  4. Openmediavault und ioBroker Backup funktioniert nicht
    5.8k
15 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    wusa
    ich habe einen Openmediavault aufgesetzt, damit ich meine ioBroker Backups auslagern kann.
    Leider funktioniert das nicht wie erwartet.
    Als Fehler erscheint in ioBroker folgendes:
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.7.14:/export/iobroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.iobroker 1549 states saved
    [DEBUG] [iobroker] - host.iobroker 1922 objects saved
    [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2022_06_07-08_53_54_backupiobroker.tar.gz'
    [DEBUG] [iobroker] - done
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
    [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
    [DEBUG] [javascripts] - found Script: RollosEG
    [DEBUG] [javascripts] - found Script: RollosOG
    [DEBUG] [javascripts] - found Script: Benzinpreis
    [DEBUG] [javascripts] - found Script: test_sayit
    [DEBUG] [javascripts] - found Script: Heizung
    [DEBUG] [javascripts] - found Script: Muell
    [DEBUG] [javascripts] - found Script: Handy_laden
    [DEBUG] [javascripts] - found Script: Trockner
    [DEBUG] [javascripts] - found Script: Telegram
    [DEBUG] [javascripts] - javascript Backup not created
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 9
    Soweit ich das richtig deute, ist das ein Fehler innerhalb ioBroker.
    Es kann nicht auf /opt/... geschrieben werden.
    In Richtung OMV sieht das ganze bisher soweit gut aus.
    Nutze ich das Backup lokal, dann funktionierte es bisher ohne Probleme.
    Zumindest sehe ich Backups, welche ich Wiederherstellen könnte.
    Kann mir hier jemand helfen?
    • W wusa
      [EXIT] 9
      crunchipC Abwesend
      crunchipC Abwesend
      @wusa sagte in Openmediavault und ioBroker Backup funktioniert nicht:
      Kein Fehler, keine Berechtigung
      W 1 Antwort Letzte Antwort
        W Offline
        W Offline
        wusa
        @crunchip
        Ja war vielleicht falsch ausgedrückt. Aber wie kann ich das beheben? Ich habe bisher noch nichts im Dateisystem selbst gemacht. Bisher nur ioBroker über die GUI genutzt.
        Einzig für Updates nutzte ich die Konsole. Und dort auch nur strikt nach Anleitung.
        Ich könnte jetzt natürlich die Ordnerberechtigung verändern, aber ist das die Lösung?
        • W wusa
          @crunchip
          @wusa
          NFS? Da sollte der User auf dem Server die gleiche uid haben/bekommen wie der User 'iobroker' auf dem iobroker-System.
          Dann passen auch die Berechtigungen.
          So wie das jetzt gemountet ist dürfte das ab mountpunkt dem roof gehören, da darf der iobroker nix schreiben.
            @wusa
            W Offline
            W Offline
            wusa
            Nehme ich den Haken bei
            Als root-Benutzer mounten (sudo)
            raus, dann kommt folgende Meldung
            [DEBUG] [mount] - nfs-mount command: "mount 192.168.7.14:/export/iobroker /opt/iobroker/backups"
            [ERROR] [mount] - [undefined mount: only root can do that
            [ERROR] [mount] - Error: Command failed: mount 192.168.7.14:/export/iobroker /opt/iobroker/backups
            Ist das jetzt ein Fehler in OMV oder ioBroker?
            • W wusa
              Weder noch. Das ist ein Fehler in der Anlage der Berechtigungen. Musst du dich mit deinem Admin auf für die Kiste in Verbinddung setzen.
                W Offline
                W Offline
                wusa
                Der Admin bin ich selber. Da mein NAS aber schon so alt ist, dass ich es für diese Sachen nicht mehr verwenden kann, habe ich mir OMV installiert.
                Da ich damit aber noch nicht gearbeitet habe, hatte ich gehofft, dass ich hier vielleicht Hilfe bekomme.
                Bei den NFS Freigaben ist doch eigentlich nur die IP Ausschlaggebend. Diese wurde freigegeben.
                Speziell User kann soweit ich weiß bei NFS nicht angegeben werden.
                • W wusa
                  Doch, gerade NFS setzt auf die Unix-Rechte, die Rechte auf uid und gid werden da 1:1 durchgereicht. Oder man muss die beim mounten mappen.
                    W Offline
                    W Offline
                    wusa
                    Ich verstehe es noch nicht ganz.
                    Lasse ich mir die UID und GID von iobroker anzeigen.
                    sudo -u iobroker id
                    uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),112(bluetooth),997(gpio),998(i2c)
                    Bekomme ich bei uid und gid die 1001.
                    Diese 2 IDs müssen jetzt in OMV hinterlegt werden? Oder wo müssen die rein?
                    subtree_check,insecure,anonuid=1001,anongid=1001
                    So würde es jetzt in OMV aussehen. Allerdings funktioniert das nicht.
                    • W wusa
                      sudo -u iobroker id
                      @wusa
                      Ich hab das nie in OMV aufgesetzt. Aber in deren Handbuch steht:
                      Permissions
                      NFS relies on uid/gid matching at the remote/local filesystem and it doesn’t provide any authentication/security at all. Basic security is provided by using network allow, and squash options. If you want extra security in NFS, you will need to configure it to use kerberos ticketing system.
                      https://openmediavault.readthedocs.io/en/5.x/administration/services/nfs.html
                      Das ist genau so wie ich das für NFS kenne. Kerberos usw. ist natürlich für kleine Heimnetze totaler overkill.
                        @wusa
                        Permissions
                        W Offline
                        W Offline
                        wusa
                        Wenn ich das richtig verstehe, dann brauche ich aber auf dem OMV Server auch einen User iobroker mit den selben uid/gid?
                        Bisher habe ich noch keinen User angelegt, da über die GUI keine uid/gid eingetragen werden kann.
                        • W wusa
                          @wusa said in Openmediavault und ioBroker Backup funktioniert nicht:
                          Ja.
                          • W wusa
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @wusa also ich habe in omv einen user angelegt.
                            Dieser ist in der Gruppe
                            Users, ssh, sudo, sambashare
                            Ich verwende allerdings nicht nfs, sondern cifs.
                            Dieser user mit Passwort ist dann im backitup Adapter hinterlegt.
                            W 2 Antworten Letzte Antwort
                              W Offline
                              W Offline
                              wusa
                              @crunchip
                              Ok das teste ich.
                              Ich wollte eigentlich NFS verwenden, da beide Systeme auf Linux Basis sind.
                              Aber vielleicht klappt es mit CIFS.
                                W Offline
                                W Offline
                                wusa
                                @crunchip
                                Danke mit CIFS hat es auf Anhieb funktioniert!
