  4. Slave meldet sich nicht mehr
    6.3k
82 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • SMSS SMS
    @thomas-braun Das war leider nicht die Lösung.
    Das Ereignis war ja am 21.10. Das Backup vom 17.10.
    pi@MotionEye:~ $ iobroker status
    /opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:56
          throw err
    SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
        at JSON.parse (<anonymous>)
        at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:52:17)
        at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2722:23)
        at CLIProcess.status (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliProcess.js:202:9)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:426:25)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2910:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
    Doch neu aufspielen? Also SD-Karte formatieren und alles neu?
    arteckA Offline
    arteckA Offline
    arteck
    @sms zeigmal die ausgabe
    cd /opt/iobroker
    iobroker setup custom
    SMSS 1 Antwort Letzte Antwort
    • arteckA arteck
      cd /opt/iobroker
      SMSS Offline
      SMSS Offline
      SMS
      @arteck
      Last login: Sun Oct 24 17:06:11 2021 from 192.168.178.128
      pi@MotionEye:~ $ cd /opt/iobroker                                               pi@MotionEye:/opt/iobroker $ iobroker setup custom                              /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:517
             const currentObjectsType = originalConfig.objects.type || 'file';
      TypeError: Cannot read property 'objects' of undefined
         at Setup.setupCustom (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:517:51)
         at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:469:23)
         at Function.Module._load (internal/modules/cjs/loader.js:708:14)
         at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
         at internal/main/run_main_module.js:17:47
      • SMSS SMS
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        @sms und die anderen laufen??? komisch
        die objects ist im eimer.. müsste aber auf dem master sein..
        • arteckA arteck
          SMSS Offline
          SMSS Offline
          SMS
          schrieb am zuletzt editiert von SMS
          @arteck d.h.? Bringt eine Neuinstallation des Slaves was?
          Also die Ausgabe ist vom Slave.
          • SMSS SMS
                  throw err
            @sms sagte in Slave meldet sich nicht mehr:
            Das sagt doch alles ... das Haupt Konfigfile iobrpker.json ist kaputt
            Auf machen und schauen was es ist und gff retten. ggf den Inhalt in einen Online JSON editor kopieren. Der sagt Dir was falsch ist. Und ggf iobroker.json aus einem Backup holen und vergleichen
            • apollon77A apollon77
              SMSS Offline
              SMSS Offline
              SMS
              @apollon77 da ist nix drin 😆
              pi@MotionEye:/opt/iobroker/iobroker-data $ ls -l
              insgesamt 2644
              drwxrwxr-x+ 2 iobroker iobroker    4096 Jan  3  2021 backup-objects
              drwxrwxr-x+ 5 iobroker iobroker    4096 Jan  3  2021 files
              -rw-rwxr--+ 1 iobroker iobroker       0 Okt 23 15:06 iobroker.json
              -rw-rw-r--+ 1 iobroker iobroker       3 Sep 30 18:58 notifications.json
              -rw-rwxr--+ 1 iobroker iobroker 1924466 Jan  3  2021 objects.json
              -rw-rwxr--+ 1 iobroker iobroker  293536 Jan  3  2021 objects.json.bak
              -rw-rwxr--+ 1 iobroker iobroker  237326 Jan  3  2021 states.json
              -rw-rwxr--+ 1 iobroker iobroker  237298 Jan  3  2021 states.json.bak
              Also ich schaue immer noch auf dem Slave, richtig?
              Was soll denn da in etwa drin stehen?
              • SMSS SMS
                insgesamt 2644
                @sms Da sist blöd das da nix drin ist ... schau doch auf nem anderen slave oder dem master ... da steht dann mehr drin.
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @apollon77 in einem anderen Slave steht was drin. Kann ich das dann grad rüber kopieren? Sehe auf den ersten Blick nichts Slavespezifisches.
