  5. Verständnisfrage Blockly / Trigger <-> mehrere Bedingungen
blockly
33 Beiträge 5 Kommentatoren 4.2k Aufrufe 3 Beobachtet
  • hydrotecH Offline
    hydrotecH Offline
    hydrotec
    Nur der Vollständigkeit halber, nochmal das ganze script inklusive Schalter.
    Anstatt 680 Zeilen, nur noch 311 Zeilen an Code.
    Das kann sich sehen lassen ;-)
      <block type="on_ext" id="A@hLFm%=f,-t)_p~5;Ck" x="363" y="337">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="L?#|2YS]$o7!/nz}+6Kl">
            <field name="oid">mqtt.1.zigbee2mqtt.xi_switch_01.action</field>
          </shadow>
        </value>
        <value name="OID1">
          <shadow type="field_oid" id="#Miu][z7z%=0;T_5lUvZ">
            <field name="oid">mqtt.1.zigbee2mqtt.xi_switch_02.action</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="_4Is,2PE0{{s;Ub8JHaQ">
            <value name="IF0">
              <block type="logic_operation" id="Qq0{~;5/Juz):X(#fH0F" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="logic_operation" id="cmKKJT[XtHs5[eu7fSFY" inline="false">
                    <field name="OP">OR</field>
                    <value name="A">
                      <block type="logic_compare" id="d-mUr/_G$*Gp/gw?o$.|">
                        <field name="OP">EQ</field>
                        <value name="A">
                          <block type="get_value" id="(_O?$k2_.vB+Z(@cXJU[">
                            <field name="OID">mqtt.1.zigbee2mqtt.xi_switch_01.action</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="b|w6^%!zi$UxcI[y|N=B">
                            <field name="TEXT">single</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="CguO%DZ/~DEiYA8cxh.Y">
                        <value name="A">
                          <block type="get_value" id="*qpVLDhkVY[L@RmsfxRy">
                            <field name="OID">mqtt.1.zigbee2mqtt.xi_switch_02.action</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="WWq%Ind[Bt2Xrho0n.j:">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="JWRqy^.A{}jE3ro7a9*x">
                    <value name="A">
                      <block type="get_value" id="nPF^F;yVRK87msS~ph3C">
                        <field name="OID">hue.0.z_hallway_ceiling.on</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="}^2jX]hdHR/Y^#dptLzX">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="d6^Bj@_$L@d*D)kLOwt-">
                <field name="OID">hue.0.z_hallway_ceiling.scene_entspannen</field>
                <value name="VALUE">
                  <block type="logic_boolean" id="6gj_[tUX$*IK09#mWl(j">
                  </block>
                </value>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_operation" id="W.]bz|NZL8^t0*eO4a9a" inline="false">
                <value name="A">
                  <block type="logic_operation" id="mCOAEFKy;=xJh{c9e(q-" inline="false">
                    <value name="A">
                      <block type="logic_compare" id="^Ee81fc]m`]2%OLr:Lg[">
                        <value name="A">
                          <block type="get_value" id="_~)7TAlh~yN7J?7.X!ud">
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="VC:tW0ln!k60.ITWjIw)">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="VD[(T$#(QMx;bKSrU$?-">
                        <value name="A">
                          <block type="get_value" id="iO9*V;cy`4RIq:}J$p$j">
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="~I0w~~V]IZ_,|Hq0:$dB">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="`Sm/G#6s+5kNBaklTQ@h">
                    <value name="A">
                      <block type="get_value" id=",vHU(%n{94y-~bUNOF@9">
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="PX?lqN5`BL}YnE5HNYXE">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO1">
              <block type="control" id="16!faWg[OYmoOmq=FqS+">
                  <block type="logic_boolean" id="nUZ7:G_{-@o.la$qepYY">
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="on" id="nyDQxdsX}/5jI`;q2eQ]">
            <field name="OID">mqtt.1.zigbee2mqtt.hue_dimmer_switch_01.action</field>
              <block type="controls_if" id="vP]u{ZL*qzm$TW2P;Y8!">
                <value name="IF0">
                  <block type="logic_compare" id="DRgLJQB{2L5XxuZ[xb9(">
                    <value name="A">
                      <block type="on_source" id="wCQ3BFiDtcN6^rYL|qZj">
                      </block>
                    </value>
                    <value name="B">
                      <block type="text" id="pIF`P@/0-l}+P+([Y;b.">
                        <field name="TEXT">on_press_release</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="control" id="{%R$|avQPJq7J8h7ohPQ">
