  4. Installation JavaScript NPM Modul in JS Adapter
15 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • F Offline
    Flo 0
    Ich würde gerne das puppeteer npm Modul in dem JavaScript Adapter installieren. Aber sobald ich dieses in den Settings Eintrage passiert folgendes im Log:
    error	Cannot install npm packet: puppeteer
    error	Cannot install puppeteer: 217
    error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-04T08_28_29_114Z-debug.log
    error
    error	ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
    error	npm ERR!
    error	npm ERR! errno -39
    error	ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m
    error	npm
    info	npm install puppeteer --production (System call)
    error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-04T08_28_25_486Z-debug.log
    error
    error	npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
    error	/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2mnpm ERR! errno -39
    error	ENOTEMPTYnpm ERR! syscall renamenpm ERR! path
    error	code
    error
    error	ERR!
    error
    error	npm
    error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-04T08_28_20_741Z-debug.log
    error
    error	ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
    error	npm
    error	ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2mnpm ERR! errno -39
    error	npm
    info	starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.8.0, js-controller: 3.3.18
    Wenn ich in der Shell schaue fehlen da einige dependencies:
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm ls
    iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript
    ├── UNMET DEPENDENCY @alcalzone/release-script@^2.2.1
    ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.5.1
    ├── UNMET DEPENDENCY @types/iobroker@^3.3.4
    ├── @types/node@12.20.28 invalid: "^16.11.6" from the root project
    ├── UNMET DEPENDENCY @types/request@^2.48.7
    ├── UNMET DEPENDENCY alcalzone-shared@^4.0.0
    ├── UNMET DEPENDENCY chai@^4.3.4
    ├── UNMET DEPENDENCY coffee-compiler@^0.3.2
    ├── UNMET DEPENDENCY coffee-script@^1.12.7
    ├── UNMET DEPENDENCY del@^6.0.0
    ├── UNMET DEPENDENCY eslint@^7.32.0
    ├── UNMET DEPENDENCY gulp-rename@^2.0.0
    ├── UNMET DEPENDENCY gulp-replace@^1.1.3
    ├── UNMET DEPENDENCY gulp@^4.0.2
    ├── UNMET DEPENDENCY jsonata@^1.8.5
    ├── UNMET DEPENDENCY mocha@^9.1.1
    ├── UNMET DEPENDENCY node-inspect@^2.0.0
    ├── UNMET DEPENDENCY node-schedule@2.0.0
    ├── UNMET DEPENDENCY request@^2.88.2
    ├── UNMET DEPENDENCY semver@^7.3.5
    ├── UNMET DEPENDENCY suncalc2@^1.8.1
    ├── UNMET DEPENDENCY timekeeper@^2.2.0
    ├── UNMET DEPENDENCY typescript@^4.4.2
    ├── UNMET DEPENDENCY virtual-tsc@^0.6.1
    ├── UNMET OPTIONAL DEPENDENCY vm2@^3.9.3
    └── UNMET DEPENDENCY wake_on_lan@^1.0.0
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: @alcalzone/release-script@^2.2.1, required by iobroker.javascript@5.2.13
    npm ERR! missing: @iobroker/adapter-core@^2.5.1, required by iobroker.javascript@5.2.13
    npm ERR! missing: @types/iobroker@^3.3.4, required by iobroker.javascript@5.2.13
    npm ERR! invalid: @types/node@12.20.28 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR! missing: @types/request@^2.48.7, required by iobroker.javascript@5.2.13
    npm ERR! missing: alcalzone-shared@^4.0.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: chai@^4.3.4, required by iobroker.javascript@5.2.13
    npm ERR! missing: coffee-compiler@^0.3.2, required by iobroker.javascript@5.2.13
    npm ERR! missing: coffee-script@^1.12.7, required by iobroker.javascript@5.2.13
    npm ERR! missing: del@^6.0.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: eslint@^7.32.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: gulp-rename@^2.0.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: gulp-replace@^1.1.3, required by iobroker.javascript@5.2.13
    npm ERR! missing: gulp@^4.0.2, required by iobroker.javascript@5.2.13
    npm ERR! missing: jsonata@^1.8.5, required by iobroker.javascript@5.2.13
    npm ERR! missing: mocha@^9.1.1, required by iobroker.javascript@5.2.13
    npm ERR! missing: node-inspect@^2.0.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: node-schedule@2.0.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: request@^2.88.2, required by iobroker.javascript@5.2.13
    npm ERR! missing: semver@^7.3.5, required by iobroker.javascript@5.2.13
    npm ERR! missing: suncalc2@^1.8.1, required by iobroker.javascript@5.2.13
    npm ERR! missing: timekeeper@^2.2.0, required by iobroker.javascript@5.2.13
    npm ERR! missing: typescript@^4.4.2, required by iobroker.javascript@5.2.13
    npm ERR! missing: virtual-tsc@^0.6.1, required by iobroker.javascript@5.2.13
    npm ERR! missing: wake_on_lan@^1.0.0, required by iobroker.javascript@5.2.13
    Hat jemand ein Tipp für mich wie ich das Modul hinzufügen kann und die Fehler beheben?