                  • SMSS SMS
                    und wir sehen gar nichts
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @homoran @apollon77
                      Slave kellerkind4GB:
                        "system": {
                          "memoryLimitMB": 0,
                          "hostname": "",
                          "statisticsInterval": 15000,
                          "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
                          "checkDiskInterval": 300000,
                          "checkDiskIntervalComment": "Interval how often the disk size will be checked",
                          "noChmod": false,
                          "instanceStartInterval": 2000,
                          "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
                          "compact": false,
                          "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in$
                          "allowShellCommands": false,
                          "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
                          "memLimitWarn": 100,
                          "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
                          "memLimitError": 50,
                          "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
                        "multihostService": {
                          "enabled": false,
                          "secure": true
                        "network": {
                          "IPv4": true,
                          "IPv6": true,
                          "bindAddress": null
                        "objects": {
                          "type": "file",
                          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                          "host": "192.168.178.58",
                          "port": 9001,
                          "user": "",
                          "pass": "",
                          "noFileCache": false,
                          "connectTimeout": 2000,
                          "writeFileInterval": 5000,
                          "options": {
                            "auth_pass": null,
                            "retry_max_delay": 5000
                          "backup": {
                            "disabled": false,
                            "files": 24,
                            "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
                            "hours": 48,
                            "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
                            "period": 120,
                            "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
                            "path": "",
                            "pathComment": "Absolute path to backup directory or empty to backup in data directory"
                        "log": {
                          "level": "info",
                          "maxDays": 7,
                          "noStdout": true,
                          "transport": {
                            "file1": {
                              "type": "file",
                              "enabled": true,
                              "filename": "log/iobroker",
                              "fileext": ".log",
                              "maxSize": null,
                              "maxFiles": null
                            "syslog1": {
                              "type": "syslog",
                              "enabled": false,
                              "host": "localhost",
                              "hostComment": "The host running syslogd, defaults to localhost.",
                              "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                              "protocol": "udp4",
                              "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                              "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                              "facilityComment": "Syslog facility to use (Default: local0).",
                              "localhost": "iobroker",
                              "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
                              "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
                              "app_nameComment": "The name of the application (Default: process.title).",
                              "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
                        "dataDirComment": "Always relative to iobroker.js-controller/",
                        "plugins": {},
                        "dataDir": "../../iobroker-data/"
                      HomoranH apollon77A 2 Antworten Letzte Antwort
                      • SMSS SMS
                        @homoran @apollon77
                          "system": {
                            "memoryLimitMB": 0,
                            "hostname": "",
                            "noChmod": false,
                            "compact": false,
                            "enabled": false,
                            "secure": true
                          "network": {
                            "IPv4": true,
                            "IPv6": true,
                            "bindAddress": null
                          "objects": {
                            "type": "file",
                            "port": 9001,
                            "user": "",
                            "pass": "",
                            "options": {
                              "auth_pass": null,
                            "backup": {
                              "disabled": false,
                              "files": 24,
                              "hours": 48,
                              "period": 120,
                              "path": "",
                          "log": {
                            "level": "info",
                            "maxDays": 7,
                            "noStdout": true,
                            "transport": {
                              "file1": {
                                "type": "file",
                                "enabled": true,
                                "fileext": ".log",
                                "maxSize": null,
                                "maxFiles": null
                              "syslog1": {
                                "type": "syslog",
                                "enabled": false,
                                "protocol": "udp4",
                          "plugins": {},
                        ist das der Master?
                        @apollon77 mag da sicher mehr erkennen ob die ganzen null und "" in Ordnung sind
                          ist das der Master?
                          SMSS Offline
                          SMSS Offline
                          SMS
                          @homoran ja ist der Master
                          • SMSS SMS
                            SMSS Offline
                            SMSS Offline
                            SMS
                            @Homoran @apollon77
                            Wenn ich die Datei iobroker.json auf dem nicht mehr funktionierenden Slave öffne, erschein unten:
                            [ Fehler beim Lesen der Sperrdatei ./.iobroker.json.swp: Nicht genügend Daten gelesen ]
                            • SMSS SMS
                              @Homoran @apollon77
                              dann darfst du die als User pi nicht öffnen
                                SMSS Offline
                                SMSS Offline
                                SMS
                                @homoran Seltsam, das ich die Datei bei den anderen Slaves und beim Master öffnen kann.
                                • SMSS SMS
                                  @Homoran @apollon77
                                  @sms
                                  sudo -u iobroker nano /opt/iobroker/iobroker-data/iobroker.json
                                  Aber das war ja die defekte Datei, oder nicht?
                                  SMSS HomoranH 2 Antworten Letzte Antwort
                                    @sms
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @thomas-braun bei der defekten Datei erscheint
                                      @sms
                                      @thomas-braun sagte in Slave meldet sich nicht mehr:
                                      ich denke ja, oder kann auch fehlende Zugriffsrechte zu diesem Fehler führen?
                                        Andersherum eher. Die Rechte können ja auch 'kaputt' gehen. Das könnte dann ein Hinweis auf ein sterbendes Dateisystem sein.
                                        dmesg -T | grep -i ext4
                                        auf dem Host 'MotionEye' bringt?
                                        Und
                                        getfacl /opt/iobroker/iobroker-data/iobroker.json
                                        bitte.
                                        HomoranH SMSS 2 Antworten Letzte Antwort
                                          Und
                                          bitte.
                                          das wäre dann auch meine letzte Möglichkeit gewesen.
                                          Dann sollte man sowieso eine neue Karte nehmen und neu aufbauen