                      <block type="logic_boolean" id="GJP}KpgWEWDvg.YzB;Ok">
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="^$#@e(v|TUy7zag:YF}Z">
                    <value name="A">
                      <block type="on_source" id="Glb3vYG`:WGg@;k%S/-(">
                      </block>
                    </value>
                    <value name="B">
                      <block type="text" id="Z.{3@@JabqW_4-Il.t4P">
                        <field name="TEXT">off_press_release</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="control" id="bz]YzxN);~+edl$00wL#">
                      <block type="logic_boolean" id="+Ge$S$C2+VsHc=s][RR+">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
              <block type="on_ext" id="*|#mcW[?)%S%x[SlEG,a">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
                <value name="OID0">
                  <shadow type="field_oid" id="q,D5hL!um?3EjegVTtJ7">
                    <field name="oid">0_userdata.0.general.presence.iCal_4_Anwesenheit.timer</field>
                  </shadow>
                </value>
                <value name="OID1">
                  <shadow type="field_oid" id="n}#i8blXZhTv{yU:W?b8">
                    <field name="oid">0_userdata.0.general.sensor.xi_sensor_light_01.isday</field>
                  </shadow>
                </value>
                <value name="OID2">
                  <shadow type="field_oid" id="mZ[TOtA:Sgg8iI|)5g~?">
                    <field name="oid">0_userdata.0.general.presence.MyPhone11Pro.presence</field>
                  </shadow>
                </value>
                  <block type="controls_if" id="/L+oZ{ge73[67}1YgoU5">
                    <value name="IF0">
                      <block type="logic_operation" id="cqy(sqhVhWFV]9mG2,Gf" inline="false">
                        <value name="A">
                          <block type="get_value" id="n~LZ,LV)qor$OJ#DLZH#">
                            <field name="OID">0_userdata.0.general.presence.iCal_4_Anwesenheit.timer</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_operation" id="NbHR!`:cyQ6=H+CD4B5f" inline="false">
                            <value name="A">
                              <block type="logic_negate" id="Mz./9Mt=Pyb8UhoV5+@b">
                                <value name="BOOL">
                                  <block type="get_value" id="ort4i|M;OVF+VsTBQXL-">
                                    <field name="OID">0_userdata.0.general.sensor.xi_sensor_light_01.isday</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="get_value" id="P3@Xw,v@yj7Ag1El*5-D">
                                <field name="OID">0_userdata.0.general.presence.MyPhone11Pro.presence</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="~vSQzYjEiTQ|p@T=:o!Q">
                          <block type="logic_boolean" id="48`/T8+GE1xdIyULKD@u">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <statement name="ELSE">
                      <block type="control" id="D_qrgPs{?qDtS0}pY~Xy">
                          <block type="logic_boolean" id="Gws9V?:Xr#(_%_PkYH;*">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    Ubuntu 22.04 LTS (LXD/LXC)
    admin: v6.3.5
    js-controller: v4.0.24
    node: v18.16.1
    npm: v9.5.1
    repository: stable
    CinimodC T 2 Antworten Letzte Antwort
    • hydrotecH hydrotec
          <value name="OID0">
            </shadow>
          </value>
          <value name="OID1">
            </shadow>
          </value>
              <value name="IF0">
                  <value name="A">
                      <value name="A">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                </block>
              </statement>
              <value name="IF1">
                  <value name="A">
                      <value name="A">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                </block>
              </statement>
            </block>
          </statement>
          <next>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </statement>
              <next>
                  <value name="OID0">
                    </shadow>
                  </value>
                  <value name="OID1">
                    </shadow>
                  </value>
                  <value name="OID2">
                    </shadow>
                  </value>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                  <value name="BOOL">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      CinimodC Offline
      CinimodC Offline
      Cinimod
      @hydrotec Falls sich der dritte Schalter auch mit "aktualisiert" trigger funktioniert, kannst daraus ja auch eins machen, dann mit nem oder block "wert = "on press releae"" verknüpfen.
