  4. Slave meldet sich nicht mehr
    6.3k
82 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • apollon77A apollon77
    @sms Da sist blöd das da nix drin ist ... schau doch auf nem anderen slave oder dem master ... da steht dann mehr drin.
    SMSS Offline
    SMSS Offline
    SMS
    @apollon77 in einem anderen Slave steht was drin. Kann ich das dann grad rüber kopieren? Sehe auf den ersten Blick nichts Slavespezifisches.
    • SMSS SMS
      @sms sagte in Slave meldet sich nicht mehr:
      und wir sehen gar nichts
      SMSS 1 Antwort Letzte Antwort
        SMSS Offline
        SMSS Offline
        SMS
        @homoran @apollon77
        Slave kellerkind4GB:
          "system": {
            "memoryLimitMB": 0,
            "hostname": "",
            "statisticsInterval": 15000,
            "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
            "checkDiskInterval": 300000,
            "checkDiskIntervalComment": "Interval how often the disk size will be checked",
            "noChmod": false,
            "instanceStartInterval": 2000,
            "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
            "compact": false,
            "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in$
            "allowShellCommands": false,
            "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
            "memLimitWarn": 100,
            "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
            "memLimitError": 50,
            "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
          "multihostService": {
            "enabled": false,
            "secure": true
          "network": {
            "IPv4": true,
            "IPv6": true,
            "bindAddress": null
          "objects": {
            "type": "file",
            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
            "host": "192.168.178.58",
            "port": 9001,
            "user": "",
            "pass": "",
            "noFileCache": false,
            "connectTimeout": 2000,
            "writeFileInterval": 5000,
            "options": {
              "auth_pass": null,
              "retry_max_delay": 5000
            "backup": {
              "disabled": false,
              "files": 24,
              "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
              "hours": 48,
              "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
              "period": 120,
              "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
              "path": "",
              "pathComment": "Absolute path to backup directory or empty to backup in data directory"
          "log": {
            "level": "info",
            "maxDays": 7,
            "noStdout": true,
            "transport": {
              "file1": {
                "type": "file",
                "enabled": true,
                "filename": "log/iobroker",
                "fileext": ".log",
                "maxSize": null,
                "maxFiles": null
              "syslog1": {
                "type": "syslog",
                "enabled": false,
                "host": "localhost",
                "hostComment": "The host running syslogd, defaults to localhost.",
                "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                "protocol": "udp4",
                "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                "facilityComment": "Syslog facility to use (Default: local0).",
                "localhost": "iobroker",
                "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
                "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
                "app_nameComment": "The name of the application (Default: process.title).",
                "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
          "dataDirComment": "Always relative to iobroker.js-controller/",
          "plugins": {},
          "dataDir": "../../iobroker-data/"
        HomoranH apollon77A 2 Antworten Letzte Antwort
        • SMSS SMS
          @homoran @apollon77
            "system": {
              "memoryLimitMB": 0,
              "hostname": "",
              "noChmod": false,
              "compact": false,
              "enabled": false,
              "secure": true
            "network": {
              "IPv4": true,
              "IPv6": true,
              "bindAddress": null
            "objects": {
              "type": "file",
              "port": 9001,
              "user": "",
              "pass": "",
              "options": {
                "auth_pass": null,
              "backup": {
                "disabled": false,
                "files": 24,
                "hours": 48,
                "period": 120,
                "path": "",
            "log": {
              "level": "info",
              "maxDays": 7,
              "noStdout": true,
              "transport": {
                "file1": {
                  "type": "file",
                  "enabled": true,
                  "fileext": ".log",
                  "maxSize": null,
                  "maxFiles": null
                "syslog1": {
                  "type": "syslog",
                  "enabled": false,
                  "protocol": "udp4",
            "plugins": {},
          ist das der Master?
          @apollon77 mag da sicher mehr erkennen ob die ganzen null und "" in Ordnung sind
            ist das der Master?
            SMSS Offline
            SMSS Offline
            SMS
            @homoran ja ist der Master
            • SMSS SMS
              SMSS Offline
              SMSS Offline
              SMS
              @Homoran @apollon77
              Wenn ich die Datei iobroker.json auf dem nicht mehr funktionierenden Slave öffne, erschein unten:
              [ Fehler beim Lesen der Sperrdatei ./.iobroker.json.swp: Nicht genügend Daten gelesen ]
              • SMSS SMS
                @Homoran @apollon77
                dann darfst du die als User pi nicht öffnen
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @homoran Seltsam, das ich die Datei bei den anderen Slaves und beim Master öffnen kann.