    • F Flo 0
      error
      error	npm ERR!
      error	npm
      error
      error	code
      error
      error	ERR!
      error
      error	npm
      error
      error	npm
      error	npm
      arteckA Offline
      arteckA Offline
      arteck
      @flo-0 bei mir gehts.. wie installierst du es ??
      liegts an NODE 16 ?
      F 1 Antwort Letzte Antwort
      • arteckA arteck
        liegts an NODE 16 ?
        Flo 0
        @arteck Habe es gleich wie du eingetragen. Sonst steht da bei mir keine anderen Module aktiviert in den Settings. Ich weiss auch nicht von wo die Depdencies kommen.
        Der tut sich schwer mit anderen Modulen welche ich aber gar nicht selbst in meinem node_modules im JavaScript Ordner drin habe.
        F arteckA 2 Antworten Letzte Antwort
        • F Flo 0
          Flo 0
          schrieb am zuletzt editiert von Flo 0
          Habe /opt/iobroker/node_modules/iobroker.javascript/node_modules komplett geleert Adapter neu gestartet nochmals Module Eingetragen und jetzt erscheint folgede Fehler :-), ja vielleicht hat es mit meiner Version zu tun :(
          • F Flo 0
            arteckA Offline
            arteckA Offline
            arteck
            @flo-0 lass ich tippe auf NODE 16
            kannst das mal auf NODE 14 machen... mit 12 gehts
            • arteckA arteck
              @arteck sagte in Installation JavaScript NPM Modul in JS Adapter:
              aber spätestens dann auch auf npm v6 achten!
                Flo 0
                habe das Modul ausserhalb iobroker installiert klappt 1A. An der Node installation will ich nichts ändern :(. Kommen die deps nicht von der package.json Datei im iobroker.javascript root?
                • F Flo 0
                  @flo-0 sagte in Installation JavaScript NPM Modul in JS Adapter:
                  Aber deine Version ist noch nicht für ioB freigegeben
                  und welche npm Version hast du?
                    Flo 0
                    Das wusste ich nicht :(.
                    pi@raspberrypi:~/puppeteer $ npm -v
                    7.21.0
                    pi@raspberrypi:~/puppeteer $ node -v
                    v16.8.0
                    Bis auf der mi-home-vacum adapter welcher ständig abstürzt ^^, läuft das System ganz stabil ....
                    • F Flo 0
                      7.21.0
                      v16.8.0
                      npm -v
                      7.21.0
                      npm v7 funktioniert nicht mit ioBroker, zumindest nicht bei node v12 oder v14
                      • F Flo 0
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        Das sind WARNungen. ioBroker interpretiert die nur als Fehler, weil sie von npm im stderr ausgegeben werden.
                        • AlCalzoneA AlCalzone
                          Flo 0
                          Vielen Dank euch allen. Habe jetzt NODE und NPM downgraded und ganz ehrlich mir war gar nicht wohl dabei ^^ aber habe worstcase Image vom System.
                          Und ja I love iobroker! Hat wunderbar geklappt, nur zigbee musste noch rebuildet werden. Jetzt läuft alles. Das Modul ist in JS integriert ohne die vielen Meldungen.
                          Ich hoffe das ich jetzt auch die richtige Version am laufen habe ^^:
                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ nodejs -v && npm -v
                          v12.22.7
                          6.14.15
                          LG und en schöne Tag.
                          • F Flo 0
                            7.21.0
                            v16.8.0
                            @flo-0
                            Ich würde da dringend auf node12 oder 14 springen.
                              @flo-0
                              @thomas-braun sagte in Installation JavaScript NPM Modul in JS Adapter:
                              Hat er doch:
                              v12.22.7
                              6.14.15
                                Hat er doch:
                                v12.22.7
                                6.14.15
                                @homoran @Flo-0
                                Hat sich überschnitten.
