  4. VIS 1.14.5 lässt sich nicht installieren
112 Beiträge 12 Kommentatoren 15.8k Aufrufe 9 Beobachtet
  • A AndyGR42
    @andygr42 Was auch reproduzierbar bleibt ist das Problem mit dem VIS Adapter (weshalb ich überhaupt den ganzen Aufriss mit dem Restore auf dem Test System gemacht habe):
    2022-06-22 07:25:37.356  - warn: host.gt-iob01 startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
    2022-06-22 07:25:37.356  - info: host.gt-iob01 iobroker install vis@1.4.15 using installedFrom
    2022-06-22 07:25:41.477  - info: host.gt-iob01 iobroker npm-install: NPM version: 8.11.0
    2022-06-22 07:25:41.479  - info: host.gt-iob01 iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2022-06-22 07:25:56.983  - info: vis.0 (14042) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
    2022-06-22 07:25:57.179  - info: vis.0 (14042) vis license is OK.
    2022-06-22 07:25:57.515  - error: vis.0 (14042) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-06-22 07:25:57.517  - error: vis.0 (14042) unhandled promise rejection: Not exists
    2022-06-22 07:25:57.521  - error: vis.0 (14042) Error: Not exists
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
        at processImmediate (node:internal/timers:468:21)
    2022-06-22 07:25:57.524  - error: vis.0 (14042) Not exists
    2022-06-22 07:25:58.031  - info: vis.0 (14042) terminating
    2022-06-22 07:25:58.033  - warn: vis.0 (14042) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-06-22 07:25:58.869  - error: host.gt-iob01 iobroker npm-install: host.gt-iob01 Cannot install iobroker.vis@1.4.15: 6
    2022-06-22 07:25:59.905  - info: host.gt-iob01 iobroker npm-install: exit 25
    2022-06-22 07:26:00.905  - warn: host.gt-iob01 startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
    2022-06-22 07:26:00.908  - info: host.gt-iob01 iobroker install vis@1.4.15 using installedVersion
    2022-06-22 07:26:04.954  - info: host.gt-iob01 iobroker npm-install: NPM version: 8.11.0
    2022-06-22 07:26:04.957  - info: host.gt-iob01 iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2022-06-22 07:26:20.268  - info: vis.0 (14088) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
    2022-06-22 07:26:20.451  - info: vis.0 (14088) vis license is OK.
    2022-06-22 07:26:20.799  - error: vis.0 (14088) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-06-22 07:26:20.801  - error: vis.0 (14088) unhandled promise rejection: Not exists
    2022-06-22 07:26:20.806  - error: vis.0 (14088) Error: Not exists
    2022-06-22 07:26:20.808  - error: vis.0 (14088) Not exists
    2022-06-22 07:26:21.315  - info: vis.0 (14088) terminating
    2022-06-22 07:26:21.317  - warn: vis.0 (14088) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-06-22 07:26:22.166  - error: host.gt-iob01 iobroker npm-install: host.gt-iob01 Cannot install iobroker.vis@1.4.15: 6
    2022-06-22 07:26:23.210  - info: host.gt-iob01 iobroker npm-install: exit 25
    2022-06-22 07:26:24.211  - warn: host.gt-iob01 startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    2022-06-22 07:26:24.212  - info: host.gt-iob01 iobroker install vis@1.4.15 using installedVersion
    2022-06-22 07:26:28.304  - info: host.gt-iob01 iobroker npm-install: NPM version: 8.11.0
    2022-06-22 07:26:28.307  - info: host.gt-iob01 iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2022-06-22 07:26:43.559  - info: vis.0 (14134) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
    2022-06-22 07:26:43.772  - info: vis.0 (14134) vis license is OK.
    2022-06-22 07:26:44.107  - error: vis.0 (14134) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-06-22 07:26:44.109  - error: vis.0 (14134) unhandled promise rejection: Not exists
    2022-06-22 07:26:44.114  - error: vis.0 (14134) Error: Not exists
    2022-06-22 07:26:44.116  - error: vis.0 (14134) Not exists
    2022-06-22 07:26:44.623  - info: vis.0 (14134) terminating
    2022-06-22 07:26:44.625  - warn: vis.0 (14134) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-06-22 07:26:45.474  - error: host.gt-iob01 iobroker npm-install: host.gt-iob01 Cannot install iobroker.vis@1.4.15: 6
    2022-06-22 07:26:46.508  - info: host.gt-iob01 iobroker npm-install: exit 25
    2022-06-22 07:26:47.509  - error: host.gt-iob01 Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    crunchipC Offline
    crunchipC Offline
    #101
    @andygr42 wo wir wieder bei dem Thema sind
    https://forum.iobroker.net/post/813432
    Unter anderem würde es wahrscheinlich auch mit einer älteren js-controller Version funktionieren. Ab welcher das Problem jedoch aufkam, kann ich aber nicht aus dem Stehgreif sagen, das war irgendwo in einem anderen Thread.
