  4. Fehler beim js-controller update
39 Beiträge 3 Kommentatoren 7.1k Aufrufe 3 Beobachtet
    @headder9999
    iobroker update -i
    Komplette Ein- und Ausgabe bedeutet inkl. Eingabezeile / prompt.
    headder9999
    so?
    user@iobroker-pi:~ $ iobroker update -i
    Used repository: stable
    hash changed or no sources cached => force download of new sources
    update done
    Adapter    "admin"         : 5.3.1    , installed 5.1.23 [Updateable]
    Adapter    "alarm"         : 3.0.5    , installed 2.0.2 [Updateable]
    Adapter    "backitup"      : 2.3.3    , installed 2.1.13 [Updateable]
    Adapter    "discovery"     : 2.7.5    , installed 2.7.0 [Updateable]
    Adapter    "history"       : 1.10.5   , installed 1.9.13 [Updateable]
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "iot"           : 1.8.24   , installed 1.8.22 [Updateable]
    Adapter    "javascript"    : 5.2.21   , installed 5.2.21
    Controller "js-controller" : 4.0.21   , installed 3.2.16 [Updateable]
    Adapter    "net-tools"     : 0.1.7    , installed 0.1.5 [Updateable]
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "plenticore"    : 2.2.0    , installed 2.2.0
    Adapter    "simple-api"    : 2.6.2    , installed 2.6.1 [Updateable]
    Adapter    "socketio"      : 4.1.4    , installed 3.1.4 [Updateable]
    Adapter    "tr-064"        : 4.2.15   , installed 4.2.14 [Updateable]
    Adapter    "web"           : 4.2.0    , installed 3.4.7 [Updateable]
    Rasperry Pi3
    iobroker mit Homematic CCU image
    • H headder9999
      so?
      update done
      @headder9999
      Ja, so.
      Bist aber eher ein Update-Muffel...
      iobroker upgrade
      H 1 Antwort Letzte Antwort
        @headder9999
        Ja, so.
        iobroker upgrade
        headder9999
        schrieb am zuletzt editiert von headder9999
        beim ersten update kommt gleich wieder ne npm fehlermeldung:
        user@iobroker-pi:~ $ iobroker upgrade
        Adapter "accuweather"    is not installed.
        Adapter "adb"            is not installed.
        Adapter "adguard"        is not installed.
        Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
        Adapter "aio"            is not installed.
        Adapter "airconwithme"   is not installed.
        Adapter "airzone"        is not installed.
        This upgrade of "alarm" will at least introduce the following changes:
        -> 3.0.5:
        fixed pushover issue
        -> 3.0.4:
        changed burgle concept, added silent alarm at sharp inside, fixed little issues
        -> 2.2.1:
        added notification when warnings at beginning night rest
        -> 2.2.0:
        added telegram special parameters
        -> 2.1.2:
        fixed "colors" vulnerabilities
        -> 2.1.1:
        added countdown state for silent alarm
        -> 2.1.0:
        extend list states and speech output, added leave option
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
        Update alarm from @2.0.2 to @3.0.5
        NPM version: 8.5.0
        npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
        npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
        npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_31_11_681Z-debug-0.log
        host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
        Rasperry Pi3
        • H headder9999
          -> 3.0.5:
          -> 3.0.4:
          -> 2.2.1:
          -> 2.2.0:
          -> 2.1.2:
          -> 2.1.1:
          -> 2.1.0:
          NPM version: 8.5.0
          npm ERR! errno -39
          @headder9999 Alles?
