  4. Probleme beim der installation
    6.0k
61 Beiträge 5 Kommentatoren 3.8k Aufrufe 3 Beobachtet
  • Chris SchneidergruberC Chris Schneidergruber
    @chris-schneidergruber ```
    chris@homeserver:~$ tail -f /opt/iobroker/log/iobroker.current.log
    2022-03-01 13:48:08.419  - info: host.homeserver ip addresses: 192.168.1.133 fe8                                                      0::42a8:f0ff:fe26:83a0
    2022-03-01 13:48:08.759  - info: host.homeserver connected to Objects and States
    2022-03-01 13:48:08.771  - info: host.homeserver added notifications configurati                                                      on of host
    2022-03-01 13:48:08.944  - info: host.homeserver 3 instances found
    2022-03-01 13:48:08.948  - info: host.homeserver starting 3 instances
    2022-03-01 13:48:08.974  - info: host.homeserver instance system.adapter.admin.0                                                       started with pid 820320
    2022-03-01 13:48:09.726  - info: admin.0 (820320) starting. Version 5.3.1 in /op                                                      t/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.15
    2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all states
    2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all objects
    2022-03-01 13:48:09.927  - info: admin.0 (820320) received all objects
    2022-03-01 13:48:09.996  - info: admin.0 (820320) Request actual repository...
    2022-03-01 13:48:10.003  - info: admin.0 (820320) http server listening on port                                                       8081
    2022-03-01 13:48:10.004  - info: admin.0 (820320) Use link "http://localhost:808                                                      1" to configure.
    2022-03-01 13:48:10.144  - info: host.homeserver Updating repository "stable" un                                                      der "http://download.iobroker.net/sources-dist.json"
    2022-03-01 13:48:11.295  - info: admin.0 (820320) Repository received successful                                                      ly.
    2022-03-01 13:48:12.964  - info: host.homeserver instance system.adapter.discove                                                      ry.0 started with pid 820463
    2022-03-01 13:48:13.621  - info: discovery.0 (820463) starting. Version 2.7.5 in                                                       /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4                                                      .0.15
    2022-03-01 13:48:16.968  - info: host.homeserver instance system.adapter.backitu                                                      p.0 started with pid 820567
    2022-03-01 13:48:17.673  - info: backitup.0 (820567) starting. Version 2.3.3 in                                                       /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0                                                      .15
    2022-03-01 13:48:17.702  - info: backitup.0 (820567) [iobroker] backup was activ                                                      ated at 02:40 every 1 day(s)
    wendy2702W Online
    wendy2702W Online
    @chris-schneidergruber Sieht gut aus.
    jetzt mit Browser und
    http://<IOBroker_IP-Adresse>:8081
    den Admin öffnen
    Chris SchneidergruberC 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      den Admin öffnen
      Chris SchneidergruberC Offline
      @wendy2702
      was soll ich dort machen?
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        @chris-schneidergruber Na wenn die Seite sich öffnet läuft dein IoBroker, was du dann mit dem ioBroker machen willst kann ich dir ja nicht sagen.
        Z.B: über die Adapter Seite einen Adapter den du benötigst installieren.
          @wendy2702
          2022-03-01 14:07:35.529  - info: host.homeserver iobroker add deconz --host homeserver
          2022-03-01 14:07:36.585  - info: host.homeserver iobroker NPM version: 6.14.16
          2022-03-01 14:07:36.586  - info: host.homeserver iobroker Installing iobroker.deconz@1.3.19... (System call)
          2022-03-01 14:07:39.138  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.deconz@1.3.19: 243
          2022-03-01 14:07:40.155  - info: host.homeserver iobroker exit 25
          kannst du mir sagen was der errror hier bedeutet
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            @chris-schneidergruber Was kommt bei
            iob update
            Hast du das log zusammen geschnitten?
              iob update
              schrieb am zuletzt editiert von Chris Schneidergruber
              @wendy2702
              chris@homeserver:~$ iob update
              Used repository: stable
              Adapter    "admin"        : 5.3.1    , installed 5.3.1
              Adapter    "backitup"     : 2.3.3    , installed 2.3.3
              Adapter    "discovery"    : 2.7.5    , installed 2.7.5
              Controller "js-controller": 4.0.15   , installed 4.0.15
              Log hab ich nicht zusammen geschnitten
                @wendy2702
                wendy2702W Online
                wendy2702W Online
                @chris-schneidergruber Hat der iobroker internet Zugang?
                Was steht hier bei dir eingetragen:
                Erreicht man über den Schraubenschlüssel oben links im Admin
                  @wendy2702
                  würde safeb usr das sekve wie bei dir.
                  Aber der Fehler kommt immer egal welchen Adapter ich installieren will
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    @chris-schneidergruber Mal von der Console
                    ping 8.8.8.8
                      ping 8.8.8.8
                      @wendy2702
                      chris@homeserver:~$ ping 8.8.8.8
                      PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                      64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=42.3 ms
                      64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=34.9 ms
                      64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=29.9 ms
                      64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=32.6 ms
                      64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=29.8 ms
                      64 bytes from 8.8.8.8: icmp_seq=6 ttl=117 time=23.8 ms
                      64 bytes from 8.8.8.8: icmp_seq=7 ttl=117 time=25.8 ms
                      64 bytes from 8.8.8.8: icmp_seq=8 ttl=117 time=25.8 ms
                      • wendy2702W Online
                        wendy2702W Online
                        @chris-schneidergruber Kannst du mal das loggen für den Admin auf Debug stellen und bei dem Fenster zur Installation den haken bei Debug messages machen und dann nochmal posten.