      hydrotecH 1 Antwort Letzte Antwort
      • CinimodC Cinimod
        hydrotecH Offline
        hydrotecH Offline
        hydrotec
        @cinimod
        Das war mein erster Versuch, funktioniert leider nicht.
        Selbst wenn die Lampe aus ist, und "off_press_release" betätigt wird, schaltet sich die Lampe ein.
        Ist jetzt, aus meiner Sicht, nicht so dramatisch, wenn das ein extra Trigger ist.
        Wenn ich mal wieder die Muse habe, werde ich mich damit beschäftigen, warum das so ist.
        Für's Erste bin ich soweit zufrieden. Funktion ist wie gewünscht.
        Und das Wichtigste, ich habe wieder etwas dazu gelernt ;-)
        Danke dir nochmal.
        Gruß, Karsten
        admin: v6.3.5
        node: v18.16.1
        npm: v9.5.1
        repository: stable
        • hydrotecH Offline
          hydrotecH Offline
          hydrotec
          Jetzt muss ich doch noch einmal nachhaken.
          Wenn ich folgendes script, welches in dieser Form funktioniert, umstrukturiere, dann wird bei der Lautstärkenänderung das Radio ausgeschaltet und anschließend wieder eingeschaltet.
          Ein und ausschalten funktioniert bei beiden scripten wie es soll.
          Wo liegt mein Denkfehler?
          Basis script
            <block type="comment" id="|hu]OPgX!qta+29}/G;u" x="438" y="-887">
              <field name="COMMENT">192_168_78_113 manually</field>
              <next>
                <block type="on" id="]EDrUB(`|b#ZkvDo;;s(">
                  <field name="OID">mqtt.1.zigbee2mqtt.xi_switch_05.action</field>
                    <block type="controls_if" id="g+#*tlvP_aoAqSF!]]4N">
                      <value name="IF0">
                        <block type="logic_operation" id="uk^ax4eXRhj-=R1JBF^b" inline="false">
                          <value name="A">
                            <block type="logic_compare" id="9V9=jLk2:bEucI-O%KgS">
                              <value name="A">
                                <block type="get_value" id="B#@Ool0#DI/_EAa8+e9J">
                                </block>
                              </value>
                              <value name="B">
                                <block type="text" id="o:%7-=zwT7SOcR^N(I(X">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="m@BiE$o%-{DyrNE/BuZ5">
                              <value name="A">
                                <block type="get_value" id="cK7V|UwOq^1FRFO)$~y)">
                                  <field name="OID">sonos.0.root.192_168_78_113.state_simple</field>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="T9rM6c+-5=S^(A1M2X@~">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="comment" id="j)Sl$T^lnG`:+-ME8a}%">
                          <field name="COMMENT">192_168_78_113.play</field>
                          <next>
                            <block type="control" id="Tu6Y}c|0HGeTs,{re~TY">
                              <field name="OID">sonos.0.root.192_168_78_113.play</field>
                                <block type="logic_boolean" id="[FY!zE4uuzDKm;1jK1uj">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <value name="IF1">
                        <block type="logic_operation" id="SEDgkY(j!WQce]~eIX.," inline="false">
                          <value name="A">
                            <block type="logic_compare" id="?96xn!HU[k7$gkcS=,7^">
                              <value name="A">
                                <block type="get_value" id="h=_1{GGLcN7/Zx7s;p(B">
                                </block>
                              </value>
                              <value name="B">
                                <block type="text" id="Drz(N:^J`KDV/|m:_0?N">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="zw^QcQDHcM1~mvTJ-o8*">
                              <value name="A">
                                <block type="get_value" id="on]xh~1|E`C{eni@3ZMu">
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="?fP=@DW$cS}Ff6vhdY,9">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="comment" id="R@m.^{uV9a%-;VX.i~@p">
                          <field name="COMMENT">192_168_78_113.stop</field>
                          <next>
                            <block type="control" id="~BX[1(b*O*#t8SYDG,ph">
                              <field name="OID">sonos.0.root.192_168_78_113.stop</field>
                                <block type="logic_boolean" id="y5JMaV|]I)[VA#Om0K:r">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                    <block type="on" id="5:qkeqjSlxRf35Fy@9#p">
                      <field name="OID">mqtt.1.zigbee2mqtt.ik_remote_symfonisk_02.action</field>
                        <block type="controls_if" id="0sk?fA:QXcbH3:p.=~Gc">
                          <mutation elseif="3"></mutation>
                          <value name="IF0">
