  4. GELÖST-Backitup auf Raspi verbindet sich nicht mit Synology
153 Beiträge 7 Kommentatoren 13.0k Aufrufe 6 Beobachtet
  • G gdow1895
    @homoran Die Logs bisher waren ja immer nach dem Neustart des Adapters.
    Habe jetzt mal ein Backup angestoßen was meiner Meinung nach schon zu lange dauert, für das bisschen was es zu sichern gibt (ca. 5 MB in der Sicherungsdatei).
    Das hier wird aktuell angezeigt, aber das Backup läuft noch:
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****"}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups
    Unable to find suitable address.
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups\nUnable to find suitable address.\n"},"done":[],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi4-iob 2642 states saved
    [DEBUG] [iobroker] - host.raspberrypi4-iob 2777 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_27-11_20_25_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_12_27-11_20_25_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups\nUnable to find suitable address.\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27. Dezember 2021 um 11:20 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_12_27-11_20_25_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups\nUnable to find suitable address.\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27. Dezember 2021 um 11:20 Uhr"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"00-11-32-EB-AB-0C","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Backups/ioBroker","dirMinimal":"Backups/ioBroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    @gdow1895 sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
    den kenn ich noch nicht ;-)
    Ist das das log?
    da fehlen die Uhrzeiten
    G 1 Antwort Letzte Antwort
      Ist das das log?
      gdow1895
      @homoran Magst du mir nen Tipp geben wie ich die zwei miteinander bekanntmachen kann? :)
      • G gdow1895
        was willst du mir damit sagen?
        Vielleicht liege ich falsch, aber IMHO rattert da nicht direkt ein Backup los wenn man den Adapter startet.
        Aber ist denn dein mountpunkt leer?
        • G gdow1895
          ich sagte doch, dass ich diese Meldung noch nie gesehen habe.
          Möglicherweise bezieht sich das auf den Mountpoint. Das muss ein leeres Verzeichnis sein.
          Hast du da noch die alten Backups drin?
          Ansonsten müsste @simatec sagen wofür er diese meldung eingebaut hat
          simatecS G 2 Antworten Letzte Antwort
          • G gdow1895
            da_WoodyD Offline
            da_WoodyD Offline
            da_Woody
            @gdow1895 abgesehn davon, daß du im ersten posting die IP ausgext hast. die passt? eventuell einen passwortfehler?
            gruß vom Woody
              simatecS Offline
              simatecS Offline
              simatec
              @homoran Die Meldung kommt vom mount selber.
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • G gdow1895
                Riecht nach Netzwerktrouble.
                  gdow1895
                  @homoran sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
                  Ich habe gedacht du meintest, dass mein Raspi den nicht kennt :D Sorry für das Missverständnis.
                  Ich habe ein altes Backup, von vor ein paar Monaten unter "homes/backup/ioBroker" und ".../CCU" liegen. Da hatte es einmalig geklappt und ich dachte es läuft. Als ich dann gesehen habe, das keine weiteren Backups gelaufen sind habe ich alles upgedatet und neu eingerichtet. Danach läuft es nun leider nicht mehr.
                  IP passt. Passwort auch, da es aus nem Passwortmanager kopiert ist und ich mich damit auch einloggen kann.
                  @simatec Wie kann ich den Mount denn leeren oder anpassen?
                  HomoranH da_WoodyD 2 Antworten Letzte Antwort
                  • G gdow1895
                    Hast du das passwort geändert nachdem es funktionierte?
                    Nicht dass da spezielle Sonderzeichen Probleme machen
                    • G gdow1895
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      da ist schon viel unfug passiert mit plötzlich angehängten leerzeichen...
                      gruß vom Woody
                      • da_WoodyD da_Woody
                        gdow1895
                        @da_woody @Homoran Ich habe den Nutzer komplett neu angelegt, im übrigen nach dieser Anleitung und damit hatte es bei der Ersteinrichtung vor einiger Zeit auch einmalig funktioniert: Smart Home Backup
                        Wie gesagt, Benutzer (inkl. Passwort) und der Ordner Backups wurden komplett neu angelegt. Kann auch gerne nochmal alles löschen und nochmal neu anlegen 🤔
                        Das Passwort besteht aus 8 Zeichen: Groß- und Kleinbuchstaben, Zahlen und Bindestrichen als Sonderzeichen. Habe das extra so gewählt, da ich gelesen habe, dass zu lange Passwörter mit einigen Sonderzeichen ebenfalls Probleme bereiten.
                        Thomas BraunT GlasfaserG HomoranH 3 Antworten Letzte Antwort
                        • G gdow1895
                          @gdow1895
                          Ich hatte mal Probleme mit einem Bindestrich im PW. Das wurde als Option interpretiert. War natürlich Quatsch.
