  4. Probleme beim der installation
    6.0k
61 Beiträge 5 Kommentatoren 3.8k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @chris-schneidergruber
    dann iob start
    und mit
    tail -f /opt/iobroker/logs/iobroker.current.log
    mal das logfile beobachten
    Chris SchneidergruberC Offline
    @wendy2702
    chris@homeserver:~$ tail -f /opt/iobroker/log/iobroker.current.log
    2022-03-01 13:42:30.711  - info: admin.0 (809034) Request actual repository...
    2022-03-01 13:42:30.722  - info: admin.0 (809034) http server listening on port 8081
    2022-03-01 13:42:30.722  - info: admin.0 (809034) Use link "http://localhost:8081" to configure.
    2022-03-01 13:42:30.856  - info: host.homeserver Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-03-01 13:42:32.773  - info: admin.0 (809034) Repository received successfully.
    2022-03-01 13:42:33.722  - info: host.homeserver instance system.adapter.discovery.0 started with pid 809139
    2022-03-01 13:42:34.409  - info: discovery.0 (809139) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4.0.15
    2022-03-01 13:42:37.718  - info: host.homeserver instance system.adapter.backitup.0 started with pid 809274
    2022-03-01 13:42:38.436  - info: backitup.0 (809274) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.15
    2022-03-01 13:42:38.508  - info: backitup.0 (809274) [iobroker] backup was activated at 02:40 every 1 day(s)
    bitte schön
    Chris SchneidergruberC 1 Antwort Letzte Antwort
    • Chris SchneidergruberC Chris Schneidergruber
      @wendy2702
      bitte schön
      schrieb am zuletzt editiert von Chris Schneidergruber
      @chris-schneidergruber ```
      2022-03-01 13:48:08.419  - info: host.homeserver ip addresses: 192.168.1.133 fe8                                                      0::42a8:f0ff:fe26:83a0
      2022-03-01 13:48:08.759  - info: host.homeserver connected to Objects and States
      2022-03-01 13:48:08.771  - info: host.homeserver added notifications configurati                                                      on of host
      2022-03-01 13:48:08.944  - info: host.homeserver 3 instances found
      2022-03-01 13:48:08.948  - info: host.homeserver starting 3 instances
      2022-03-01 13:48:08.974  - info: host.homeserver instance system.adapter.admin.0                                                       started with pid 820320
      2022-03-01 13:48:09.726  - info: admin.0 (820320) starting. Version 5.3.1 in /op                                                      t/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.15
      2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all states
      2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all objects
      2022-03-01 13:48:09.927  - info: admin.0 (820320) received all objects
      2022-03-01 13:48:09.996  - info: admin.0 (820320) Request actual repository...
      2022-03-01 13:48:10.003  - info: admin.0 (820320) http server listening on port                                                       8081
      2022-03-01 13:48:10.004  - info: admin.0 (820320) Use link "http://localhost:808                                                      1" to configure.
      2022-03-01 13:48:10.144  - info: host.homeserver Updating repository "stable" un                                                      der "http://download.iobroker.net/sources-dist.json"
      2022-03-01 13:48:11.295  - info: admin.0 (820320) Repository received successful                                                      ly.
      2022-03-01 13:48:12.964  - info: host.homeserver instance system.adapter.discove                                                      ry.0 started with pid 820463
      2022-03-01 13:48:13.621  - info: discovery.0 (820463) starting. Version 2.7.5 in                                                       /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4                                                      .0.15
      2022-03-01 13:48:16.968  - info: host.homeserver instance system.adapter.backitu                                                      p.0 started with pid 820567
      2022-03-01 13:48:17.673  - info: backitup.0 (820567) starting. Version 2.3.3 in                                                       /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0                                                      .15
      2022-03-01 13:48:17.702  - info: backitup.0 (820567) [iobroker] backup was activ                                                      ated at 02:40 every 1 day(s)
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @chris-schneidergruber Sieht gut aus.
        jetzt mit Browser und
        http://<IOBroker_IP-Adresse>:8081
        den Admin öffnen
          den Admin öffnen
          @wendy2702
          was soll ich dort machen?
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            wendy2702
            @chris-schneidergruber Na wenn die Seite sich öffnet läuft dein IoBroker, was du dann mit dem ioBroker machen willst kann ich dir ja nicht sagen.
            Z.B: über die Adapter Seite einen Adapter den du benötigst installieren.