    A 1 Antwort Letzte Antwort
      AndyGR42
      schrieb am zuletzt editiert von AndyGR42
      #102
      @crunchip Ja, hier bin ich auch einen Schritt weiter. Ich muss das aber nochmal sauber reproduzieren. Es scheint aber so, als ob man bei gestoppten iobroker mit "npm install iobroker.vis" einen Zustand herstellen kann, dass beim nächsten Start von iobroker VIS automatisch installiert wird. Wie gesagt, muss ich nochmal reproduzieren.
      P.S.: zu früh gefreut. VIS Adapter lässt sich installieren, läuft aber nicht...
      • A AndyGR42
        @homoran Das ist leider inkorrekt:
        2022-06-22 06:57:03.677  - info: host.odroid received SIGTERM
        2022-06-22 06:57:03.683  - info: backitup.0 (11567) cleaned everything up...
        2022-06-22 06:57:03.683  - info: admin.0 (11537) terminating http server on port 8081
        2022-06-22 06:57:03.687  - info: host.odroid stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-06-22 06:57:03.688  - info: host.odroid stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-06-22 06:57:03.689  - info: host.odroid stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-06-22 06:57:03.701  - info: admin.0 (11537) Got terminate signal TERMINATE_YOURSELF
        2022-06-22 06:57:03.704  - info: discovery.0 (11552) Got terminate signal TERMINATE_YOURSELF
        2022-06-22 06:57:03.704  - info: backitup.0 (11567) Got terminate signal TERMINATE_YOURSELF
        2022-06-22 06:57:03.708  - info: host.odroid stopInstance system.adapter.admin.0 send kill signal
        2022-06-22 06:57:03.710  - info: admin.0 (11537) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-22 06:57:03.710  - info: backitup.0 (11567) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-22 06:57:03.710  - info: discovery.0 (11552) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-22 06:57:03.750  - info: host.odroid stopInstance system.adapter.discovery.0 send kill signal
        2022-06-22 06:57:03.751  - info: host.odroid stopInstance system.adapter.backitup.0 send kill signal
        2022-06-22 06:57:04.346  - info: host.odroid instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-22 06:57:04.380  - info: host.odroid instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-22 06:57:04.382  - info: host.odroid instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-22 06:57:04.382  - info: host.odroid All instances are stopped.
        2022-06-22 06:57:04.522  - info: host.odroid terminated
        2022-06-22 07:00:22.780  - info: host.gt-iob01 iobroker.js-controller version 4.0.23 js-controller starting
        2022-06-22 07:00:22.790  - info: host.gt-iob01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-06-22 07:00:22.791  - info: host.gt-iob01 hostname: gt-iob01, node: v16.15.1
        2022-06-22 07:00:22.793  - info: host.gt-iob01 ip addresses: 192.168.67.57 fe80::8db6:672a:d749:62d
        2022-06-22 07:00:27.984  - info: host.gt-iob01 connected to Objects and States
        2022-06-22 07:00:28.109  - info: host.gt-iob01 added notifications configuration of host
        2022-06-22 07:00:29.163  - info: host.gt-iob01 Delete host system.host.odroid
        2022-06-22 07:00:29.409  - info: host.gt-iob01 41 instances found
        2022-06-22 07:00:29.445  - warn: host.gt-iob01 does not start any instances on this host
        #103
        @andygr42 sagte in VIS 1.14.5 lässt sich nicht installieren:
        was genau?
        Der Hostname wird bei der Installation des OS vergeben.
        Deswegen muss dieser bei Änderung zum Backup nach dem Restore und vor dem ersten Start von ioBroker diesem via iobroker host this mitgeteilt werden.
          was genau?
          AndyGR42
          #104
          @homoran Restore ändert den Hostname. Du meintest, dass würde nicht passieren. Passt der Hostname vom Zielsystem nicht zum Hostname aus dem Backup, dann schlägt der Restore fehl und kein Adapter startet. Dennoch wird der Hostname des Zielsystem geändert, so dass bei einem zweiten Restore alles (bis auf VIS) funktioniert. Wenn man das weiß, ist alles ok. Eine Abfrage beim Restore wäre perfekt, aber so geht's ja auch.
          P.S.: oder natürlich man passt den Namen vorher an.
          HomoranH apollon77A 2 Antworten Letzte Antwort
          • A AndyGR42
            #105
            das kann sein, wenn der neue Hostname der ioBroker Installation aus dem Backup nicht mitgeteilt wurde. (siehe letzten Post)
            Das war schon immer so, zumindest gab es dann immer schon mal Probleme.