                            <block type="logic_operation" id="30LVRQ=(W1+E;@SI#R}E" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="F*Mvq6qe`qtf=E.Z6#,(">
                                  <value name="A">
                                    <block type="get_value" id="+R:Unj85lZi!E`u_.5AX">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="[Ow1k.-DpO*x-VI[zQ}L">
                                      <field name="TEXT">toggle</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="dQukAP:Ciks]Lf*b3~#t">
                                  <value name="A">
                                    <block type="get_value" id="`_cAb0pu!0sQ9^8^E*PZ">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="A=tK8yRX5uZduuzQ.t?+">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="comment" id="b_Q[o[!7H87C]Hu/a5x-">
                              <next>
                                <block type="control" id="G~hr5%t2)gfJ4CW{kOsN">
                                    <block type="logic_boolean" id="R,1fB+:VkD3F!x[0dtfQ">
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                          <value name="IF1">
                            <block type="logic_operation" id="LyT;RS6Xt1w#!KtxvtWd" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="Aii@JCeq=,/Eg|P_kn~u">
                                  <value name="A">
                                    <block type="get_value" id="n``w1Gi@`EP%/~~n2^]E">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="dP9XWDKStK572W5A4yDT">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="xfu?0[LvZ4(AgZ+v(Z4]">
                                  <value name="A">
                                    <block type="get_value" id="n6[,/I$KWR4_N2||XNQ9">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="k|Q|m?3{$gTTIte!G+ki">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="comment" id="`(rvV}LfD}X5_Le?Qr8m">
                              <next>
                                <block type="control" id="!RbuUyGZ)8QFw,`R+4q3">
                                    <block type="logic_boolean" id="VqVZWV]AIeMfSjs5l=He">
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                          <value name="IF2">
                            <block type="logic_operation" id="mh[((L=_3oB:N+ApV!Rw" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="TdHr=0B*0A8SGu#rF~5r">
                                  <value name="A">
                                    <block type="get_value" id="9V@e/6l:!b4C4|et7%j=">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="#Zi^55bSD.=y_+O.Vn7F">
                                      <field name="TEXT">brightness_move_down</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="@vm-_k%@raTT~_Bd{{B3">
                                  <value name="A">
                                    <block type="get_value" id="aSLIK/@V(}R|LUjRN#um">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="[gbH:}1XFo24P~Nm,jLo">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <statement name="DO2">
                            <block type="comment" id="3B8=ATk!6g[MMLE+d!y_">
                              <field name="COMMENT">192_168_78_113.group_volume down</field>
                              <next>
                                <block type="control" id="qV97K``8QAkW3GN(SuqO">
                                  <field name="OID">sonos.0.root.192_168_78_113.group_volume</field>
                                    <block type="math_arithmetic" id="lxGS_~s(lo%/@ECge+X@">
                                      <value name="A">
                                        <shadow type="math_number" id="%wH-rIkC^(*GX}]O!(WD">
                                          <field name="NUM">1</field>
                                        </shadow>
                                        <block type="get_value" id="mc$4Ze1nXs40.T?n2rRt">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <shadow type="math_number" id="(3)}c=t-7A^u#,_?.G5I">
                                          <field name="NUM">2</field>
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                          <value name="IF3">
                            <block type="logic_operation" id="#P%^nv]g^J~;RO0-:x0P" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="2daA{Fu=x$V]EIZX;o2(">
                                  <value name="A">
                                    <block type="get_value" id="2W.^J{q|yD*ln@9ZK,{^">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="Uo34{vyC*//jA^Pbt[1K">
                                      <field name="TEXT">brightness_move_up</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="a@Zjz:/@!)6?uhIm)JmT">
                                  <value name="A">
                                    <block type="get_value" id="GGC5.[sPf5Ni%rsc.Zy_">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="K?[`iF:%C+!,fUy!bjYs">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <statement name="DO3">
