  4. Zigbee iobroker Error while opening serialport
    2.5k
    4.5k
231 Beiträge 28 Kommentatoren 60.7k Aufrufe 24 Beobachtet
  • W Offline
    W Offline
    wusa
    schrieb am zuletzt editiert von wusa
    #61
    leider schaffe ich es nicht, den Adapter zum Laufen zu bekommen.
    Auf meinem Test System lief der Stick wunderbar. Jetzt auf dem Echtsystem will dieser allerdings nicht mehr.
    Hier die Logs.
    zigbee.0
    2022-06-09 22:04:52.616	error	Error herdsman start
    zigbee.0
    2022-06-09 22:04:52.614	error	Failed to start Zigbee
    zigbee.0
    2022-06-09 22:04:52.610	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2022-06-09 22:04:51.913	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-06-09 22:04:51.864	info	Starting Zigbee npm ...
    zigbee.0
    2022-06-09 22:04:51.861	info	Try to reconnect. 1 attempts left
    zigbee.0
    2022-06-09 22:04:41.851	error	Error herdsman start
    zigbee.0
    2022-06-09 22:04:41.849	error	Failed to start Zigbee
    zigbee.0
    2022-06-09 22:04:41.847	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2022-06-09 22:04:41.064	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2022-06-09 22:04:41.062	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2022-06-09 22:04:41.060	error	Please update configuration to prevent further issues.
    zigbee.0
    2022-06-09 22:04:41.058	error	- Channel List: configured=20, adapter=11
    zigbee.0
    2022-06-09 22:04:41.055	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2022-06-09 22:04:41.053	error	- Extended PAN ID: configured=23d1dddddd23c1ab, adapter=00124b0024c8bc28
    zigbee.0
    2022-06-09 22:04:41.051	error	- PAN ID: configured=6754, adapter=6754
    zigbee.0
    2022-06-09 22:04:41.049	error	Configuration is not consistent with adapter state/backup!
    Der Adapter ist wie folgt eingestellt:
    Genau der Beitrag über mir hat die selben Probleme, aber ich verstehe nicht, wie das passieren kann?
    Der Stick ist erstmalig in Betrieb gegangen auf diesem System.
    Edit: ich habe die Datei nvbackup.json gelöscht. Aber die Frage bleibt, woher kommen die Backups auf einem komplett neuen System an dem der Stick noch nie war?
    • W wusa
      Hier die Logs.
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      #62
      @wusa
      Du musst die aufgeführten Parameter jetzt überein bringen.
      • Y Offline
        Y Offline
        Yoshi
        #63
        Kann mir hier einer bitte helfen.
        Habe den Conbee II Stick und habe ihn auch zum laufen bekommen. Habe ein paar Teilnehmer angelernt und dann den Raspy nochmal neugestartet und nun verbindet er sich nicht mehr mit dem Stick. Habe den Stick mal umgesteckt dann lief es mal kurz und nun wieder nicht.
        Egal was ich mache kommt immer diese Fehlermeldung
        zigbee.0
        2022-08-15 17:48:22.472	error	Error herdsman start
        zigbee.0
        2022-08-15 17:48:22.471	error	Failed to start Zigbee
        zigbee.0
        2022-08-15 17:48:22.470	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'"
        zigbee.0
        2022-08-15 17:48:22.252	info	Installed Version: iobroker.zigbee@1.7.6
        zigbee.0
        2022-08-15 17:48:22.209	info	Starting Zigbee npm ...
        zigbee.0
        2022-08-15 17:48:22.208	info	Try to reconnect. 1 attempts left
        zigbee.0
        2022-08-15 17:48:12.208	info	Installed Version: iobroker.zigbee@1.7.6
        zigbee.0
        2022-08-15 17:48:12.204	error	Error herdsman start
        zigbee.0
        2022-08-15 17:48:12.204	error	Failed to start Zigbee
        zigbee.0
        2022-08-15 17:48:12.203	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'"
        zigbee.0
        2022-08-15 17:48:11.473	info	Starting Zigbee npm ...
        zigbee.0
        2022-08-15 17:48:11.469	info	delete old Backup files. keep only last 10
        zigbee.0
        2022-08-15 17:48:11.344	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
        • Y Yoshi
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #64
          @yoshi du musst auch das Log des 1. Startversuchs zeigen. Du zeigst nur den 2. und 3. Startversuch. Nach dem ersten ist die serielle Schnittstelle noch geöffnet und daher kann der Adapter nicht laufen.