            Das sieht man unter system.host.xxxx
            im Betriebssystem??
            kann ich nicht glauben
            • A AndyGR42
              #106
              @andygr42 AAaaalso wenn man tiefer reinschauen wollte ....
              Den Hostnamen des Hosts ändern wir in keinem Fall beim Restore. Was aber sein kann ist folgendes:
              Man kann im iobroker.json den Hostname quasi überschreiben. Wenn das bei einem System gemacht wurde und das dann gebackupped wird dann steht dieser Hostname im backup und wird beim Restore auch wieder hergestellt. Wenn dort keiner definiert ist dann kommt auch keiner in die Konfig und es gilt der Hostname des Systems.
              Weiterhin gibt es beim backup eine Logik die "die Objekte von dem Host wo das Backup läuft" mit nem Patzhalter versieht und beim Restore wird der Platzhalter mit dem Hostname der nach obiger Logik dann gilt wieder geschrieben. Wenn aber noch andere Hosts im System sind (zb wegen Multihost) dann bleiben die auf Ihren Namen auch nach dem backup.
              Lange rede kurzer Sinn: Das kann schnell etwas komplexig werden und ohne jetzt bei Dir hier genau zu schauen welche Kombination beim Backup war und was dann beim Restore galt kommen wir nicht weiter
              • A AndyGR42
                Starte ich nun den gleichen Restore nochmal, mit dem nun gleichen Hostname, funktioniert es einwandfrei:
                2022-06-22 07:01:55.692  - info: host.gt-iob01 received SIGTERM
                2022-06-22 07:01:55.757  - info: host.gt-iob01 terminated
                2022-06-22 07:04:49.372  - info: host.gt-iob01 iobroker.js-controller version 4.0.23 js-controller starting
                2022-06-22 07:04:49.381  - info: host.gt-iob01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-06-22 07:04:49.383  - info: host.gt-iob01 hostname: gt-iob01, node: v16.15.1
                2022-06-22 07:04:49.385  - info: host.gt-iob01 ip addresses: 192.168.67.57 fe80::8db6:672a:d749:62d
                2022-06-22 07:04:55.980  - info: host.gt-iob01 connected to Objects and States
                2022-06-22 07:04:56.104  - info: host.gt-iob01 added notifications configuration of host
                2022-06-22 07:04:57.186  - info: host.gt-iob01 Delete host system.host.gt-iob01
                2022-06-22 07:04:57.443  - info: host.gt-iob01 41 instances found
                2022-06-22 07:04:57.505  - warn: host.gt-iob01 startInstance cannot find adapter "devices@1.0.10". Try to install it... 1 attempt
                2022-06-22 07:04:57.506  - info: host.gt-iob01 iobroker install devices@1.0.10 using installedFrom
                2022-06-22 07:04:57.579  - info: host.gt-iob01 starting 2 instances
                2022-06-22 07:04:57.919  - info: host.gt-iob01 instance system.adapter.admin.0 started with pid 11868
                2022-06-22 07:05:02.150  - info: host.gt-iob01 instance system.adapter.backitup.0 started with pid 11883
                2022-06-22 07:05:03.583  - info: host.gt-iob01 iobroker npm-install: NPM version: 8.11.0Installing iobroker.devices@1.0.10... (System call)
                2022-06-22 07:05:05.447  - info: admin.0 (11868) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
                2022-06-22 07:05:05.533  - info: admin.0 (11868) requesting all states
                2022-06-22 07:05:05.534  - info: admin.0 (11868) requesting all objects
                Einstein67
                schrieb am zuletzt editiert von Einstein67
                #107
                @andygr42 said in VIS 1.14.5 lässt sich nicht installieren:
                Kann (muss) ich leider bestätigen. Das hat aber vor ein paar Tagen noch problemlos funktioniert.
                Edit: Fehler tritt bei mir nur auf wenn das BackUp von einer SSL geschützten Iobroker-Installation gemacht wird. Ohne SSL gibts keine Probleme.
                  im Betriebssystem??
                  AndyGR42
                  #108
                  @homoran Natürlich nicht der vom OS sondern von iobroker
                  @apollon77 Danke für die ausführliche Erklärung. Mein Quellsystem hatte den iobroker Host Namen vom OS übernommen. Da bin ich mir ziemlich sicher, da ich damals im Netzwerk noch mit dynamischen DNS Updates per DHCP gearbeitet habe und deshalb der OS Hostname wichtig war. Mache ich mittlerweile nicht mehr, weil zu aufwändig. Die 2-3 Systeme wo DNS Auflösung wichtig ist, bekommen halt eine feste IP und einen DNS Eintrag. Von daher bin ich ziemlich sicher, dass ich nix per Hand in eine config Datei geschrieben haben. Multihost hab ich auch nicht.