                            <block type="comment" id="3i!_IQQ`*@mTupiC0z(a">
                              <field name="COMMENT">192_168_78_113.group_volume up</field>
                              <next>
                                <block type="control" id="HE%#VC{b!gO=Y]K_M8,J">
                                    <block type="math_arithmetic" id="8{g;v)W*I,P_MGxs]Gj.">
                                      <field name="OP">ADD</field>
                                      <value name="A">
                                        <shadow type="math_number">
                                        </shadow>
                                        <block type="get_value" id="CcV$.b`@7y1B%7/SKIb+">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <shadow type="math_number" id="}@W.6znn)L+L#N+6Ry8.">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                        <block type="comment" id="Y;E/TqHDYg[md%RKNHw/">
                          <field name="COMMENT">192_168_78_113 automatic</field>
                          <next>
                            <block type="on_ext" id="pQi.%,OhPQz?`4Vdz6s3">
                              <value name="OID0">
                                <shadow type="field_oid" id="cJS[o(p::!QU@oRo}:Ue">
                                </shadow>
                              </value>
                              <value name="OID1">
                                <shadow type="field_oid" id="G}CnwOt9RdiY]vT56MX%">
                                </shadow>
                              </value>
                                <block type="controls_if" id="U-^hwn%g_#T@I(6P-pbB">
                                  <value name="IF0">
                                    <block type="logic_operation" id="CNOVL(NO9~LVxM89Zed-" inline="false">
                                      <value name="A">
                                        <block type="logic_operation" id="z#^t?UUidxU!V[j(P~X7" inline="false">
                                          <value name="A">
                                            <block type="get_value" id="cB_-%t5Nt-aTHpXIfRgn">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="get_value" id="]9;a)[E$V^q{b#/y3]/0">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_compare" id="HTwu~l_5Zs|DDB@40(!j">
                                          <value name="A">
                                            <block type="get_value" id="%0M:(5|~8^#w6g~0xx1{">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_boolean" id="27JWLa5{hCLlC]#i2l-;">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="comment" id="*7S_y$,,*E[{bta|:(W}">
                                      <field name="COMMENT">192_168_78_113.group_volume</field>
                                      <next>
                                        <block type="control" id="`|1LwE!UbzR9Yak@~=a%">
                                            <block type="math_number" id="[zEf)WQT(pu/n`:gq+`[">
                                              <field name="NUM">16</field>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="comment" id="gTE#33GT27Rx-,U}f4{1">
                                              <next>
                                                <block type="control" id="rGbvudP^s_3}1xaJR[Eu">
                                                    <block type="logic_boolean" id="y@1ABCgvmq@H$+/.gQ{5">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                    <block type="logic_operation" id="U6g{p{=R/ja^8A8lRGzB" inline="false">
                                      <value name="A">
                                        <block type="logic_operation" id="U~er*6{Oavo~,i5E.YN]" inline="false">
                                          <value name="A">
                                            <block type="logic_negate" id="l%;I`CeXn`ME*^EspWss">
                                              <value name="BOOL">
                                                <block type="get_value" id="aW,.{LoAgB#jOUY(bN~z">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_negate" id="?TK9!xtLwNgh;R![7]Ij">
                                              <value name="BOOL">
                                                <block type="get_value" id="aT~UP]XA3eaa76v)2N;t">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_compare" id="C%lc)QT;i5Kef`v2*YxX">
                                          <value name="A">
                                            <block type="get_value" id="JZ@lMpDvw*J05I?LdWGk">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_boolean" id="2fF9aSo^moL6pA=^|HE!">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="comment" id="E952D?u66HgnhpqK3O~Q">
                                      <next>
                                        <block type="control" id="rW.(7CW0r2!{*th##75g">
                                            <block type="logic_boolean" id="{L#fAaZFdMqc)cU0V@Ec">