          A.
          Y 1 Antwort Letzte Antwort
          • AsgothianA Asgothian
            A.
            Y Offline
            Y Offline
            Yoshi
            #65
            @asgothian
            Hab die Instanz nochmal gestartet und dann kam das raus
            zigbee.0
            2022-08-15 18:01:38.138	error	Error herdsman start
            zigbee.0
            2022-08-15 18:01:38.137	error	Failed to start Zigbee
            zigbee.0
            2022-08-15 18:01:38.135	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
            zigbee.0
            2022-08-15 18:01:37.901	info	Installed Version: iobroker.zigbee@1.7.6
            zigbee.0
            2022-08-15 18:01:37.874	info	Starting Zigbee npm ...
            zigbee.0
            2022-08-15 18:01:37.873	info	Try to reconnect. 1 attempts left
            zigbee.0
            2022-08-15 18:01:27.873	info	Installed Version: iobroker.zigbee@1.7.6
            zigbee.0
            2022-08-15 18:01:27.869	error	Error herdsman start
            zigbee.0
            2022-08-15 18:01:27.869	error	Failed to start Zigbee
            zigbee.0
            2022-08-15 18:01:27.867	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
            zigbee.0
            2022-08-15 18:01:27.198	info	Starting Zigbee npm ...
            zigbee.0
            2022-08-15 18:01:27.195	info	delete old Backup files. keep only last 10
            zigbee.0
            2022-08-15 18:01:27.052	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
            zigbee.0
            2022-08-15 18:01:19.986	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            zigbee.0
            2022-08-15 18:01:19.984	info	terminating
            zigbee.0
            2022-08-15 18:01:19.954	info	Zigbee: disabling joining new devices.
            zigbee.0
            2022-08-15 18:01:19.892	info	cleaned everything up...
            zigbee.0
            2022-08-15 18:01:19.890	info	Got terminate signal TERMINATE_YOURSELF
            zigbee.0
            2022-08-15 18:01:09.457	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            • Y Yoshi
              @asgothian
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #66
              @yoshi lesen bildet:
              @asgothian sagte in Zigbee iobroker Error while opening serialport:
              A.
              zigbee.0
              auch diese Meldung stammt von einem vorherigen Startversuch.
              Bitte folgendes machen:
              • Adapter anhalten
              • 30 Sekunden warten
              • adapter starten
              • ALLE Meldungen des Adapters ab dem Startzeitpunkt posten. Nicht nur Fehler oder Warnmeldungen
              A.
                A.
                zigbee.0
                • Adapter anhalten
                • adapter starten
                A.
                Y Offline
                Y Offline
                Yoshi
                #67
                @asgothian
                Genauso gemacht und leider kommt das selbe bei raus
                • Y Yoshi
                  @asgothian
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #68
                  @yoshi
                  ich habe Probleme das zu glauben. Auf jeden fall gibt es ein problem damit das die serielle Schnittstelle von einem anderen Prozess genutzt wird und noch geöffnet ist.
                  A.
                    @yoshi
                    A.
                    Y Offline
                    Y Offline
                    Yoshi
                    schrieb am zuletzt editiert von Yoshi
                    #69
                    @asgothian
                    ich versuche den Adapter nochmal zu installieren
                    • Y Yoshi
                      @asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #70
                      @yoshi sagte in Zigbee iobroker Error while opening serialport:
                      @asgothian
                      das bringt nix. Du musst prüfen welcher Prozess auf den Conbee zugreift. Hast du die decent software noch installiert / aktiv ?
                      A.
                        @asgothian
                        A.
                        Y Offline
                        Y Offline
                        Yoshi
                        #71
                        @asgothian
                        Ich hab in der Phoscon Oberfläche das Gateway zurückgesetzt und Deconz komplett deinstalliert.
                        Wie kann ich das prüfen was den Stick belegt ?
                        • Y Yoshi
                          @asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #72
                          Bist du sicher ? mach mal bitte in der console
                          ps -ax | grep -e deconz
                          und poste die Ausgaben hier.
                          A.
                            A.
