  4. SONOFF Adapter in Kollision mit MQTT Adapter
    5.6k
54 Beiträge 9 Kommentatoren 4.9k Aufrufe 6 Beobachtet
  • G Offline
    GOETSCHHOFER
    #41
    @haselchen
    Die Zeit ist in der Console korrekt.
    • ChaotC Chaot
      @goetschhofer Brauchst du doch gar nicht.
      Gib mal in der Konsole
      PowerDelta101
      ein. Dann wird bei Änderung >1W der Wert gesendet.
      Geht auch
      PowerDelta1
      Dann wird bei Änderung von 1% gesendet.
      Hier:
      https://tasmota.github.io/docs/Commands/#power-monitoring
      kannst du vieles nachlesen
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      #42
      @chaot said in SONOFF Adapter in Kollision mit MQTT Adapter:
      PowerDelta101
      Bei PowerDelta101 bekomme ich eine Fehlermeldung ?
      11:21:09.457 CMD: PowerDelta101
      11:21:09.464 MQT: stat/IntelliGrid_3E6087/RESULT = {"Command":"Error"}
      11:21:12.424 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:21:12","Uptime":"0T02:08:29","UptimeSec":7709,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":1,"Downtime":"0T00:00:05"}}
      11:21:12.456 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:21:12","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":220,"Current":0.000}}
      11:21:22.419 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:21:22","Uptime":"0T02:08:39","UptimeSec":7719,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":44,"Signal":-78,"LinkCount":1,"Downtime":"0T00:00:05"}}
      11:21:22.451 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:21:22","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":220,"Current":0.000}}
      11:21:32.419 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:21:32","Uptime":"0T02:08:49","UptimeSec":7729,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:05"}}
      11:21:32.452 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:21:32","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":219,"Current":0.000}}
      11:21:42.406 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:21:42","Uptime"
      Bei PowerDelta1 nicht.
      11:23:00.501 CMD: PowerDelta1
      11:23:00.508 MQT: stat/IntelliGrid_3E6087/RESULT = {"PowerDelta1":0}
      11:23:02.406 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:23:02","Uptime":"0T02:10:19","UptimeSec":7819,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":44,"Signal":-78,"LinkCount":1,"Downtime":"0T00:00:05"}}
      11:23:02.439 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:23:02","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":218,"Current":0.000}}
      11:23:12.449 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:23:12","Uptime":"0T02:10:29","UptimeSec":7829,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:05"}}
      11:23:12.481 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:23:12","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":218,"Current":0.000}}
      11:23:22.432 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:23:22","Uptime":"0T02:1
      • G GOETSCHHOFER
        PowerDelta101
        ChaotC Offline
        ChaotC Offline
        Chaot
        #43
        @goetschhofer Oh, Leerzeichen vergessen:
        powerdelta 101
        G 1 Antwort Letzte Antwort
        • ChaotC Chaot
          powerdelta 101
          GOETSCHHOFER
          #44
          powerdelta 101
          Sehr gut, danke.
          11:31:21.294 CMD: powerdelta 101
          11:31:21.301 MQT: stat/IntelliGrid_3E6087/RESULT = {"PowerDelta1":101}
          11:31:22.443 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:31:22","Uptime":"0T02:18:39","UptimeSec":8319,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":1,"Downtime":"0T00:00:05"}}
          11:31:22.475 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:31:22","ENERGY":{"TotalStartTime":"2022-11-26T18:09:02","Total":3.333,"Yesterday":0.021,"Today":0.028,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":221,"Current":0.000}}
          11:31:32.427 MQT: tele/IntelliGrid_3E6087/STATE = {"Time":"2022-11-27T11:31:32","Uptime":"0T02:18:49","UptimeSec":8329,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 US-2,4 GHz","BSSId":"DC:39:6F:DB:30:7F","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":1,"Downtime":"0T00:00:05"}}
          11:31:32.460 MQT: tele/IntelliGrid_3E6087/SENSOR = {"Time":"2022-11-27T11:31:32","ENERGY":{"
          • G GOETSCHHOFER
            powerdelta 101
            Sehr gut, danke.
            ChaotC Offline
            ChaotC Offline
            Chaot
            #45
            @goetschhofer Aber dir muss klar sein das du jetzt jede Menge Traffic in deinem WLan hast.
            • ChaotC Chaot
              GOETSCHHOFER
              #46
              Welche Einstellung würdest du empfehlen ?
              Ist Powerdelta 101 alle 10 Sekunden ?
