  4. Fehler beim js-controller update
39 Beiträge 3 Kommentatoren 7.1k Aufrufe 3 Beobachtet
    @headder9999
    sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    headder9999
    @thomas-braun sagte in Fehler beim js-controller update:
    done
    Rasperry Pi3
    iobroker mit Homematic CCU image
    • H headder9999
      done
      @headder9999 Dann nochmal...
      iobroker upgrade
      H 1 Antwort Letzte Antwort
        iobroker upgrade
        headder9999
        Hi, da bin ich wieder...
        der letzte Befehl brachte nicht den gewünschten Erfolg:
        user@iobroker-pi:~ $ iobroker upgrade
        Adapter "accuweather"    is not installed.
        Adapter "adb"            is not installed.
        Adapter "adguard"        is not installed.
        Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
        Adapter "aio"            is not installed.
        Adapter "airconwithme"   is not installed.
        Adapter "airzone"        is not installed.
        This upgrade of "alarm" will at least introduce the following changes:
        -> 3.0.5:
        fixed pushover issue
        -> 3.0.4:
        changed burgle concept, added silent alarm at sharp inside, fixed little issues
        -> 2.2.1:
        added notification when warnings at beginning night rest
        -> 2.2.0:
        added telegram special parameters
        -> 2.1.2:
        fixed "colors" vulnerabilities
        -> 2.1.1:
        added countdown state for silent alarm
        -> 2.1.0:
        extend list states and speech output, added leave option
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
        Update alarm from @2.0.2 to @3.0.5
        NPM version: 8.5.0
        npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (Syst
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/typescript
        npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
        npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
        host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
        Rasperry Pi3
        • H headder9999
          -> 3.0.5:
          -> 3.0.4:
          -> 2.2.1:
          -> 2.2.0:
          -> 2.1.2:
          -> 2.1.1:
          -> 2.1.0:
          NPM version: 8.5.0
          npm ERR! errno -39
          @headder9999
          Gleiche Nummer, anderes Modul...
          Verzeichnis umbenennen.
            @headder9999
            headder9999
            so`?
            sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
            Rasperry Pi3
            • H headder9999
              so`?
              @headder9999
              Nein, der Quell-Ordner ist
                @headder9999
                headder9999
                nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
                user@iobroker-pi:~ $ iobroker upgrade self
                Update js-controller from @3.2.16 to @4.0.21
                NPM version: 8.5.0
                npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
                Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                Starting node restart.js
                Rasperry Pi3
                • H headder9999
                  NPM version: 8.5.0
                  headder9999
                  @Thomas-Braun
                  Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                  Soweit so gut
                  aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                  Ich verstehe die Welt nicht mehr....
                  Rasperry Pi3
                  • H headder9999
                    @Thomas-Braun
                    Soweit so gut
                    @headder9999
                    iobroker stop
                    iobroker upload all
                    iobroker update
                    iobroker upgrade
                    Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                    H 2 Antworten Letzte Antwort
                      @headder9999
                      iobroker stop
                      iobroker upload all
                      iobroker update
                      iobroker upgrade
                      headder9999
                      ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                      danke bis hier her!!
                      Rasperry Pi3
                        @headder9999
                        iobroker stop
                        iobroker upload all
                        iobroker update
                        iobroker upgrade
                        headder9999
                        da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                        Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                        Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                        Habt ihr eine Idee?
                        Rasperry Pi3
                        • H headder9999
                          Habt ihr eine Idee?
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @headder9999 sagte in Fehler beim js-controller update:
                          die aktuell nur du siehst😜
                            headder9999
                            @crunchip
                            Oh...
                            pi@iobroker-pi:~ $ iob upgrade
                            This upgrade of "yamaha" will introduce the following changes:
                            -> 0.5.3:
                            Fix crash cases reported by Sentry
                            -> 0.5.2:
                            Would you like to upgrade yamaha from @0.5.1 to @0.5.3 now? [(y)es, (n)o]: y
                            Update yamaha from @0.5.1 to @0.5.3
                            NPM version: 8.19.3
                            Installing iobroker.yamaha@0.5.3... (System call)
                            host.iobroker-pi Cannot install iobroker.yamaha@0.5.3: 217
                            Rasperry Pi3
                            • H headder9999
                              @crunchip
                              Oh...
                              -> 0.5.3:
                              -> 0.5.2:
                              NPM version: 8.19.3
                              @headder9999
                              Ist oben angepinnt...
                              • H headder9999
                                @crunchip
                                Oh...
                                -> 0.5.3:
                                -> 0.5.2:
                                NPM version: 8.19.3
                                crunchipC Abwesend
                                crunchipC Abwesend
                                  @headder9999
                                  headder9999
                                  was heißt oben angepinnt?
                                  Rasperry Pi3
                                  • H headder9999
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                      headder9999
                                      @crunchip was heißt das nun für mich?
                                      Rasperry Pi3
                                      • H headder9999
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @headder9999 das machen was drin steht
                                        die Zeile ausführen
                                        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
