  3. Einsteigerfragen
  4. Problem mit Admin und so
    1.9k
    2.4k
71 Beiträge 7 Kommentatoren 8.1k Aufrufe 5 Beobachtet
    @marcus-hamburg
    Siehe oben. Verzeichnis umbenennen.
    Marcus HamburgM Offline
    Marcus Hamburg
    #41
    @thomas-braun Ich verzweifle an mich selbst. 😞 😞 😞
    pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    mv: der Aufruf von stat für '/opt/iobroker/node_modules/iobroker.javascript' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
    • Marcus HamburgM Marcus Hamburg
      #42
      @marcus-hamburg sagte in Problem mit Admin und so:
      sudo -u iobroker mv /opt/iobroker/node_modules/typescript /opt/iobroker/node_modules/.typescript-rKKYB1QG
      Marcus HamburgM 1 Antwort Letzte Antwort
        Marcus Hamburg
        #43
        @thomas-braun und noch immer
        pi@raspberrypi:~ $ iob upgrade
        This upgrade of "tr-064" will introduce the following changes:
        -> 4.2.15:
        fix crash case (Sentry IOBROKER-TR-064-35)
        Would you like to upgrade tr-064 from @4.2.14 to @4.2.15 now? [(y)es, (n)o]: n
        No upgrade of "tr-064" desired.
        This upgrade of "simple-api" will introduce the following changes:
        -> 2.6.2:
        Support of new flags for `getPlainValue`: `json` and `noStringify`
        Would you like to upgrade simple-api from @2.6.1 to @2.6.2 now? [(y)es, (n)o]: y
        Update simple-api from @2.6.1 to @2.6.2
        NPM version: 8.3.1
        npm install iobroker.simple-api@2.6.2 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/virtual-tsc
        npm ERR! dest /opt/iobroker/node_modules/.virtual-tsc-7cNzXXUj
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/virtual-tsc' -> '/opt/iobroker/node_modules/.virtual-tsc-7cNzXXUj'
        npm ERR!     /home/iobroker/.npm/_logs/2022-03-16T17_38_14_891Z-debug-0.log
        host.raspberrypi Cannot install iobroker.simple-api@2.6.2: 217
        pi@raspberrypi:~ $
          -> 4.2.15:
          -> 2.6.2:
          NPM version: 8.3.1
          npm ERR! errno -39
          pi@raspberrypi:~ $
          #44
          @marcus-hamburg
          Die Nummer ist immer gleich...
          Die angebotenen Upgrades solltest du aber auch ausführen...
            @marcus-hamburg
            Marcus Hamburg
            #45
            @thomas-braun Danke bin jetzt wieder weiter, einer der letzten Sachen:
            Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y
            Update javascript from @5.2.13 to @5.2.21
            NPM version: 8.3.1
            Installing iobroker.javascript@5.2.21... (System call)
            host.raspberrypi Cannot install iobroker.javascript@5.2.21: 217
              NPM version: 8.3.1
              #46
              @marcus-hamburg
              Mehr kommt da nicht?
              iobroker stop
              iobroker update -u
              iobroker upgrade
              Marcus HamburgM HomoranH 2 Antworten Letzte Antwort
                @marcus-hamburg
                iobroker stop
                iobroker update -u
                iobroker upgrade
                Marcus Hamburg
                #47
                @thomas-braun ne nicht wirklich:
                pi@raspberrypi:~ $ iob stop
                pi@raspberrypi:~ $ iob update -u
                Used repository: stable
                Adapter    "javascript"   : 5.2.21   , installed 5.2.13 [Updatable]
                This upgrade of "javascript" will at least introduce the following changes:
                -> 5.2.21:
                Fixed build process
                -> 5.2.20:
                Fixed build process
                -> 5.2.19:
                Fix broken dependency
                -> 5.2.18:
                Fixed some german translations
                Fixed astro schedules
                -> 5.2.17:
                -> 5.2.16:
                Fixed fonts
                -> 5.2.15:
                Added the monitoring of symlinks my mirroring
                Fix two crash cases reported by Sentry
                NPM version: 8.3.1
                  @marcus-hamburg
                  iobroker stop
                  iobroker update -u
                  iobroker upgrade
                  #48
                  @thomas-braun sagte in Problem mit Admin und so:
                  zum Error 217 hab ich nichts gefunden :-(
                    Marcus Hamburg
                    #49
                    @homoran OK. Werde mal für heute Schluss machen, grundsätzlich bin sehr froh über diese tolle schnell Hilfe. Mein System ist wieder Schick und die 217 bekommt bestimmt noch jemand gelöst. Danke Danke Danke.