                  • SMSS SMS
                    @Homoran @apollon77
                    @sms
                    sudo -u iobroker nano /opt/iobroker/iobroker-data/iobroker.json
                    Aber das war ja die defekte Datei, oder nicht?
                    SMSS HomoranH 2 Antworten Letzte Antwort
                      @sms
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @thomas-braun bei der defekten Datei erscheint
                        @sms
                        @thomas-braun sagte in Slave meldet sich nicht mehr:
                        ich denke ja, oder kann auch fehlende Zugriffsrechte zu diesem Fehler führen?
                          Andersherum eher. Die Rechte können ja auch 'kaputt' gehen. Das könnte dann ein Hinweis auf ein sterbendes Dateisystem sein.
                          dmesg -T | grep -i ext4
                          auf dem Host 'MotionEye' bringt?
                          Und
                          getfacl /opt/iobroker/iobroker-data/iobroker.json
                          bitte.
                          HomoranH SMSS 2 Antworten Letzte Antwort
                            Und
                            bitte.
                            das wäre dann auch meine letzte Möglichkeit gewesen.
                            Dann sollte man sowieso eine neue Karte nehmen und neu aufbauen
                            • SMSS SMS
                              @homoran @apollon77
                                "system": {
                                  "memoryLimitMB": 0,
                                  "hostname": "",
                                  "noChmod": false,
                                  "compact": false,
                                  "enabled": false,
                                  "secure": true
                                "network": {
                                  "IPv4": true,
                                  "IPv6": true,
                                  "bindAddress": null
                                "objects": {
                                  "type": "file",
                                  "port": 9001,
                                  "user": "",
                                  "pass": "",
                                  "options": {
                                    "auth_pass": null,
                                  "backup": {
                                    "disabled": false,
                                    "files": 24,
                                    "hours": 48,
                                    "period": 120,
                                    "path": "",
                                "log": {
                                  "level": "info",
                                  "maxDays": 7,
                                  "noStdout": true,
                                  "transport": {
                                    "file1": {
                                      "type": "file",
                                      "enabled": true,
                                      "fileext": ".log",
                                      "maxSize": null,
                                      "maxFiles": null
                                    "syslog1": {
                                      "type": "syslog",
                                      "enabled": false,
                                      "protocol": "udp4",
                                "plugins": {},
                              @sms Wenn das das File vom anderen Slave ist und die IPs drin die vom master sind und hostname oben "leer" ist dann ja kannst DU so übernehemn auf den anderen Slave
                                Und
                                bitte.
                                SMSS Offline
                                SMSS Offline
                                SMS
                                pi@MotionEye:~ $ dmesg -T | grep -i ext4
                                [Mo Okt 25 16:13:24 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:E2:9D:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d666f4cc-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                [Mo Okt 25 16:13:27 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                [Mo Okt 25 16:13:27 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mo Okt 25 16:13:29 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                pi@MotionEye:~ $ getfacl /opt/iobroker/iobroker-data/iobroker.json
                                getfacl: Entferne führende '/' von absoluten Pfadnamen
                                # file: opt/iobroker/iobroker-data/iobroker.json
                                # owner: iobroker
                                # group: iobroker
                                user::rw-
                                group::r--
                                group:iobroker:rwx
                                mask::rwx
                                other::r--
                                  SMSS Offline
                                  SMSS Offline
                                  SMS
                                  @apollon77
                                  Klappt auch nicht:
                                  • SMSS SMS
                                    @apollon77
                                    Klappt auch nicht:
                                    @sms
                                    Äh, Partition rappeldicht voll?
                                    df -h /
                                      @sms
                                      df -h /
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      @thomas-braun Seltsam: 🙁
                                      pi@MotionEye:/opt/iobroker/iobroker-data $ df -h
                                      Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                      /dev/root        15G     14G     0  100% /
                                      devtmpfs        3,7G       0  3,7G    0% /dev
                                      tmpfs           3,9G     16K  3,9G    1% /dev/shm
                                      tmpfs           3,9G    8,5M  3,9G    1% /run
                                      tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                      tmpfs           3,9G       0  3,9G    0% /sys/fs/cgroup
                                      /dev/mmcblk0p1  253M     49M  204M   20% /boot
                                      tmpfs           790M       0  790M    0% /run/user/1000
                                      • SMSS SMS
                                        Dicht.
                                          Dicht.
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          schrieb am zuletzt editiert von SMS
                                          @thomas-braun aber warum? Außer backups, welche doch auf dem Master abgelegt werden sollten, mache ich da nichts
                                          Oder kommt das von den Updates.