                          @wendy2702
                          da ist das einzige was ich gefunden habe zum umstellen.
                          aber log bleibt gleich
                          2022-03-01 15:12:41.857  - info: host.homeserver iobroker add accuweather auto --host homeserver
                          2022-03-01 15:12:42.955  - info: host.homeserver iobroker NPM version: 6.14.16
                          2022-03-01 15:12:42.956  - info: host.homeserver iobroker Installing iobroker.accuweather@1.2.1... (System call)
                          2022-03-01 15:12:44.718  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.accuweather@1.2.1: 243
                          2022-03-01 15:12:45.731  - info: host.homeserver iobroker exit 25
                            @wendy2702
                            wendy2702W Online
                            wendy2702W Online
                            @chris-schneidergruber Ich meinte hier: (Beispiel)
                              @wendy2702
                              wollt grad zu greifen aber bekomm folgende seite
                              wie bekomm ich die menüs wieder zurück
                                @wendy2702
                                wendy2702W Online
                                wendy2702W Online
                                @chris-schneidergruber klick mal oben links auf das iobroker logo
                                  @wendy2702
                                  2022-03-01 15:52:23.850  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskFree
                                  2022-03-01 15:52:23.851  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                                  2022-03-01 15:52:23.851  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskSize
                                  2022-03-01 15:52:23.852  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                                  2022-03-01 15:52:23.852  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.diskWarning
                                  2022-03-01 15:52:23.853  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, system.host.*.freemem, *.info.connection
                                  2022-03-01 15:52:23.853  - debug: admin.1 (64110) Unsubscribe STATES: system.host.*.freemem
                                  2022-03-01 15:52:23.854  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive, *.info.connection
                                  2022-03-01 15:52:23.854  - debug: admin.1 (64110) Unsubscribe STATES: *.info.connection
                                  2022-03-01 15:52:23.855  - debug: admin.1 (64110) Subscribes: system.host.homeserver.alive, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.admin.0.alive
                                  2022-03-01 15:52:52.452  - info: host.homeserver iobroker add accuweather auto --host homeserver
                                  2022-03-01 15:52:53.743  - info: host.homeserver iobroker NPM version: 6.14.16
                                  2022-03-01 15:52:53.745  - info: host.homeserver iobroker Installing iobroker.accuweather@1.2.1... (System call)
                                  2022-03-01 15:52:55.719  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.accuweather@1.2.1: 243
                                  2022-03-01 15:52:56.739  - info: host.homeserver iobroker exit 25
                                  habs geschafft und über einen neue admin instanc wieder rein gekommen.
                                  • wendy2702W Online
                                    wendy2702W Online
                                    Hm,
                                    wenn ich mich richtig erinnere hat das was mit Zugriffsrechten zu tun.
                                    iob stop
                                    iob update
                                    iob upgrade
                                    iob fix
                                    iob start
                                    Wenn es dann nicht geht gehen mir die ideen aus...
                                    @Thomas-Braun : fällt dir dazu noch etwas ein?
                                    • Chris SchneidergruberC Offline
                                      @wendy2702
                                      danke hab ich versucht kommt der gleiche fehler
                                        Hm,
                                        iob stop
                                        iob update
                                        iob upgrade
                                        iob fix
                                        iob start
                                        @wendy2702
                                        Ich hab jetzt mal versucht per console einen adapter zu installieren und bekomme das zurück
                                        chris@homeserver:/opt/iobroker$ npm install iobroker.knx
                                        npm ERR! code EACCES
                                        npm ERR! syscall mkdir
                                        npm ERR! path /home/iobroker
                                        npm ERR! errno -13
                                        npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'
                                        npm ERR!  [OperationalError: EACCES: permission denied, mkdir '/home/iobroker'] {
                                        npm ERR!   cause: [Error: EACCES: permission denied, mkdir '/home/iobroker'] {
                                        npm ERR!     errno: -13,
                                        npm ERR!     code: 'EACCES',
                                        npm ERR!     syscall: 'mkdir',
                                        npm ERR!     path: '/home/iobroker'
                                        npm ERR!   },
                                        npm ERR!   isOperational: true,
                                        npm ERR! }
                                        npm ERR!
                                        npm ERR! The operation was rejected by your operating system.
                                        npm ERR! It is likely you do not have the permissions to access this file as the current user
                                        npm ERR!
                                        npm ERR! If you believe this might be a permissions issue, please double-check the
                                        npm ERR! permissions of the file and its containing directories, or try running
                                        npm ERR! the command again as root/Administrator.
                                        wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                                          @wendy2702
                                          npm ERR! errno -13
                                          npm ERR!   },
                                          npm ERR! }
                                          npm ERR!
                                          npm ERR!
                                          wendy2702W Online
                                          wendy2702W Online
                                          iob stop
                                          iob fix
                                          iob start
                                          dann erneut probieren