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </xml>
          umstrukturiertes script
            <block type="comment" id=":aD+m^UU`o2S+obB*Co{" x="438" y="-585">
              <next>
                <block type="on_ext" id="_|fb$VE*@CpLjZ9@7)~s">
                  <value name="OID0">
                    <shadow type="field_oid" id="jLf[molnI1Z}K/OrfZ5r">
                      <field name="oid">mqtt.1.zigbee2mqtt.ik_remote_symfonisk_02.action</field>
                    </shadow>
                  </value>
                  <value name="OID1">
                    <shadow type="field_oid" id="RJjNT8Alvup-B#/1Td$p">
                      <field name="oid">mqtt.1.zigbee2mqtt.xi_switch_05.action</field>
                    </shadow>
                  </value>
                    <block type="controls_if" id="21sX(|_V8yH?3.[E5by{">
                      <value name="IF0">
                        <block type="logic_operation" id="?]WD/oNi~Se*hXHX*)=U" inline="false">
                          <value name="A">
                            <block type="logic_operation" id="p*LHLi9t^sVnB?n_||)M" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="PEgVJru[KYlNUZ1A::iM">
                                  <value name="A">
                                    <block type="get_value" id="h;dzZwnoV3ygy_LRtZQJ">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="%Ps|$]w=yND$J42t5}kI">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="bCa~3|e#hKF*,P?8Twuo">
                                  <value name="A">
                                    <block type="get_value" id="ETkEp9l*g8oJ|xr93Oqq">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="VMlDERw@o=T_1Ch?Bplk">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="joyG{1WdQ]wgHHI[q:Ja">
                              <value name="A">
                                <block type="get_value" id="(Rg?e4zOBGh*[48SV;X7">
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="1qs@5i_qC{Kz,gqFgHrN">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="comment" id=".Md_CV0)[D@r(rW#c`@/">
                          <next>
                            <block type="control" id="ZNrOB)^*cVS2zL6lO:cL">
                                <block type="logic_boolean" id="`afBuH-Q[KtEbQ5PT[Tk">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <value name="IF1">
                        <block type="logic_operation" id="AcMBpXut2)-ctKTS{V75" inline="false">
                          <value name="A">
                            <block type="logic_operation" id="krD?*(Y@~3nd)i_ZgM+r" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="2QKUS:FS#2[P9el]$;+7">
                                  <value name="A">
                                    <block type="get_value" id="81Drs.S$1P_S71-3Up49">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="T|r9f)H#s4R)6A}BFrwE">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id=";Hylb!)aIFH:_8Qj-}?E">
                                  <value name="A">
                                    <block type="get_value" id="#bir1B.0*:QaF9hmx0IW">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="text" id="{uNy/L7!G,jlh$+}*p`3">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="3JKvmod(v0.6l?u@I-fU">
                              <value name="A">
                                <block type="get_value" id="gzK~PURwdkEu/isx7%U`">
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="[Jv{M.V7[b;D:$5TU$}v">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="comment" id="s:;q{Bt,nt*.LXWH[_bb">
                          <next>
                            <block type="control" id="/}!:-:qt/#plx+Q2*jA3">
                                <block type="logic_boolean" id="js`HpeMy;wRyv;ETb$($">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <value name="IF2">
                          <value name="A">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="cNaIWrsNjP82b{0$B`Xp">
                              <value name="A">
                                <block type="get_value" id="1:xChr5Fhvxkl4d9^|w$">
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="aOjC%mqR5+$P:+tC33xy">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                          <next>
                                  <value name="A">
                                    </shadow>
                                    </block>
                                  </value>
                                  <value name="B">
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <value name="IF3">
                          <value name="A">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="bpZ/F-!_=}5;~Kb)(%ul">
                              <value name="A">
                                <block type="get_value" id="@S{d;Xw2a6FU-L1Lb?(.">
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="!9p`EbmK/@up`e-W-^kX">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                          <next>