              • G GOETSCHHOFER
                ChaotC Offline
                ChaotC Offline
                Chaot
                #47
                @goetschhofer Das kommt darauf an wie ausgelastet dein Netzwerk ist.
                Wenn du nur ein paar Geräte hast sehe ich da wenig Probleme. Bei mir sind knapp 80 Geräte aktiv. Da ist es schon blöd wenn ein Gerät so das Netz zuballert.
                • ChaotC Chaot
                  GOETSCHHOFER
                  #48
                  Wenn es nur um das Wlan geht sieht es bei mir folgendermaßen aus:
                  1 IR-Lesekopf für Auslesen EVU-Smartmeter, 2 Shellys u. aktuell 1 Sonoff-Stecker.
                  Aber ich denke, es werden sicherlich noch ca. 5 dazu kommen. 😄
                  Aber welche Einstellung hast du ?
                  Powerdelta 101 bedeutet ?
                  • G GOETSCHHOFER
                    ChaotC Offline
                    ChaotC Offline
                    Chaot
                    #49
                    @goetschhofer
                    Poerdelta bedeutet das ein Datenpaket gesendet wird sobald sich der Wert um den eingestellten Faktor ändert.
                    Bei 101 heißt das bei Änderung um 1 Watt.
                    Für was wird der Stecker denn benutzt? Oder anders ausgedrückt: Wie genau brauchst du das denn überhaupt?
                    Der interne Wert des Verbrauchs wird permanent aufgezeichnet. Dazu benötigt man keine Telemetrieperiode. Mir reicht es in der VIS wenn ich alle 5 Minuten den Verbrauch übertragen bekomme. Ich benötige nicht sekundengenau den aktuellen Verbrauchswert.
                    • ChaotC Chaot
                      @goetschhofer
                      GOETSCHHOFER
                      #50
                      @goetschhofer
                      Das ganze dient ja anfangs nur zu Test- und Informationszwecken, darum meine Genauigkeit.
                      Mich interessiert eben, aus Lastprofil-Sicht, wie tickt ein Kühlschrank, Geschirrspüler oder Waschmaschine.
                      Ich teste so meine Verbraucher durch.
                      Langfristig hat es keinen Sinn Datenmüll, vor allem auch auf der InfluxDB, zu erzeugen.
                      ChaotC crunchipC 2 Antworten Letzte Antwort
                      • G GOETSCHHOFER
                        @goetschhofer
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        #51
                        @goetschhofer Bei solchen Geräten kannst du aber auch höhere Deltawerte verwenden. Ob der Motor mal 1-2 Watt hin und her schwankt ist ja dann unerheblich.
                        Also reicht dir im Grunde die 105, also 5 Watt Änderung locker aus.
                        Bei einem Kühlschrank macht es auch Sinn den Verbrauch auf 7 Tage zu sehen und dann durch die Stunden zu teilen. Dann hast du einen realistischen Wert. Da wird am Sonntag mal öfter die Tür aufgemacht und dafür am Dienstag beispielsweise kaum usw. Also Zählerwert von Montag 8:00 Uhr bis Montag 7:59 Uhr geteilt durch 168 Stunden ist der Stundenverbrauch des Kühlschranks. Der Wert mal 52 ist der Jahresverbrauch usw....
                        Waschmaschine und Geschirrspüler habe ich bei mir einzeln getestet mit den entsprechendem Programmablauf. Also meine Arbeitsklamotten auf 60°C mit dem Programm X brauchen xxx Watt pro Waschgang. Das ist eine Zahl die ich einfacher meiner Frau verkaufen kann: "Waschen mit Programm X kostet X,xx €"
                        • G GOETSCHHOFER
                          @goetschhofer
                          crunchipC Offline
                          crunchipC Offline
                          #52
                          @goetschhofer sagte in SONOFF Adapter in Kollision mit MQTT Adapter:
                          kann man für kurzfristige Sachen aber auch einfach in den Historie Adapter schreiben
                          oder aber, man legt sich eine 2Influxdb Instanz an(zum spielen), die kann man einfach leeren, mit einem klick
                          • ChaotC Chaot
                            GOETSCHHOFER
                            #53
                            @chaot
                            Ja, ich werde dies auf jeden Fall auf 105 hochstellen.
                            So wie du dies gemacht hast, stelle ich mir dies auch vor bezüglich hochskalieren.
                            Am Ende zählt der Verbrauch in Wh pro Zeitperiode.
                              GOETSCHHOFER
                              #54
                              @crunchip
                              an diese Möglichkeiten hab ich noch gar nicht gedacht. 👍
