  4. js-controller 4.0 jetzt im BETA/LATEST!
    6.0k
747 Beiträge 70 Kommentatoren 275.5k Aufrufe 60 Beobachtet
  • apollon77A apollon77
    Hi All,
    vielen Dank für Euren Support, die 4.0.6 kommt über Nacht wieder ins Repo und hat:
    4.0.6 (2022-02-09)
    • (AlCalzone) Optimize some JSONL cases
    • (foxriver76) Optimize Backup restore process
    • (AlCalzone) Fix issues that prevented adapter installs/updates (npm can not be located error message)
    • (Apollon77) Fix seq Logging issue
    • (foxriver76/Apollon77) Prevent several crash cases seen in Sentry
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    #221
    @apollon77
    Ist da mein Fall auch mit abgedeckt?
    • O oFbEQnpoLKKl6mbY5e13
      @apollon77
      #222
      @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
      O 1 Antwort Letzte Antwort
        O Abwesend
        O Abwesend
        schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
        #223
        @apollon77
        # iobroker upgrade self
        Update js-controller from @3.3.22 to @4.0.6
        NPM version: 6.14.16
        npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        Uncaught Rejection: TypeError: Cannot read property '_id' of null
            at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
            at Array.map (<anonymous>)
            at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
            at processTicksAndRejections (internal/process/task_queues.js:95:5)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 6
        npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
        npm ERR! Exit status 6
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
        host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
        Hilft das?:
        npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
        > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
        npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
        foxriver76F 2 Antworten Letzte Antwort
          @apollon77 @AlCalzone
          Das finde ich interessant. Was war da der Grund das npm nicht im $PATH gefunden wurde?
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #224
          @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
          Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
            @apollon77
            npm ERR! errno 6
            npm ERR!
            Hilft das?:
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            #225
            @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
            Videotutorials & mehr
            • foxriver76F foxriver76
              O Abwesend
              O Abwesend
              #226
              @foxriver76
              Redis States und Objects.
              • DiginixD Offline
                DiginixD Offline
                Diginix
                #227
                Update von 4.0.5 auf 4.0.6 ohne Probleme.
                CLI Ausgabe:
                Update js-controller from @4.0.5 to @4.0.6
                Stopped Objects DB
                Stopped States DB
                Installing iobroker.js-controller@4.0.6... (System call)
                > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                Successfully migrated 18783 objects to Redis Sets
                object _design/system updated
                  "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
                  "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
                Update certificate defaultPrivate
                The object "system.certificates" was updated successfully.
                Update certificate defaultPublic
                + iobroker.js-controller@4.0.6
                updated 13 packages in 47.713s
                73 packages are looking for funding
                  run `npm fund` for details
                ..:: So long! Tom ::..
                  @apollon77
                  npm ERR! errno 6
                  npm ERR!
                  Hilft das?:
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #228
                  @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                  npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                  Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
                    O Abwesend
                    O Abwesend
                    #229
                    @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    # pwd
                    /opt/iobroker
                    # npm i iobroker.js-controller@next
                    > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                    > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                    npm ERR! errno 6
                    npm ERR! iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                    npm ERR!
                    npm ERR! Failed at the iobroker.js-controller@4.0.5 install script.
                    npm ERR!     /root/.npm/_logs/2022-02-10T08_31_44_396Z-debug.log
                      # pwd
                      /opt/iobroker
                      npm ERR! errno 6
                      npm ERR!
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #230
                      @ofbeqnpolkkl6mby5e13 ok da passiert kein logging davor, thanks.
                        # pwd
                        /opt/iobroker
                        npm ERR! errno 6
                        npm ERR!
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        #231
                        @ofbeqnpolkkl6mby5e13 single host oder multihost?
                          O Abwesend
                          O Abwesend
                          #232
                          @foxriver76
                          Single.
                            @foxriver76
                            Single.
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            #233
                            @ofbeqnpolkkl6mby5e13 super strange, dann müsste vor dem ersten view mindestens die ausgabe dass er zu sets migrieren möchte kommen. Zeig mal bitte Ausgabe von iob object list system.host.*
                            O 2 Antworten Letzte Antwort
                              O Abwesend
                              O Abwesend
                              #234
                              Der JS-Controller ist ja jetzt nicht installiert, müsste ich erst die 3er wieder installieren.