          • H headder9999
            -> 3.0.5:
            -> 3.0.4:
            -> 2.2.1:
            -> 2.2.0:
            -> 2.1.2:
            -> 2.1.1:
            -> 2.1.0:
            NPM version: 8.5.0
            npm ERR! errno -39
            @headder9999
            sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
              @headder9999
              headder9999
              @thomas-braun sagte in Fehler beim js-controller update:
              done
              Rasperry Pi3
              • H headder9999
                done
                @headder9999 Dann nochmal...
                iobroker upgrade
                  iobroker upgrade
                  headder9999
                  Hi, da bin ich wieder...
                  der letzte Befehl brachte nicht den gewünschten Erfolg:
                  -> 3.0.5:
                  -> 3.0.4:
                  -> 2.2.1:
                  -> 2.2.0:
                  -> 2.1.2:
                  -> 2.1.1:
                  -> 2.1.0:
                  NPM version: 8.5.0
                  npm ERR! path /opt/iobroker/node_modules/typescript
                  npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
                  Rasperry Pi3
                  • H headder9999
                    -> 3.0.5:
                    -> 3.0.4:
                    -> 2.2.1:
                    -> 2.2.0:
                    -> 2.1.2:
                    -> 2.1.1:
                    -> 2.1.0:
                    NPM version: 8.5.0
                    npm ERR! errno -39
                    @headder9999
                    Gleiche Nummer, anderes Modul...
                    Verzeichnis umbenennen.
                      @headder9999
                      headder9999
                      so`?
                      sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
                      Rasperry Pi3
                      • H headder9999
                        so`?
                        @headder9999
                        Nein, der Quell-Ordner ist
                          @headder9999
                          headder9999
                          nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
                          user@iobroker-pi:~ $ iobroker upgrade self
                          Update js-controller from @3.2.16 to @4.0.21
                          NPM version: 8.5.0
                          npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                          Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                          Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                          Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                          Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                          Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
                          Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                          Starting node restart.js
                          Rasperry Pi3
                          • H headder9999
                            NPM version: 8.5.0
                            headder9999
                            @Thomas-Braun
                            Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                            Soweit so gut
                            aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                            Ich verstehe die Welt nicht mehr....
                            Rasperry Pi3
                            • H headder9999
                              @Thomas-Braun
                              Soweit so gut
                              @headder9999
                              iobroker stop
                              iobroker upload all
                              iobroker update
                              iobroker upgrade
                              Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                              H 2 Antworten Letzte Antwort
                                @headder9999
                                iobroker stop
                                iobroker upload all
                                iobroker update
                                iobroker upgrade
                                headder9999
                                ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                                danke bis hier her!!
                                Rasperry Pi3
                                  @headder9999
                                  iobroker stop
                                  iobroker upload all
                                  iobroker update
                                  iobroker upgrade
                                  headder9999
                                  da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                                  Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                                  Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                                  Habt ihr eine Idee?
                                  Rasperry Pi3
                                  • H headder9999
                                    Habt ihr eine Idee?
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @headder9999 sagte in Fehler beim js-controller update:
                                    die aktuell nur du siehst😜
                                      headder9999
                                      @crunchip
                                      Oh...
                                      pi@iobroker-pi:~ $ iob upgrade
                                      This upgrade of "yamaha" will introduce the following changes:
                                      -> 0.5.3:
                                      Fix crash cases reported by Sentry
                                      -> 0.5.2:
                                      Would you like to upgrade yamaha from @0.5.1 to @0.5.3 now? [(y)es, (n)o]: y
                                      Update yamaha from @0.5.1 to @0.5.3
                                      NPM version: 8.19.3
                                      Installing iobroker.yamaha@0.5.3... (System call)
                                      host.iobroker-pi Cannot install iobroker.yamaha@0.5.3: 217
                                      Rasperry Pi3
                                      • H headder9999
                                        @crunchip
                                        Oh...
                                        -> 0.5.3:
                                        -> 0.5.2:
                                        NPM version: 8.19.3
                                        @headder9999
                                        Ist oben angepinnt...
                                        • H headder9999
                                          @crunchip
                                          Oh...
                                          -> 0.5.3:
                                          -> 0.5.2:
                                          NPM version: 8.19.3
                                          crunchipC Abwesend
                                          crunchipC Abwesend