                                  <value name="A">
                                    </shadow>
                                    </block>
                                  </value>
                                  <value name="B">
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                      <next>
                          <value name="OID0">
                            </shadow>
                          </value>
                          <value name="OID1">
                            </shadow>
                          </value>
                              <value name="IF0">
                                  <value name="A">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                  <next>
                                        </block>
                                      </value>
                                      <next>
                                          <next>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                              <value name="IF1">
                                  <value name="A">
                                      <value name="A">
                                          <value name="BOOL">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                          <value name="BOOL">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                  <next>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </xml>
          Gruß, Karsten
          admin: v6.3.5
          node: v18.16.1
          npm: v9.5.1
          repository: stable
            @cinimod
            Danke dir nochmal.
            Gruß, Karsten
            CinimodC Offline
            CinimodC Offline
            Cinimod
            @hydrotec sagte in Verständnisfrage Blockly / Trigger <-> mehrere Bedingungen:
            @cinimod
            Ok hätte ja klappen können :)
            Da hast du recht.
            Danke dir nochmal.
            Gruß, Karsten
            Gern :)
                  <value name="OID0">
                    </shadow>
                  </value>
                  <value name="OID1">
                    </shadow>
                  </value>
                      <value name="IF0">
                          <value name="A">
                              <value name="A">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                          <value name="A">
                              <value name="A">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                          <value name="IF1">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                          <value name="OID0">
                            </shadow>
                          </value>
                          <value name="OID1">
                            </shadow>
                          </value>
                          <value name="OID2">
                            </shadow>
                          </value>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                          <value name="BOOL">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </xml>
              TDCroPower
              @hydrotec ich hätte für dich hier den Tipp, das du versuchen solltest eine doppelte Prüfung zu vermeiden, falls natürlich möglich.
              Im ersten Fall kannst du es durch eine doppelte "Falls" Verschachtelung erreichen.
              Ist dann immer aufwändig/fehleranfällig wenn man den Datenpunkt ändert.
              Auch den Trigger würde ich versuchen immer auf "wurde geändert" anstatt "wurde aktualisiert" zu setzen, wenn man nur auf eine Änderung des Datenpunktes reagieren möchte z.B. ein Wechsel von "true" auf "false".
              auch die doppelte Prüfung auf "hue.0.z_hallwall_ceiling_on", kannst du dir sparen wenn er nur "true" oder "false" als Zustand besitzt...
              • T TDCroPower
                hydrotecH Offline
                hydrotecH Offline
                hydrotec
                @tdcropower
                Guten Morgen TDCroPower,
                @tdcropower sagte ...
                Der Datenpunkt "action" ändert sich nicht bei den Xiaomi WXKG12LM wenn man den button nur einmal betätigt.
                Deswegen muss ich "wurde aktualisiert" verwenden.
                ... das du versuchen solltest eine doppelte Prüfung zu vermeiden, falls natürlich möglich.
                ... auch die doppelte Prüfung auf "hue.0.z_hallwall_ceiling_on", kannst du dir sparen wenn er nur "true" oder "false" als Zustand besitzt...
                Das ist ein guter Tipp, den ich gleich mal umgesetzt, und erfolgreich getestet, habe.
                ... Ist dann immer aufwändig/fehleranfällig wenn man den Datenpunkt ändert.
                Ja, stimme dir zu, doch da bin ich noch am überlegen, wie ich das am Besten realisiere.
                (Alias Manager, Blockly Gruppen/Listen, usw.)
