  4. Fehler beim js-controller update
39 Beiträge 3 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • H headder9999
    beim ersten update kommt gleich wieder ne npm fehlermeldung:
    user@iobroker-pi:~ $ iobroker upgrade
    Adapter "accuweather"    is not installed.
    Adapter "adb"            is not installed.
    Adapter "adguard"        is not installed.
    Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
    Adapter "aio"            is not installed.
    Adapter "airconwithme"   is not installed.
    Adapter "airzone"        is not installed.
    This upgrade of "alarm" will at least introduce the following changes:
    -> 3.0.5:
    fixed pushover issue
    -> 3.0.4:
    changed burgle concept, added silent alarm at sharp inside, fixed little issues
    -> 2.2.1:
    added notification when warnings at beginning night rest
    -> 2.2.0:
    added telegram special parameters
    -> 2.1.2:
    fixed "colors" vulnerabilities
    -> 2.1.1:
    added countdown state for silent alarm
    -> 2.1.0:
    extend list states and speech output, added leave option
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
    Update alarm from @2.0.2 to @3.0.5
    NPM version: 8.5.0
    npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_31_11_681Z-debug-0.log
    host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
    @headder9999
    sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    H 1 Antwort Letzte Antwort
      @headder9999
      headder9999
      @thomas-braun sagte in Fehler beim js-controller update:
      done
      Rasperry Pi3
      iobroker mit Homematic CCU image
      • H headder9999
        done
        @headder9999 Dann nochmal...
        iobroker upgrade
          iobroker upgrade
          headder9999
          Hi, da bin ich wieder...
          der letzte Befehl brachte nicht den gewünschten Erfolg:
          -> 3.0.5:
          -> 3.0.4:
          -> 2.2.1:
          -> 2.2.0:
          -> 2.1.2:
          -> 2.1.1:
          -> 2.1.0:
          NPM version: 8.5.0
          npm ERR! path /opt/iobroker/node_modules/typescript
          npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
          npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
          Rasperry Pi3
          • H headder9999
            -> 3.0.5:
            -> 3.0.4:
            -> 2.2.1:
            -> 2.2.0:
            -> 2.1.2:
            -> 2.1.1:
            -> 2.1.0:
            NPM version: 8.5.0
            npm ERR! errno -39
            @headder9999
            Gleiche Nummer, anderes Modul...
            Verzeichnis umbenennen.
              @headder9999
              headder9999
              so`?
              sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
              Rasperry Pi3
              • H headder9999
                so`?
                @headder9999
                Nein, der Quell-Ordner ist
                  @headder9999
                  headder9999
                  nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
                  user@iobroker-pi:~ $ iobroker upgrade self
                  Update js-controller from @3.2.16 to @4.0.21
                  NPM version: 8.5.0
                  npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                  Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                  Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                  Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                  Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
                  Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                  Starting node restart.js
                  Rasperry Pi3
                  • H headder9999
                    NPM version: 8.5.0
                    headder9999
                    @Thomas-Braun
                    Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                    Soweit so gut
                    aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                    Ich verstehe die Welt nicht mehr....
                    Rasperry Pi3
                    • H headder9999
                      @Thomas-Braun
                      Soweit so gut
                      @headder9999
                      iobroker stop
                      iobroker upload all
                      iobroker update
                      iobroker upgrade
                      Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                      H 2 Antworten Letzte Antwort
                        @headder9999
                        iobroker stop
                        iobroker upload all
                        iobroker update
                        iobroker upgrade
                        headder9999
                        ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                        danke bis hier her!!
                        Rasperry Pi3
                          @headder9999
                          iobroker stop
                          iobroker upload all
                          iobroker update
                          iobroker upgrade
                          headder9999
                          da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                          Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                          Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                          Habt ihr eine Idee?
                          Rasperry Pi3
                          • H headder9999
                            Habt ihr eine Idee?
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @headder9999 sagte in Fehler beim js-controller update:
                            die aktuell nur du siehst😜
                              headder9999
                              @crunchip
                              Oh...
                              pi@iobroker-pi:~ $ iob upgrade
                              This upgrade of "yamaha" will introduce the following changes:
                              -> 0.5.3:
                              Fix crash cases reported by Sentry
                              -> 0.5.2:
                              Would you like to upgrade yamaha from @0.5.1 to @0.5.3 now? [(y)es, (n)o]: y
                              Update yamaha from @0.5.1 to @0.5.3
                              NPM version: 8.19.3
                              Installing iobroker.yamaha@0.5.3... (System call)
                              host.iobroker-pi Cannot install iobroker.yamaha@0.5.3: 217
                              Rasperry Pi3
                              • H headder9999
                                @crunchip
                                Oh...
                                -> 0.5.3:
                                -> 0.5.2:
                                NPM version: 8.19.3
                                @headder9999
                                Ist oben angepinnt...
                                • H headder9999
                                  @crunchip
                                  Oh...
                                  -> 0.5.3:
                                  -> 0.5.2:
                                  NPM version: 8.19.3
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                    @headder9999
                                    headder9999
                                    was heißt oben angepinnt?
                                    Rasperry Pi3
                                    • H headder9999
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                        headder9999
                                        @crunchip was heißt das nun für mich?
                                        Rasperry Pi3
                                        • H headder9999
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @headder9999 das machen was drin steht
                                          die Zeile ausführen
                                          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