                  • A AndyGR42
                    #109
                    klar!
                    weil backitup nach dem restore ein iobroker host this macht, bevor iobroker wieder gestartet wird.
                      klar!
                      AndyGR42
                      #110
                      @homoran sagte in VIS 1.14.5 lässt sich nicht installieren:
                      klar!
                      Also ändert ein Restore doch den iob Host Name, wenn dieser zwischen Ziel- und Quellsystem unterschiedlich ist? Egal, wie man dieses Problem löst ist ja bekannt und einfach.
                      Ich habe aber immer noch Probleme mit VIS nach dem Restore. Das passiert jedes Mal, wenn ich versuche die Instanz zu starten:
                      2022-06-22 10:50:40.071  - info: host.gt-iob01 "system.adapter.vis.0" disabled
                      2022-06-22 10:50:42.226  - info: host.gt-iob01 "system.adapter.vis.0" enabled
                      2022-06-22 10:50:43.979  - debug: vis.0 (21503) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2022-06-22 10:50:44.088  - debug: vis.0 (21503) Objects client ready ... initialize now
                      2022-06-22 10:50:44.092  - debug: vis.0 (21503) Objects create System PubSub Client
                      2022-06-22 10:50:44.094  - debug: vis.0 (21503) Objects create User PubSub Client
                      2022-06-22 10:50:44.258  - debug: vis.0 (21503) Objects client initialize lua scripts
                      2022-06-22 10:50:44.271  - debug: vis.0 (21503) Objects connected to redis: 127.0.0.1:9001
                      2022-06-22 10:50:44.276  - silly: vis.0 (21503) redis psubscribe cfg.o.system.user.*
                      2022-06-22 10:50:44.338  - silly: vis.0 (21503) redis psubscribe cfg.o.enum.*
                      2022-06-22 10:50:44.348  - silly: vis.0 (21503) objectDB connected
                      2022-06-22 10:50:44.353  - debug: vis.0 (21503) Redis States: Use Redis connection: 127.0.0.1:9000
                      2022-06-22 10:50:44.433  - debug: vis.0 (21503) States create System PubSub Client
                      2022-06-22 10:50:44.436  - debug: vis.0 (21503) States create User PubSub Client
                      2022-06-22 10:50:44.625  - debug: vis.0 (21503) States connected to redis: 127.0.0.1:9000
                      2022-06-22 10:50:44.627  - silly: vis.0 (21503) statesDB connected
                      2022-06-22 10:50:44.977  - info: vis.0 (21503) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
                      2022-06-22 10:50:45.035  - silly: vis.0 (21503) States system redis pmessage system.adapter.vis.0.logLevel/system.adapter.vis.0.logLevel:{"val":"silly","ack":true,"ts":1655895045019,"q":0,"from":"system.adapter.vis.0","lc":1655299810220}
                      2022-06-22 10:50:45.229  - info: vis.0 (21503) vis license is OK.
                      2022-06-22 10:50:46.135  - info: vis.0 (21503) Terminated (NO_ERROR): Without reason
                      2022-06-22 10:50:46.784  - info: host.gt-iob01 instance system.adapter.vis.0 terminated while should be started once
                      VIS läuft aber! Damit habe ich im Prinzip den gleichen Zustand wie in meinem prod System, was ich wohl irgendwie durch eine Installation einer VIS Version während des Restore bzw. Neustart hingebastelt habe. So wirklich überzeugend ist das aber nicht :(
                      Das System (Ubuntu 20.04.4 LTS auf Odroid C4) habe ich wie folgt vorbereitet:
                      • iobroker entfernt:
                      sudo rm -fR /usr/lib/node_modules
                      sudo rm -fR /opt/iobroker
                      sudo apt remove --purge nodejs
                      sudo systemctl disable iobroker.service
                      • iobroker per Script neu installiert (node 16.15.1, npm 8.11.0)
                      • Host Name per Admin geändert
                      • VIS 1.14.5 per CLI installiert (läuft, wenn auch ohne Lizenz)
                      • Restore per CLI (funktioniert einwandfrei, alle Adapter werden installiert)
                      • A AndyGR42
                        klar!
                        #111
                        auch richtig.
                        Das issue mit vis ist temporär und bekannt.
                        Hat (fast) nichts mit dem Rest zu tun
                          auch richtig.
                          AndyGR42
                          #112
                          @homoran Gut, dann warte ich auf ein VIS Update bevor ich das prod System noch mal restore oder andere Adapter aktualisiere.