                Bin ja noch Frischling in Sachen ioBroker und seine Möglichkeiten.
                Bis jetzt habe ich mich vorrangig erst einmal damit beschäftigt,
                das die Automatisationen der vorherigen Software funktionieren.
                Auf jeden Fall einmal Dankeschön für deine Tipps :-)
                Noch einen angenehmen Tag
                Gruß, Karsten
                admin: v6.3.5
                node: v18.16.1
                npm: v9.5.1
                repository: stable
                  @tdcropower
                  Gruß, Karsten
                  TDCroPower
                  @hydrotec den Taster habe ich sogar ebenfalls, jedoch reagiere ich auf den Datenpunkt "click" der "true"/"false" switched.
                  Habe aber keinen Datenpunkt "action" bei meinem Taster!?
                  Liegt vielleicht daran das ich den "ZigBee" Adapter nutze?
                  Hier reagiere ich sogar lediglich beim Trigger mit "ist wahr", wodurch der Trigger beim drücken nur 1x ausgeführt wird.
                  Beim single drücken wechselt dieser nämlich von "false" -> "true" -> "false", sodass "wurde aktualisiert" und "wurde geändert" den Trigger 2x ausführen würde.
                  hier meine Datenpunkte bei dem Switch...
                  • T TDCroPower
                    hydrotecH Offline
                    hydrotecH Offline
                    hydrotec
                    @tdcropower sagte in Verständnisfrage Blockly / Trigger <-> mehrere Bedingungen:
                    ... Liegt vielleicht daran das ich den "ZigBee" Adapter nutze? ...
                    Ja
                    Ich verwende für ioBroker, mqtt und zigbee2mqtt jeweils getrennte Container.
                    Und bei zigbee2mqtt ist in der config noch folgender Eintrag mit drin.
                    # Optional: experimental options
                    experimental:
                      # Optional: MQTT output type: json, attribute or attribute_and_json (default: shown below)
                      # Examples when 'state' of a device is published
                      # json: topic: 'zigbee2mqtt/my_bulb' payload '{"state": "ON"}'
                      # attribute: topic 'zigbee2mqtt/my_bulb/state' payload 'ON"
                      # attribute_and_json: both json and attribute (see above)
                      output: 'attribute'
                    Und dann werden die Objekte in ioBroker eben so angelegt.
                    admin: v6.3.5
                    node: v18.16.1
                    npm: v9.5.1
                    repository: stable
                      Ja
                      experimental:
                        output: 'attribute'
                      TDCroPower
                      @hydrotec ah ok, darf ich fragen warum du für ZigBee es über diesen Umweg machst?
                      Mit dem ZigBee Adapter im ioBroker kommunizierst du direkt mit allen ZigBee Geräten.
                      • T TDCroPower
                        hydrotecH Offline
                        hydrotecH Offline
                        hydrotec
                        Weil ich es kann 😆
                        Nein, hat folgenden Hintergrund.
                        Bei mir sind relativ viele Hue dimmer switch verbaut,
                        bei denen ich die on/off Taste mehrfach belegt habe.
                        Mein letzter Kenntnisstand, bei dem Zigbee-Adapter werden beide Tasten in ein Objekt (state) gelegt.
                        Damit funktioniert die Mehrfachbelegung nicht.
                        Was aber nicht heißen soll, das der Zigbee-Adapter deswegen schlechter ist.
                        admin: v6.3.5
                        node: v18.16.1
                        npm: v9.5.1
                        repository: stable
                        FredFF 1 Antwort Letzte Antwort
                          Weil ich es kann 😆
                          FredFF Offline
                          FredFF Offline
                          FredF
                          Most Active Forum Testing
                          Nö.
                          • FredFF FredF
                            Nö.
                            hydrotecH Offline
                            hydrotecH Offline
                            hydrotec
                            @fredf
                            Danke für den Hinweis ;-)
                            Ist ja schön wenn es jetzt anders ist.
                            admin: v6.3.5
                            node: v18.16.1
                            npm: v9.5.1
                            repository: stable
