  4. Probleme beim der installation
    6.0k
61 Beiträge 5 Kommentatoren 3.8k Aufrufe 3 Beobachtet
  • Chris SchneidergruberC Chris Schneidergruber
    @wendy2702
    chris@homeserver:~$ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.0
    v14.19.0
    6.14.16
    chris
    /home/chris
    [sudo] password for chris:
    Hit:1 http://at.archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://phoscon.de/apt/deconz focal InRelease
    Hit:3 http://at.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:4 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu focal InRelease
    Hit:5 http://archive.canonical.com/ubuntu focal InRelease
    Hit:6 http://at.archive.ubuntu.com/ubuntu focal-backports InRelease
    Hit:7 http://at.archive.ubuntu.com/ubuntu focal-security InRelease
    Hit:8 https://deb.nodesource.com/node_14.x focal InRelease
    Ign:9 http://downloads.linux.hpe.com/SDR/repo/mcp focal/current InRelease
    Hit:10 http://downloads.linux.hpe.com/SDR/repo/mcp focal/current Release
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    nodejs:
      Installed: 14.19.0-deb-1nodesource1
      Candidate: 14.19.0-deb-1nodesource1
      Version table:
     *** 14.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://at.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    wendy2702W Online
    wendy2702W Online
    @chris-schneidergruber Das sieht erstmal gut aus.
    Was sagt der Fixer?
    Chris SchneidergruberC 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      Was sagt der Fixer?
      Chris SchneidergruberC Offline
      @wendy2702
      chris@homeserver:~$ iob fix
      library: loaded
      Library version=2022-02-10
          Welcome to the ioBroker installation fixer!
          Script version: 2022-02-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Hit:1 http://phoscon.de/apt/deconz focal InRelease
      Hit:2 http://at.archive.ubuntu.com/ubuntu focal InRelease
      Hit:5 http://at.archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:6 https://deb.nodesource.com/node_14.x focal InRelease
      Hit:8 http://archive.canonical.com/ubuntu focal InRelease
      Installed gcc-c++
      Installed python-dev
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      schaut in Ordnung aus
        @wendy2702
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        wendy2702W Online
        wendy2702W Online
        dann iob start
        und mit
        tail -f /opt/iobroker/logs/iobroker.current.log
        mal das logfile beobachten
          dann iob start
          und mit
          @wendy2702
          chris@homeserver:~$ tail -f /opt/iobroker/log/iobroker.current.log
          2022-03-01 13:42:30.711  - info: admin.0 (809034) Request actual repository...
          2022-03-01 13:42:30.722  - info: admin.0 (809034) http server listening on port 8081
          2022-03-01 13:42:30.722  - info: admin.0 (809034) Use link "http://localhost:8081" to configure.
          2022-03-01 13:42:30.856  - info: host.homeserver Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2022-03-01 13:42:32.773  - info: admin.0 (809034) Repository received successfully.
          2022-03-01 13:42:33.722  - info: host.homeserver instance system.adapter.discovery.0 started with pid 809139
          2022-03-01 13:42:34.409  - info: discovery.0 (809139) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4.0.15
          2022-03-01 13:42:37.718  - info: host.homeserver instance system.adapter.backitup.0 started with pid 809274
          2022-03-01 13:42:38.436  - info: backitup.0 (809274) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.15
          2022-03-01 13:42:38.508  - info: backitup.0 (809274) [iobroker] backup was activated at 02:40 every 1 day(s)
          bitte schön
            @wendy2702
            bitte schön
            schrieb am zuletzt editiert von Chris Schneidergruber
            @chris-schneidergruber ```
            2022-03-01 13:48:08.419  - info: host.homeserver ip addresses: 192.168.1.133 fe8                                                      0::42a8:f0ff:fe26:83a0
            2022-03-01 13:48:08.759  - info: host.homeserver connected to Objects and States
            2022-03-01 13:48:08.771  - info: host.homeserver added notifications configurati                                                      on of host
            2022-03-01 13:48:08.944  - info: host.homeserver 3 instances found
            2022-03-01 13:48:08.948  - info: host.homeserver starting 3 instances
            2022-03-01 13:48:08.974  - info: host.homeserver instance system.adapter.admin.0                                                       started with pid 820320
            2022-03-01 13:48:09.726  - info: admin.0 (820320) starting. Version 5.3.1 in /op                                                      t/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.15
            2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all states
            2022-03-01 13:48:09.749  - info: admin.0 (820320) requesting all objects
            2022-03-01 13:48:09.927  - info: admin.0 (820320) received all objects
            2022-03-01 13:48:09.996  - info: admin.0 (820320) Request actual repository...
            2022-03-01 13:48:10.003  - info: admin.0 (820320) http server listening on port                                                       8081
            2022-03-01 13:48:10.004  - info: admin.0 (820320) Use link "http://localhost:808                                                      1" to configure.