                    • Thomas BraunT Online
                      #50
                      @homoran sagte in Problem mit Admin und so:
                      Ich schon...
                      Hatte damals mit dem nodeJS-Setup zu tun.
                        Ich schon...
                        #51
                        das einzige was ich fand ging in die Richtung bei node-red
                        Irgendwas mit User Zuordnung
                          #52
                          https://forum.iobroker.net/topic/49058/installation-javascript-npm-modul-in-js-adapter
                          Kann natürlich sein, das die Versionen aus 'stable' noch nicht mit aktuellen node/npm-Installationen parat kommen.
                          @Marcus-Hamburg Geh mal mit nodeJS auf die Version 14 inkl. npm@6 runter.
                          • H Offline
                            hearp
                            schrieb am zuletzt editiert von hearp
                            #53
                            ich hatte das selbe Problem.
                            Gelöst habe ich es, indem ich den erweiterten Modus eingeschaltet habe. Im Log kam dann immer die Meldung, daß irgendein Verzeichnis nicht leer sei. Das Verzeichnis habe ich dann mittels rm -rf gelöscht. Nach dem dritten Verzeichnis habe ich mittels
                            find /opt/iobroker/node_modules -name .\*-\* >out
                            mir alle potentiellen Problemverzeichnisse gesucht. In der Datei sind noch ein paar Verzeichnisse, die nicht gelöscht werden sollten. Das Namensschema ist ungefähr .admin-PkhUgfdt - also .Adapername-Zufallsstring
                            Alle anderen Verzeichnisse habe ich raus gelöscht und dann mittels
                            while read a
                            do
                            rm -rf ${a}
                            done <out
                            die ganzen Verzeichnisse gelöscht.
                            Das geht sicherlich eleganter mit dem richtigen regulären Ausdruck und dem find exec …
                            Jedenfalls habe ich mit diesem Ansatz die Installationblockade beseitigen können.
                            Vielleicht hilft es bei der Fehlersuch.
                            Hearp
                            • H hearp
                              while read a
                              do
                              rm -rf ${a}
                              done <out
                              Hearp
                              #54
                              @hearp
                              Eleganter geht es so:
                              https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                              • Marcus HamburgM Offline
                                Marcus Hamburg
                                #55
                                Hallo Forum!
                                ein Jahr später läuft mein iobroker eigentlich ganz, wenn ich nicht doch ein recht schwachen PI und nun hab ich einen neuen bestellt. In diesem Zusammenhang stellte ich fest, dass seit auf den Tag genau kein Automatisches Update durchgeführt wurde. Manuell über das Terminal kam folgende Ausgabe.
                                pi@raspberrypi:/opt/iobroker $ ./iobroker backup
                                host.raspberrypi 11971 states saved
                                host.raspberrypi 17365 objects saved
                                <--- Last few GCs --->
                                [15135:0x54a8cf0]    43648 ms: Mark-sweep 303.8 (328.3) -> 202.6 (219.8) MB, 405.4 / 0.1 ms  (average mu = 0.914, current mu = 0.905) external memory pressure scavenge might not succeed
                                [15135:0x54a8cf0]    47162 ms: Mark-sweep (reduce) 305.4 (320.6) -> 305.3 (311.6) MB, 824.0 / 0.1 ms  (+ 75.1 ms in 30 steps since start of marking, biggest step 5.5 ms, walltime since start of marking 1150 ms) (average mu = 0.831, current mu = 0.744) all
                                <--- JS stacktrace --->
                                FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                ./iobroker: Zeile 10: 15134 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                  Hallo Forum!
                                  #56
                                  Updates werden grundsätzlich nicht automatisch ausgeführt. Die musst du selber anstoßen.
                                  iob stop
                                  iob fix
                                  iob diag
                                  sagt? Insbesondere die vollständige Ausgabe des letzten Befehls interessiert.