                            Y Offline
                            Y Offline
                            Yoshi
                            #73
                            @asgothian said in Zigbee iobroker Error while opening serialport:
                            16936 pts/0    S+     0:00 grep --color=auto -e deconz
                            • Y Yoshi
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #74
                              @yoshi hmm.. bitte zieh des Stick mal ab, warte 30 Sekunden, und steck den danach wieder an.
                              Danach nochmal den Adapter starten.
                              A.
                                A.
                                Y Offline
                                Y Offline
                                Yoshi
                                #75
                                @asgothian
                                leider das gleich Problem,
                                aber wie schon oben beschrieben, hatte ich ihn schon mal zum laufen bekommen. Was auch mal funktioniert hat, den USB Port zu wechseln und dann die Instanz neu starten.
                                Nun geht nichts davon
                                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                • Y Yoshi
                                  @asgothian
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #76
                                  BITTE keine Aussagen .... immer Log´s dazu zeigen !!!
                                  • Y Yoshi
                                    @asgothian
                                    #77
                                    @yoshi
                                    systemctl status deconz deconz-gui
                                    • GlasfaserG Glasfaser
                                      Y Offline
                                      Y Offline
                                      Yoshi
                                      #78
                                      @glasfaser
                                      zigbee.0
                                      2022-08-15 19:03:06.791	error	Error herdsman start
                                      zigbee.0
                                      2022-08-15 19:03:06.791	error	Failed to start Zigbee
                                      zigbee.0
                                      2022-08-15 19:03:06.789	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
                                      zigbee.0
                                      2022-08-15 19:03:06.561	info	Installed Version: iobroker.zigbee@1.7.6
                                      zigbee.0
                                      2022-08-15 19:03:06.539	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2022-08-15 19:03:06.537	info	Try to reconnect. 1 attempts left
                                      zigbee.0
                                      2022-08-15 19:02:56.537	info	Installed Version: iobroker.zigbee@1.7.6
                                      zigbee.0
                                      2022-08-15 19:02:56.534	error	Error herdsman start
                                      zigbee.0
                                      2022-08-15 19:02:56.533	error	Failed to start Zigbee
                                      zigbee.0
                                      2022-08-15 19:02:56.532	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
                                      zigbee.0
                                      2022-08-15 19:02:55.925	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2022-08-15 19:02:55.922	info	delete old Backup files. keep only last 10
                                      zigbee.0
                                      2022-08-15 19:02:55.809	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                                      host.raspberrypi4-iob
                                      2022-08-15 19:02:51.679	info	instance system.adapter.zigbee.0 started with pid 12761
                                      2022-08-15 19:02:51.472	info	"system.adapter.zigbee.0" enabled
                                        @yoshi
                                        Y Offline
                                        Y Offline
                                        Yoshi
                                        #79
                                        pi@raspberrypi4-iob:~ $ systemctl status deconz deconz-gui
                                        ● deconz.service - deCONZ: ZigBee gateway -- REST API
                                             Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset>
                                             Active: active (running) since Mon 2022-08-15 18:51:20 CEST; 18min ago
                                           Main PID: 349 (deCONZ)
                                              Tasks: 4 (limit: 4915)
                                             CGroup: /system.slice/deconz.service
                                                     └─349 /usr/bin/deCONZ -platform minimal --http-port=80
                                        Aug 15 18:52:14 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 18:52:16 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 18:53:15 raspberrypi4-iob deCONZ[349]: "Keine derartige Schnittstelle »o>
                                        Aug 15 18:59:34 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 19:02:31 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 19:04:37 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 19:04:53 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 19:04:55 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        Aug 15 19:05:11 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
                                        {1}
                                        ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
                                             Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor pr>
                                             Active: activating (auto-restart) (Result: signal) since Mon 2022-08-15 19>
                                            Process: 16935 ExecStart=/usr/bin/deCONZ --http-port=80 (code=killed, signa>
                                        lines 1-23
                                        {1}
                                        {1}
                                        • Y Yoshi
                                          {1}
                                          lines 1-23
                                          {1}
                                          {1}
                                          #80
                                          @yoshi
                                          sudo systemctl stop deconz
                                          sudo systemctl disable deconz
                                          sudo systemctl stop deconz-gui
                                          sudo systemctl disable deconz-gui