            2022-03-01 13:48:10.144  - info: host.homeserver Updating repository "stable" un                                                      der "http://download.iobroker.net/sources-dist.json"
            2022-03-01 13:48:11.295  - info: admin.0 (820320) Repository received successful                                                      ly.
            2022-03-01 13:48:12.964  - info: host.homeserver instance system.adapter.discove                                                      ry.0 started with pid 820463
            2022-03-01 13:48:13.621  - info: discovery.0 (820463) starting. Version 2.7.5 in                                                       /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4                                                      .0.15
            2022-03-01 13:48:16.968  - info: host.homeserver instance system.adapter.backitu                                                      p.0 started with pid 820567
            2022-03-01 13:48:17.673  - info: backitup.0 (820567) starting. Version 2.3.3 in                                                       /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0                                                      .15
            2022-03-01 13:48:17.702  - info: backitup.0 (820567) [iobroker] backup was activ                                                      ated at 02:40 every 1 day(s)
              wendy2702W Online
              wendy2702W Online
              @chris-schneidergruber Sieht gut aus.
              jetzt mit Browser und
              http://<IOBroker_IP-Adresse>:8081
              den Admin öffnen
                den Admin öffnen
                @wendy2702
                was soll ich dort machen?
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  @chris-schneidergruber Na wenn die Seite sich öffnet läuft dein IoBroker, was du dann mit dem ioBroker machen willst kann ich dir ja nicht sagen.
                  Z.B: über die Adapter Seite einen Adapter den du benötigst installieren.
                    @wendy2702
                    2022-03-01 14:07:35.529  - info: host.homeserver iobroker add deconz --host homeserver
                    2022-03-01 14:07:36.585  - info: host.homeserver iobroker NPM version: 6.14.16
                    2022-03-01 14:07:36.586  - info: host.homeserver iobroker Installing iobroker.deconz@1.3.19... (System call)
                    2022-03-01 14:07:39.138  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.deconz@1.3.19: 243
                    2022-03-01 14:07:40.155  - info: host.homeserver iobroker exit 25
                    kannst du mir sagen was der errror hier bedeutet
                      @wendy2702
                      wendy2702W Online
                      wendy2702W Online
                      @chris-schneidergruber Was kommt bei
                      iob update
                      Hast du das log zusammen geschnitten?
                        iob update
                        @wendy2702
                        chris@homeserver:~$ iob update
                        Used repository: stable
                        Adapter    "admin"        : 5.3.1    , installed 5.3.1
                        Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                        Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                        Controller "js-controller": 4.0.15   , installed 4.0.15
                        Log hab ich nicht zusammen geschnitten
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @chris-schneidergruber Hat der iobroker internet Zugang?
                          Was steht hier bei dir eingetragen:
                          Erreicht man über den Schraubenschlüssel oben links im Admin
                            @wendy2702
                            würde safeb usr das sekve wie bei dir.
                            Aber der Fehler kommt immer egal welchen Adapter ich installieren will
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              @chris-schneidergruber Mal von der Console
                              ping 8.8.8.8
                                ping 8.8.8.8
                                @wendy2702
                                chris@homeserver:~$ ping 8.8.8.8
                                PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                                64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=42.3 ms
                                64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=34.9 ms
                                64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=29.9 ms
                                64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=32.6 ms
                                64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=29.8 ms
                                64 bytes from 8.8.8.8: icmp_seq=6 ttl=117 time=23.8 ms
                                64 bytes from 8.8.8.8: icmp_seq=7 ttl=117 time=25.8 ms
                                64 bytes from 8.8.8.8: icmp_seq=8 ttl=117 time=25.8 ms
                                • wendy2702W Online
                                  wendy2702W Online
                                  @chris-schneidergruber Kannst du mal das loggen für den Admin auf Debug stellen und bei dem Fenster zur Installation den haken bei Debug messages machen und dann nochmal posten.
                                    @wendy2702
                                    da ist das einzige was ich gefunden habe zum umstellen.
                                    aber log bleibt gleich
                                    2022-03-01 15:12:41.857  - info: host.homeserver iobroker add accuweather auto --host homeserver
                                    2022-03-01 15:12:42.955  - info: host.homeserver iobroker NPM version: 6.14.16
                                    2022-03-01 15:12:42.956  - info: host.homeserver iobroker Installing iobroker.accuweather@1.2.1... (System call)
                                    2022-03-01 15:12:44.718  - error: host.homeserver iobroker host.homeserver Cannot install iobroker.accuweather@1.2.1: 243
                                    2022-03-01 15:12:45.731  - info: host.homeserver iobroker exit 25
                                      @wendy2702
                                      wendy2702W Online
                                      wendy2702W Online
                                      @chris-schneidergruber Ich meinte hier: (Beispiel)
                                        @wendy2702
                                        wollt grad zu greifen aber bekomm folgende seite
                                        wie bekomm ich die menüs wieder zurück
                                          @wendy2702
                                          wendy2702W Online
                                          wendy2702W Online
                                          @chris-schneidergruber klick mal oben links auf das iobroker logo
