  4. Fehler beim js-controller update
39 Beiträge 3 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • H headder9999
    @thomas-braun sagte in Fehler beim js-controller update:
    sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    done
    @headder9999 Dann nochmal...
    iobroker upgrade
    H 1 Antwort Letzte Antwort
      iobroker upgrade
      headder9999
      Hi, da bin ich wieder...
      der letzte Befehl brachte nicht den gewünschten Erfolg:
      user@iobroker-pi:~ $ iobroker upgrade
      Adapter "accuweather"    is not installed.
      Adapter "adb"            is not installed.
      Adapter "adguard"        is not installed.
      Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
      Adapter "aio"            is not installed.
      Adapter "airconwithme"   is not installed.
      Adapter "airzone"        is not installed.
      This upgrade of "alarm" will at least introduce the following changes:
      -> 3.0.5:
      fixed pushover issue
      -> 3.0.4:
      changed burgle concept, added silent alarm at sharp inside, fixed little issues
      -> 2.2.1:
      added notification when warnings at beginning night rest
      -> 2.2.0:
      added telegram special parameters
      -> 2.1.2:
      fixed "colors" vulnerabilities
      -> 2.1.1:
      added countdown state for silent alarm
      -> 2.1.0:
      extend list states and speech output, added leave option
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
      Update alarm from @2.0.2 to @3.0.5
      NPM version: 8.5.0
      npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (Syst
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/typescript
      npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
      host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
      Rasperry Pi3
      iobroker mit Homematic CCU image
      • H headder9999
        -> 3.0.5:
        -> 3.0.4:
        -> 2.2.1:
        -> 2.2.0:
        -> 2.1.2:
        -> 2.1.1:
        -> 2.1.0:
        NPM version: 8.5.0
        npm ERR! errno -39
        @headder9999
        Gleiche Nummer, anderes Modul...
        Verzeichnis umbenennen.
          @headder9999
          headder9999
          so`?
          sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
          Rasperry Pi3
          • H headder9999
            so`?
            @headder9999
            Nein, der Quell-Ordner ist
              @headder9999
              headder9999
              nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
              user@iobroker-pi:~ $ iobroker upgrade self
              Update js-controller from @3.2.16 to @4.0.21
              NPM version: 8.5.0
              npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
              Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
              Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
              Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
              Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
              Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
              Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Starting node restart.js
              Rasperry Pi3
              • H headder9999
                NPM version: 8.5.0
                headder9999
                @Thomas-Braun
                Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                Soweit so gut
                aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                Ich verstehe die Welt nicht mehr....
                Rasperry Pi3
                • H headder9999
                  @Thomas-Braun
                  Soweit so gut
                  @headder9999
                  iobroker stop
                  iobroker upload all
                  iobroker update
                  iobroker upgrade
                  Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                  H 2 Antworten Letzte Antwort
                    @headder9999
                    iobroker stop
                    iobroker upload all
                    iobroker update
                    iobroker upgrade
                    headder9999
                    ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                    danke bis hier her!!
                    Rasperry Pi3
                      @headder9999
                      iobroker stop
                      iobroker upload all
                      iobroker update
                      iobroker upgrade
                      headder9999
                      da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                      Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                      Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                      Habt ihr eine Idee?
                      Rasperry Pi3
                      • H headder9999
                        Habt ihr eine Idee?
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @headder9999 sagte in Fehler beim js-controller update:
                        die aktuell nur du siehst😜
                          headder9999
                          @crunchip
                          Oh...
                          pi@iobroker-pi:~ $ iob upgrade
                          This upgrade of "yamaha" will introduce the following changes:
                          -> 0.5.3:
                          Fix crash cases reported by Sentry
                          -> 0.5.2:
                          Would you like to upgrade yamaha from @0.5.1 to @0.5.3 now? [(y)es, (n)o]: y
                          Update yamaha from @0.5.1 to @0.5.3
                          NPM version: 8.19.3
                          Installing iobroker.yamaha@0.5.3... (System call)
                          host.iobroker-pi Cannot install iobroker.yamaha@0.5.3: 217
                          Rasperry Pi3
                          • H headder9999
                            @crunchip
                            Oh...
                            -> 0.5.3:
                            -> 0.5.2:
                            NPM version: 8.19.3
                            @headder9999
                            Ist oben angepinnt...
                            • H headder9999
                              @crunchip
                              Oh...
                              -> 0.5.3:
                              -> 0.5.2:
                              NPM version: 8.19.3
                              crunchipC Abwesend
                              crunchipC Abwesend
                                @headder9999
                                headder9999
                                was heißt oben angepinnt?
                                Rasperry Pi3
                                • H headder9999
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                    headder9999
                                    @crunchip was heißt das nun für mich?
                                    Rasperry Pi3
                                    • H headder9999
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @headder9999 das machen was drin steht
                                      die Zeile ausführen
                                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