              @wendy2702
              2022-03-01 14:07:35.529  - info: host.homeserver iobroker add deconz --host homeserver
              2022-03-01 14:07:36.585  - info: host.homeserver iobroker NPM version: 6.14.16
              2022-03-01 14:07:36.586  - info: host.homeserver iobroker Installing iobroker.deconz@1.3.19... (System call)
              2022-03-01 14:07:39.138  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.deconz@1.3.19: 243
              2022-03-01 14:07:40.155  - info: host.homeserver iobroker exit 25
              kannst du mir sagen was der errror hier bedeutet
                @wendy2702
                wendy2702W Online
                wendy2702W Online
                wendy2702
                @chris-schneidergruber Was kommt bei
                iob update
                Hast du das log zusammen geschnitten?
                  iob update
                  @wendy2702
                  chris@homeserver:~$ iob update
                  Used repository: stable
                  Adapter    "admin"        : 5.3.1    , installed 5.3.1
                  Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                  Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                  Controller "js-controller": 4.0.15   , installed 4.0.15
                  Log hab ich nicht zusammen geschnitten
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    @chris-schneidergruber Hat der iobroker internet Zugang?
                    Was steht hier bei dir eingetragen:
                    Erreicht man über den Schraubenschlüssel oben links im Admin
                      @wendy2702
                      würde safeb usr das sekve wie bei dir.
                      Aber der Fehler kommt immer egal welchen Adapter ich installieren will
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        @chris-schneidergruber Mal von der Console
                        ping 8.8.8.8
                          ping 8.8.8.8
                          @wendy2702
                          chris@homeserver:~$ ping 8.8.8.8
                          PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                          64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=42.3 ms
                          64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=34.9 ms
                          64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=29.9 ms
                          64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=32.6 ms
                          64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=29.8 ms
                          64 bytes from 8.8.8.8: icmp_seq=6 ttl=117 time=23.8 ms
                          64 bytes from 8.8.8.8: icmp_seq=7 ttl=117 time=25.8 ms
                          64 bytes from 8.8.8.8: icmp_seq=8 ttl=117 time=25.8 ms
                          • wendy2702W Online
                            wendy2702W Online
                            wendy2702
                            @chris-schneidergruber Kannst du mal das loggen für den Admin auf Debug stellen und bei dem Fenster zur Installation den haken bei Debug messages machen und dann nochmal posten.
                              @wendy2702
                              da ist das einzige was ich gefunden habe zum umstellen.
                              aber log bleibt gleich
                              2022-03-01 15:12:41.857  - info: host.homeserver iobroker add accuweather auto --host homeserver
                              2022-03-01 15:12:42.955  - info: host.homeserver iobroker NPM version: 6.14.16
                              2022-03-01 15:12:42.956  - info: host.homeserver iobroker Installing iobroker.accuweather@1.2.1... (System call)
                              2022-03-01 15:12:44.718  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.accuweather@1.2.1: 243
                              2022-03-01 15:12:45.731  - info: host.homeserver iobroker exit 25
                                @wendy2702
                                wendy2702W Online
                                wendy2702W Online
                                wendy2702
                                @chris-schneidergruber Ich meinte hier: (Beispiel)
                                  @wendy2702
                                  wollt grad zu greifen aber bekomm folgende seite
                                  wie bekomm ich die menüs wieder zurück
                                    @wendy2702
                                    wendy2702W Online
                                    wendy2702W Online
                                    wendy2702
                                    @chris-schneidergruber klick mal oben links auf das iobroker logo
                                      @wendy2702
                                      2022-03-01 15:52:23.850  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskFree
                                      2022-03-01 15:52:23.851  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                                      2022-03-01 15:52:23.851  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskSize
                                      2022-03-01 15:52:23.852  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                                      2022-03-01 15:52:23.852  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskWarning
                                      2022-03-01 15:52:23.853  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.freemem, *.info.connection
                                      2022-03-01 15:52:23.853  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.freemem
                                      2022-03-01 15:52:23.854  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, *.info.connection
                                      2022-03-01 15:52:23.854  - debug: admin.1 (64110) Unsubscribe STATES: *.info.connection
                                      2022-03-01 15:52:23.855  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive
                                      2022-03-01 15:52:52.452  - info: host.homeserver iobroker add accuweather auto --host homeserver
                                      2022-03-01 15:52:53.743  - info: host.homeserver iobroker NPM version: 6.14.16
                                      2022-03-01 15:52:53.745  - info: host.homeserver iobroker Installing iobroker.accuweather@1.2.1... (System call)
                                      2022-03-01 15:52:55.719  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.accuweather@1.2.1: 243
                                      2022-03-01 15:52:56.739  - info: host.homeserver iobroker exit 25
                                      habs geschafft und über einen neue admin instanc wieder rein gekommen.
                                      • wendy2702W Online
                                        wendy2702W Online
                                        wendy2702
                                        Hm,
                                        wenn ich mich richtig erinnere hat das was mit Zugriffsrechten zu tun.
                                        iob stop
                                        iob update
                                        iob upgrade
                                        iob fix
                                        iob start
                                        Wenn es dann nicht geht gehen mir die ideen aus...
                                        @Thomas-Braun : fällt dir dazu noch etwas ein?
                                        • Chris SchneidergruberC Offline
                                          @wendy2702
                                          danke hab ich versucht kommt der gleiche fehler
