 0.3.3 [Updatable]
                Adapter    "info"         : 1.9.19   , installed 1.9.8  [Updatable]
                Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
                Adapter    "parcel"       : 0.0.20   , installed 0.0.12 [Updatable]
                Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
                Thomas BraunT Rette70R 2 Antworten Letzte Antwort
                • Rette70R Rette70
                  @rette70
                  @rette70
                  Auf dem Slave:
                  iobroker upgrade all
                  Danach das gleiche auf dem Master
                  • Rette70R Rette70
                    @rette70
                    Rette70R Offline
                    Rette70R Offline
                    Rette70
                    @rette70 jetzt hatte der Master schon die neue Version. Ging aber auch nicht, als beide noch bei 5.. waren. Versuche den Slave Adapter updaten, ging aber gestern auch nicht. Kam auch Fehler 25 den ich nicht beseitigen konnte
                    • Rette70R Rette70
                      Rette70R Offline
                      Rette70R Offline
                      Rette70
                      @rette70 ERROR: Process exited with code 25
                      weniger
                      mehr
                      $ iobroker upgrade admin@6.2.22 --debug
                      Update admin from @5.3.8 to @6.2.22
                      NPM version: 8.15.0
                      Installing iobroker.admin@6.2.22... (System call)
                      npm ERR! code ENOTEMPTY
                      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-09-18T18_43_21_565Z-debug-0.log
                      host.IoBroker-Slave Cannot install iobroker.admin@6.2.22: 217
                      • Rette70R Rette70
                        weniger
                        mehr
                        NPM version: 8.15.0
                        @rette70
                        Nicht aus der GUI, nimm ein Terminal dafür.
                        • Rette70R Rette70
                          weniger
                          mehr
                          NPM version: 8.15.0
                          @rette70
                          Vermutlich aber was aus der Ecke:
                          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                            @rette70
                            Rette70R Offline
                            Rette70R Offline
                            Rette70
                            @thomas-braun kannst du mir kurz bitte den Befehl schreiben?
                            • Rette70R Rette70
                              @rette70
                              Steht doch drin?
                              iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slave
                              Bei Multihost muss der Host angegeben werden.
                                @rette70
                                Steht doch drin?
                                Rette70R Offline
                                Rette70R Offline
                                Rette70
                                @thomas-braun ja danke. Dachte ist ein anderer Befehl.
                                hab jetzt über die Konsole installiert. Das gleiche
                                This upgrade of "admin" will at least introduce the following changes:
                                -> 6.2.22:
                                Corrected admin4 adapter settings
                                -> 6.2.21:
                                Corrected small JSON config issue
                                -> 6.2.20:
                                Corrected GUI issues
                                -> 6.2.19:
                                Corrected some issues
                                -> 6.2.18:
                                Corrected GUI bugs on custom settings
                                -> 6.2.17:
                                Corrected GUI bug on intro tab
                                -> 6.2.16:
                                Corrected many GUI issues
                                Added `stable` flag for repositories
                                Added reset button for repositories
                                Improved `writeFile` function for socket communication
                                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                Would you like to upgrade admin from @5.3.8 to @6.2.22 now? [(y)es, (n)o]: y
                                NPM version: 8.15.0
                                npm ERR! syscall rename
                                npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                                npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                npm ERR! errno -39
                                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T18_55_48_988Z-debug-0.log
                                * ****list item****
                                • Rette70R Rette70
                                  -> 6.2.22:
                                  -> 6.2.21:
                                  -> 6.2.20:
                                  -> 6.2.19:
                                  -> 6.2.18:
                                  -> 6.2.17:
                                  -> 6.2.16:
                                  NPM version: 8.15.0
                                  npm ERR! errno -39
                                  * ****list item****
                                  Das gleiche
                                  Nein, ist nicht das gleiche.
                                  Die Lösung hatte ich oben schon verlinkt.
                                    Das gleiche
                                    Rette70R Offline
                                    Rette70R Offline
                                    Rette70
                                    pi@IoBroker-Slave:~ $ iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slav                                                               e
                                    -> 6.2.22:
                                    -> 6.2.21:
                                    -> 6.2.20:
                                    -> 6.2.19:
                                    -> 6.2.18:
                                    -> 6.2.17:
                                    -> 6.2.16:
                                    NPM version: 8.15.0
                                    npm ERR! errno -39
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T19_01_57_380Z-debug-0.log
                                    • Rette70R Rette70
                                      -> 6.2.22:
                                      -> 6.2.21:
                                      -> 6.2.20:
                                      -> 6.2.19:
                                      -> 6.2.18:
                                      -> 6.2.17:
                                      -> 6.2.16:
                                      NPM version: 8.15.0
                                      npm ERR! errno -39
                                      @rette70
                                      Bitte CodeTags verwenden. Danke
                                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                      Auf beiden Kisten.
                                        @rette70
                                        Auf beiden Kisten.
                                        Rette70R Offline
                                        Rette70R Offline
                                        Rette70
                                        @thomas-braun Du bist mein Held!! Ich habe gestern den ganzen Tag daran gesessen und dein Post auch auf beiden durch geführt. Aber jetzt die manuelle Installation funktioniert. Eventl. weil ich nie den Host angegeben habe. Dachte wenn ich mit Putty auf dem drauf bin , weiß er das es dort hin soll.
                                        Was sind Code TAGs?
                                        Ah ok.
                                        code_text
                                        Habs gefunden. Vielen Dank