                          • G gdow1895
                            Hallo liebe Community,
                            ich weiß, dieses Thema gab es schon öfter aber es scheint doch auch sehr individuell zu sein, weshalb die gefundenen Beiträge mir offensichtlich nicht weiterhelfen :(
                            Ich möchte gerne meine ioBroker-Installations (Raspi) auf meine Synology NAS (DS218) über den Backitup-Adapter sichern. Leider komme ich nicht auf mein NAS drauf. Weder per FTP, noch CIFS oder NFS.
                            Sowohl der Raspi als auch der NAS sind up to date. Alle Freigaben und Einstellungen im Backitup-Adapter und auf dem NAS sollten auch passen...
                            Bei der Eingabe von "showmount" bekomme ich folgendes angezeigt (die IP Adresse in der Konsole ist korrekt):
                            pi@raspberrypi4-iob:~ $ showmount -e 192.168.xxx.xx
                            clnt_create: RPC: Unable to receive
                            Bei CIFS sieht es so im LOG aus:
                            Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.xxx.xx/volume1/Backups/ioBroker /opt/iobroker/backups Unable to find suitable address.
                            Bei NFS so:
                            Error: Command failed: sudo mount 192.168.xxx.xx:/volume1/Backups/ioBroker /opt/iobroker/backups mount.nfs: Connection timed out
                            Bei FTP so:
                            Error: connect EHOSTUNREACH 192.168.xxx.xx:21
                            Generell werden die Backups aber auf der SD-Karte vom Raspi, also lokal, gespeichert:
                            pi@raspberrypi4-iob:/opt/iobroker/backups $ dir
                            2021_03_23-20_51_53_backupiobroker.tar.gz
                            2021_12_11-18_06_44_backupiobroker.tar.gz
                            2021_12_26-17_35_10_backupiobroker.tar.gz
                            homematic_2021_12_11-23_49_12_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_13-01_30_12_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_16-01_30_11_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_19-01_30_11_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_22-01_30_11_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_25-01_30_11_3.61.6_backupiobroker.tar.sbk
                            homematic_2021_12_26-16_20_41_3.61.6_backupiobroker.tar.sbk
                            iobroker_2021_12_11-19_52_28_backupiobroker.tar.gz
                            iobroker_2021_12_11-23_48_27_backupiobroker.tar.gz
                            iobroker_2021_12_12-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_13-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_14-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_15-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_16-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_17-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_18-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_19-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_20-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_21-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_22-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_23-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_24-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_25-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_26-02_40_10_backupiobroker.tar.gz
                            iobroker_2021_12_26-16_20_21_backupiobroker.tar.gz
                            iobroker_2021_12_26-16_22_08_backupiobroker.tar.gz
                            iobroker_2021_12_26-18_35_28_backupiobroker.tar.gz
                            iobroker_2021_12_26-19_10_03_backupiobroker.tar.gz
                            Ich hoffe sehr, dass auch für mich und mein Problem eine Lösung gefunden werden kann.
                            Vielen lieben Dank für Eure Mühe :)
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            Noch einmal zeigen was kommt
                            und auch ein Ping
                            • GlasfaserG Glasfaser
                              und auch ein Ping
                              gdow1895
                              @glasfaser
                              Showmount-Befehl:
                              pi@raspberrypi4-iob:~ $ showmount -e 192.168.178.56
                              Ping Befehl (auf den NAS) läuft durch:
                              ping -c 5  192.168.178.56
                              PING 192.168.178.56 (192.168.178.56): 56 data bytes
                              64 bytes from 192.168.178.56: icmp_seq=0 ttl=64 time=35.723 ms
                              64 bytes from 192.168.178.56: icmp_seq=1 ttl=64 time=17.589 ms
                              64 bytes from 192.168.178.56: icmp_seq=2 ttl=64 time=17.079 ms
                              64 bytes from 192.168.178.56: icmp_seq=3 ttl=64 time=17.721 ms
                              64 bytes from 192.168.178.56: icmp_seq=4 ttl=64 time=15.767 ms
                              --- 192.168.178.56 ping statistics ---
                              5 packets transmitted, 5 packets received, 0.0% packet loss
                              @Thomas-Braun Passwort habe ich jetzt auf Zahlen und Buchstaben geändert, ohne Sonderzeichen. Ergebnis ist das gleiche.
                              • G gdow1895
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @gdow1895
                                Du hast noch DSM6
                                gibt es da ( bei mir DSM7 )
                                  @gdow1895
                                  Du hast noch DSM6
                                  gdow1895
                                  @glasfaser Gibt nur diese drei Optionen
                                  • G gdow1895
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    @gdow1895
                                    zu NFS , das Protokoll :
                                    G HomoranH 2 Antworten Letzte Antwort
                                      @gdow1895
                                      gdow1895
                                      @glasfaser Habe ich nicht zur Auswahl, auch nicht in den erweiterten Einstellungen
                                      • G gdow1895
                                        Dann müsste ich dich jetzt an den Ersteller des Videos verweisen.
                                        kann Probleme machen
                                          @gdow1895
                                          @glasfaser sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
                                          ich bin der Meinung wir sollten jetzt nicht auch noch das Protokoll wechseln.
                                          NFS hat noch mehr Stolperfallen