                                    iob stop
                                    iob fix
                                    iob diag
                                    Marcus Hamburg
                                    #57
                                    ======== Start marking the full check here =========
                                    Skript v.2023-01-02
                                    *** BASE SYSTEM ***
                                    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
                                    Architecture:   armv7l
                                    Docker:         false
                                    Virtualization: none
                                    Distributor ID: Raspbian
                                    Description:    Raspbian GNU/Linux 10 (buster)
                                    Release:        10
                                    Codename:       buster
                                    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                    NAME="Raspbian GNU/Linux"
                                    VERSION_ID="10"
                                    VERSION="10 (buster)"
                                    VERSION_CODENAME=buster
                                    ID=raspbian
                                    ID_LIKE=debian
                                    HOME_URL="http://www.raspbian.org/"
                                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                    Systemuptime and Load:
                                     21:15:00 up 34 min,  4 users,  load average: 1.71, 1.51, 1.03
                                    CPU threads: 4
                                    *** Time and Time Zones ***
                                    Mon Mar 13 20:15:00 UTC 2023
                                    Mon Mar 13 21:15:00 CET 2023
                                    CET +0100
                                    Europe/Berlin
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:           923M         62M        416M        1.0M        444M        795M
                                    Swap:           99M         70M         29M
                                    Total:         1.0G        132M        446M
                                              923 M total memory
                                               62 M used memory
                                              210 M active memory
                                              190 M inactive memory
                                              416 M free memory
                                              106 M buffer memory
                                              337 M swap cache
                                               99 M total swap
                                               70 M used swap
                                               29 M free swap
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       30G  6.3G   22G  23% /
                                    devtmpfs       devtmpfs  430M     0  430M   0% /dev
                                    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                                    tmpfs          tmpfs     462M   13M  450M   3% /run
                                    tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
                                    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
                                    tmpfs          tmpfs      93M  4.0K   93M   1% /run/user/1000
                                    Messages in dmesg:
                                    [Mon Mar 13 20:40:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19f36f42-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Mon Mar 13 20:40:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                    [Mon Mar 13 20:40:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Mon Mar 13 20:40:36 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                    Show mounted filesystems (real ones only):
                                    TARGET                SOURCE         FSTYPE          OPTIONS
                                    /                     /dev/mmcblk0p2 ext4            rw,noatime
                                    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                                    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    592M    /var/
                                    361M    /var/cache
                                    349M    /var/cache/apt
                                    290M    /var/cache/apt/archives
                                    124M    /var/lib
                                    /opt/iobroker/backups:
                                    18M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    288M    /opt/iobroker/iobroker-data/
                                    135M    /opt/iobroker/iobroker-data/backup-objects
                                    113M    /opt/iobroker/iobroker-data/files
                                    51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    17M     /opt/iobroker/iobroker-data/objects.jsonl
                                    8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                                    8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v16.19.1
                                    /usr/bin/node           v16.19.1
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
                                    nodejs:
                                      Installed: 16.19.1-deb-1nodesource1
                                      Candidate: 16.19.1-deb-1nodesource1
                                      Version table:
                                     *** 16.19.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                            100 /var/lib/dpkg/status
                                         10.24.0~dfsg-1~deb10u3 500
                                    Temp directories causing npm8 problem: 13
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    iobroker is not running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  4.0.24
                                    admin:          6.3.5
                                    javascript:     6.1.4
                                    Adapters from github:   0
                                    Adapter State
                                      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                      system.adapter.habpanel.0               : habpanel              : raspberrypi                              -  enabled
                                      system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                                      system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                                      system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 443
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                      system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
                                      system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
                                      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.21, run as: admin
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Installed ioBroker-Instances
                                    Adapter    "admin"        : 6.3.5    , installed 6.3.5
                                    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                                    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                    Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                    Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                    Controller "js-controller": 4.0.24   , installed 4.0.24
                                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                                    Adapter    "renault"      : 0.0.15   , installed 0.0.15
                                    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                                    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                                    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                    Adapter    "web"          : 4.3.0    , installed 4.3.0
                                    Adapter    "ws"           : 1.3.0    , installed 1.3.0
                                    Objects and States
                                    Objects:        17872
                                    States:         12436
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Reading package lists...