                              # iob object list system.host.*
                              internal/modules/cjs/loader.js:905
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                  at internal/main/run_main_module.js:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                                O Abwesend
                                O Abwesend
                                #235
                                ObjectAC | StateAC |     User     |     Group    | ID
                                rw-rw-r--                    admin  administrator system.host.NAS.notifications
                                rw-rw-r--                    admin  administrator system.host.NAS.plugins.sentry
                                rw-rw-r--                    admin  administrator system.host.NAS.zip
                                rw-rw-r--                    admin  administrator system.host.d631abdf99e6.plugins.sentry
                                rw-rw-r--                    admin  administrator system.host.d631abdf99e6.zip
                                rw-rw-r--                    admin  administrator system.host.iobroker
                                rw-rw-r--                    admin  administrator system.host.iobroker-d.notifications
                                rw-rw-r--                    admin  administrator system.host.iobroker-d.plugins.sentry
                                rw-rw-r--                    admin  administrator system.host.iobroker-d.zip
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.alive
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactModeEnabled
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactgroupProcesses
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cpu
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cputime
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskFree
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskSize
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskWarning
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.eventLoopLag
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.freemem
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.inputCount
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsCompact
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsProcess
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.load
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.logLevel
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.mem
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memAvailable
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapTotal
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapUsed
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memRss
                                rw-rw-r--                    admin  administrator system.host.iobroker.notifications
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.notifications.system
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.outputCount
                                rw-rw-r--                    admin  administrator system.host.iobroker.plugins.sentry
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.plugins.sentry.enabled
                                rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.uptime
                                rw-rw-r--                    admin  administrator system.host.iobroker.zip
                                    throw err;
                                    requireStack: []
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #236
                                  @ofbeqnpolkkl6mby5e13 Dann bitte
                                  redis-cli keys cfg.o.system.host.*
                                    O Abwesend
                                    O Abwesend
                                    #237
                                    Auf einem der Redis-Server?
                                    # redis-cli keys cfg.o.system.host.*
                                     1) "cfg.o.system.host.iobroker-d.cpu"
                                     2) "cfg.o.system.host.iobroker-d"
                                     3) "cfg.o.system.host.iobroker-d.diskFree"
                                     4) "cfg.o.system.host.iobroker-d.memRss"
                                     5) "cfg.o.system.host.iobroker-d.compactgroupProcesses"
                                     6) "cfg.o.system.host.iobroker-d.freemem"
                                     7) "cfg.o.system.host.iobroker-d.mem"
                                     8) "cfg.o.system.host.iobroker-d.logLevel"
                                     9) "cfg.o.system.host.iobroker-d.memAvailable"
                                    10) "cfg.o.system.host.iobroker-d.memHeapTotal"
                                    11) "cfg.o.system.host.iobroker-d.cputime"
                                    12) "cfg.o.system.host.iobroker-d.plugins.sentry"
                                    13) "cfg.o.system.host.iobroker-d.zip"
                                    14) "cfg.o.system.host.iobroker-d.compactModeEnabled"
                                    15) "cfg.o.system.host.iobroker-d.plugins.sentry.enabled"
                                    16) "cfg.o.system.host.iobroker-d.alive"
                                    17) "cfg.o.system.host.iobroker-d.diskWarning"
                                    18) "cfg.o.system.host.iobroker-d.outputCount"
                                    19) "cfg.o.system.host.iobroker-d.load"
                                    20) "cfg.o.system.host.iobroker-d.uptime"
                                    21) "cfg.o.system.host.iobroker-d.instancesAsCompact"
                                    22) "cfg.o.system.host.iobroker-d.eventLoopLag"
                                    23) "cfg.o.system.host.iobroker-d.inputCount"
                                    24) "cfg.o.system.host.iobroker-d.instancesAsProcess"
                                    25) "cfg.o.system.host.iobroker-d.memHeapUsed"
                                    26) "cfg.o.system.host.iobroker-d.diskSize"
                                      O Abwesend
                                      O Abwesend
                                      #238
                                      @foxriver76
                                      Soll ich den Hostname vielleicht noch mal setzen?
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #239
                                        Da sind aber noch host Leichen, und iwie stimmt das auch nicht ganz mit den Entries in der redis DB überein.
                                        Was gibt ìob status?
                                          O Abwesend
                                          O Abwesend
                                          #240
                                          @foxriver76
                                          Richtig, das liegt aber daran, dass in der iobroker_startup.sh des Containers bei jedem Container-Start der Hostname gesetzt wird. Und mal ist das Ergebnis der Name des NAS (bei mir halt NAS), mal der Name des Containers (iobroker-d) und mal eben der von mir bestimmte Name iobroker. Kann ich nicht ändern...
                                          # iob status
                                          iobroker is not running on this host.
                                          No iobroker host is running.
                                          Objects type: redis
                                          States  type: redis
                                          # iobroker version
                                          3.3.22
                                          Habe den 3.3.22 wieder installiert. Der macht keine Probleme.