                                    Pending Updates: 4
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16000      471/sshd
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16625      343/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          16002      471/sshd
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16624      343/cupsd
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16013      423/dhcpcd
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15968      447/cups-browsed
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16613      389/avahi-daemon: r
                                    udp        0      0 0.0.0.0:39363           0.0.0.0:*                           108        14108      389/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        16614      389/avahi-daemon: r
                                    udp6       0      0 :::45481                :::*                                108        14109      389/avahi-daemon: r
                                    2023-03-13 21:11:24.777  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
                                    2023-03-13 21:11:24.778  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                                    2023-03-13 21:11:24.779  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.190  - warn: host.raspberrypi instance system.adapter.trashschedule.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.191  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code null ()
                                    2023-03-13 21:11:25.192  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.194  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.195  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code null ()
                                    2023-03-13 21:11:25.196  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.197  - warn: host.raspberrypi instance system.adapter.hue.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.197  - info: host.raspberrypi instance system.adapter.hue.0 terminated with code null ()
                                    2023-03-13 21:11:25.198  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.199  - warn: host.raspberrypi instance system.adapter.info.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.199  - info: host.raspberrypi instance system.adapter.info.0 terminated with code null ()
                                    2023-03-13 21:11:25.200  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.401  - warn: host.raspberrypi instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.402  - info: host.raspberrypi instance system.adapter.tankerkoenig.0 terminated with code null ()
                                    2023-03-13 21:11:25.402  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.403  - warn: host.raspberrypi instance system.adapter.renault.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.404  - info: host.raspberrypi instance system.adapter.renault.0 terminated with code null ()
                                    2023-03-13 21:11:25.404  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.405  - warn: host.raspberrypi instance system.adapter.backitup.0 terminated due to SIGTERM
                                    2023-03-13 21:11:25.406  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code null ()
                                    2023-03-13 21:11:25.406  - info: host.raspberrypi All instances are stopped.
                                    2023-03-13 21:11:25.549  - info: host.raspberrypi terminated
                                    iob diag has finished.
                                    Press any key for a summary
                                      Skript v.2023-01-02
                                      *** BASE SYSTEM ***
                                      Docker:         false
                                      Release:        10
                                      Codename:       buster
                                      VERSION_ID="10"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                      CET +0100
                                      Europe/Berlin
                                      pi
                                      /home/pi
                                      X-Server:       true
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           99M         70M         29M
                                                923 M total memory
                                                 62 M used memory
                                                210 M active memory
                                                416 M free memory
                                                106 M buffer memory
                                                337 M swap cache
                                                 99 M total swap
                                                 70 M used swap
                                                 29 M free swap
                                      *** FILESYSTEM ***
                                      Messages in dmesg:
                                      /var:
                                      592M    /var/
                                      361M    /var/cache
                                      349M    /var/cache/apt
                                      124M    /var/lib
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        17872
                                      States:         12436
                                      Pending Updates: 4
                                      #58
                                      Mem: 923M
                                      und dann tatsächlich 23 Instanzen?
                                      UND NOCH
                                      X-Server: true
                                      das klappt nicht
                                        Skript v.2023-01-02
                                        *** BASE SYSTEM ***
                                        Docker:         false
                                        Release:        10
                                        Codename:       buster
                                        VERSION_ID="10"
                                        ID=raspbian
                                        ID_LIKE=debian
                                        CPU threads: 4
                                        CET +0100
                                        Europe/Berlin
                                        pi
                                        /home/pi
                                        X-Server:       true
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           99M         70M         29M
                                                  923 M total memory
                                                   62 M used memory
                                                  210 M active memory
                                                  416 M free memory
                                                  106 M buffer memory
                                                  337 M swap cache
                                                   99 M total swap
                                                   70 M used swap
                                                   29 M free swap
                                        *** FILESYSTEM ***
                                        Messages in dmesg:
                                        /var:
                                        592M    /var/
                                        361M    /var/cache
                                        349M    /var/cache/apt
                                        124M    /var/lib
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        javascript:     6.1.4
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        17872
                                        States:         12436
                                        Pending Updates: 4
                                        #59
                                        @marcus-hamburg
                                        Deine Installation ist zu fett.
                                        Und das OS wird nicht mehr maintained.
                                          @marcus-hamburg
                                          Marcus Hamburg
                                          #60
                                          Das ist ja der Grund, warum ich nun gerne umziehen möchte. Gibt es vielleicht eine Lösung ohne alles neu machen zu müssen. Der neue Raspberry ist auch heute eingetroffen, wäre cool wenn wer ne Idee hat für mich. Danke
                                          83.2k
